[参考译文] RM48L952:HALCOGEN 问题
Guru**** 2894990 points
Other Parts Discussed in Thread: HALCOGEN
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/724603/rm48l952-halcogen-issue
器件型号:RM48L952
主题中讨论的其他器件:HALCOGEN
HALCOGEN 能否生成闪存驱动程序?我找不到
2.如果无法生成 API,是否可以使用 API? 是否有任何相关信息?
