[参考译文] TM4C129ENCPDT:嵌入式 ENET PHY 是否支持电容耦合?
Guru**** 2928980 points
Other Parts Discussed in Thread: TM4C129ENCPDT, TLK110
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1305372/tm4c129encpdt-does-the-embedded-enet-phy-support-capacitive-coupling
器件型号:TM4C129ENCPDT
主题中讨论的其他器件: TLK110
尊敬的团队:
TM4C129ENCPDT 内部的嵌入式 ENET PHY 是否支持电容耦合? 是否有任何其他 TI PHY 可用作后续问题的参考?
此博客文章是否适用于嵌入式 PHY?
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1265741/faq-ti-ethernet-phy-capacitive-coupling-transformerless-operation?tisearch=e2e-sitesearch&keymatch=TM4C129ENCPDT%252520capacitive%252520coupling#
丹尼尔
