[参考译文] 编译器/TMS570LS1114:当我构建 TMS570LS114 C 代码项目时、没有错误显示、但无法生成.out 文件?
Guru**** 2618835 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/691249/compiler-tms570ls1114-when-i-build-my-tms570ls114-c-code-project-there-is-no-error-display-but-can-not-generate-the-out-file
器件型号:TMS570LS1114
工具/软件:TI C/C++编译器
大家好:
 我使用了 CCS 版本:6.0.0.00040来构建 C 代码项目、但无法生成.out 文件、并且没有错误显示。
结果来自构建项目、如下所示:
控制台的详细信息如下所示:
****为项目 PRJ_DCAN _CS_01构建配置调试****
"C:\\ti\\ccsv6\\utils\\bin\\gmake"-k all
'构建文件:./PRJ_DCAN HAL_01/source/ADC.c'
'调用:ARM 编译器'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl "-mv7R4 -code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include --include_path="D:/tms570LS/PRJ_DC1215_CS_02/PRJ_CS_01/PRJ_DR_01_ADC_MOTOR_01/PRJ_01_CK_01_DCAN-01_PRJ_PRJ_CH_AD_01/PRJ_AD_01_CK_01_PRJ_AD_01_AD_PRJ_01_AD_01_CK_01_PRJ_CH_PRJ_AD_01_AD_01_AD_01_DC_CH_PRJ_CH_PRJ_01_AD_01_DC_01_AD_01_AD_015_CH_CH_CH_PRJ_CH_PRJ_PRJ_CH_PRJ_AD_01_DC_PRJ_AD_PRJ_AD_01_AD_01_AD_01_AD_CH_PRJ_015_
'已完成构建:./PRJ_DCAN HAL_01/SOURCE /ADC.c'
'构建文件:./PRJ_DCAN HAL_01/source/CAN.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/source/CAN.c'
'生成文件:./PRJ_DCAN HAL_01/source/dabort.asm'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/dabort.asm'
'生成文件:./PRJ_DCAN HAL_01/source/DCC.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/DCC.c'
'构建文件:./PRJ_DCAN HAL_01/SOURCE /ESM.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/SOURCE /ESM.c'
'生成文件:./PRJ_DCAN HAL_01/source/etpwm.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/etpwm.c'
'生成文件:./PRJ_DCAN HAL_01/source/Gio.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/Gio.c'
'生成文件:./PRJ_DCAN HAL_01/source/het.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/het.c'
'生成文件:./PRJ_DCAN HAL_01/source/notification.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/SOURCE /通知.c'
'构建文件:./PRJ_DCAN HAL_01/source/pinmux.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/pinmux.c'
'构建文件:./PRJ_DCAN HAL_01/source/SPI.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/SOURCE /SPI.c'
'生成文件:./PRJ_DCAN HAL_01/source/sys_core.asm'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_core.asm'
'生成文件:./PRJ_DCAN HAL_01/source/sys_dma.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_dma.c'
'生成文件:./PRJ_DCAN HAL_01/source/sys_intvecs.asm'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_intvecs.asm'
'生成文件:./PRJ_DCAN HAL_01/source/sys_main.c'
'调用:ARM 编译器'
"...\PRJ_DCAN HAL_01\SOURE\..\my_HEADER\./PWM_application/PWM_application.h"、第15行:警告#734-D:元素类型不完整的数组是非标准的
"...\PRJ_DCAN HAL_01\SOURE\..\my_HEADER\./PWM_application/PWM_application.h"、第15行:警告#71-D:不允许输入不完整类型
"...\PRJ_DCAN HAL_01\SOURE\..\my_HEADER\./PWM_application/PWM_application.h"、第15行:错误#237:变量"pwmOut"被声明为从未完成的类型
1在编译"../PRJ_DCAN HAL_01/SOURCE /SYS_MAIN.c"时检测到错误。
>>编译失败
gmake:***[PRJ_DCAN HAL_01/source/sys_main.obj]错误1
'生成文件:./PRJ_DCAN HAL_01/source/sys_MPU.asm'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_MPU.asm'
'生成文件:./PRJ_DCAN HAL_01/source/sys_PCR.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_PCR.c'
'生成文件:./PRJ_DCAN HAL_01/source/sys_phantome.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/source/sys_phantome.c'
'生成文件:./PRJ_DCAN HAL_01/source/sys_PMM.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_PMM.c'
'生成文件:./PRJ_DCAN HAL_01/source/sys_PMU.asm'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_PMU.asm'
'生成文件:./PRJ_DCAN HAL_01/source/sys_selftest.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_selftest.c'
'生成文件:./PRJ_DCAN HAL_01/source/sys_startup.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_startup.c'
'生成文件:./PRJ_DCAN HAL_01/source/sys_vim.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/source/sys_vim.c'
'生成文件:./PRJ_DCAN HAL_01/source/system.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/source/system.c'
'生成文件:./PRJ_DCAN HAL_01/resoler/Dresoler.c'
'调用:ARM 编译器'
'已完成的建筑:./PRJ_DCAN HAL_01/resoler/resoler.c'
'生成文件:./PRJ_DCAN HAL_01/pospe_flt/POSPE_FLT.c'
'调用:ARM 编译器'
"./PRJ_DCAN HAL_01/pospe_flt/POSPE_FLT.c"、第123行:警告#552-D:设置了变量"AbsSpd"、但从未使用
'完成的构建:./PRJ_DCAN HAL_01/pospe_flt/POSPE_FLT.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/myfunfuncfile.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/my_header/myfunloopfuncfile.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/myfocirq.c'
'调用:ARM 编译器'
"...\PRJ_DCAN HAL_01\my_header\myglobaldefine.h"、第74行:错误#115:引用了函数"FaultDetection "、但未定义
1在编译"./PRJ_DCAN HAL_01/my_header/myfocirq.c"时检测到错误。
>>编译失败
gmake:***[PRJ_DCAN HAL_01/my_header/myfocirq.obj]错误1.
'生成文件:./PRJ_DCAN HAL_01/my_header/mygetvariable.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/my_header/mygetvariable.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mymainfunctions.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/my_header/mymainfunctions.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mymainwhileloop.c'
'调用:ARM 编译器'
'已完成构建:./PRJ_DCAN HAL_01/my_header/mymainwhileloop.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mysloopfuncfile.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/my_header/mysloopfuncfile.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mystatealignfuncfile.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/my_header/mystatealignfuncfile.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mystatecalibfuncfile.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/my_header/mystatecalibfuncfile.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mystatefaultfuncfile.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/my_header/mystatefaultfuncfile.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mystateinitfunfile.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/my_header/mystateinitfunfile.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mystatereadyfuncfile.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/my_header/mystatereadyfuncfile.c'
'生成文件:./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c'
'调用:ARM 编译器'
"...\PRJ_DCAN HAL_01\my_header\./PWM_application/PWM_application.h"、第15行:警告#734-D:元素类型不完整的数组不是标准数
"...\PRJ_DCAN HAL_01\my_header\./PWM_application/PWM_application.h"、第15行:警告#71-D:不允许输入不完整类型
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第21行:警告#552-D:变量"getFcnStatus"已设置但从未使用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第65行:警告#179-D:变量"iqreqbuf"已声明、但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第66行:警告#179-D:变量"idreq_sum"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第66行:警告#179-D:变量"iq_sum"已声明、但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第68行:警告#179-D:变量"iqreqlimit"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第69行:警告#179-D:变量"idreqnum"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第69行:警告#179-D:变量"idreqnum1"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第69行:警告#179-D:变量"iqreqnum"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第69行:警告#179-D:变量"iqreqnum1"已声明、但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第70行:警告#552-D:已设置变量"pmtpaidq"、但从未使用过
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第157行:警告#179-D:变量"udbuf"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第158行:警告#179-D:变量"uqbuf"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第166行:警告#179-D:变量"udfilter_sum"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第166行:警告#179-D:变量"uqfilter_sum"已声明但从未引用
"../PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第178行:警告#552-D:设置了变量"useded_KP"、但从未使用过
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第178行:警告#179-D:已声明变量"useded_ki"、但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第181行:警告#179-D:变量"iderrornum"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第181行:警告#179-D:变量"iderrornum1"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第181行:警告#179-D:变量"iqerrornum"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第181行:警告#179-D:变量"iqerrnum1"已声明、但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第182行:警告#179-D:变量"UDI"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第182行:警告#179-D:变量"udi1"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第182行:警告#179-D:变量"uqi "已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第182行:警告#179-D:变量"uqi1"已声明但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第183行:警告#179-D:已声明变量"iderror_sum"、但从未引用
"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"、第183行:警告#179-D:已声明变量"iqerror_sum"、但从未引用
"...\PRJ_DCAN HAL_01\my_header\./PWM_application/PWM_application.h"、第15行:错误#237:变量"pwmOut"被声明为从未完成的类型
1在编译"./PRJ_DCAN HAL_01/my_header/mystaterunfunfile.c"时检测到错误。
>>编译失败
gmake:***[PRJ_DCAN HAL_01/my_header/mystaterunfunfile.obj]错误1
'生成文件:./PRJ_DCAN HAL_01/moter_structure/sub.c/Estimation_Para.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/moter_structure/sub.c/Estimation_Para.c'
'构建文件:./PRJ_DCAN HAL_01/moter_structure/sub.c/Stateflow.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/moter_structure/sub.c/Stateflow.c'
'构建文件:./PRJ_DCAN HAL_01/motor_structure/sub.c_foclormal.c'
'调用:ARM 编译器'
"./PRJ_DCAN HAL_01/motor_structure/sub.c_focral.c"、第416行:警告#552-D:变量"RtbMidSaturPara"已设置但从未使用
'完成的构建:./PRJ_DCAN HAL_01/motor_structure/sub.c_foc_algorm.c'
'构建文件:./PRJ_DCAN HAL_01/math_function/sub_c/MLIB_Mul.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/math_function/sub_c/MLIB_Mul.c'
'生成文件:./PRJ_DCAN HAL_01/math_function/sub_c/Q_Format.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/math_function/sub_c/Q_Format.c'
'生成文件:./PRJ_DCAN HAL_01/dischg_prechg/dischg_prechg.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/dischg_prechg/dischg_prechg.c'
'构建文件:./PRJ_DCAN HAL_01/CAN_PACK_UNOP/sub.c/CAN_PACK_UNOP.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/CAN_PACK_UNOP/sub.c/CAN_PACK_UNOP.c'
'构建文件:./PRJ_DCAN HAL_01/CAN_PACK_UNVLO/sub.c/Glab_Sig_Output.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/CAN_PACK_UNVLO/sub.c/Glab_Sig_Output.c'
'构建文件:./PRJ_DCAN HAL_01/CAN_PACK_UNVLOW/sub.c/CAN_application.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/CAN_PACK_UNOPE/sub.c/CAN_application.c'
'生成文件:./PRJ_DCAN HAL_01/ADC_application/temp/igbttemme.c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/ADC_application/temp/igbttemme.c'
'构建文件:./PRJ_DCAN HAL_01/ADC_application/temp/motortemperature .c'
'调用:ARM 编译器'
"./PRJ_DCAN HAL_01/ADC_application/temp/motortemperature。c"、第21行:警告#552-D:变量"maxmotortemptmid"已设置但从未使用
"./PRJ_DCAN HAL_01/ADC_application/temp/motortemperature。c"、第21行:警告#552-D:设置了变量"motmintemptmid"、但从未使用过
"./PRJ_DCAN HAL_01/ADC_application/temp/motortemperature。c"、第21行:警告#552-D:变量"maxmott Rtmid"已设置但从未使用
"./PRJ_DCAN HAL_01/ADC_application/temp/motortemperature.c"、第21行:警告#552-D:变量"motminRtmid"已设置但从未使用
'完成的构建:./PRJ_DCAN HAL_01/ADC_application/temp/motortemperature .c'
'构建文件:./PRJ_DCAN HAL_01/ADC_application/ADC_application.c'
'调用:ARM 编译器'
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第157行:警告#179-D:变量"sumAraw"已声明但从未引用
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第157行:警告#179-D:变量"sumBraw"已声明但从未引用
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第157行:警告#179-D:变量"sumCraw 已声明但从未引用
"../PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第157行:警告#179-D:变量"TRANSPA1"已声明、但从未引用
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第158行:警告#179-D:变量"OBSER"已声明但从未引用
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第160行:警告#552-D:变量"objer1"已设置但从未使用
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第160行:警告#552-D:变量"obser2"已设置但从未使用
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第160行:警告#179-D:变量"obser3"已声明但从未引用
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、第287行:警告#179-D:变量"upfilterRawUdccomp"已声明但从未引用
"./PRJ_DCAN HAL_01/ADC_application/ADC_application.c"、行343:警告#179-D:变量"maxmotormid1"已声明但从未引用
'完成的构建:./PRJ_DCAN HAL_01/ADC_application/ADC_application.c'
'生成文件:./PRJ_DCAN HAL_01/ADC_application/myadcisr.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/ADC_application/myadcisr.c'
'构建文件:./PRJ_DCAN HAL_01/PWM_application/PWM_application.c'
'调用:ARM 编译器'
".\PRJ_DCAN HAL_01\PWM_application\./PWM_application/PWM_application.h"、第15行:警告#734-D:元素类型不完整的数组不是标准数
"...\PRJ_DCAN HAL_01\PWM_application\./PWM_application/PWM_application.h"、第15行:警告#71-D:不允许输入不完整类型
'完成的构建:./PRJ_DCAN HAL_01/PWM_application/PWM_application.c'
'生成文件:./PRJ_DCAN HAL_01/ErrorCode/ErrorCode.c'
'调用:ARM 编译器'
'完成构建:./PRJ_DCAN HAL_01/ErrorCode/ErrorCode.c'
'构建文件:./PRJ_DCAN HAL_01/AMMCLIB/FILTER_C/FILTER_MATH_c'
'调用:ARM 编译器'
'完成的构建:./PRJ_DCAN HAL_01/AMMCLIB/FILTER_C/FILTER_MATH_c'
gmake:目标`全部'不会由于错误而重制。
****构建完成****
我 不知道如何解决它! 谁能帮助我?
    根据您发布的日志、该错误在 sys_main.c 文件的编译中。
    >>编译失败
    这很可能是由于 Pwm_application.h 文件第15行的拼写错误所致。
