[参考译文] TMS570LC4357:您可以帮助我识别 LAUNCHXL2-570LC43上的哪个芯片
Guru**** 1151850 points
Other Parts Discussed in Thread: LAUNCHXL2-570LC43
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1213825/tms570lc4357-could-you-help-me-identify-which-chip-is-it-on-launchxl2-570lc43
器件型号:TMS570LC4357
主题中讨论的其他器件:LAUNCHXL2-570LC43
这两种版本都在 LAUNCHXL2-570LC43原理图中
1.
2.
