[参考译文] TMS570LC4357:TMS570LC43x:引导加载程序应用跳转会在启用中断后导致 UndefEntry
Guru**** 2445440 points
Other Parts Discussed in Thread: TMS570LC4357
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1338295/tms570lc4357-tms570lc43x-bootloader-application-jump-leads-to-undefentry-after-interrups-are-enabled
器件型号:TMS570LC4357
CCS/TMS570LC4357:TMS570LC4357:引导加载程序应用跳转至 SVC 条目。
最近我正在处理 TMS570LC4357上的 UART 启动加载程序。 我找到了 TI 自己的一个示例。
引导加载程序位于组0中、应用程序位于组1中。
引导加载程序切  换到应用程序工作正常,但当进入应用程序并调用  OS_StartScheduler ()时,此操作不起作用。
正如我从文档知道的,"器件只支持一个异常矢量表,位于闪存的开头(0x00000000)。 当我的应用程序中发生一个 SVC 异常时、代码会转移到0x0000000中异常表的0x08"。
我的应用程序起始地址: APP_START_ADDRESS 0x00200100
;引导加载程序  hl_sys_intvecs.asm
; HL_sys_intvecs.asm
; Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
;  Redistribution and use in source and binary forms, with or without
;  modification, are permitted provided that the following conditions
;  are met:
;    Redistributions of source code must retain the above copyright
;    notice, this list of conditions and the following disclaimer.
;    Redistributions in binary form must reproduce the above copyright
;    notice, this list of conditions and the following disclaimer in the
;    documentation and/or other materials provided with the
;    distribution.
;    Neither the name of Texas Instruments Incorporated nor the names of
;    its contributors may be used to endorse or promote products derived
;    from this software without specific prior written permission.
;  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
;  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
;  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
;  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
;  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
;  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
;  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
;  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
;  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
;  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
;  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    .sect ".intvecs"
    .arm
; import reference for interrupt routines
    .ref _c_int00
    .ref _svc
    .ref phantomInterrupt
    .def resetEntry
; interrupt vectors
resetEntry
        b   _c_int00
undefEntry
        b   undefEntry
        b   _svc
prefetchEntry
        b   prefetchEntry
dataEntry
        b   dataEntry
        b   phantomInterrupt
        ldr pc,[pc,#-0x1b0]
        ldr pc,[pc,#-0x1b0]
只是简单地说,没有 FreeRTOS 的应用程序工作正常 ,那一刻的操作系统 开始没有响应.
请尽快帮我解决这个问题。
