[参考译文] LM3S811:SO#399106 -正确的部件标记...
Guru**** 2593210 points
Other Parts Discussed in Thread: LM3S811
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/720730/lm3s811-so-399106---correct-part-marking
器件型号:LM3S811
您能否告知 P/N: LM3S811-IQN50-C2的正确部件标记?
根据器件型号查找、标记应为:
LM3S811
PT
IQN50
但器件本身的标记是:
LM3S811
IQN50C2SD
9-7CP545H
ARM     G3
P/N 查找工具指示的"PT"缺失。 这是否仍是此器件的正确标记?
谢谢你。
