[参考译文] TMS570LS0432:TMS570LS0432
Guru**** 2930270 points
Other Parts Discussed in Thread: TMS570LS0432
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/854815/tms570ls0432-tms570ls0432
器件型号:TMS570LS0432
我使用的是 TMS570ls0432、对 ADC 有疑问。   在论坛 e2e.ti.com/.../2390901
每个通道的 ADC 时序为:T (channel)= T (discharge)+ T (sample)+ T (conversion) (清除、见文档)
总 ADC 时序为:t (total)= Channel_number * T (channel)+(Channel_number - 1)* 5*T (vclk)
但我无法在文档中找到为什么 T (total)计算为 Channel_number * T (channel)+(Channel_number - 1)* 5*T (vclk)(特别是关于 (Channel_number - 1) 5*T (vclk))的参考。 您能否提供描述此公式的文档链接,并说明为什么 (Channel_number - 1)*5*T (vclk)应添加以计算总时间?
