[参考译文] MSPM0G3507:您能否建议通过 I2C DMA 读取大约100字节数据的步骤?
Guru**** 2524550 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1352528/mspm0g3507-could-you-please-suggest-the-steps-to-read-approx-100bytes-of-data-via-i2c-dma
器件型号:MSPM0G3507
通过 I2C DMA 从外部 EEPROM 芯片读取100字节的数据。
