[参考译文] TM4C129ENCPDT:适用于 TM4C1294的 ISO 802.3示例 CRC32
Guru**** 2868190 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1362259/tm4c129encpdt-crc32-for-iso-802-3-example-for-tm4c1294
器件型号:TM4C129ENCPDT
旧帖子已损坏链接:  https://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/p/552167/2017170
是否有工作示例说明如何配置 TM4C1294 CRC32外设以生成 CRC-32  、如 ISO 3309 (HDLC)、 ANSI X3.66 (ADCCP)、 FIPS PUB 71、Fed-STD-1003、  ITU-T V.42、ISO/IEC/IEEE 802-3 (以太网)等
