[参考译文] AM2434:对问题 MCUSDK-9653进行跟进
Guru**** 2031750 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1450004/am2434-follow-up-on-issue-mcusdk-9653
器件型号:AM2434
跟进此问题:
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1194412/am2434-getting-sysconfig-to-output-a-summary-of-pins-in-text-csv-excel-format
您是否有 MCUSDK-9653的状态更新
Andrew
    Andrew、您好!
    感谢您的提问。
    请留出一些时间来检查上述内容并恢复。
    Tushar
    Andrew、您好!
    我已经在内部检查了详细信息、该功能应在下一个 MCU+SDK v10.1版本中提供。
    Tushar
