[参考译文] TMS570LS0432:发送针对 FMC (闪存模块控制器)的读写擦除代码和 ECC 错误代码校正
Guru**** 2927270 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1346587/tms570ls0432-send-read-write-erase-code-for-fmc-flash-module-controller-and-ecc-error-code-correction-also
器件型号:TMS570LS0432
发送 用于 FMC (闪存模块控制器)的读写擦除代码、还发送 ECC 错误代码校正
