[参考译文] AM2431:PRU:脉冲输出实例。
Guru**** 2754255 points
Other Parts Discussed in Thread: AM2431
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1198970/am2431-pru-instance-of-pulse-output
器件型号:AM2431
尊敬的专家:您能否提供使用 AM2431的 PRU 进行脉冲输出(例如:100KHz)的实例? 谢谢~
