[参考译文] CCS/TMS570LS0914:CCS 如何生成 TMS570系列的十六进制文件? 需要设置哪些参数?
Guru**** 2933630 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/810279/ccs-tms570ls0914-how-is-the-hex-file-of-the-tms570-series-generated-by-ccs-what-parameters-need-to-be-set
器件型号:TMS570LS0914
工具/软件:Code Composer Studio
如下所示、是否只需要启用 ARM 十六进制实用程序?是否需要设置其他参数? 如何设置?
