[参考译文] RM57L843:RM57Lx 勘误器件#40 "严格排序"内存
Guru**** 2535680 points
Other Parts Discussed in Thread: HALCOGEN
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1240844/rm57l843-rm57lx-errata-device-40-strongly-ordered-memory
器件型号:RM57L843
主题中讨论的其他器件:HALCOGEN
您能提供一个示例来说明如何将所有外设帧配置为"严格排序"存储器(STRONGLYORDERD_sharable)吗?
Halcogen 附带了外围设备的预设值(如 NORMAL_OINC_NONSHARED)。
下面是我们使用的 MPU 区配置。
提前感谢您的答复。
马尔西奥
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_END_ADDRESS.VALUE=0xffffffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_PERMISSION.VALUE=PRIV_NA_USER_NA_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_PERMISSION_VALUE.VALUE=0x1000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SIZE.VALUE=4_GB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SIZE_VALUE.VALUE=0x1F
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_0_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_1_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_2_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_3_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_4_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_5_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_6_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_7_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_END_ADDRESS.VALUE=0x003fffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_PERMISSION.VALUE=PRIV_RO_USER_RO_EXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_PERMISSION_VALUE.VALUE=0x0600
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SIZE.VALUE=4_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SIZE_VALUE.VALUE=0x15
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_TYPE.VALUE=NORMAL_OIWTNOWA_NONSHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_TYPE_VALUE.VALUE=0x0002
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_BASE_ADDRESS.VALUE=0x08000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_END_ADDRESS.VALUE=0x0807ffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_PERMISSION.VALUE=PRIV_RW_USER_RW_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_PERMISSION_VALUE.VALUE=0x1300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SIZE.VALUE=512_KB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SIZE_VALUE.VALUE=0x12
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_TYPE.VALUE=NORMAL_OIWBWA_NONSHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_TYPE_VALUE.VALUE=0x000B
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_BASE_ADDRESS.VALUE=0xF8000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_END_ADDRESS.VALUE=0xffffffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_PERMISSION.VALUE=PRIV_RW_USER_RW_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_PERMISSION_VALUE.VALUE=0x1300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SIZE.VALUE=128_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SIZE_VALUE.VALUE=0x1A
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_0_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_1_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_2_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_TYPE.VALUE=DEVICE_NONSHAREABLE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_TYPE_VALUE.VALUE=0x0010
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_BASE_ADDRESS.VALUE=0x60000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_END_ADDRESS.VALUE=0x6fffffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_PERMISSION.VALUE=PRIV_RW_USER_RW_EXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_PERMISSION_VALUE.VALUE=0x0300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SIZE.VALUE=256_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SIZE_VALUE.VALUE=0x1B
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_6_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_7_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_TYPE.VALUE=STRONGLYORDERED_SHAREABLE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_TYPE_VALUE.VALUE=0x0000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_BASE_ADDRESS.VALUE=0x80000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_END_ADDRESS.VALUE=0x87ffffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_PERMISSION.VALUE=PRIV_RW_USER_RW_EXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_PERMISSION_VALUE.VALUE=0x0300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SIZE.VALUE=128_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SIZE_VALUE.VALUE=0x1A
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_TYPE.VALUE=NORMAL_OIWTNOWA_SHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_TYPE_VALUE.VALUE=0x0006
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_BASE_ADDRESS.VALUE=0xF0000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_END_ADDRESS.VALUE=0xf07fffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_PERMISSION.VALUE=PRIV_RW_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_PERMISSION_VALUE.VALUE=0x1200
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SIZE.VALUE=8_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SIZE_VALUE.VALUE=0x16
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_END_ADDRESS.VALUE=0x0000001f
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_PERMISSION.VALUE=PRIV_RW_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_PERMISSION_VALUE.VALUE=0x1200
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SIZE.VALUE=32_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SIZE_VALUE.VALUE=0x04
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_TYPE.VALUE=DEVICE_NONSHAREABLE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_TYPE_VALUE.VALUE=0x0010
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_END_ADDRESS.VALUE=0x0000001f
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_PERMISSION.VALUE=PRIV_RW_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_PERMISSION_VALUE.VALUE=0x1200
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SIZE.VALUE=32_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SIZE_VALUE.VALUE=0x04
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_TYPE.VALUE=NORMAL_OIWTNOWA_SHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_TYPE_VALUE.VALUE=0x0006
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_END_ADDRESS.VALUE=0x0000001f
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_PERMISSION.VALUE=PRIV_RW_USER_RW_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_PERMISSION_VALUE.VALUE=0x1300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SIZE.VALUE=32_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SIZE_VALUE.VALUE=0x04
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_TYPE.VALUE=NORMAL_OIWTNOWA_SHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_TYPE_VALUE.VALUE=0x000C
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_END_ADDRESS.VALUE=0x0000001f
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_PERMISSION.VALUE=PRIV_RO_USER_RO_EXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_PERMISSION_VALUE.VALUE=0x0600
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SIZE.VALUE=32_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SIZE_VALUE.VALUE=0x04
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_TYPE.VALUE=NORMAL_OIWTNOWA_SHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_TYPE_VALUE.VALUE=0x0006
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_END_ADDRESS.VALUE=0x0000001f
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_PERMISSION.VALUE=PRIV_RO_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_PERMISSION_VALUE.VALUE=0x1600
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SIZE.VALUE=32_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SIZE_VALUE.VALUE=0x04
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_TYPE.VALUE=NORMAL_OIWTNOWA_SHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_TYPE_VALUE.VALUE=0x0006
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_END_ADDRESS.VALUE=0x0000001f
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_PERMISSION.VALUE=PRIV_RO_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_PERMISSION_VALUE.VALUE=0x1600
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SIZE.VALUE=32_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SIZE_VALUE.VALUE=0x04
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_TYPE.VALUE=NORMAL_OIWTNOWA_SHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_13_TYPE_VALUE.VALUE=0x0006
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_END_ADDRESS.VALUE=0x0000001f
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_PERMISSION.VALUE=PRIV_RO_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_PERMISSION_VALUE.VALUE=0x1600
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SIZE.VALUE=32_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SIZE_VALUE.VALUE=0x04
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_TYPE.VALUE=NORMAL_OIWTNOWA_SHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_14_TYPE_VALUE.VALUE=0x0006
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_END_ADDRESS.VALUE=0x0000001f
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_PERMISSION.VALUE=PRIV_RO_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_PERMISSION_VALUE.VALUE=0x1600
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SIZE.VALUE=32_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SIZE_VALUE.VALUE=0x04
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_TYPE.VALUE=NORMAL_OIWTNOWA_SHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_15_TYPE_VALUE.VALUE=0x0006
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_BASE_ADDRESS.VALUE=0xFFF80000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_END_ADDRESS.VALUE=0xffffffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_PERMISSION.VALUE=PRIV_RW_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_PERMISSION_VALUE.VALUE=0x1200
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SIZE.VALUE=512_KB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SIZE_VALUE.VALUE=0x12
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_TYPE.VALUE=DEVICE_NONSHAREABLE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_16_TYPE_VALUE.VALUE=0x0010
