[参考译文] TMS570LS3137:CAN ISR 问题
Guru**** 2943430 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1181542/tms570ls3137-can-isr-issue
器件型号:TMS570LS3137
我在尝试使 CAN 中断实现 FreeRTOS 时遇到问题。 它只触发一次 ISR、而不会再次执行。
我在它们之间连接了 CAN2和 CAN3以检查通信。
随附以下完整代码:
/** @file sys_main.c
*   @brief Application main file
*   @date 07-July-2017
*   @version 04.07.00
*   This file contains an empty main function,
*   which can be used for the application.
* Copyright (C) 2009-2016 Texas Instruments Incorporated - www.ti.com
*  Redistribution and use in source and binary forms, with or without
*  modification, are permitted provided that the following conditions
*  are met:
*    Redistributions of source code must retain the above copyright
*    notice, this list of conditions and the following disclaimer.
*    Redistributions in binary form must reproduce the above copyright
*    notice, this list of conditions and the following disclaimer in the
*    documentation and/or other materials provided with the
*    distribution.
*    Neither the name of Texas Instruments Incorporated nor the names of
*    its contributors may be used to endorse or promote products derived
*    from this software without specific prior written permission.
*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
#define EXTWD_PRIORITY          ( tskIDLE_PRIORITY + 3)
#define SCI_PRIORITY            ( tskIDLE_PRIORITY + 2)
#define MAIN_PRIORITY           ( tskIDLE_PRIORITY + 2)
#define CAN_PRIORITY            ( tskIDLE_PRIORITY + 2)
/* USER CODE END */
/* Include Files */
#include "sys_common.h"
/* USER CODE BEGIN (1) */
#include "system.h"
#include "het.h"
#include "gio.h"
#include "reg_pcr.h"
#include "sys_pcr.h"
#include "sys_pmm.h"
#include "reg_vim.h"
#include "sci.h"
#include "string.h"
#include "reg_can.h"
#include "bl_can.h"
#include "can.h"
#include "sys_core.h"
/* Include FreeRTOS scheduler files */
#include "FreeRTOS.h"
#include "os_task.h"
#include "os_queue.h"
//Command List:
#include "interfacesCommandDef.h"
/* USER CODE END */
/** @fn void main(void)
*   @brief Application main function
*   @note This function is empty by default.
*   This function is called after startup.
*   The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
//Settings:
//Globals:
//Task Handlers:
xTaskHandle xTask1Handle1;          //vExtWD task handle
xTaskHandle xTask2Handle1;          //vUART task handle
xTaskHandle xTask3Handle1;          //vMain task handle
xTaskHandle xTask4Handle1;          //vCAN task handle
//Queue handlers:
QueueHandle_t xQueue1;              //Queue1 is used to send data from vUART to vMain task.
QueueHandle_t xQueue2;              //Queue2 is used to send data from sciNotification to vUART task.
QueueHandle_t xQueue3;              //Queue3 is used to send data from canMessageNotification to vCAN task.
//Set of structures to be sent through queues:
struct qMessage
    uint8_t     len, sciRxMessage, rxData;
    uint8_t     buffer[128];
}xMessage;
struct qMessage2
}xMessage2;
struct qMessage3
}xMessage3;
//Functions:
void sysInit(void);
void osInit(void);
void sciDisplayData(sciBASE_t *, uint8 *,uint32);
bool cDecoder(struct qMessage *);
uint8_t delayms(uint16);
//Tasks:
void vExtWD(void *pvParameters);        //External watchdog pulse generation
void vCAN(void *pvParameters);          //CAN communication task
void vUART(void *pvParameters);         //Debug UART communication task
void vMain(void *pvParameters);         //Main task
/* USER CODE END */
int main(void)
/* USER CODE BEGIN (3) */
    sysInit();  //System initialization.
    osInit();   //Operative System initialization.
    /* Run forever */
    while(1);
/* USER CODE END */
    return 0;
/* USER CODE BEGIN (4) */
 * Functions, Tasks and ISR routines *
 * CAN interrupt service routine *
void canMessageNotification(canBASE_t *node, uint32 messageBox)
    //uint8_t rxKey;
    uint8_t *Buffer;
    uint16_t teleBuffer[8];
    Buffer = ((uint8_t *)teleBuffer);
    uint32_t ulBytes;
    sciSend(scilinREG, 18, "CAN ISR entered.\r\n");
    //struct qMessage3 *rxCanMessage;
    //rxCanMessage = &xMessage3;
    //We have not woken a task at the start of the ISR.
    //BaseType_t canHigherPriorityTaskWoken = pdFALSE;
    if(node == canREG2)
        PacketRead(canREG2, Buffer, &ulBytes);
        delayms(100);
    else if(node == canREG3)
        PacketRead(canREG3, Buffer, &ulBytes);
        delayms(100);
    //if(xQueueIsQueueEmptyFromISR(xQueue3) == pdTRUE)
        //sciDisplayData(scilinREG, (uint8 *) fillQ, 1);                          //Only for printing on the terminal.
    //    if(xQueueSendToBackFromISR(xQueue3, &rxCanMessage, &canHigherPriorityTaskWoken) == errQUEUE_FULL)
            //xQueueReset(xQueue2);
    //        sciSend(scilinREG, 68, "\r\nError: Data did not send from CAN interrupt service routine [TBD].");
 * SCI interrupt service routine *
void sciNotification(sciBASE_t *sci, unsigned flags)
    uint8_t rxKey;
    struct qMessage2 *rxUartMessage;
    rxUartMessage = &xMessage2;
    BaseType_t sciYieldRequired;
    BaseType_t sciHigherPriorityTaskWoken = pdFALSE;//, fillQ;
    sciYieldRequired = xTaskResumeFromISR(xTask2Handle1);          //This ISR wakes up the vUART task each time a character is received.
    sciReceive(scilinREG, 1, (unsigned char *)&rxKey);
    rxUartMessage->rxData = rxKey;
    //fillQ = uxQueueSpacesAvailable(xQueue2);    //xQueueIsQueueFullFromISR
    if(xQueueIsQueueEmptyFromISR(xQueue2) == pdTRUE)
        if(xQueueSendToBackFromISR(xQueue2, &rxUartMessage, &sciHigherPriorityTaskWoken) == errQUEUE_FULL)
            sciSend(scilinREG, 73, "\r\nError: Data did not send from UART SCI interrupt service routine [TBD].");
    portYIELD_FROM_ISR(sciYieldRequired);
 * Delay in ms.                 *
 * t: time in ms to be delayed. *
uint8_t delayms(uint16 t)
    uint16 h, i, j;
    for(h = 0; h < t; h++){                 //ts = 1000 to set 1 second.
        for(i = 0; i<1350; i++)             //Time between samples 1 ms.
            for(j = 0; j< 8; j++);}
    return 1;
 * sysInit function *
void sysInit()
    uint8_t generic;
    sciInit();                                      //SCI initialization.
    canInit();                                      //CAN initialization.
    //Enable interrupts:
    _enable_interrupt_();                           //General interrupt flag.
    //Enable SCI interrupt:
    sciEnableNotification(scilinREG,SCI_RX_INT);    //Enable SCI interrupt by Rx.
    //Enable CAN interrupt:
    canEnableErrorNotification(canREG2);            //Enable canREG2 interrupt.
    canEnableErrorNotification(canREG3);            //Enable canREG3 interrupt.
    sciReceive(scilinREG,1, (unsigned char *)&generic);
    sciSend(scilinREG, 37, (unsigned char *)"Initializing system. Please wait...\r\n");
    gioInit();                                      //GIO module initialization.
    gioSetDirection(hetPORT1, 1 << 15);             //Enable N2HET1[15] as output. This is the output signal to the external watch-dog.
    sciSend(scilinREG, 27, (unsigned char *)"\t************************\r\n");
    sciSend(scilinREG, 27, (unsigned char *)"\tLabOSat-02 [OBC] OS V1.0\r\n");
    sciSend(scilinREG, 1, (unsigned char *)"\n");
    sciSend(scilinREG, 14, (unsigned char *)"Developers: \r\n");
    sciSend(scilinREG, 30, (unsigned char *)"\t Gagliardi Leandro Luciano \r\n");
    sciSend(scilinREG, 22, (unsigned char *)"\t Di Nardo Federico \r\n");
 * osInit function  *
void osInit()
    //Queues Creation:
    xQueue1 = xQueueCreate(20, sizeof(struct xMessage *));                   //Queue used between vUART task and vMain task.
    xQueue2 = xQueueCreate(200, sizeof(struct xMessage *));                  //Queue used between sciNotification ISR and vUART task.
    xQueue3 = xQueueCreate(200, sizeof(struct xMessage3 *));                 //Queue used between canMessageNotification ISR and vCAN task.
    //if( xQueue1 == NULL || xQueue2 == NULL || xQueue3 == NULL){sciSend(scilinREG, 58, (unsigned char *)"\r\nError: Queue was not created and must not be used [TBD].");}
    if(xQueue1 == NULL){sciSend(scilinREG, 59, (unsigned char *)"\r\nError: Queue1 was not created and must not be used [TBD].");}
    if(xQueue2 == NULL){sciSend(scilinREG, 59, (unsigned char *)"\r\nError: Queue2 was not created and must not be used [TBD].");}
    if(xQueue3 == NULL){sciSend(scilinREG, 59, (unsigned char *)"\r\nError: Queue3 was not created and must not be used [TBD].");}
    //Tasks Creation:
    if (xTaskCreate(vExtWD,"vExtWD", configMINIMAL_STACK_SIZE, NULL, EXTWD_PRIORITY, &xTask1Handle1) != pdTRUE){while(1);}  //Task could not be created
    if (xTaskCreate(vUART,"vUART", configMINIMAL_STACK_SIZE, NULL, SCI_PRIORITY, &xTask2Handle1) != pdTRUE){while(1);}      //Task could not be created
    if (xTaskCreate(vMain,"vMain", configMINIMAL_STACK_SIZE, NULL, MAIN_PRIORITY, &xTask3Handle1) != pdTRUE){while(1);}     //Task could not be created
    if (xTaskCreate(vCAN,"vCAN", configMINIMAL_STACK_SIZE, NULL, CAN_PRIORITY, &xTask4Handle1) != pdTRUE){while(1);}     //Task could not be created
    //Start Scheduler:
    vTaskStartScheduler();
 * sciDisplayData function *
void sciDisplayData(sciBASE_t *sci, uint8 *text,uint32 length)
    uint8 txt = 0;
    uint8 txt1 = 0;
#if ((__little_endian__ == 1) || (__LITTLE_ENDIAN__ == 1))
text = text + (length -1);
#endif
    while(length--)
        txt = *text--;
#else
        txt = *text++;
#endif
        txt1 = txt;
        txt  &= ~(0xF0);
        txt1 &= ~(0x0F);
        txt1  =txt1>>4;
        if(txt<=0x9)
            txt +=0x30;
        else if(txt > 0x9 && txt <= 0xF)
            txt +=0x37;
        else
            txt = 0x30;
        if(txt1 <= 0x9)
            txt1 +=0x30;
        else if((txt1 > 0x9) && (txt1 <= 0xF))
            txt1 +=0x37;
        else
            txt1 = 0x30;
        while ((scilinREG->FLR & 0x4) == 4); /* wait until busy */
        sciSendByte(scilinREG,txt1);      /* send out text   */
        sciSendByte(scilinREG,txt);      /* send out text   */
 * This task avoids external watch-dog reset            *
 * It considers the following watch-dog configuration:  *
 * SET0 = 0;                                            *
 * SET1 = 0;                                            *
 * twdu(min) = 77.455 s * 0.905 = 70.09 s               *
 * twdu(typ) = 77.4 * Ccwd + 0.055 = 77.455 s           *
 * twdu(max) = 1.095 * 77.455 s = 85 s                  *
 * twdl(min) = 70096 s * 0.125 = 8.762 s                *
 * twdl(typ) = 77455 s * 0.125 = 9.682 s                *
 * twdl(max) = 70096 s * 0.125 = 10.602 s               *
 *             10.602 s < tpulse < 70.09 s              *
void vExtWD(void *pvParameters)     //Watchdog send a pulse each 77 seconds.
    uint8_t i, j;
    TickType_t xLastWakeTime;
    const TickType_t xTimeIncrement = 30000; //Each 30 seconds the MCU generates a pulse that avoids the system reset.
    //Initialise the xLastWakeTime variable with the current time.
    xLastWakeTime = xTaskGetTickCount();
    //Meter un sciSend para ver si esta tarea se está ejecutando.
    for(;;)
        sciSend(scilinREG, 11, (unsigned char *)" vExtWD\r\n> ");       //A signal to know if the task is executed.
        vTaskDelayUntil( &xLastWakeTime, xTimeIncrement);
        //vTaskDelay(xTimeIncrement);
        gioSetBit(hetPORT1, 15, 1);  //0x00100000
        for(i = 0; i<10; i++){for(j = 0; j<100; j++){}} // It defines the pulse width (100us approximately)
        gioSetBit(hetPORT1, 15, 0);  //0x00000000
 * CAN Communication interface task                     *
 * Through this interface the user can send commands    *
 * and execute experiments on the payloads.             *
    sciSend(scilinREG, 23, (unsigned char *)"CAN message received.\r\n");
    vTaskSuspend(NULL);                                             //The task is suspended up to the CAN interrupt wakes it up.
 * Debug UART Communication interface task              *
void vUART(void *pvParameters)     //Debug UART communication task
    //Basic variables:
    uint8_t com_char = 0, i = 0, message[8] = {0x00, 0x02, 0x04, 0x06, 0x08, 0x0A, 0x0C, 0x0E};
    uint8_t *uBuffer;
    uint8_t UART_Buffer[128];
    uBuffer = ((uint8_t *)UART_Buffer);
    uint32_t msgId = (0 << 30 | 1 << 29 | 0x06);            //CAN test ID
    //qMessage Structure creation to send data through a queue
    struct qMessage *uartMessage;
    uartMessage = &xMessage;
    //UART_Buffer initialization:
    for(i = 0; i < 128; i++)
        UART_Buffer[i] = 0;
    //Delay of 50 ms:
    const TickType_t xUART_delay = 50;
    vTaskDelay(xUART_delay);
    sciSend(scilinREG, 34, (unsigned char *)"Debug UART communication started\r\n");        //A signal to know if the task is executed.
    sciSend(scilinREG, 17, (unsigned char *)"< Press any key >");                           //Press any key to start.
    for(;;)
        //UART com
        if(xQueue2 != NULL)
            if(xQueueReceive(xQueue2, &uartMessage, (TickType_t) 10) == pdPASS)
                //CAN Test frame
                PacketWrite(canREG2, CAN_ALIVE, message, 8, 2);                    //Test frame sent through messageBox1. CAN_ALIVE has an ID of 0x06 and null payload.
                *uBuffer = uartMessage->rxData;
                sciSend(scilinREG, 1, uBuffer);                                      //Print a keyboard symbol
                if(*uBuffer == 0x0D && com_char < 128)        //If we press enter...
                    sciSend(scilinREG, 4, (unsigned char *)"\r\n> ");               //New command line
                    uBuffer++;
                    com_char++;
                    uBuffer = uBuffer - com_char;                                                   //Return to the first buffer position
                    uartMessage->len = com_char;                                                    //Number of characters
                    for(i = 0; i < com_char; i++)                                                   //Data stored in the structure
                        uartMessage->buffer[i] = UART_Buffer[i];
                    if(5 < uxQueueSpacesAvailable(xQueue1))
                        if(xQueueSendToBack(xQueue1, (void *) &uartMessage, (TickType_t) 10) == errQUEUE_FULL)
                            sciSend(scilinREG, 49, "\r\nError: Data did not send from vUART task [TBD].");
                    else
                        xQueueReset(xQueue1);
                        //sciSend(scilinREG, 30, "\r\nError: Queue1 is full [TBD].");
                    com_char = 0;                                                           //Number of characters variable reseted
                else
                    uBuffer++;
                    com_char++;
                    if(127 < com_char)
                        com_char = 0;
                        for(i = 0; i < uartMessage->len; i++)
                            uartMessage->buffer[i] = 0;
                        uartMessage->len = 1;
                        sciSend(scilinREG, 31, (unsigned char *)"\r\n> Error: uBuffer Filled [TBD]");                     //uBuffer filled
                if(uxQueueSpacesAvailable(xQueue2) < 10)
                    sciSend(scilinREG, 37, "\r\nError: Queue2 is almost full [TBD].");
            else{}  //sciSend(scilinREG, 33, "\r\nError: Data not received [TBD].");
            vTaskResume(xTask3Handle1);                                     //This task wakes up vMain task each time an enter key is pressed.
            vTaskSuspend(NULL);                                             //The task is suspended up to the sci interrupt wakes up it.
        else{sciSend(scilinREG, 27, "\r\nError: Null Queue2 [TBD].");}      //sciSend(scilinREG, 27, "\r\nError: Null Queue2 [TBD].");
 * Main Application task                                *
 * Through this task all commands received from the     *
 * communication interfaces are decoded and an action   *
 * is executed.                                         *
    //Basic variables:
    uint8_t i=0;
    bool isValid = false;
    //qMessage Structure creation to receive data through a queue
    struct qMessage *dMessage;
    //Delay of 100 ms
    //const TickType_t xDeco_delay = 100;
    for(;;)
        if(xQueue1 != NULL)
            //sciSend(scilinREG, 6, "\r\nChau");
            if(5 < uxQueueSpacesAvailable(xQueue1) && xQueueReceive(xQueue1, &dMessage, (TickType_t) 10) == pdPASS)
              sciSend(scilinREG, dMessage->len, dMessage->buffer);          //Print the command received
              isValid = cDecoder(dMessage);
              if(dMessage->buffer[0] == 0x0D){sciSend(scilinREG, 4, (unsigned char *)"\r\n> ");}    //New command line
              else
                  if(isValid == false){sciSend(scilinREG, 32, (unsigned char *)"\r\n. Error: Unknown Command [TBD]");}//Error Message.
                  else{sciSend(scilinREG, 22, (unsigned char *)"\r\n. Execute an action.");}
              for(i = 0; i < dMessage->len; i++)
                  dMessage->buffer[i] = 0;
              dMessage->len = 1;
            vTaskSuspend(NULL);     //The task is suspended up to the vUART task wakes it up.
        else{sciSend(scilinREG, 27, "\r\nError: Null Queue1 [TBD].");}       //sciSend(scilinREG, 27, "\r\nError: Null Queue1 [TBD].");
//Include 'interfacesCommandDef.h' before use this function in your project.
bool cDecoder(struct qMessage * command)
    uint8_t         i = 0, j = 0;
    command->len = command->len - 1;                    //Enter (0x0D) is ignored.
    for(i = 0; i < COMMAND_LIST_LEN; i++)
        if(commandLength[i] == command->len)            //It compares the command length received with the command in the list.
            for(j = 0; j < command->len; j++)
                if(command->buffer[j] == *(commandList[i] + j))     //It comapres character by character the command received and the command in list.
                    isValid = true;
                else
                    isValid = false;
                    j = command->len;
            if(isValid == true)
                return isValid;
    return isValid;
/* USER CODE END */
该代码目前有四个任务。
如果一个 CAN ISR 被触发、VCAN 必须被制动。
VUART 作为 VCAN 工作、但工作正常。 在该任务中 、每次按下 ENTER 键时、CAN 帧都会从 CAN2发送到 CAN3。 我 做了一个简单的测试。
我在下面附上一张显示基本用户界面的串行终端图片:
正在初始化系统。 请稍候...
开发人员:
di Nardo Federico
VExtWD
>收到 CAN 消息。
调试 UART 通信已启动
<按任意键>输入的 CAN ISR。
。 错误:未知命令[TBD]
CAN ISR 启动是第一次按下 ENTER 键后的通知。 然后、在使用各种回车键后、再也不会触发。
有人对这种奇怪的行为有什么想法?
非常感谢、此致、
莱安德罗
    您好、Leandro、
    我不明白为什么您在处理程序中调用"PacketRead"函数两次?
    我尝试在我的末尾触发问题、因此我使用了您的代码、但我遇到了以下.h 文件未找到的错误
    #include "bl_ca.h"
    那么、您能否提供高于.h 的文件来在我的结尾触发问题?
    谢谢、此致、
    Jagadish。
    Jagadish 您好、
    感谢你的答复。 我附加了.h 和.c 文件。
    我认为问题可能出在 PacketRead 函数中、因为我使用了"canGetData (canREG2、canMESSAGE_BOX2、Buffer);"函数、它起作用。 随附以下修改后的代码:
    *   @version 04.07.00
    *  are met:
    *    distribution.
    /* USER CODE END */
    /* Include Files */
    #include "system.h"
    #include "het.h"
    #include "gio.h"
    #include "sci.h"
    #include "string.h"
    #include "bl_can.h"
    #include "can.h"
    #include "sys_vim.h"
    //Command List:
    /* USER CODE END */
    //Settings:
    //Globals:
    //Task Handlers:
    //Queue handlers:
    struct qMessage
    }xMessage;
    struct qMessage2
    }xMessage2;
    struct qMessage3
    }xMessage3;
    //Functions:
    void sysInit(void);
    void osInit(void);
    //Tasks:
    /* USER CODE END */
    int main(void)
        /* Run forever */
        while(1);
    /* USER CODE END */
        return 0;
        //uint8_t rxKey;
        uint8_t *Buffer;
        uint32_t ulBytes;
        if(node == canREG2)
            while(!canIsRxMessageArrived(canREG2, canMESSAGE_BOX2));
            //PacketRead(canREG2, Buffer, &ulBytes, 2);
            canGetData(canREG2, canMESSAGE_BOX2, Buffer); /* copy to RAM */
            while(!canIsRxMessageArrived(canREG3, canMESSAGE_BOX2));
            //PacketRead(canREG3, Buffer, &ulBytes, 2);
            canGetData(canREG3, canMESSAGE_BOX2, Buffer); /* copy to RAM */
        uint8_t rxKey;
     * Delay in ms.                 *
        uint16 h, i, j;
        return 1;
    void sysInit()
        uint8_t generic;
        vimInit();
     * osInit function  *
    void osInit()
        //Queues Creation:
        //Tasks Creation:
        //Start Scheduler:
        uint8 txt = 0;
        uint8 txt1 = 0;
    #endif
        while(length--)
            txt = *text--;
    #else
            txt = *text++;
    #endif
            txt1 = txt;
            txt  &= ~(0xF0);
            txt1 &= ~(0x0F);
            txt1  =txt1>>4;
            if(txt<=0x9)
                txt +=0x30;
                txt +=0x37;
            else
                txt = 0x30;
            if(txt1 <= 0x9)
                txt1 +=0x30;
                txt1 +=0x37;
            else
                txt1 = 0x30;
     * SET0 = 0;                                            *
     * SET1 = 0;                                            *
        uint8_t i, j;
        for(;;)
        //Basic variables:
        uint8_t *uBuffer;
            UART_Buffer[i] = 0;
        //Delay of 50 ms:
        for(;;)
            //UART com
            if(xQueue2 != NULL)
                    //CAN Test frame
                        uBuffer++;
                        com_char++;
                        else
                    else
                        uBuffer++;
                        com_char++;
                        if(127 < com_char)
                            com_char = 0;
     * is executed.                                         *
        //Basic variables:
        uint8_t i=0;
        //Delay of 100 ms
        for(;;)
            if(xQueue1 != NULL)
                  else
                  dMessage->len = 1;
                        isValid = true;
                    else
                        isValid = false;
                        j = command->len;
                if(isValid == true)
                    return isValid;
        return isValid;
    /* USER CODE END */
    莱安德罗
    e2e.ti.com/.../interfacesCommandDef.he2e.ti.com/.../bl_5F00_can.he2e.ti.com/.../bl_5F00_can.c
    您好、Leandro、
    [引用 userid="430073" URL"~/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1181542/tms570ls3137-can-isr-issue/4452108 #4452108"]我认为问题可能出在 PacketRead 函数中,因为我使用了"canGetData (canREG2、canMESSAGE_BOX2、Buffer"函数,该函数起作用。
    那么、如果我们使用"canGetData"对、这意味着处理程序多次调用吗?
    问题发生不对?
    谢谢、此致、
    Jagadish。
    Jagadish 您好、
    实际上、如果我实施"canGetData"、则在 de ISR 句柄中没有问题。
    我将使用此函数。 非常感谢。
    莱安德罗
