[FAQ] [参考译文] [常见问题解答] TM4C129CNCPDT:您是否有一个具有 SPI 闪存的 TI-RTOS (SYS/BIOS)示例?
Guru**** 2928980 points
Other Parts Discussed in Thread: EK-TM4C1294XL
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/946535/faq-tm4c129cncpdt-do-you-have-an-ti-rtos-sys-bios-example-with-spi-flash
器件型号:TM4C129CNCPDT
Thread 中讨论的其他器件:EK-TM4C1294XL
我想看一个 SPI 闪存在基于 TI-RTOS (SYS/BIOS)的应用中的使用示例。
