[FAQ] [参考译文] [FAQ] TLV320AIC编解码器:TLV320AIC EVM的Windows 7兼容性
Guru**** 2813875 points
Other Parts Discussed in Thread: TLV320AIC31, TLV320AIC3253, TLV320AIC32, TLV320AIC3256, PCM3070, TLV320AIC3254, TLV320DAC3203, TLV320AIC3104, TLV320AIC3105, TLV320AIC3106, TLV320AIC3107, TLV320AIC33, TLV320AIC3101, TLV320AIC3206, TLV320AIC3204, TLV320ADC3101, TLV320AIC3007, TLV320AIC34
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/773058/faq-tlv320aic-codecs-windows-7-compatibility-of-tlv320aic-evms
主题中讨论的其他部件:TLV320AIC31TLV320AIC3253TLV320AIC32TLV320AIC3256PCM3070TLV320AIC3254TLV320DAC3203TLV320AIC3104TLV320AIC3105TLV320AIC3106TLV320AIC3107TLV320AIC33TLV320AIC3101TLV320AIC3206TLV320AIC3204TLV320ADC3101TLV320AIC3007TLV320AIC34
解决与TLV320AIC GUI的Windows 7兼容性问题的提示?
TLV320AIC3254,TLV320AIC3204,TLV320AIC3253,TLV320AIC3256, TLV320AIC3206, TLV320AIC36,  TLV320ADC3101, TLV320DAC3203,PCM3070, TLV320AIC31, TLV320AIC32,  TLV320AIC33, TLV320AIC34, TLV320AIC3007, TLV320AIC3107, TLV320AIC3101,  TLV320AIC3104, TLV320AIC3105, TLV320AIC3106,
