[参考译文] EK-TM4C123GXL:让 EK-TM4C123GXL 睡眠的 Energia sketch
Guru**** 2611705 points
Other Parts Discussed in Thread: EK-TM4C123GXL, ENERGIA
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/591087/ek-tm4c123gxl-energia-sketch-to-make-ek-tm4c123gxl-sleep
器件型号:EK-TM4C123GXL
主题中讨论的其他器件: Energia
 Energia 中是否有任何人有一张 sketch、该 sketch 设置了 EK-TM4C123GXL 睡眠等模式、然后将其唤醒、执行一个小程序、然后再次睡眠。
