[参考译文] TM4C129LNCZAD:以太网 LED 反转
Guru**** 2895520 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1322905/tm4c129lnczad-ethernet-led-inversion
器件型号:TM4C129LNCZAD
是否可以反转 TM4C129LNCZADT3固件中的以太网 LED 逻辑?
     可以。 您可以将极性更改为低。
