[参考译文] MSPM0G1505:mspm0g1505计时器
Guru**** 2779905 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1335683/mspm0g1505-mspm0g1505-timer
器件型号:MSPM0G1505
我,比较模式示例,系统集上升和下降模式‘、但它始终可以进入"cC0_UP"且 pwmPeriod_1 =0。
我只想达到两个边沿(上升和下降)、读取计数器值。
void compare_0_INST_IRQHandler (void)
开关(DL_TimerG_getPendingInterrupt (COMPARE_0_INST)){
案例 DL_TIMER_IIDX_CC0_UP:
pwmPeriod_0 = DL_TimerG_getCaptureCompareValue (COMPARE_0_INST、DL_TIMER_CC_1_INDEX);//
__BKPT (0);
中断;
案例 DL_TIMER_IIDX_CC0_DN:
pwmPeriod_1 = DL_TimerG_getCaptureCompareValue (COMPARE_0_INST、DL_TIMER_CC_1_INDEX);//
//__BKPT (0);
中断;
默认值:
中断;
