Other Parts Discussed in Thread: TCA6424
主题中讨论的其他器件:TCA6424
尊敬的先生/ AM:
mcan_external_read_write在带有装配(PROC159E2 (001)的 AM263Px 控制卡上从 MCU+SDK 版本10.0.0.35运行示例时、示例正常工作。 但是、它在装配:PROC159A(001)卡上无法正常工作。 在查看代码时、我注意到mcan_transceiver.c、第56至58行包含相关定义(随附代码片段)。 正如 BOM 和目视检查所确认的、两个卡版本中使用的 CAN 收发器是相同的。
* Copyright (C) 2023-24 Texas Instruments Incorporated
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Include Files */
#include <stdint.h>
#include <board/ioexp/ioexp_tca6424.h>
#include <board/eeprom.h>
#include <drivers/i2c.h>
#include "ti_drivers_open_close.h"
#include "ti_board_open_close.h"
/* Macros & Typedefs */
/* PORT 0, PIN 4 -> ioIndex : 0*8 + 4 = 4*/
#define IO_MUX_MCAN_SEL (4U)
/* PORT 2, PIN 1 -> ioIndex : 2*8 + 1 = 17 */
#define IO_MUX_MCAN_STB (17U)
/* MCAN_SEL PIN OUTPUT -> 0 */
#define TCA6424_IO_MUX_MCAN_SEL_PORT_LINE_STATE (TCA6424_OUT_STATE_LOW)
/* MCAN_STB PIN OUTPUT -> 1 */
#define TCA6424_IO_MUX_MCAN_STB_PORT_LINE_STATE (TCA6424_OUT_STATE_HIGH)
#define EEPROM_OFFSET_READ_PCB_REV (0x0022U)
#define EEPROM_READ_PCB_REV_DATA_LEN (0x2U)
#define BOARD_VERSION_E2 ('2')
/* Global Variables */
static TCA6424_Config gTCA6424_Config;
/* Function Definitions */
int32_t TCA6424_Transceiver(void)
int32_t status = SystemP_SUCCESS;
TCA6424_Params tca6424Params;
TCA6424_Params_init(&tca6424Params);
status = TCA6424_open(&gTCA6424_Config, &tca6424Params);
DebugP_assert(SystemP_SUCCESS == status);
/* For MCAN_SEL */
status = TCA6424_setOutput(
&gTCA6424_Config,
IO_MUX_MCAN_SEL,
TCA6424_IO_MUX_MCAN_SEL_PORT_LINE_STATE);
status += TCA6424_config(
&gTCA6424_Config,
IO_MUX_MCAN_SEL,
TCA6424_MODE_OUTPUT);
/* For MCAN_STB*/
status += TCA6424_setOutput(
&gTCA6424_Config,
IO_MUX_MCAN_STB,
TCA6424_IO_MUX_MCAN_STB_PORT_LINE_STATE);
&gTCA6424_Config,
IO_MUX_MCAN_STB,
if(status != SystemP_SUCCESS)
DebugP_log("Transceiver Setup Failure !!");
TCA6424_close(&gTCA6424_Config);
return status;
void mcanEnableTransceiver()
uint8_t boardVer[2] = "";
Board_eepromOpen();
status = EEPROM_read(gEepromHandle[CONFIG_EEPROM0], EEPROM_OFFSET_READ_PCB_REV, boardVer, EEPROM_READ_PCB_REV_DATA_LEN);
if(status == SystemP_SUCCESS)
if(boardVer[1] == BOARD_VERSION_E2)
/* boardVer is E2 */
status = TCA6424_Transceiver();
else
/* boardVer is E1 */
/* MCAN Transceiver is enabled by default in E1*/
DebugP_assert(status == SystemP_SUCCESS);
Board_eepromClose();
