[参考译文] MSPM0L1305-Q1:您能否帮助我检查 MSPM0诊断库是否支持 MSPM0L1305/6-Q1?
Guru**** 2589115 points
Other Parts Discussed in Thread: MSPM0L1305
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1259979/mspm0l1305-q1-could-you-help-me-check-whether-mspm0l1305-6-q1-is-supported-by-mspm0-diagnostics-library
器件型号:MSPM0L1305-Q1
您好、 TI 专家:
    您能否帮助我检查  此库是否支持 MSPM0L1305/6-Q1?
   我单击"文档"中的所有错误文档、能否请我检查一下并发送给我?
 链接: https://www.ti.com/product/MSPM0L1305?keyMatch=&tisearch=search-everything&usecase=partmatches#software-development
