[参考译文] TMS570LS1224:想知道我是否可以使用 python 与这个电路板通信
Guru**** 2609955 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/750686/tms570ls1224-would-like-to-know-if-i-can-use-python-to-communicate-with-this-board
器件型号:TMS570LS1224
我能否获取 python 3示例代码以开始使用此开发板? 是否已经有任何支持来满足这一要求?
