[参考译文] MSPM0G1107:如何将内部振荡器频率设置为80MHz?
Guru**** 2946270 points
Other Parts Discussed in Thread: MSPM0G1107, SYSCONFIG
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1245464/mspm0g1107-how-to-setup-up-internal-oscillator-frequency-to-80mhz
器件型号:MSPM0G1107
主题中讨论的其他器件: SysConfig
我认为 MSPM0G1107支持80MHz。 如何在 SysConfig 工具中设置80MHz?
贾斯廷
