[参考译文] TM4C1294NCPDT:有关 IAR 仿真器的问题
Guru**** 2577385 points
Other Parts Discussed in Thread: TM4C1294NCPDT
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/654852/tm4c1294ncpdt-questions-about-iar-emulator
器件型号:TM4C1294NCPDT
你好。
我有疑问。
IAR 仿真器"I - jet Trace for ARM Cortex - M"的 ETM 跟踪功能是否可与 TM4C1294NCPDT 配合使用?
如果是,您能告诉我如何连接(原理图)吗?
