[参考译文] TMS570LC4357-TMS570LC4357 EP:擦除、读取和写入闪存的示例代码
Guru**** 2943350 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1295191/tms570lc4357-ep-sample-code-to-erase-read-and-write-to-flash-memory
器件型号:EP
您好
我将为该部件编写引导加载程序。 如果您能提供示例引导加载程序代码和示例闪存读取、写入和擦除、我将不胜感激。 谢谢!
