[参考译文] TMS570LS3137-TMS570LS/LC EP 错误注入
Guru**** 2943430 points
Other Parts Discussed in Thread: HALCOGEN
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1353973/tms570ls3137-ep-tms570ls-lc-error-injection
器件型号:EP
主题中讨论的其他器件:HALCOGEN
是否可以通过编程方式将锁步错误强制在内核上的 CCM-R4/R5-->ESM  寄存器 是多少?
如果是、是否有任何示例(可能通过 Halcogen 或某些库)?
