[参考译文] TLV320AIC3262:Linux驱动程序未按预期工作
Guru**** 2971470 points
Other Parts Discussed in Thread: TLV320AIC3262
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/1094367/tlv320aic3262-linux-driver-not-working-as-expected
部件号:TLV320AIC3262
线程中讨论的其他部件: ADS7828, PCM3168A, TMP108, TAS2562, TAS5086, CSD, TLV320AIC23, TCA8418, LM3533, TPS6.591万, TPIC2810, LM3639, LM9.5241万, TS3A227E, TPS6.5218万, TPS6.501万, CDCE925, PCM1681, LM77, TPS6.5217万, INA3221, LP3943, LM73, LM92, ADC128D818, TMP102, TMP401, TPD12S015, LM63, LM8333, CDCE706, PCM3060, BQ2.4257万, BQ2.4735万, TMP513, LP8727, PCM1789, AMC6821, TCA6416, LM93, LM90, BQ2.598万, INA209, TMP421, LM83, LM3630A, TWL6040, LM80, LM87, TAS6424, LM9.5245万, BQ2.589万, SN65DSI86, LM9.5234万, TMP103, TPA6130A2, TPS6.509万, TFP410, TAS2764, TPS6.5086万, TAS2770, TAS2552, TPS6.5912万
我已从 /CFS文件/__key/communityserver-discussions-组件文件/6/3262_2D00_E2E.zip下载了适用于aic3262的Linux驱动程序 ,并将其集成到我的内核中。
我从e2e线下获得了此驱动程序,
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/106.6656万/tlv320aic3262-platform-driver-vs-i2c-driver/3955046?tisearch=e2e-sitesearch&keymatch=aic3262#3955046</s>3262 395.5046万3262395.5046万
如果我要使用 此https://www.ti.com/tool/TLV320AIC32XX-DRIVERS Linux驱动程序,那么我在这里没有Linux驱动程序集成的所有可用文件,请告诉我其他文件在哪里?
我还有mkcfw工具来生成Linux驱动程序请求的"tlv320aic3262_FW_v1.bin"。
我使用的是Linux内核版本- 5.10 ................................................................41
我的内核配置
# Automatically generated file; DO NOT EDIT.
# Linux/riscv 5.10.41 Kernel Configuration
CONFIG_CC_VERSION_TEXT="riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.24.0) 8.3.0"
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=80300
CONFIG_LD_VERSION=232000000
CONFIG_CLANG_VERSION=0
CONFIG_LLD_VERSION=0
CONFIG_CC_CAN_LINK=y
CONFIG_CC_CAN_LINK_STATIC=y
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_CC_HAS_ASM_INLINE=y
CONFIG_IRQ_WORK=y
CONFIG_THREAD_INFO_IN_TASK=y
# General setup
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION="-nb2"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_BUILD_SALT=""
CONFIG_DEFAULT_INIT=""
CONFIG_DEFAULT_HOSTNAME="nb2-pearl"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_WATCH_QUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
# end of IRQ subsystem
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_ARCH_CLOCKSOURCE_INIT=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ is not set
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_PSI is not set
# end of CPU/Task time and stats accounting
# RCU Subsystem
CONFIG_TINY_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TINY_SRCU=y
CONFIG_TASKS_RCU_GENERIC=y
CONFIG_TASKS_TRACE_RCU=y
# end of RCU Subsystem
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
# CONFIG_IKHEADERS is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# end of Scheduler features
CONFIG_CC_HAS_INT128=y
CONFIG_ARCH_SUPPORTS_INT128=y
CONFIG_CGROUPS=y
# CONFIG_MEMCG is not set
# CONFIG_BLK_CGROUP is not set
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
# CONFIG_RT_GROUP_SCHED is not set
# CONFIG_CGROUP_PIDS is not set
# CONFIG_CGROUP_RDMA is not set
# CONFIG_CGROUP_FREEZER is not set
# CONFIG_CGROUP_DEVICE is not set
# CONFIG_CGROUP_CPUACCT is not set
CONFIG_CGROUP_BPF=y
# CONFIG_CGROUP_DEBUG is not set
CONFIG_SOCK_CGROUP_DATA=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
CONFIG_CHECKPOINT_RESTORE=y
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE="core-image-tiny-initramfs-nb2-20220413111759.rootfs.cpio.gz"
CONFIG_INITRAMFS_ROOT_UID=0
CONFIG_INITRAMFS_ROOT_GID=0
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_RD_ZSTD=y
CONFIG_INITRAMFS_COMPRESSION_GZIP=y
# CONFIG_INITRAMFS_COMPRESSION_BZIP2 is not set
# CONFIG_INITRAMFS_COMPRESSION_LZMA is not set
# CONFIG_INITRAMFS_COMPRESSION_XZ is not set
# CONFIG_INITRAMFS_COMPRESSION_LZO is not set
# CONFIG_INITRAMFS_COMPRESSION_LZ4 is not set
# CONFIG_INITRAMFS_COMPRESSION_ZSTD is not set
# CONFIG_INITRAMFS_COMPRESSION_NONE is not set
# CONFIG_BOOT_CONFIG is not set
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_SYSCTL_EXCEPTION_TRACE=y
CONFIG_BPF=y
CONFIG_EXPERT=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
# CONFIG_SYSFS_SYSCALL is not set
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_HAVE_FUTEX_CMPXCHG=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
CONFIG_KALLSYMS_BASE_RELATIVE=y
CONFIG_BPF_SYSCALL=y
# CONFIG_BPF_PRELOAD is not set
# CONFIG_USERFAULTFD is not set
CONFIG_KCMP=y
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
# CONFIG_PERF_EVENTS is not set
# end of Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
# CONFIG_PROFILING is not set
# end of General setup
CONFIG_64BIT=y
CONFIG_RISCV=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=18
CONFIG_ARCH_MMAP_RND_BITS_MAX=24
CONFIG_RISCV_SBI=y
CONFIG_MMU=y
CONFIG_ZONE_DMA=y
CONFIG_VA_BITS=39
CONFIG_PA_BITS=56
CONFIG_PAGE_OFFSET=0xffffffe000000000
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_ARCH_SELECT_MEMORY_MODEL=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y
CONFIG_SYS_SUPPORTS_HUGETLBFS=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_GENERIC_BUG=y
CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_GENERIC_CSUM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_PGTABLE_LEVELS=3
CONFIG_LOCKDEP_SUPPORT=y
# SoC selection
CONFIG_SOC_SIFIVE=y
# CONFIG_SOC_VIRT is not set
CONFIG_SOC_SIFIVE_NB2=y
# end of SoC selection
# Platform type
# CONFIG_ARCH_RV32I is not set
CONFIG_ARCH_RV64I=y
# CONFIG_CMODEL_MEDLOW is not set
CONFIG_CMODEL_MEDANY=y
CONFIG_MODULE_SECTIONS=y
CONFIG_MAXPHYSMEM_128GB=y
# CONFIG_SMP is not set
CONFIG_TUNE_GENERIC=y
CONFIG_RISCV_ISA_C=y
CONFIG_FPU=y
# end of Platform type
# Kernel features
# CONFIG_HZ_100 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_300 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=250
CONFIG_SCHED_HRTICK=y
CONFIG_RISCV_SBI_V01=y
# end of Kernel features
# Boot options
CONFIG_CMDLINE=""
CONFIG_EFI_STUB=y
CONFIG_EFI=y
# end of Boot options
# Power management options
# CONFIG_SUSPEND is not set
# CONFIG_PM is not set
# end of Power management options
# Firmware Drivers
# CONFIG_FIRMWARE_MEMMAP is not set
# CONFIG_GOOGLE_FIRMWARE is not set
# EFI (Extensible Firmware Interface) Support
CONFIG_EFI_ESRT=y
CONFIG_EFI_PARAMS_FROM_FDT=y
CONFIG_EFI_RUNTIME_WRAPPERS=y
CONFIG_EFI_GENERIC_STUB=y
# CONFIG_EFI_BOOTLOADER_CONTROL is not set
# CONFIG_EFI_CAPSULE_LOADER is not set
# CONFIG_EFI_TEST is not set
# CONFIG_RESET_ATTACK_MITIGATION is not set
# CONFIG_EFI_DISABLE_PCI_DMA is not set
# end of EFI (Extensible Firmware Interface) Support
CONFIG_EFI_EARLYCON=y
# Tegra firmware driver
# end of Tegra firmware driver
# end of Firmware Drivers
# General architecture-dependent options
# CONFIG_JUMP_LABEL is not set
CONFIG_HAVE_64BIT_ALIGNED_ACCESS=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_ARCH_HAS_SET_DIRECT_MAP=y
CONFIG_HAVE_ASM_MODVERSIONS=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_HAVE_ARCH_JUMP_LABEL_RELATIVE=y
CONFIG_HAVE_ARCH_SECCOMP=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP=y
CONFIG_SECCOMP_FILTER=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_ARCH_WANT_HUGE_PMD_SHARE=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_RELA=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_ARCH_MMAP_RND_BITS=18
CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
CONFIG_CLONE_BACKWARDS=y
# CONFIG_COMPAT_32BIT_TIME is not set
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_USE_MEMREMAP_PROT=y
# CONFIG_LOCK_EVENT_COUNTS is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
# end of GCOV-based kernel profiling
CONFIG_HAVE_GCC_PLUGINS=y
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_BLOCK=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
# CONFIG_BLK_WBT is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# CONFIG_BLK_INLINE_ENCRYPTION is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
# end of Partition Types
CONFIG_BLK_MQ_VIRTIO=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
# end of IO Schedulers
CONFIG_ASN1=y
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_ARCH_HAS_MMIOWB=y
# Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
CONFIG_ARCH_HAS_BINFMT_FLAT=y
# CONFIG_BINFMT_FLAT is not set
# CONFIG_BINFMT_MISC is not set
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_SPARSEMEM_VMEMMAP_ENABLE=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_MEMORY_BALLOON=y
CONFIG_BALLOON_COMPACTION=y
CONFIG_COMPACTION=y
CONFIG_PAGE_REPORTING=y
CONFIG_MIGRATION=y
CONFIG_PHYS_ADDR_T_64BIT=y
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
# CONFIG_CMA is not set
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
# CONFIG_ZSMALLOC is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_BENCHMARK is not set
CONFIG_ARCH_HAS_PTE_SPECIAL=y
# end of Memory Management options
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
# CONFIG_UNIX_DIAG is not set
# CONFIG_TLS is not set
# CONFIG_XFRM_USER is not set
# CONFIG_NET_KEY is not set
# CONFIG_XDP_SOCKETS is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_NET_IPVTI is not set
# CONFIG_NET_FOU is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_INET_UDP_DIAG is not set
# CONFIG_INET_RAW_DIAG is not set
# CONFIG_INET_DIAG_DESTROY is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=y
CONFIG_IPV6_ROUTER_PREF=y
# CONFIG_IPV6_ROUTE_INFO is not set
CONFIG_IPV6_OPTIMISTIC_DAD=y
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_IPV6_MIP6 is not set
CONFIG_INET6_TUNNEL=y
# CONFIG_IPV6_VTI is not set
# CONFIG_IPV6_SIT is not set
CONFIG_IPV6_TUNNEL=y
CONFIG_IPV6_MULTIPLE_TABLES=y
# CONFIG_IPV6_SUBTREES is not set
# CONFIG_IPV6_MROUTE is not set
# CONFIG_IPV6_SEG6_LWTUNNEL is not set
# CONFIG_IPV6_SEG6_HMAC is not set
# CONFIG_IPV6_RPL_LWTUNNEL is not set
# CONFIG_MPTCP is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_BPFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
# CONFIG_6LOWPAN is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
CONFIG_NETLINK_DIAG=y
# CONFIG_MPLS is not set
# CONFIG_NET_NSH is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
# CONFIG_NET_L3_MASTER_DEV is not set
# CONFIG_QRTR is not set
# CONFIG_NET_NCSI is not set
# CONFIG_CGROUP_NET_PRIO is not set
# CONFIG_CGROUP_NET_CLASSID is not set
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
# CONFIG_BPF_STREAM_PARSER is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# end of Network testing
# end of Networking options
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
# CONFIG_CFG80211 is not set
# CFG80211 needs to be enabled for MAC80211
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
# CONFIG_FAILOVER is not set
CONFIG_ETHTOOL_NETLINK=y
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
CONFIG_HAVE_PCI=y
# CONFIG_PCI is not set
# CONFIG_PCCARD is not set
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE="tlv320aic3262_fw_v1.bin"
CONFIG_EXTRA_FIRMWARE_DIR="/india/proj_ssw/work/pragneshp/project/mkcfw_r6.10fix6_130516"
# CONFIG_FW_LOADER_USER_HELPER is not set
# CONFIG_FW_LOADER_COMPRESS is not set
# end of Firmware loader
CONFIG_ALLOW_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_MMIO=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
# end of Generic Driver Options
# Bus devices
# CONFIG_MHI_BUS is not set
# end of Bus devices
# CONFIG_CONNECTOR is not set
# CONFIG_GNSS is not set
# CONFIG_MTD is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
CONFIG_BLK_DEV_NBD=y
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
CONFIG_VIRTIO_BLK=y
# CONFIG_BLK_DEV_RBD is not set
# NVME Support
# CONFIG_NVME_FC is not set
# end of NVME Support
# Misc devices
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
CONFIG_SRAM=y
# CONFIG_XILINX_SDFEC is not set
# CONFIG_PVPANIC is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# CONFIG_ECHO is not set
# end of Misc devices
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_BLK_DEV_SR is not set
CONFIG_CHR_DEV_SG=y
CONFIG_CHR_DEV_SCH=y
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_VIRTIO is not set
# CONFIG_SCSI_DH is not set
# end of SCSI device support
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
# CONFIG_NETDEVICES is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
# CONFIG_INPUT_FF_MEMLESS is not set
# CONFIG_INPUT_POLLDEV is not set
# CONFIG_INPUT_SPARSEKMAP is not set
# CONFIG_INPUT_MATRIXKMAP is not set
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_GPIO is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
CONFIG_LDISC_AUTOLOAD=y
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set
CONFIG_SERIAL_8250_16550A_VARIANTS=y
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_NR_UARTS=6
CONFIG_SERIAL_8250_RUNTIME_UARTS=6
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_DWLIB=y
CONFIG_SERIAL_8250_DW=y
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
CONFIG_SERIAL_EARLYCON_RISCV_SBI=y
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_SIFIVE=y
CONFIG_SERIAL_SIFIVE_CONSOLE=y
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_FSL_LINFLEXUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_SPRD is not set
# end of Serial drivers
CONFIG_SERIAL_MCTRL_GPIO=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_NULL_TTY is not set
# CONFIG_TRACE_SINK is not set
CONFIG_HVC_DRIVER=y
CONFIG_HVC_RISCV_SBI=y
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_TTY_PRINTK is not set
CONFIG_VIRTIO_CONSOLE=y
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
# CONFIG_HW_RANDOM_BA431 is not set
CONFIG_HW_RANDOM_VIRTIO=y
CONFIG_HW_RANDOM_SIFIVE=y
# CONFIG_HW_RANDOM_CCTRNG is not set
# CONFIG_HW_RANDOM_XIPHERA is not set
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_XILLYBUS is not set
# end of Character devices
# CONFIG_RANDOM_TRUST_BOOTLOADER is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
# CONFIG_I2C_COMPAT is not set
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
CONFIG_I2C_DESIGNWARE_CORE=y
# CONFIG_I2C_DESIGNWARE_SLAVE is not set
CONFIG_I2C_DESIGNWARE_PLATFORM=y
# CONFIG_I2C_EMEV2 is not set
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_TAOS_EVM is not set
# Other I2C/SMBus bus drivers
# end of I2C Hardware Bus support
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
# CONFIG_SPI is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
# CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
# CONFIG_PTP_1588_CLOCK_IDTCM is not set
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_MCP23S08 is not set
CONFIG_PINCTRL_NB2=y
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
# CONFIG_PINCTRL_STMFX is not set
# CONFIG_PINCTRL_OCELOT is not set
# Renesas pinctrl drivers
# end of Renesas pinctrl drivers
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_CDEV=y
CONFIG_GPIO_CDEV_V1=y
CONFIG_GPIO_GENERIC=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_CADENCE is not set
CONFIG_GPIO_DWAPB=y
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_LOGICVC is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_SAMA5D2_PIOBU is not set
# CONFIG_GPIO_SIFIVE is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCA9570 is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_TPIC2810 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
# end of MFD GPIO expanders
# CONFIG_GPIO_AGGREGATOR is not set
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_W1 is not set
# CONFIG_POWER_RESET is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
CONFIG_POWER_SUPPLY_HWMON=y
# CONFIG_PDA_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
# CONFIG_BATTERY_CW2015 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ2515X is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_BQ25980 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_BD99954 is not set
CONFIG_HWMON=y
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM1177 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_AS370 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_AXI_FAN_CONTROL is not set
# CONFIG_SENSORS_ASPEED is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_CORSAIR_CPRO is not set
# CONFIG_SENSORS_DS620 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_FTSTEUTATES is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_JC42 is not set
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC2947_I2C is not set
# CONFIG_SENSORS_LTC2990 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX31730 is not set
# CONFIG_SENSORS_MAX6621 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_MR75203 is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM73 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_NPCM7XX is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
# CONFIG_SENSORS_PWM_FAN is not set
# CONFIG_SENSORS_SHT15 is not set
# CONFIG_SENSORS_SHT21 is not set
# CONFIG_SENSORS_SHT3x is not set
# CONFIG_SENSORS_SHTC1 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_STTS751 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
# CONFIG_SENSORS_INA2XX is not set
# CONFIG_SENSORS_INA3221 is not set
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP108 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_TMP513 is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_W83773G is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
# CONFIG_THERMAL is not set
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
CONFIG_WATCHDOG_SYSFS=y
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
CONFIG_DW_WATCHDOG=y
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_MEN_A21_WDT is not set
CONFIG_SSB_POSSIBLE=y
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AXP20X_I2C is not set
# CONFIG_MFD_MADERA is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_GATEWORKS_GSC is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_MP2629 is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_IQS62X is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77650 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6360 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_LOCHNAGAR is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_MFD_ROHM_BD70528 is not set
# CONFIG_MFD_ROHM_BD71828 is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
# end of Multifunction device drivers
# CONFIG_REGULATOR is not set
# CONFIG_RC_CORE is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
# CONFIG_MEDIA_SUPPORT is not set
# Graphics support
CONFIG_DRM=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_MM is not set
# CONFIG_DRM_DEBUG_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_KMS_FB_HELPER=y
# CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
# CONFIG_DRM_DP_CEC is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
# ARM devices
# CONFIG_DRM_KOMEDA is not set
# end of ARM devices
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_VKMS is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_RCAR_LVDS is not set
# CONFIG_DRM_VIRTIO_GPU is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ARM_VERSATILE is not set
CONFIG_DRM_PANEL_LVDS=y
CONFIG_DRM_PANEL_SIMPLE=y
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# end of Display Panels
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_CDNS_DSI is not set
# CONFIG_DRM_CHRONTEL_CH7033 is not set
# CONFIG_DRM_DISPLAY_CONNECTOR is not set
# CONFIG_DRM_LONTIUM_LT9611 is not set
# CONFIG_DRM_LVDS_CODEC is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NWL_MIPI_DSI is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_PARADE_PS8640 is not set
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_SII9234 is not set
# CONFIG_DRM_SIMPLE_BRIDGE is not set
# CONFIG_DRM_THINE_THC63LVD1024 is not set
# CONFIG_DRM_TOSHIBA_TC358762 is not set
# CONFIG_DRM_TOSHIBA_TC358764 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TOSHIBA_TC358768 is not set
# CONFIG_DRM_TOSHIBA_TC358775 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_TI_SN65DSI86 is not set
# CONFIG_DRM_TI_TPD12S015 is not set
# CONFIG_DRM_ANALOGIX_ANX6345 is not set
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# CONFIG_DRM_CDNS_MHDP8546 is not set
# end of Display Interface Bridges
# Pearl/NB2 Display Driver
CONFIG_DRM_NB2=y
CONFIG_DRM_NB2_LVDS=y
# CONFIG_DRM_NB2_DW_MIPI_DSI is not set
# end of Pearl/NB2 Display Driver
# CONFIG_DRM_ETNAVIV is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_MXSFB is not set
# CONFIG_DRM_LEGACY is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB=y
CONFIG_FIRMWARE_EDID=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
CONFIG_FB_FOREIGN_ENDIAN=y
CONFIG_FB_BOTH_ENDIAN=y
# CONFIG_FB_BIG_ENDIAN is not set
# CONFIG_FB_LITTLE_ENDIAN is not set
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_EFI is not set
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_SIMPLE is not set
# CONFIG_FB_SSD1307 is not set
# end of Frame buffer Devices
# Backlight & LCD device support
CONFIG_LCD_CLASS_DEVICE=y
# CONFIG_LCD_PLATFORM is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_KTD253 is not set
CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_QCOM_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# end of Backlight & LCD device support
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_VGA_CONSOLE=y
CONFIG_DUMMY_CONSOLE=y
CONFIG_DUMMY_CONSOLE_COLUMNS=80
CONFIG_DUMMY_CONSOLE_ROWS=25
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER=y
# end of Console display driver support
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
# end of Graphics support
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
# CONFIG_SND_OSSEMUL is not set
CONFIG_SND_PCM_TIMER=y
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_SEQUENCER is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_ALOOP is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# HD-Audio
# end of HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
CONFIG_SND_CADENCE_I2S=y
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_AUDMIX is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_FSL_MICFIL is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# end of SoC Audio for Freescale CPUs
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# CONFIG_SND_SOC_MTK_BTCVSD is not set
CONFIG_SND_SOC_NB2_PDM=y
# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
# STMicroelectronics STM32 SOC audio support
# end of STMicroelectronics STM32 SOC audio support
# CONFIG_SND_SOC_XILINX_I2S is not set
# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
# CONFIG_SND_SOC_XILINX_SPDIF is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# AIC326X DRIVER
# Texas Instruments aic326x device
CONFIG_SND_SOC_AIC326X=y
# end of Texas Instruments aic326x device
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU7002 is not set
# CONFIG_SND_SOC_ADAU7118_HW is not set
# CONFIG_SND_SOC_ADAU7118_I2C is not set
# CONFIG_SND_SOC_AK4118 is not set
# CONFIG_SND_SOC_AK4458 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_AK5558 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BD28623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS35L36 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4234 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4341 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_CX2072X is not set
# CONFIG_SND_SOC_DA7213 is not set
CONFIG_SND_SOC_DMIC=y
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98088 is not set
# CONFIG_SND_SOC_MAX98357A is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98373_I2C is not set
# CONFIG_SND_SOC_MAX98390 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM186X_I2C is not set
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_RK3328 is not set
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_SGTL5000 is not set
# CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
# CONFIG_SND_SOC_SPDIF is not set
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS2562 is not set
# CONFIG_SND_SOC_TAS2764 is not set
# CONFIG_SND_SOC_TAS2770 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TAS6424 is not set
# CONFIG_SND_SOC_TDA7419 is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
# CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
# CONFIG_SND_SOC_TLV320AIC3X is not set
# CONFIG_SND_SOC_TLV320ADCX140 is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_TSCS42XX is not set
# CONFIG_SND_SOC_TSCS454 is not set
# CONFIG_SND_SOC_UDA1334 is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8904 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_MAX9759 is not set
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_MT6358 is not set
# CONFIG_SND_SOC_MT6660 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8822 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
# end of CODEC drivers
CONFIG_SND_SIMPLE_CARD_UTILS=y
CONFIG_SND_SIMPLE_CARD=y
# CONFIG_SND_AUDIO_GRAPH_CARD is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
# CONFIG_HID_A4TECH is not set
# CONFIG_HID_ACRUX is not set
# CONFIG_HID_APPLE is not set
# CONFIG_HID_AUREAL is not set
# CONFIG_HID_BELKIN is not set
# CONFIG_HID_CHERRY is not set
# CONFIG_HID_CHICONY is not set
# CONFIG_HID_COUGAR is not set
# CONFIG_HID_MACALLY is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
# CONFIG_HID_CYPRESS is not set
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_EZKEY is not set
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_GLORIOUS is not set
# CONFIG_HID_VIVALDI is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_VIEWSONIC is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
# CONFIG_HID_ITE is not set
# CONFIG_HID_JABRA is not set
# CONFIG_HID_TWINHAN is not set
# CONFIG_HID_KENSINGTON is not set
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LENOVO is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MALTRON is not set
# CONFIG_HID_MAYFLASH is not set
# CONFIG_HID_REDRAGON is not set
# CONFIG_HID_MICROSOFT is not set
# CONFIG_HID_MONTEREY is not set
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTI is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEAM is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# end of Special HID drivers
# I2C HID support
# CONFIG_I2C_HID is not set
# end of I2C HID support
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
# CONFIG_USB_SUPPORT is not set
# CONFIG_MMC is not set
# CONFIG_MEMSTICK is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_SUPPORT=y
# CONFIG_EDAC is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc1"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc1"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABEOZ9 is not set
# CONFIG_RTC_DRV_ABX80X is not set
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_HYM8563 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_ISL12026 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF85363 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8010 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV3028 is not set
# CONFIG_RTC_DRV_RV3032 is not set
# CONFIG_RTC_DRV_RV8803 is not set
# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_PCF2127 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# Platform RTC drivers
CONFIG_RTC_DRV_DWAPB=y
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_EFI is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
# CONFIG_RTC_DRV_CADENCE is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
CONFIG_DW_AXI_DMAC=y
# CONFIG_FSL_EDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_XILINX_ZYNQMP_DPDMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# CONFIG_SF_PDMA is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
CONFIG_DMATEST=y
CONFIG_DMA_ENGINE_RAID=y
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# CONFIG_DMABUF_MOVE_NOTIFY is not set
# CONFIG_DMABUF_SELFTESTS is not set
# CONFIG_DMABUF_HEAPS is not set
# end of DMABUF options
# CONFIG_AUXDISPLAY is not set
CONFIG_UIO=y
CONFIG_UIO_PDRV_GENIRQ=y
CONFIG_UIO_DMEM_GENIRQ=y
# CONFIG_UIO_PRUSS is not set
# CONFIG_VFIO is not set
# CONFIG_VIRT_DRIVERS is not set
CONFIG_VIRTIO=y
CONFIG_VIRTIO_MENU=y
CONFIG_VIRTIO_BALLOON=y
CONFIG_VIRTIO_INPUT=y
CONFIG_VIRTIO_MMIO=y
# CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set
# CONFIG_VDPA is not set
CONFIG_VHOST_MENU=y
# CONFIG_VHOST_NET is not set
# CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
# CONFIG_GREYBUS is not set
# CONFIG_STAGING is not set
# CONFIG_GOLDFISH is not set
CONFIG_HAVE_CLK=y
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# CONFIG_COMMON_CLK_MAX9485 is not set
# CONFIG_COMMON_CLK_SI5341 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_CLK_ANALOGBITS_WRPLL_CLN28HPC=y
CONFIG_CLK_SIFIVE=y
CONFIG_CLK_SIFIVE_FU540_PRCI=y
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_RISCV_TIMER=y
# CONFIG_MICROCHIP_PIT64B is not set
# end of Clock Source drivers
# CONFIG_MAILBOX is not set
CONFIG_IOMMU_SUPPORT=y
# Generic IOMMU Pagetable Support
# end of Generic IOMMU Pagetable Support
# CONFIG_IOMMU_DEBUGFS is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# end of Remoteproc drivers
# Rpmsg drivers
CONFIG_RPMSG=y
CONFIG_RPMSG_CHAR=y
CONFIG_RPMSG_VIRTIO=y
# end of Rpmsg drivers
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Aspeed SoC drivers
# end of Aspeed SoC drivers
# Broadcom SoC drivers
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# end of NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
# end of i.MX SoC drivers
# Qualcomm SoC drivers
# end of Qualcomm SoC drivers
CONFIG_SIFIVE_L2=y
CONFIG_IPC_DRV_NB2=y
# CONFIG_SOC_TI is not set
# Xilinx SoC drivers
# CONFIG_XILINX_VCU is not set
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
# CONFIG_PM_DEVFREQ is not set
# CONFIG_EXTCON is not set
# CONFIG_MEMORY is not set
# CONFIG_IIO is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_DEBUG is not set
# CONFIG_PWM_CADENCE is not set
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
# CONFIG_PWM_SIFIVE is not set
# IRQ chip support
CONFIG_IRQCHIP=y
# CONFIG_AL_FIC is not set
CONFIG_RISCV_INTC=y
CONFIG_SIFIVE_PLIC=y
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_RESET_CONTROLLER=y
# CONFIG_RESET_BRCMSTB_RESCAL is not set
# CONFIG_RESET_INTEL_GW is not set
# CONFIG_RESET_TI_SYSCON is not set
# PHY Subsystem
# CONFIG_GENERIC_PHY is not set
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_CADENCE_TORRENT is not set
# CONFIG_PHY_CADENCE_DPHY is not set
# CONFIG_PHY_CADENCE_SIERRA is not set
# CONFIG_PHY_CADENCE_SALVO is not set
# CONFIG_PHY_FSL_IMX8MQ_USB is not set
# CONFIG_PHY_MIXEL_MIPI_DPHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
# CONFIG_NB2_M31_USB2_PHY is not set
# CONFIG_NB2_M31_USB3_PHY is not set
# CONFIG_NB2_M31_MIPI_DPHY is not set
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
CONFIG_RAS=y
# Android
# CONFIG_ANDROID is not set
# end of Android
# CONFIG_LIBNVDIMM is not set
# CONFIG_DAX is not set
CONFIG_NVMEM=y
# CONFIG_NVMEM_SYSFS is not set
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# end of HW tracing support
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
# CONFIG_INTERCONNECT is not set
# CONFIG_COUNTER is not set
# end of Device Drivers
# File systems
# CONFIG_VALIDATE_FS_PARSER is not set
CONFIG_FS_IOMAP=y
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
CONFIG_EXT4_FS=y
# CONFIG_EXT4_USE_FOR_EXT2 is not set
CONFIG_EXT4_FS_POSIX_ACL=y
# CONFIG_EXT4_FS_SECURITY is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
# CONFIG_FS_DAX is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
# CONFIG_FS_VERITY is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
CONFIG_AUTOFS4_FS=y
CONFIG_AUTOFS_FS=y
# CONFIG_FUSE_FS is not set
# CONFIG_OVERLAY_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# end of Caches
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# end of CD-ROM/DVD Filesystems
# DOS/FAT/EXFAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
CONFIG_FAT_DEFAULT_UTF8=y
# CONFIG_EXFAT_FS is not set
CONFIG_NTFS_FS=y
# CONFIG_NTFS_DEBUG is not set
CONFIG_NTFS_RW=y
# end of DOS/FAT/EXFAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_PROC_CHILDREN=y
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
# CONFIG_TMPFS_INODE64 is not set
# CONFIG_HUGETLBFS is not set
CONFIG_MEMFD_CREATE=y
CONFIG_ARCH_HAS_GIGANTIC_PAGE=y
# CONFIG_CONFIGFS_FS is not set
CONFIG_EFIVAR_FS=m
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_EROFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=m
CONFIG_NFS_V2=m
CONFIG_NFS_V3=m
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=m
# CONFIG_NFS_SWAP is not set
CONFIG_NFS_V4_1=y
# CONFIG_NFS_V4_2 is not set
CONFIG_PNFS_FILE_LAYOUT=m
CONFIG_PNFS_FLEXFILE_LAYOUT=m
CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
# CONFIG_NFS_V4_1_MIGRATION is not set
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFS_DISABLE_UDP_SUPPORT=y
# CONFIG_NFSD is not set
CONFIG_GRACE_PERIOD=m
CONFIG_LOCKD=m
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=m
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=m
CONFIG_SUNRPC_GSS=m
CONFIG_SUNRPC_BACKCHANNEL=y
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_CODEPAGE_737=y
CONFIG_NLS_CODEPAGE_775=y
CONFIG_NLS_CODEPAGE_850=y
CONFIG_NLS_CODEPAGE_852=y
CONFIG_NLS_CODEPAGE_855=y
CONFIG_NLS_CODEPAGE_857=y
CONFIG_NLS_CODEPAGE_860=y
CONFIG_NLS_CODEPAGE_861=y
CONFIG_NLS_CODEPAGE_862=y
CONFIG_NLS_CODEPAGE_863=y
CONFIG_NLS_CODEPAGE_864=y
CONFIG_NLS_CODEPAGE_865=y
CONFIG_NLS_CODEPAGE_866=y
CONFIG_NLS_CODEPAGE_869=y
CONFIG_NLS_CODEPAGE_936=y
CONFIG_NLS_CODEPAGE_950=y
CONFIG_NLS_CODEPAGE_932=y
CONFIG_NLS_CODEPAGE_949=y
CONFIG_NLS_CODEPAGE_874=y
CONFIG_NLS_ISO8859_8=y
CONFIG_NLS_CODEPAGE_1250=y
CONFIG_NLS_CODEPAGE_1251=y
CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=y
CONFIG_NLS_ISO8859_2=y
CONFIG_NLS_ISO8859_3=y
CONFIG_NLS_ISO8859_4=y
CONFIG_NLS_ISO8859_5=y
CONFIG_NLS_ISO8859_6=y
CONFIG_NLS_ISO8859_7=y
CONFIG_NLS_ISO8859_9=y
CONFIG_NLS_ISO8859_13=y
CONFIG_NLS_ISO8859_14=y
CONFIG_NLS_ISO8859_15=y
CONFIG_NLS_KOI8_R=y
CONFIG_NLS_KOI8_U=y
CONFIG_NLS_MAC_ROMAN=y
CONFIG_NLS_MAC_CELTIC=y
CONFIG_NLS_MAC_CENTEURO=y
CONFIG_NLS_MAC_CROATIAN=y
CONFIG_NLS_MAC_CYRILLIC=y
CONFIG_NLS_MAC_GAELIC=y
CONFIG_NLS_MAC_GREEK=y
CONFIG_NLS_MAC_ICELAND=y
CONFIG_NLS_MAC_INUIT=y
CONFIG_NLS_MAC_ROMANIAN=y
CONFIG_NLS_MAC_TURKISH=y
CONFIG_NLS_UTF8=y
# CONFIG_UNICODE is not set
CONFIG_IO_WQ=y
# end of File systems
# Security options
CONFIG_KEYS=y
# CONFIG_KEYS_REQUEST_CACHE is not set
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity,bpf"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
# CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
# end of Memory initialization
# end of Kernel hardening options
# end of Security options
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_SKCIPHER=y
CONFIG_CRYPTO_SKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
# CONFIG_CRYPTO_NULL is not set
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
CONFIG_CRYPTO_ENGINE=y
# Public-key cryptography
CONFIG_CRYPTO_RSA=y
# CONFIG_CRYPTO_DH is not set
# CONFIG_CRYPTO_ECDH is not set
# CONFIG_CRYPTO_ECRDSA is not set
# CONFIG_CRYPTO_SM2 is not set
# CONFIG_CRYPTO_CURVE25519 is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
# CONFIG_CRYPTO_AEGIS128 is not set
# CONFIG_CRYPTO_SEQIV is not set
# CONFIG_CRYPTO_ECHAINIV is not set
# Block modes
# CONFIG_CRYPTO_CBC is not set
# CONFIG_CRYPTO_CFB is not set
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
# CONFIG_CRYPTO_ECB is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_OFB is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# CONFIG_CRYPTO_ADIANTUM is not set
# CONFIG_CRYPTO_ESSIV is not set
# Hash modes
# CONFIG_CRYPTO_CMAC is not set
# CONFIG_CRYPTO_HMAC is not set
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
# CONFIG_CRYPTO_XXHASH is not set
# CONFIG_CRYPTO_BLAKE2B is not set
# CONFIG_CRYPTO_BLAKE2S is not set
# CONFIG_CRYPTO_CRCT10DIF is not set
# CONFIG_CRYPTO_GHASH is not set
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_MD4 is not set
# CONFIG_CRYPTO_MD5 is not set
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
# CONFIG_CRYPTO_SHA1 is not set
CONFIG_CRYPTO_SHA256=y
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_SM3 is not set
# CONFIG_CRYPTO_STREEBOG is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
# CONFIG_CRYPTO_AES is not set
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
# CONFIG_CRYPTO_DES is not set
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_SM4 is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_LZO is not set
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
# CONFIG_CRYPTO_ZSTD is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
# CONFIG_CRYPTO_DRBG_MENU is not set
# CONFIG_CRYPTO_JITTERENTROPY is not set
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HASH_INFO=y
# Crypto library routines
# CONFIG_CRYPTO_LIB_BLAKE2S is not set
# CONFIG_CRYPTO_LIB_CHACHA is not set
# CONFIG_CRYPTO_LIB_CURVE25519 is not set
CONFIG_CRYPTO_LIB_POLY1305_RSIZE=1
# CONFIG_CRYPTO_LIB_POLY1305 is not set
# CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set
CONFIG_CRYPTO_LIB_SHA256=y
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
# CONFIG_CRYPTO_DEV_SIFIVE_HCA is not set
CONFIG_CRYPTO_DEV_VIRTIO=y
# CONFIG_CRYPTO_DEV_SAFEXCEL is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
# CONFIG_CRYPTO_DEV_AMLOGIC_GXL is not set
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
# CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
CONFIG_PKCS7_MESSAGE_PARSER=y
# Certificates for signature checking
# CONFIG_SYSTEM_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# end of Certificates for signature checking
# Library routines
# CONFIG_PACKING is not set
CONFIG_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
# CONFIG_CORDIC is not set
# CONFIG_PRIME_NUMBERS is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
# CONFIG_CRC_CCITT is not set
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC64 is not set
# CONFIG_CRC4 is not set
CONFIG_CRC7=y
# CONFIG_LIBCRC32C is not set
# CONFIG_CRC8 is not set
CONFIG_XXHASH=y
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_DECOMPRESS=y
CONFIG_XZ_DEC=y
# CONFIG_XZ_DEC_X86 is not set
# CONFIG_XZ_DEC_POWERPC is not set
# CONFIG_XZ_DEC_IA64 is not set
# CONFIG_XZ_DEC_ARM is not set
# CONFIG_XZ_DEC_ARMTHUMB is not set
# CONFIG_XZ_DEC_SPARC is not set
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_DECOMPRESS_ZSTD=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_DMA_ADDR_T_64BIT=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_SWIOTLB=y
# CONFIG_DMA_API_DEBUG is not set
CONFIG_SGL_ALLOC=y
CONFIG_DQL=y
CONFIG_NLATTR=y
CONFIG_CLZ_TAB=y
# CONFIG_IRQ_POLL is not set
CONFIG_MPILIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_UCS2_STRING=y
CONFIG_HAVE_GENERIC_VDSO=y
CONFIG_GENERIC_GETTIMEOFDAY=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_SG_POOL=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# end of Library routines
CONFIG_GENERIC_IOREMAP=y
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_DYNAMIC_DEBUG is not set
# CONFIG_DYNAMIC_DEBUG_CORE is not set
CONFIG_SYMBOLIC_ERRNAME=y
CONFIG_DEBUG_BUGVERBOSE=y
# end of printk and dmesg options
# Compile-time checks and compiler options
CONFIG_DEBUG_INFO=y
# CONFIG_DEBUG_INFO_REDUCED is not set
# CONFIG_DEBUG_INFO_COMPRESSED is not set
# CONFIG_DEBUG_INFO_SPLIT is not set
# CONFIG_DEBUG_INFO_DWARF4 is not set
# CONFIG_DEBUG_INFO_BTF is not set
# CONFIG_GDB_SCRIPTS is not set
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=2048
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_HEADERS_INSTALL is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_FUNCTION_ALIGN_32B is not set
CONFIG_ARCH_WANT_FRAME_POINTERS=y
CONFIG_FRAME_POINTER=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
# Generic Kernel Debugging Instruments
CONFIG_MAGIC_SYSRQ=y
CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
CONFIG_MAGIC_SYSRQ_SERIAL=y
CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE=""
CONFIG_DEBUG_FS=y
CONFIG_DEBUG_FS_ALLOW_ALL=y
# CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
# CONFIG_DEBUG_FS_ALLOW_NONE is not set
CONFIG_HAVE_ARCH_KGDB=y
CONFIG_HAVE_ARCH_KGDB_QXFER_PKT=y
# CONFIG_KGDB is not set
# CONFIG_UBSAN is not set
# end of Generic Kernel Debugging Instruments
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_MISC=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_RODATA_TEST is not set
CONFIG_ARCH_HAS_DEBUG_WX=y
# CONFIG_DEBUG_WX is not set
CONFIG_GENERIC_PTDUMP=y
# CONFIG_PTDUMP_DEBUGFS is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
CONFIG_SCHED_STACK_END_CHECK=y
CONFIG_ARCH_HAS_DEBUG_VM_PGTABLE=y
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_VM_PGTABLE is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
CONFIG_HAVE_ARCH_KASAN=y
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
# CONFIG_KASAN is not set
# end of Memory Debugging
# CONFIG_DEBUG_SHIRQ is not set
# Debug Oops, Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
CONFIG_LOCKUP_DETECTOR=y
CONFIG_SOFTLOCKUP_DETECTOR=y
# CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set
CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC_VALUE=0
CONFIG_DETECT_HUNG_TASK=y
CONFIG_DEFAULT_HUNG_TASK_TIMEOUT=120
# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0
CONFIG_WQ_WATCHDOG=y
# CONFIG_TEST_LOCKUP is not set
# end of Debug Oops, Lockups and Hangs
# Scheduler Debugging
CONFIG_SCHED_DEBUG=y
# CONFIG_SCHEDSTATS is not set
# end of Scheduler Debugging
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# CONFIG_SCF_TORTURE_TEST is not set
# CONFIG_CSD_LOCK_WAIT_DEBUG is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
# Debug kernel data structures
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# end of Debug kernel data structures
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_SCALE_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_REF_SCALE_TEST is not set
# CONFIG_RCU_TRACE is not set
# CONFIG_RCU_EQS_DEBUG is not set
# end of RCU Debugging
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_LATENCYTOP is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
# CONFIG_SAMPLES is not set
# riscv Debugging
# Kernel Testing and Coverage
# CONFIG_KUNIT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_KCOV is not set
# CONFIG_RUNTIME_TESTING_MENU is not set
CONFIG_MEMTEST=y
# end of Kernel Testing and Coverage
# end of Kernel hacking
我的内核DTS
        sound0: sound0 {
                compatible = "simple-audio-card";
                simple-audio-card,name = "tlv320aic3262-hifi";
                simple-audio-card,format = "i2s";
                simple-audio-card,bitclock-master = <&sound_master>;
                simple-audio-card,frame-master = <&sound_master>;
                sound_master: simple-audio-card,cpu {
                        sound-dai = <&i2s0>;
                        //dai-tdm-slot-num = <2>;
                simple-audio-card,codec {
                        sound-dai = <&tlv320aic3262>;
&i2c3 {
        status = "okay";
        tlv320aic3262: codec@18 {
                compatible = "ti,aic3262";
                reg = <0x18>;
                #sound-dai-cells= <0>;
                status = "okay";
                i2s0: i2s0@300080000 {
                        #sound-dai-cells = <0>;
                        compatible = "cdns,cadence-i2s";
                        reg = <0x3 0x00080000 0x0 0x1000>;
                        interrupt-parent = <&plic0>;
                        interrupts = <76>;
                        dmas = <&dmac2 0 1>, <&dmac2 1 1>;
                        dma-names = "rx", "tx";
                        clock-names = "clk_i2s", "clk";
                        clocks = <&i2sclk>, <&i2sclk>;
                        pinctrl-names = "default";
                        pinctrl-0 = <&pinctrl_i2s0_clk_grp0
                                     &pinctrl_i2s0_lrclk_grp0
                                     &pinctrl_i2s0_dout_grp0
                                     &pinctrl_i2s0_din_grp0>;
                        status = "okay";
我在aic3262 (我的内核调试日志)中添加了一些调试日志
U-Boot SPL 2020.07-rc3-00015-gcdbb212-dirty (Apr 18 2022 - 18:29:07 +0530)
Trying to boot from RAM
U-Boot 2020.07-rc3-00015-gcdbb212-dirty (Apr 18 2022 - 18:29:07 +0530)
CPU:   rv64imafdc
Model: SiFive Pearl
DRAM:  1.8 GiB
In:    serial@4F0009000
Out:   serial@4F0009000
Err:   serial@4F0009000
Hit any key to stop autoboot:  0
## Flattened Device Tree blob at 80f000000
   Booting using the fdt blob at 0x80f000000
   Using Device Tree in place at 000000080f000000, end 000000080f0102e5
Starting kernel ...
[    0.000000] Linux version 5.10.41-nb2+ (pragneshp@osubuntu003) (riscv64-unknown-linux-gnu-gcc (crosstool-NG
1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #1193 Mon Apr 18 18:19:00 IST 2022
[    0.000000] OF: fdt: Ignoring memory range 0x800600000 - 0x800800000
[    0.000000] efi: UEFI not found.
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000800800000-0x00000008705fffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000800800000-0x00000008475fcfff]
[    0.000000]   node   0: [mem 0x00000008475fd000-0x00000008494fffff]
[    0.000000]   node   0: [mem 0x0000000849500000-0x00000008495fffff]
[    0.000000]   node   0: [mem 0x0000000849600000-0x00000008585fffff]
[    0.000000]   node   0: [mem 0x0000000858600000-0x00000008705fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000800800000-0x00000008705fffff]
[    0.000000] SBI specification v0.2 detected
[    0.000000] SBI implementation ID=0x1 Version=0x9
[    0.000000] SBI v0.2 TIME extension detected
[    0.000000] SBI v0.2 IPI extension detected
[    0.000000] SBI v0.2 RFENCE extension detected
[    0.000000] software IO TLB: mapped [mem 0x0000002800800000-0x0000002804800000] (64MB)
[    0.000000] CPU with hartid=1 is not available
[    0.000000] CPU with hartid=2 is not available
[    0.000000] CPU with hartid=3 is not available
[    0.000000] riscv: ISA extensions acdfim
[    0.000000] riscv: ELF capabilities acdfim
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 451975
[    0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 root=/dev/ram0 rw rdinit=/sbin/init
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Sorting __ex_table...
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1486304K/1832960K available (4508K kernel code, 4305K rwdata, 4096K rodata, 176K init, 2
90K bss, 346656K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] riscv-intc: 64 local interrupts mapped
[    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@1/interrupt-controller
[    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@2/interrupt-controller
[    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@3/interrupt-controller
[    0.000000] plic: interrupt-controller@c000000: mapped 137 interrupts with 1 handlers for 2 contexts.
[    0.000000] random: get_random_bytes called from start_kernel+0x31a/0x49e with crng_init=0
[    0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
[    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3
526361616960 ns
[    0.000006] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
[    0.000733] Console: colour dummy device 80x25
[    0.001307] printk: console [tty1] enabled
[    0.001380] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=40
00)
[    0.001425] pid_max: default: 32768 minimum: 301
[    0.001706] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.001845] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.004487] EFI services will not be available.
[    0.005242] devtmpfs: initialized
[    0.017878] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.017947] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[    0.018116] pinctrl core: initialized pinctrl subsystem
[    0.018859] NET: Registered protocol family 16
[    0.041075] fbcon: Taking over console
[    0.041517] SCSI subsystem initialized
[    0.041662] pps_core: LinuxPPS API ver. 1 registered
[    0.041696] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.041773] PTP clock support registered
[    0.042020] Advanced Linux Sound Architecture Driver Initialized.
[    0.043167] clocksource: Switched to clocksource riscv_clocksource
[    0.054925] NET: Registered protocol family 2
[    0.055947] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.057691] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.057827] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.058327] TCP bind hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.058833] TCP: Hash tables configured (established 16384 bind 16384)
[    0.059446] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.059620] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.060016] NET: Registered protocol family 1
[    2.018823] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    2.027727] ntfs: driver 2.1.32 [Flags: R/W].
[    2.028410] Key type asymmetric registered
[    2.028453] Asymmetric key parser 'x509' registered
[    2.028544] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    2.028589] io scheduler mq-deadline registered
[    2.028615] io scheduler kyber registered
[    2.033312] dw_axi_dmac_platform 261000000.dma-controller: DesignWare AXI DMA Controller, 6 channels
[    2.034212] dw_axi_dmac_platform 261004000.dma-controller: DesignWare AXI DMA Controller, 8 channels
[    2.034611] L2CACHE: No. of Banks in the cache: 4
[    2.034646] L2CACHE: No. of ways per bank: 16
[    2.034660] L2CACHE: Sets per bank: 256
[    2.034674] L2CACHE: Bytes per cache block: 64
[    2.034689] L2CACHE: Index of the largest way enabled: 2
[    2.063308] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    2.064983] printk: console [ttyS0] disabled
[    2.065072] 4f0009000.serial: ttyS0 at MMIO 0x4f0009000 (irq = 15, base_baud = 1625000) is a 16550A
[    2.620317] printk: console [ttyS0] enabled
[    2.626286] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* No display-controller for displa
y-subsystem.
[    2.637257] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* nb2_drm_platform_of_probe failed
[    2.658006] loop: module loaded
[    2.683412] SCSI Media Changer driver v0.25
[    2.688037] i2c /dev entries driver
[    2.694026] tlv320aic3262-codec 2-0018: aic3xxx_device_init beginning
[    2.711254] tlv320aic3262-codec 2-0018: TLV320AIC3262 revision G
[    2.717423] tlv320aic3262-codec 2-0018: aic3xxx_device_init added mfd devices
[    2.726349] NET: Registered protocol family 10
[    2.731802] Segment Routing with IPv6
[    2.736102] NET: Registered protocol family 17
[    2.740653] Key type dns_resolver registered
[    2.746586] aic3262_codec_probe enter
[    2.746602] driver_init: Allocated Major Number: 245
[    2.746602]
[    2.756821] driver_init: Registered cfw driver
[    2.761479] aic3262_codec_read enter
[    2.762206] tlv320aic3262-codec 2-0018: p 1 , r 30 7a 1
[    2.771072] aic3262_codec_read exit
[    2.771076] aic3262_codec_write enter
[    2.774589] tlv320aic3262-codec 2-0018: p 1, w 30 7a 5
[    2.783429] aic3262_codec_write exit
[    2.823690] aic3262_codec_read enter
[    2.827686] tlv320aic3262-codec 2-0018: p 1 , r 30 23 10
[    2.836623] aic3262_codec_read exit
[    2.836625] aic3262_codec_write enter
[    2.840137] tlv320aic3262-codec 2-0018: p 1, w 30 23 30
[    2.849061] aic3262_codec_write exit
[    2.849363] aic3262_codec_probe exit
[    2.853083] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
AC_CLK] -> ASI1_BCLK Route)
[    2.868905] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI1_BCLK Route
[    2.878247] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI1_BCLK Route
[    2.887597] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
-> [DAC_MOD_CLK] -> ASI1_BCLK Route)
[    2.900588] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI1_BCLK Ro
ute
[    2.910711] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI1_BCLK Ro
ute
[    2.920834] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
DC_CLK] -> ASI1_BCLK Route)
[    2.933041] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI1_BCLK Route
[    2.942381] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI1_BCLK Route
[    2.951721] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
-> [ADC_MOD_CLK] -> ASI1_BCLK Route)
[    2.964709] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI1_BCLK Ro
ute
[    2.974829] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI1_BCLK Ro
ute
[    2.984956] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
AC_CLK] -> ASI2_BCLK Route)
[    2.997164] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI2_BCLK Route
[    3.006506] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI2_BCLK Route
[    3.015852] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
-> [DAC_MOD_CLK] -> ASI2_BCLK Route)
[    3.028842] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI2_BCLK Ro
ute
[    3.038963] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI2_BCLK Ro
ute
[    3.049085] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
DC_CLK] -> ASI2_BCLK Route)
[    3.061290] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI2_BCLK Route
[    3.070629] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI2_BCLK Route
[    3.079969] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
-> [ADC_MOD_CLK] -> ASI2_BCLK Route)
[    3.092956] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI2_BCLK Ro
ute
[    3.103078] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI2_BCLK Ro
ute
[    3.113216] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
AC_CLK] -> ASI3_BCLK Route)
[    3.125427] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI3_BCLK Route
[    3.134767] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI3_BCLK Route
[    3.144113] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
-> [DAC_MOD_CLK] -> ASI3_BCLK Route)
[    3.157103] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI3_BCLK Ro
ute
[    3.167226] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI3_BCLK Ro
ute
[    3.177349] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
DC_CLK] -> ASI3_BCLK Route)
[    3.189556] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI3_BCLK Route
[    3.198895] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI3_BCLK Route
[    3.208234] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
-> [ADC_MOD_CLK] -> ASI3_BCLK Route)
[    3.221223] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI3_BCLK Ro
ute
[    3.231345] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI3_BCLK Ro
ute
[    3.241476] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI1
_BCLK Route -> ASI1_BCLK)
[    3.253510] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI1_BCLK Route --> (null) --> ASI1_BCLK
[    3.263024] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI1_BCLK Route -> direct -> ASI1_BCLK
[    3.272543] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI2
_BCLK Route -> ASI2_BCLK)
[    3.284577] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI2_BCLK Route --> (null) --> ASI2_BCLK
[    3.294090] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI2_BCLK Route -> direct -> ASI2_BCLK
[    3.303610] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI3
_BCLK Route -> ASI3_BCLK)
[    3.315644] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI3_BCLK Route --> (null) --> ASI3_BCLK
[    3.325158] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI3_BCLK Route -> direct -> ASI3_BCLK
[    3.334712] aic3262_codec_read enter
[    3.334926] tlv320aic3262-codec 2-0018: Firmware binary load
[    3.344256] Entering crc 7489
[    3.344557] CRC pass
[    3.347548] Loaded firmware inside unpickle
[    3.353963] Unable to handle kernel paging request at virtual address ffffffe049b02a31
[    3.361916] Oops [#1]
[    3.364202] Modules linked in:
[    3.367276] CPU: 0 PID: 3 Comm: kworker/0:0 Not tainted 5.10.41-nb2+ #1193
[    3.374189] Workqueue: events request_firmware_work_func
[    3.379519] epc: ffffffe00066165a ra : ffffffe00066161e sp : ffffffe0028abd60
[    3.386670]  gp : ffffffe0024bea28 tp : ffffffe002891080 t0 : ffffffe002414f70
[    3.393917]  t1 : ffffffe00044419a t2 : 00000000000016ad s0 : ffffffe0028abd90
[    3.401163]  s1 : ffffffe001ef5800 a0 : 000000000000001f a1 : ffffffe0024812f0
[    3.408409]  a2 : 0000000000000058 a3 : ffffffe049b029f1 a4 : ffffffe001ef5801
[    3.415654]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 000000000000002e
[    3.422900]  s2 : ffffffe007a37ac0 s3 : 0000000000000001 s4 : ffffffffc0a7c5f8
[    3.430145]  s5 : ffffffe00240efe8 s6 : 0000000000000000 s7 : ffffffe00240f050
[    3.437390]  s8 : 0000000000000001 s9 : 0000000000000402 s10: ffffffffffffffff
[    3.444637]  s11: ffffffe002832240 t3 : 8068454649079b00 t4 : ffffffe002200328
[    3.451882]  t5 : ffffffe00240f5d8 t6 : ffffffe0028abac8
[    3.457208] status: 0000000200000120 badaddr: ffffffe049b02a31 cause: 000000000000000d
[    3.465163] ---[ end trace 2999eb325d73b790 ]---
[    3.469892] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[    3.475164] aic3262_codec_read exit
[    3.475191] aic3262_codec_read enter
[    3.479106] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[    3.487959] aic3262_codec_read exit
[    3.487974] aic3262_codec_read enter
[    3.491883] tlv320aic3262-codec 2-0018: p 1 , r 30 1c 7f
[    3.500817] aic3262_codec_read exit
[    3.500825] aic3262_codec_read enter
[    3.504732] tlv320aic3262-codec 2-0018: p 1 , r 30 1d 7f
[    3.513664] aic3262_codec_read exit
[    3.513672] aic3262_codec_read enter
[    3.517578] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[    3.526422] aic3262_codec_read exit
[    3.526429] aic3262_codec_read enter
[    3.530335] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[    3.539181] aic3262_codec_read exit
[    3.539194] aic3262_codec_read enter
[    3.543094] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
[    3.551939] aic3262_codec_read exit
[    3.551961] aic3262_codec_read enter
[    3.555868] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
[    3.564720] aic3262_codec_read exit
[    3.564731] aic3262_codec_read enter
[    3.568639] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
[    3.577482] aic3262_codec_read exit
[    3.577489] aic3262_codec_read enter
[    3.581394] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
[    3.590239] aic3262_codec_read exit
[    3.590246] aic3262_codec_read enter
[    3.594150] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
[    3.602999] aic3262_codec_read exit
[    3.603012] aic3262_codec_read enter
[    3.606919] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
[    3.615764] aic3262_codec_read exit
[    3.615772] aic3262_codec_read enter
[    3.619678] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
[    3.628523] aic3262_codec_read exit
[    3.628535] aic3262_codec_read enter
[    3.632445] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
[    3.641291] aic3262_codec_read exit
[    3.641303] aic3262_codec_read enter
[    3.645211] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
[    3.654056] aic3262_codec_read exit
[    3.654089] aic3262_codec_read enter
[    3.658002] tlv320aic3262-codec 2-0018: p 1 , r 30 24 7f
[    3.666934] aic3262_codec_read exit
[    3.666947] aic3262_codec_read enter
[    3.670854] tlv320aic3262-codec 2-0018: p 1 , r 30 26 7f
[    3.679788] aic3262_codec_read exit
[    3.679800] aic3262_codec_read enter
[    3.683708] tlv320aic3262-codec 2-0018: p 1 , r 30 27 7f
[    3.692640] aic3262_codec_read exit
[    3.692652] aic3262_codec_read enter
[    3.696561] tlv320aic3262-codec 2-0018: p 1 , r 30 25 7f
[    3.705496] aic3262_codec_read exit
[    3.705515] aic3262_codec_read enter
[    3.709422] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
[    3.718268] aic3262_codec_read exit
[    3.718279] aic3262_codec_read enter
[    3.722187] tlv320aic3262-codec 2-0018: p 1 , r 30 2e 7f
[    3.731120] aic3262_codec_read exit
[    3.731128] aic3262_codec_read enter
[    3.735033] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
[    3.743878] aic3262_codec_read exit
[    3.743890] aic3262_codec_read enter
[    3.747796] tlv320aic3262-codec 2-0018: p 1 , r 30 2f 7f
[    3.756727] aic3262_codec_read exit
[    3.756739] aic3262_codec_read enter
[    3.760648] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
[    3.769495] aic3262_codec_read exit
[    3.769533] aic3262_codec_read enter
[    3.773737] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[    3.782586] aic3262_codec_read exit
[    3.782594] aic3262_codec_read enter
[    3.786499] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[    3.795344] aic3262_codec_read exit
[    3.795353] aic3262_codec_read enter
[    3.799252] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[    3.808091] aic3262_codec_read exit
[    3.808098] aic3262_codec_read enter
[    3.812004] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[    3.820846] aic3262_codec_read exit
[    3.820853] aic3262_codec_read enter
[    3.824757] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[    3.833601] aic3262_codec_read exit
[    3.833608] aic3262_codec_read enter
[    3.837512] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
[    3.846365] aic3262_codec_read exit
[    3.846382] aic3262_codec_read enter
[    3.850295] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[    3.859144] aic3262_codec_read exit
[    3.859152] aic3262_codec_read enter
[    3.863057] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[    3.871899] aic3262_codec_read exit
[    3.871908] aic3262_codec_read enter
[    3.875813] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[    3.884658] aic3262_codec_read exit
[    3.884666] aic3262_codec_read enter
[    3.888570] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[    3.897416] aic3262_codec_read exit
[    3.897423] aic3262_codec_read enter
[    3.901328] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[    3.910175] aic3262_codec_read exit
[    3.910182] aic3262_codec_read enter
[    3.914086] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
[    3.922931] aic3262_codec_read exit
[    3.922939] aic3262_codec_read enter
[    3.926842] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[    3.935686] aic3262_codec_read exit
[    3.935693] aic3262_codec_read enter
[    3.939597] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[    3.948441] aic3262_codec_read exit
[    3.948449] aic3262_codec_read enter
[    3.952354] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[    3.961198] aic3262_codec_read exit
[    3.961205] aic3262_codec_read enter
[    3.965110] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[    3.973956] aic3262_codec_read exit
[    3.973964] aic3262_codec_read enter
[    3.977869] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[    3.986705] aic3262_codec_read exit
[    3.986712] aic3262_codec_read enter
[    3.990619] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
[    3.999465] aic3262_codec_read exit
[    3.999480] aic3262_codec_read enter
[    4.003378] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.012223] aic3262_codec_read exit
[    4.012229] aic3262_codec_read enter
[    4.016137] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.024983] aic3262_codec_read exit
[    4.024989] aic3262_codec_read enter
[    4.028892] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.037738] aic3262_codec_read exit
[    4.037751] aic3262_codec_read enter
[    4.041658] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.050503] aic3262_codec_read exit
[    4.050513] aic3262_codec_read enter
[    4.054417] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.063264] aic3262_codec_read exit
[    4.063271] aic3262_codec_read enter
[    4.067173] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.076014] aic3262_codec_read exit
[    4.076020] aic3262_codec_read enter
[    4.079925] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.088770] aic3262_codec_read exit
[    4.088779] aic3262_codec_read enter
[    4.092686] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.101533] aic3262_codec_read exit
[    4.101538] aic3262_codec_read enter
[    4.105444] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.114290] aic3262_codec_read exit
[    4.114295] aic3262_codec_read enter
[    4.118200] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
[    4.127046] aic3262_codec_read exit
[    4.127054] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Le
ft DAC
[    4.140946] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Left DAC
[    4.150722] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Left DAC
[    4.160498] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Ri
ght DAC
[    4.170967] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Right DAC
[    4.180829] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Right DAC
[    4.190690] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Le
ft DAC
[    4.201073] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Left DAC
[    4.210844] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Left DAC
[    4.220620] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Ri
ght DAC
[    4.231089] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Right DAC
[    4.240950] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Right DAC
[    4.250809] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Le
ft DAC
[    4.261190] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Left DAC
[    4.270964] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Left DAC
[    4.280739] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Ri
ght DAC
[    4.291206] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Right DAC
[    4.301066] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Right DAC
[    4.310937] aic3262_codec_read enter
[    4.311631] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
[    4.320477] aic3262_codec_read exit
[    4.320488] aic3262_codec_read enter
[    4.324397] tlv320aic3262-codec 2-0018: p 1 , r 30 12 3f
[    4.333331] aic3262_codec_read exit
[    4.333347] aic3262_codec_read enter
[    4.337256] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
[    4.346102] aic3262_codec_read exit
[    4.346124] aic3262_codec_read enter
[    4.350035] tlv320aic3262-codec 2-0018: p 1 , r 30 13 3f
[    4.358973] aic3262_codec_read exit
[    4.358989] aic3262_codec_read enter
[    4.362796] random: fast init done
[    4.370214] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
[    4.375380] aic3262_codec_read exit
[    4.375388] aic3262_codec_read enter
[    4.379289] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
[    4.388043] aic3262_codec_read exit
[    4.388062] aic3262_codec_read enter
[    4.392259] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
[    4.401106] aic3262_codec_read exit
[    4.401113] aic3262_codec_read enter
[    4.405020] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
[    4.413865] aic3262_codec_read exit
[    4.413873] aic3262_codec_read enter
[    4.417778] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
[    4.426625] aic3262_codec_read exit
[    4.426633] aic3262_codec_read enter
[    4.430538] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
[    4.439381] aic3262_codec_read exit
[    4.439389] aic3262_codec_read enter
[    4.443288] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
[    4.452129] aic3262_codec_read exit
[    4.452136] aic3262_codec_read enter
[    4.456041] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
[    4.464887] aic3262_codec_read exit
[    4.464893] aic3262_codec_read enter
[    4.468800] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
[    4.477643] aic3262_codec_read exit
[    4.477651] aic3262_codec_read enter
[    4.481558] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
[    4.490402] aic3262_codec_read exit
[    4.490414] aic3262_codec_read enter
[    4.494322] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
[    4.503166] aic3262_codec_read exit
[    4.503176] aic3262_codec_read enter
[    4.507075] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
[    4.515920] aic3262_codec_read exit
[    4.515934] aic3262_codec_read enter
[    4.519843] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
[    4.528690] aic3262_codec_read exit
[    4.528697] aic3262_codec_read enter
[    4.532603] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
[    4.541452] aic3262_codec_read exit
[    4.541457] aic3262_codec_read enter
[    4.545365] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
[    4.554210] aic3262_codec_read exit
[    4.554217] aic3262_codec_read enter
[    4.558124] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
[    4.566970] aic3262_codec_read exit
[    4.566983] aic3262_codec_read enter
[    4.570891] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
[    4.579738] aic3262_codec_read exit
[    4.579749] aic3262_codec_read enter
[    4.583659] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
[    4.592509] aic3262_codec_read exit
[    4.592519] aic3262_codec_read enter
[    4.596428] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
[    4.605274] aic3262_codec_read exit
[    4.605281] aic3262_codec_read enter
[    4.609186] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
[    4.618033] aic3262_codec_read exit
[    4.618043] aic3262_codec_read enter
[    4.621949] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
[    4.630796] aic3262_codec_read exit
[    4.630803] aic3262_codec_read enter
[    4.634710] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
[    4.643556] aic3262_codec_read exit
[    4.643588] aic3262_codec_read enter
[    4.647787] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
[    4.656635] aic3262_codec_read exit
[    4.656649] aic3262_codec_read enter
[    4.660559] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
[    4.669407] aic3262_codec_read exit
[    4.669419] aic3262_codec_read enter
[    4.673326] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
[    4.682172] aic3262_codec_read exit
[    4.682185] aic3262_codec_read enter
[    4.686092] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
[    4.694938] aic3262_codec_read exit
[    4.694967] aic3262_codec_read enter
[    4.699175] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
[    4.707929] aic3262_codec_read exit
[    4.707938] aic3262_codec_read enter
[    4.711849] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
[    4.720606] aic3262_codec_read exit
[    4.720613] aic3262_codec_read enter
[    4.724519] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
[    4.733280] aic3262_codec_read exit
[    4.733286] aic3262_codec_read enter
[    4.737193] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
[    4.745954] aic3262_codec_read exit
[    4.745966] aic3262_codec_read enter
[    4.749874] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[    4.758721] aic3262_codec_read exit
[    4.758731] aic3262_codec_read enter
[    4.762636] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[    4.771483] aic3262_codec_read exit
[    4.771489] aic3262_codec_read enter
[    4.775388] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[    4.784226] aic3262_codec_read exit
[    4.784231] aic3262_codec_read enter
[    4.788138] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[    4.796986] aic3262_codec_read exit
[    4.796996] aic3262_codec_read enter
[    4.800903] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
[    4.809747] aic3262_codec_read exit
[    4.809759] aic3262_codec_read enter
[    4.813665] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[    4.822512] aic3262_codec_read exit
[    4.822522] aic3262_codec_read enter
[    4.826427] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[    4.835272] aic3262_codec_read exit
[    4.835279] aic3262_codec_read enter
[    4.839178] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[    4.848016] aic3262_codec_read exit
[    4.848022] aic3262_codec_read enter
[    4.851926] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[    4.860772] aic3262_codec_read exit
[    4.860783] aic3262_codec_read enter
[    4.864686] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
[    4.873543] aic3262_codec_read exit
[    4.873562] aic3262_codec_read enter
[    4.877474] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
[    4.886237] aic3262_codec_read exit
[    4.886246] aic3262_codec_read enter
[    4.890156] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
[    4.898914] aic3262_codec_read exit
[    4.898922] aic3262_codec_read enter
[    4.902829] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
[    4.911587] aic3262_codec_read exit
[    4.911603] aic3262_codec_read enter
[    4.915504] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
[    4.924257] aic3262_codec_read exit
[    4.924270] aic3262_codec_read enter
[    4.928179] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
[    4.937025] aic3262_codec_read exit
[    4.937034] aic3262_codec_read enter
[    4.940942] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
[    4.949788] aic3262_codec_read exit
[    4.949795] aic3262_codec_read enter
[    4.953701] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
[    4.962547] aic3262_codec_read exit
[    4.962553] aic3262_codec_read enter
[    4.966459] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
[    4.975306] aic3262_codec_read exit
[    4.975317] aic3262_codec_read enter
[    4.979220] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
[    4.988062] aic3262_codec_read exit
[    4.988070] aic3262_codec_read enter
[    4.991980] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
[    5.000824] aic3262_codec_read exit
[    5.000831] aic3262_codec_read enter
[    5.004737] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
[    5.013584] aic3262_codec_read exit
[    5.013590] aic3262_codec_read enter
[    5.017497] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
[    5.026343] aic3262_codec_read exit
[    5.026364] asoc-simple-card sound0: soc_probe_component: snd_soc_dapm_add_routes failed: -22
[    5.038431] aic3262_codec_remove enter
[    5.038437] aic3262_set_bias_level enter
[    5.042211] tlv320aic3262-codec 2-0018: set_bias_off
[    5.051138] aic3262_set_bias_level exit
[    5.051148] Unable to handle kernel NULL pointer dereference at virtual address 00000000000000a0
[    5.063823] Oops [#2]
[    5.066108] Modules linked in:
[    5.069182] CPU: 0 PID: 25 Comm: kworker/0:1 Tainted: G      D           5.10.41-nb2+ #1193
[    5.077575] Workqueue: events deferred_probe_work_func
[    5.082732] epc: ffffffe000218d44 ra : ffffffe00066130e sp : ffffffe0029af9e0
[    5.089883]  gp : ffffffe0024bea28 tp : ffffffe0029a0840 t0 : ffffffe00241cce8
[    5.097129]  t1 : ffffffe0029af9a8 t2 : 0000000000000001 s0 : ffffffe0029afa10
[    5.104375]  s1 : ffffffe0079eb218 a0 : 0000000000000000 a1 : ffffffe0024812f0
[    5.111621]  a2 : 0000000000000003 a3 : ffffffe002481310 a4 : 8068454649079b00
[    5.118867]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 8068454649079b00
[    5.126114]  s2 : 0000000000000000 s3 : ffffffe0076da718 s4 : ffffffe0024bf0a8
[    5.133360]  s5 : ffffffe007a72018 s6 : ffffffe0079eb2d0 s7 : 0000000000000001
[    5.140606]  s8 : 0000000000000000 s9 : ffffffe0024a3dd0 s10: ffffffffffffffff
[    5.147852]  s11: ffffffe007a72018 t3 : 8068454649079b00 t4 : ffffffe002200328
[    5.155098]  t5 : ffffffe00023886a t6 : ffffffe0029af748
[    5.160424] status: 0000000200000120 badaddr: 00000000000000a0 cause: 000000000000000d
[    5.168381] ---[ end trace 2999eb325d73b791 ]---
请告诉我这里的内核驱动程序有什么问题,或者请告诉我正确的内核驱动程序。
Pragnesh
    我已请我们的潜水专家来看一看。
    有关此问题的任何更新
    你(们)好
    您能告诉您遇到的确切问题是什么吗?
    如果您要检查我从驱动程序收到的以下错误的调试日志,请查看此问题
    ute
    ute
    ute
    ute
    ute
    ute
    ute
    ute
    ute
    ute
    ute
    ute
    ft DAC
    ght DAC
    ft DAC
    ght DAC
    ft DAC
    ght DAC
    你(们)好
    您能否告知i2c是否正常工作?声卡注册是否成功?
    是的,I2C工作正常,我能够使用以下代码检测编解码器修订
    RET = aic3xxx_reg_read (aic3xxx,AIC3262_DEVICE_ID);
    如果(ret < 0){
    dev_err(aic3xxx->dev,"failed to read ID register\n");
    goto err_return;
    开关(转台){
    案例3:
    DevName ="TLV320AIC3262";
    如果(aic3xxx->type != TLV320AIC3262)
    dev_warn(aic3xxx->dev,"设备注册为类型%d\n",
    aic3xxx->类型);
    aic3xxx->type = TLV320AIC3262;
    中断;
    默认:
    dev_err(aic3xxx->dev,"设备不是TLV320AIC3262";
    RET =-EINVAL;
    goto err_return;
    dev_info (aic3xxx->dev,"%s"修订版%c\n",devname,'D'+ ret);
    调试日志:
    [ 2.68.8037万 ] i2c /dev条目驱动程序
    [ 2.69.4026万 ] tlv320aic3262-codec 2-0018:aic3xxx_device_init开始
    [ 2.71.1254万 LV320AIC3262修订版G
    [ MFD] tlv320aic3262-codec 2-0018:aic3xxx_device_init已添加2.71.7423万 设备
    我使用了“简单音频卡”作为链路驱动程序,但由于AIC3262路由问题,此链路驱动程序失败
    如果您需要更多信息,请告诉我。
    我们将在内部研究内核5.10 的这个问题。我们的计划是本周提供反馈。如果我们需要更多信息,我会告诉您。
    似乎是固件解析错误。 您是否愿意在函数 aic3xxx_CFW_unpickle中添加一些日志?
    如果我们要检查调试日志,那么我们将看到EPC = ffffffffe6.6165万a,如果我将使用vmlinux的objdump
            for (i = 0; i < CFW_TRN_N; i++) {
    ffffffe00066163c:       05800613                li      a2,88
            return &base[(int)p];
    ffffffe000661640:       9726                    add     a4,a4,s1
            pjt->transition = aic3xxx_cfw_ndx2ptr(pjt->transition, p);
    ffffffe000661642:       4781                    li      a5,0
    ffffffe000661644:       f4b8                    sd      a4,104(s1)
                    if (!pjt->transition[i])
    ffffffe000661646:       74b4                    ld      a3,104(s1)
    ffffffe000661648:       96be                    add     a3,a3,a5
    ffffffe00066164a:       6298                    ld      a4,0(a3)
    ffffffe00066164c:       c315                    beqz    a4,ffffffe000661670 <aic3xxx_cfw_reload+0x176>
    ffffffe00066164e:       2701                    sext.w  a4,a4
    ffffffe000661650:       9726                    add     a4,a4,s1
                    pjt->transition[i] = aic3xxx_cfw_ndx2ptr(pjt->transition[i], p);
    ffffffe000661652:       e298                    sd      a4,0(a3)
                                                    pjt->transition[i]->desc, p);
    ffffffe000661654:       74b8                    ld      a4,104(s1)
    ffffffe000661656:       973e                    add     a4,a4,a5
    ffffffe000661658:       6314                    ld      a3,0(a4)
    ffffffe00066165a:       62b8                    ld      a4,64(a3)
            if (p)
    ffffffe00066165c:       c319                    beqz    a4,ffffffe000661662 <aic3xxx_cfw_reload+0x168>
    ffffffe00066165e:       2701                    sext.w  a4,a4
    ffffffe000661660:       9726                    add     a4,a4,s1
                    pjt->transition[i]->desc = aic3xxx_cfw_desc(
    然后它看起来像是Proble在
    静态结构CFW_project *aic3xxx_CFW_unpickle(void *p, int n)
          pjt->transition [i]= aic3xxx_CFW_ndx2ptr (pjt->transition [i],p);
    除了这种路由问题,驱动程序中也存在这种问题。
    为了调试音频路由,请勿加载固件。
    如果我将跳过固件加载,则会出现相同的路由问题
    Starting kernel ...
    1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #1197 Thu Apr 21 15:34:29 IST 2022
    [    0.000000] Memory: 1486304K/1832960K available (4507K kernel code, 4309K rwdata, 4096K rodata, 176K init, 2
    526361616960 ns
    [    0.000007] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
    [    0.000730] Console: colour dummy device 80x25
    [    0.001292] printk: console [tty1] enabled
    [    0.001363] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=40
    00)
    [    0.001408] pid_max: default: 32768 minimum: 301
    [    0.001680] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.001819] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.004462] EFI services will not be available.
    [    0.005158] devtmpfs: initialized
    [    0.016218] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.016287] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
    [    0.016454] pinctrl core: initialized pinctrl subsystem
    [    0.017181] NET: Registered protocol family 16
    [    0.038277] fbcon: Taking over console
    [    0.038715] SCSI subsystem initialized
    [    0.038854] pps_core: LinuxPPS API ver. 1 registered
    [    0.038886] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.038962] PTP clock support registered
    [    0.039195] Advanced Linux Sound Architecture Driver Initialized.
    [    0.040330] clocksource: Switched to clocksource riscv_clocksource
    [    0.051880] NET: Registered protocol family 2
    [    0.052912] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.054652] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.054788] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.055287] TCP bind hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.055792] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.056411] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.056586] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.056981] NET: Registered protocol family 1
    [    1.995396] workingset: timestamp_bits=62 max_order=19 bucket_order=0
    [    2.002152] ntfs: driver 2.1.32 [Flags: R/W].
    [    2.002793] Key type asymmetric registered
    [    2.002836] Asymmetric key parser 'x509' registered
    [    2.002927] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    2.002973] io scheduler mq-deadline registered
    [    2.003000] io scheduler kyber registered
    [    2.007531] dw_axi_dmac_platform 261000000.dma-controller: DesignWare AXI DMA Controller, 6 channels
    [    2.008434] dw_axi_dmac_platform 261004000.dma-controller: DesignWare AXI DMA Controller, 8 channels
    [    2.008827] L2CACHE: No. of Banks in the cache: 4
    [    2.008862] L2CACHE: No. of ways per bank: 16
    [    2.008877] L2CACHE: Sets per bank: 256
    [    2.008892] L2CACHE: Bytes per cache block: 64
    [    2.008906] L2CACHE: Index of the largest way enabled: 2
    [    2.037577] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
    [    2.039242] printk: console [ttyS0] disabled
    [    2.039332] 4f0009000.serial: ttyS0 at MMIO 0x4f0009000 (irq = 15, base_baud = 1625000) is a 16550A
    [    2.594590] printk: console [ttyS0] enabled
    [    2.600639] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* No display-controller for displa
    y-subsystem.
    [    2.611602] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* nb2_drm_platform_of_probe failed
    [    2.632568] loop: module loaded
    [    2.658240] SCSI Media Changer driver v0.25
    [    2.662885] i2c /dev entries driver
    [    2.668955] tlv320aic3262-codec 2-0018: aic3xxx_device_init beginning
    [    2.686179] tlv320aic3262-codec 2-0018: TLV320AIC3262 revision G
    [    2.692372] tlv320aic3262-codec 2-0018: aic3xxx_device_init added mfd devices
    [    2.701356] NET: Registered protocol family 10
    [    2.706791] Segment Routing with IPv6
    [    2.711097] NET: Registered protocol family 17
    [    2.715643] Key type dns_resolver registered
    [    2.721638] aic3262_codec_probe enter
    [    2.721652] driver_init: Allocated Major Number: 245
    [    2.721652]
    [    2.731876] driver_init: Registered cfw driver
    [    2.736531] aic3262_codec_read enter
    [    2.737257] tlv320aic3262-codec 2-0018: p 1 , r 30 7a 1
    [    2.746124] aic3262_codec_read exit
    [    2.746127] aic3262_codec_write enter
    [    2.749642] tlv320aic3262-codec 2-0018: p 1, w 30 7a 5
    [    2.758483] aic3262_codec_write exit
    [    2.798742] aic3262_codec_read enter
    [    2.802738] tlv320aic3262-codec 2-0018: p 1 , r 30 23 10
    [    2.811672] aic3262_codec_read exit
    [    2.811675] aic3262_codec_write enter
    [    2.815187] tlv320aic3262-codec 2-0018: p 1, w 30 23 30
    [    2.824113] aic3262_codec_write exit
    [    2.824412] aic3262_codec_probe exit
    [    2.828121] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
    [    2.843941] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI1_BCLK Route
    [    2.853283] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI1_BCLK Route
    [    2.862631] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
    [    2.875621] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI1_BCLK Ro
    ute
    [    2.885736] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI1_BCLK Ro
    ute
    [    2.895858] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
    [    2.908062] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI1_BCLK Route
    [    2.917402] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI1_BCLK Route
    [    2.926742] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
    [    2.939730] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI1_BCLK Ro
    ute
    [    2.949851] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI1_BCLK Ro
    ute
    [    2.959980] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
    [    2.972187] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI2_BCLK Route
    [    2.981527] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI2_BCLK Route
    [    2.990872] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
    [    3.003861] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI2_BCLK Ro
    ute
    [    3.013984] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI2_BCLK Ro
    ute
    [    3.024107] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
    [    3.036313] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI2_BCLK Route
    [    3.045653] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI2_BCLK Route
    [    3.054994] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
    [    3.067982] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI2_BCLK Ro
    ute
    [    3.078104] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI2_BCLK Ro
    ute
    [    3.088234] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DACCLK -> [D
    [    3.100442] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DACCLK --> DAC_CLK --> ASI3_BCLK Route
    [    3.109793] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DACCLK -> DAC_CLK -> ASI3_BCLK Route
    [    3.119146] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (DAC_MOD_CLK
    [    3.132137] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC_MOD_CLK --> DAC_MOD_CLK --> ASI3_BCLK Ro
    ute
    [    3.142260] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC_MOD_CLK -> DAC_MOD_CLK -> ASI3_BCLK Ro
    ute
    [    3.152382] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADCCLK -> [A
    [    3.164588] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADCCLK --> ADC_CLK --> ASI3_BCLK Route
    [    3.173929] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADCCLK -> ADC_CLK -> ASI3_BCLK Route
    [    3.183269] tlv320aic3262-codec 2-0018: Conditional paths are not supported for supply widgets (ADC_MOD_CLK
    [    3.196257] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ADC_MOD_CLK --> ADC_MOD_CLK --> ASI3_BCLK Ro
    ute
    [    3.206379] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ADC_MOD_CLK -> ADC_MOD_CLK -> ASI3_BCLK Ro
    ute
    [    3.216509] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI1
    [    3.228544] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI1_BCLK Route --> (null) --> ASI1_BCLK
    [    3.238058] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI1_BCLK Route -> direct -> ASI1_BCLK
    [    3.247576] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI2
    [    3.259610] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI2_BCLK Route --> (null) --> ASI2_BCLK
    [    3.269123] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI2_BCLK Route -> direct -> ASI2_BCLK
    [    3.278642] tlv320aic3262-codec 2-0018: Connecting non-supply widget to supply widget is not supported (ASI3
    [    3.290676] tlv320aic3262-codec 2-0018: ASoC: no dapm match for ASI3_BCLK Route --> (null) --> ASI3_BCLK
    [    3.300189] tlv320aic3262-codec 2-0018: ASoC: Failed to add route ASI3_BCLK Route -> direct -> ASI3_BCLK
    [    3.309749] aic3262_codec_read enter
    [    3.310163] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.319021] aic3262_codec_read exit
    [    3.319035] aic3262_codec_read enter
    [    3.322945] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.331796] aic3262_codec_read exit
    [    3.331811] aic3262_codec_read enter
    [    3.335719] tlv320aic3262-codec 2-0018: p 1 , r 30 1c 7f
    [    3.344653] aic3262_codec_read exit
    [    3.344660] aic3262_codec_read enter
    [    3.348559] tlv320aic3262-codec 2-0018: p 1 , r 30 1d 7f
    [    3.357486] aic3262_codec_read exit
    [    3.357495] aic3262_codec_read enter
    [    3.361401] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.370247] aic3262_codec_read exit
    [    3.370254] aic3262_codec_read enter
    [    3.374157] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.383004] aic3262_codec_read exit
    [    3.383018] aic3262_codec_read enter
    [    3.386928] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.395773] aic3262_codec_read exit
    [    3.395794] aic3262_codec_read enter
    [    3.399703] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.408549] aic3262_codec_read exit
    [    3.408561] aic3262_codec_read enter
    [    3.412461] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.421302] aic3262_codec_read exit
    [    3.421309] aic3262_codec_read enter
    [    3.425215] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.434062] aic3262_codec_read exit
    [    3.434068] aic3262_codec_read enter
    [    3.437974] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.446823] aic3262_codec_read exit
    [    3.446835] aic3262_codec_read enter
    [    3.450741] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.459586] aic3262_codec_read exit
    [    3.459594] aic3262_codec_read enter
    [    3.463500] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.472339] aic3262_codec_read exit
    [    3.472350] aic3262_codec_read enter
    [    3.476249] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.485096] aic3262_codec_read exit
    [    3.485108] aic3262_codec_read enter
    [    3.489016] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.497863] aic3262_codec_read exit
    [    3.497894] aic3262_codec_read enter
    [    3.501807] tlv320aic3262-codec 2-0018: p 1 , r 30 24 7f
    [    3.510741] aic3262_codec_read exit
    [    3.510754] aic3262_codec_read enter
    [    3.514662] tlv320aic3262-codec 2-0018: p 1 , r 30 26 7f
    [    3.523593] aic3262_codec_read exit
    [    3.523605] aic3262_codec_read enter
    [    3.527512] tlv320aic3262-codec 2-0018: p 1 , r 30 27 7f
    [    3.536445] aic3262_codec_read exit
    [    3.536457] aic3262_codec_read enter
    [    3.540359] tlv320aic3262-codec 2-0018: p 1 , r 30 25 7f
    [    3.549286] aic3262_codec_read exit
    [    3.549304] aic3262_codec_read enter
    [    3.553212] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.562058] aic3262_codec_read exit
    [    3.562070] aic3262_codec_read enter
    [    3.565979] tlv320aic3262-codec 2-0018: p 1 , r 30 2e 7f
    [    3.574913] aic3262_codec_read exit
    [    3.574921] aic3262_codec_read enter
    [    3.578828] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.587676] aic3262_codec_read exit
    [    3.587687] aic3262_codec_read enter
    [    3.591592] tlv320aic3262-codec 2-0018: p 1 , r 30 2f 7f
    [    3.600518] aic3262_codec_read exit
    [    3.600529] aic3262_codec_read enter
    [    3.604427] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.613265] aic3262_codec_read exit
    [    3.613301] aic3262_codec_read enter
    [    3.617504] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.626352] aic3262_codec_read exit
    [    3.626360] aic3262_codec_read enter
    [    3.630267] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.639116] aic3262_codec_read exit
    [    3.639124] aic3262_codec_read enter
    [    3.643031] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.651878] aic3262_codec_read exit
    [    3.651885] aic3262_codec_read enter
    [    3.655790] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.664637] aic3262_codec_read exit
    [    3.664645] aic3262_codec_read enter
    [    3.668544] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.677384] aic3262_codec_read exit
    [    3.677391] aic3262_codec_read enter
    [    3.681298] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.690143] aic3262_codec_read exit
    [    3.690161] aic3262_codec_read enter
    [    3.694069] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.702916] aic3262_codec_read exit
    [    3.702921] aic3262_codec_read enter
    [    3.706825] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.715672] aic3262_codec_read exit
    [    3.715679] aic3262_codec_read enter
    [    3.719584] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.728428] aic3262_codec_read exit
    [    3.728436] aic3262_codec_read enter
    [    3.732336] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.741176] aic3262_codec_read exit
    [    3.741183] aic3262_codec_read enter
    [    3.745090] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.753936] aic3262_codec_read exit
    [    3.753943] aic3262_codec_read enter
    [    3.757849] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.766694] aic3262_codec_read exit
    [    3.766702] aic3262_codec_read enter
    [    3.770607] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.779456] aic3262_codec_read exit
    [    3.779462] aic3262_codec_read enter
    [    3.783367] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.792214] aic3262_codec_read exit
    [    3.792222] aic3262_codec_read enter
    [    3.796124] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.804969] aic3262_codec_read exit
    [    3.804977] aic3262_codec_read enter
    [    3.808879] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.817733] aic3262_codec_read exit
    [    3.817741] aic3262_codec_read enter
    [    3.821649] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.830498] aic3262_codec_read exit
    [    3.830507] aic3262_codec_read enter
    [    3.834413] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.843260] aic3262_codec_read exit
    [    3.843277] aic3262_codec_read enter
    [    3.847183] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.856029] aic3262_codec_read exit
    [    3.856035] aic3262_codec_read enter
    [    3.859938] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.868787] aic3262_codec_read exit
    [    3.868791] aic3262_codec_read enter
    [    3.872688] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.881528] aic3262_codec_read exit
    [    3.881540] aic3262_codec_read enter
    [    3.885444] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.894291] aic3262_codec_read exit
    [    3.894301] aic3262_codec_read enter
    [    3.898209] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.907056] aic3262_codec_read exit
    [    3.907062] aic3262_codec_read enter
    [    3.910968] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.919814] aic3262_codec_read exit
    [    3.919819] aic3262_codec_read enter
    [    3.923723] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.932571] aic3262_codec_read exit
    [    3.932581] aic3262_codec_read enter
    [    3.936478] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.945318] aic3262_codec_read exit
    [    3.945324] aic3262_codec_read enter
    [    3.949227] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.958074] aic3262_codec_read exit
    [    3.958080] aic3262_codec_read enter
    [    3.961982] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.970828] aic3262_codec_read exit
    [    3.970836] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Le
    ft DAC
    [    3.984727] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Left DAC
    [    3.994502] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Left DAC
    [    4.004278] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Ri
    ght DAC
    [    4.014755] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Right DAC
    [    4.024618] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Right DAC
    [    4.034481] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Le
    ft DAC
    [    4.044866] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Left DAC
    [    4.054640] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Left DAC
    [    4.064416] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Ri
    ght DAC
    [    4.074888] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Right DAC
    [    4.084749] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Right DAC
    [    4.094609] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Le
    ft DAC
    [    4.104992] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Left DAC
    [    4.114766] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Left DAC
    [    4.124540] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Ri
    ght DAC
    [    4.135009] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Right DAC
    [    4.144870] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Right DAC
    [    4.154745] aic3262_codec_read enter
    [    4.155458] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    4.164327] aic3262_codec_read exit
    [    4.164349] aic3262_codec_read enter
    [    4.168253] tlv320aic3262-codec 2-0018: p 1 , r 30 12 3f
    [    4.177191] aic3262_codec_read exit
    [    4.177211] aic3262_codec_read enter
    [    4.181122] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    4.189971] aic3262_codec_read exit
    [    4.189993] aic3262_codec_read enter
    [    4.193902] tlv320aic3262-codec 2-0018: p 1 , r 30 13 3f
    [    4.202836] aic3262_codec_read exit
    [    4.202851] aic3262_codec_read enter
    [    4.206392] random: fast init done
    [    4.213809] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.218977] aic3262_codec_read exit
    [    4.218984] aic3262_codec_read enter
    [    4.222892] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.231653] aic3262_codec_read exit
    [    4.231671] aic3262_codec_read enter
    [    4.235866] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.244712] aic3262_codec_read exit
    [    4.244719] aic3262_codec_read enter
    [    4.248619] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.257456] aic3262_codec_read exit
    [    4.257462] aic3262_codec_read enter
    [    4.261369] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.270213] aic3262_codec_read exit
    [    4.270221] aic3262_codec_read enter
    [    4.274127] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.282971] aic3262_codec_read exit
    [    4.282978] aic3262_codec_read enter
    [    4.286885] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.295730] aic3262_codec_read exit
    [    4.295737] aic3262_codec_read enter
    [    4.299643] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.308488] aic3262_codec_read exit
    [    4.308495] aic3262_codec_read enter
    [    4.312392] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.321231] aic3262_codec_read exit
    [    4.321237] aic3262_codec_read enter
    [    4.325152] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.334003] aic3262_codec_read exit
    [    4.334018] aic3262_codec_read enter
    [    4.337926] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.346772] aic3262_codec_read exit
    [    4.346782] aic3262_codec_read enter
    [    4.350688] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.359535] aic3262_codec_read exit
    [    4.359549] aic3262_codec_read enter
    [    4.363458] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.372305] aic3262_codec_read exit
    [    4.372312] aic3262_codec_read enter
    [    4.376219] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.385063] aic3262_codec_read exit
    [    4.385069] aic3262_codec_read enter
    [    4.388979] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.397824] aic3262_codec_read exit
    [    4.397831] aic3262_codec_read enter
    [    4.401738] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    4.410582] aic3262_codec_read exit
    [    4.410597] aic3262_codec_read enter
    [    4.414505] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.423353] aic3262_codec_read exit
    [    4.423363] aic3262_codec_read enter
    [    4.427272] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.436119] aic3262_codec_read exit
    [    4.436130] aic3262_codec_read enter
    [    4.440038] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.448886] aic3262_codec_read exit
    [    4.448893] aic3262_codec_read enter
    [    4.452800] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    4.461645] aic3262_codec_read exit
    [    4.461655] aic3262_codec_read enter
    [    4.465564] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.474410] aic3262_codec_read exit
    [    4.474417] aic3262_codec_read enter
    [    4.478323] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.487170] aic3262_codec_read exit
    [    4.487203] aic3262_codec_read enter
    [    4.491408] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.500255] aic3262_codec_read exit
    [    4.500269] aic3262_codec_read enter
    [    4.504176] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.513026] aic3262_codec_read exit
    [    4.513038] aic3262_codec_read enter
    [    4.516945] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.525792] aic3262_codec_read exit
    [    4.525805] aic3262_codec_read enter
    [    4.529715] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.538560] aic3262_codec_read exit
    [    4.538589] aic3262_codec_read enter
    [    4.542790] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.551554] aic3262_codec_read exit
    [    4.551564] aic3262_codec_read enter
    [    4.555472] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.564230] aic3262_codec_read exit
    [    4.564236] aic3262_codec_read enter
    [    4.568142] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.576901] aic3262_codec_read exit
    [    4.576907] aic3262_codec_read enter
    [    4.580813] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.589573] aic3262_codec_read exit
    [    4.589585] aic3262_codec_read enter
    [    4.593492] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.602338] aic3262_codec_read exit
    [    4.602348] aic3262_codec_read enter
    [    4.606255] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.615102] aic3262_codec_read exit
    [    4.615108] aic3262_codec_read enter
    [    4.619012] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.627858] aic3262_codec_read exit
    [    4.627863] aic3262_codec_read enter
    [    4.631768] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.640616] aic3262_codec_read exit
    [    4.640625] aic3262_codec_read enter
    [    4.644523] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.653363] aic3262_codec_read exit
    [    4.653373] aic3262_codec_read enter
    [    4.657280] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.666128] aic3262_codec_read exit
    [    4.666137] aic3262_codec_read enter
    [    4.670046] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.678893] aic3262_codec_read exit
    [    4.678900] aic3262_codec_read enter
    [    4.682804] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.691649] aic3262_codec_read exit
    [    4.691656] aic3262_codec_read enter
    [    4.695560] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.704408] aic3262_codec_read exit
    [    4.704420] aic3262_codec_read enter
    [    4.708320] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.717170] aic3262_codec_read exit
    [    4.717191] aic3262_codec_read enter
    [    4.721102] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.729863] aic3262_codec_read exit
    [    4.729871] aic3262_codec_read enter
    [    4.733775] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.742539] aic3262_codec_read exit
    [    4.742546] aic3262_codec_read enter
    [    4.746449] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.755210] aic3262_codec_read exit
    [    4.755227] aic3262_codec_read enter
    [    4.759135] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.767896] aic3262_codec_read exit
    [    4.767908] aic3262_codec_read enter
    [    4.771814] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.780659] aic3262_codec_read exit
    [    4.780666] aic3262_codec_read enter
    [    4.784567] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.793406] aic3262_codec_read exit
    [    4.793412] aic3262_codec_read enter
    [    4.797320] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.806166] aic3262_codec_read exit
    [    4.806172] aic3262_codec_read enter
    [    4.810076] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.818920] aic3262_codec_read exit
    [    4.818931] aic3262_codec_read enter
    [    4.822837] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.831683] aic3262_codec_read exit
    [    4.831690] aic3262_codec_read enter
    [    4.835593] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.844449] aic3262_codec_read exit
    [    4.844456] aic3262_codec_read enter
    [    4.848355] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.857199] aic3262_codec_read exit
    [    4.857206] aic3262_codec_read enter
    [    4.861113] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.869958] aic3262_codec_read exit
    [    4.869980] asoc-simple-card sound0: soc_probe_component: snd_soc_dapm_add_routes failed: -22
    [    4.882050] aic3262_codec_remove enter
    [    4.882055] aic3262_set_bias_level enter
    [    4.885828] tlv320aic3262-codec 2-0018: set_bias_off
    [    4.894759] aic3262_set_bias_level exit
    [    4.894767] Unable to handle kernel NULL pointer dereference at virtual address 00000000000000a0
    [    4.907442] Oops [#1]
    [    4.909728] Modules linked in:
    [    4.912802] CPU: 0 PID: 25 Comm: kworker/0:1 Not tainted 5.10.41-nb2+ #1197
    [    4.919797] Workqueue: events deferred_probe_work_func
    [    4.924954] epc: ffffffe000218d44 ra : ffffffe0006611e2 sp : ffffffe0029af9e0
    [    4.932105]  gp : ffffffe0024bea28 tp : ffffffe0029a0840 t0 : ffffffe00241c558
    [    4.939352]  t1 : ffffffe0029af9a8 t2 : 00000000000016ad s0 : ffffffe0029afa10
    [    4.946599]  s1 : ffffffe0079eb218 a0 : 0000000000000000 a1 : ffffffe0024812f0
    [    4.953846]  a2 : 0000000000000003 a3 : ffffffe002481310 a4 : 2fe9ebd7692a3d00
    [    4.961092]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 2fe9ebd7692a3d00
    [    4.968339]  s2 : 0000000000000000 s3 : ffffffe0076da718 s4 : ffffffe0024bf0a8
    [    4.975584]  s5 : ffffffe007a72018 s6 : ffffffe0079eb2d0 s7 : 0000000000000001
    [    4.982830]  s8 : 0000000000000000 s9 : ffffffe0024a3dd0 s10: ffffffffffffffff
    [    4.990076]  s11: ffffffe007a72018 t3 : 2fe9ebd7692a3d00 t4 : ffffffe002200328
    [    4.997322]  t5 : ffffffe00240f5d8 t6 : ffffffe0029af748
    [    5.002648] status: 0000000200000120 badaddr: 00000000000000a0 cause: 000000000000000d
    [    5.010606] ---[ end trace c5d04462bda0a8f7 ]---
    您下载的代码是用于4.19 的,因此有些代码不兼容。
    在5,10年中,纸杯状小部件似乎可以用作来源。
    您是否可以尝试修改snd_so_dapm_supply_S ("DACCLK",2,AIC3262_NDAC_DIV_POW_REG,7,0,
    空,0),至
    Snd_SOC_DAPM_PGA_S ("DACCLK",2,AIC3262_NDAC_DIV_POW_REG,7,0,
    空,0),?
    感谢您的输入,现在更改并跳过固件加载,在路由方面几乎没有错误
    此错误适用于“路由中的DAC miniDSP”
    Starting kernel ...
    [    0.000000] Linux version 5.10.41-nb2+ (pragneshp@osubuntu003) (riscv64-unknown-linux-gnu-gcc (crosstool-NG
    1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #1198 Fri Apr 22 10:29:33 IST 2022
    [    0.000000] OF: fdt: Ignoring memory range 0x800600000 - 0x800800000
    [    0.000000] efi: UEFI not found.
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000800800000-0x00000008705fffff]
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000800800000-0x00000008475fcfff]
    [    0.000000]   node   0: [mem 0x00000008475fd000-0x00000008494fffff]
    [    0.000000]   node   0: [mem 0x0000000849500000-0x00000008495fffff]
    [    0.000000]   node   0: [mem 0x0000000849600000-0x00000008585fffff]
    [    0.000000]   node   0: [mem 0x0000000858600000-0x00000008705fffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000800800000-0x00000008705fffff]
    [    0.000000] SBI specification v0.2 detected
    [    0.000000] SBI implementation ID=0x1 Version=0x9
    [    0.000000] SBI v0.2 TIME extension detected
    [    0.000000] SBI v0.2 IPI extension detected
    [    0.000000] SBI v0.2 RFENCE extension detected
    [    0.000000] software IO TLB: mapped [mem 0x0000002800800000-0x0000002804800000] (64MB)
    [    0.000000] CPU with hartid=1 is not available
    [    0.000000] CPU with hartid=2 is not available
    [    0.000000] CPU with hartid=3 is not available
    [    0.000000] riscv: ISA extensions acdfim
    [    0.000000] riscv: ELF capabilities acdfim
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 451975
    [    0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 root=/dev/ram0 rw rdinit=/sbin/init
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Sorting __ex_table...
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    90K bss, 346656K reserved, 0K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] riscv-intc: 64 local interrupts mapped
    [    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@1/interrupt-controller
    [    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@2/interrupt-controller
    [    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@3/interrupt-controller
    [    0.000000] plic: interrupt-controller@c000000: mapped 137 interrupts with 1 handlers for 2 contexts.
    [    0.000000] random: get_random_bytes called from start_kernel+0x31a/0x49e with crng_init=0
    [    0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
    [    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3
    526361616960 ns
    [    0.000725] Console: colour dummy device 80x25
    [    0.001285] printk: console [tty1] enabled
    [    0.001353] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=40
    00)
    [    0.001404] pid_max: default: 32768 minimum: 301
    [    0.001668] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.001808] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.004455] EFI services will not be available.
    [    0.005147] devtmpfs: initialized
    [    0.016323] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.016391] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
    [    0.016557] pinctrl core: initialized pinctrl subsystem
    [    0.017281] NET: Registered protocol family 16
    [    0.038778] fbcon: Taking over console
    [    0.039219] SCSI subsystem initialized
    [    0.039359] pps_core: LinuxPPS API ver. 1 registered
    [    0.039392] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.039469] PTP clock support registered
    [    0.039706] Advanced Linux Sound Architecture Driver Initialized.
    [    0.040887] clocksource: Switched to clocksource riscv_clocksource
    [    0.052468] NET: Registered protocol family 2
    [    0.053495] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.055244] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.055380] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.055880] TCP bind hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.056383] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.056998] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.057170] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.057565] NET: Registered protocol family 1
    [    2.095152] workingset: timestamp_bits=62 max_order=19 bucket_order=0
    [    2.102136] ntfs: driver 2.1.32 [Flags: R/W].
    [    2.102751] Key type asymmetric registered
    [    2.102794] Asymmetric key parser 'x509' registered
    [    2.102884] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    2.102928] io scheduler mq-deadline registered
    [    2.102954] io scheduler kyber registered
    [    2.107459] dw_axi_dmac_platform 261000000.dma-controller: DesignWare AXI DMA Controller, 6 channels
    [    2.108309] dw_axi_dmac_platform 261004000.dma-controller: DesignWare AXI DMA Controller, 8 channels
    [    2.108709] L2CACHE: No. of Banks in the cache: 4
    [    2.108744] L2CACHE: No. of ways per bank: 16
    [    2.108759] L2CACHE: Sets per bank: 256
    [    2.108773] L2CACHE: Bytes per cache block: 64
    [    2.108788] L2CACHE: Index of the largest way enabled: 2
    [    2.137396] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
    [    2.139041] printk: console [ttyS0] disabled
    [    2.139129] 4f0009000.serial: ttyS0 at MMIO 0x4f0009000 (irq = 15, base_baud = 1625000) is a 16550A
    [    2.694333] printk: console [ttyS0] enabled
    [    2.700290] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* No display-controller for displa
    y-subsystem.
    [    2.711260] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* nb2_drm_platform_of_probe failed
    [    2.731980] loop: module loaded
    [    2.757362] SCSI Media Changer driver v0.25
    [    2.761998] i2c /dev entries driver
    [    2.767993] tlv320aic3262-codec 2-0018: aic3xxx_device_init beginning
    [    2.785222] tlv320aic3262-codec 2-0018: TLV320AIC3262 revision G
    [    2.791392] tlv320aic3262-codec 2-0018: aic3xxx_device_init added mfd devices
    [    2.800322] NET: Registered protocol family 10
    [    2.805767] Segment Routing with IPv6
    [    2.810064] NET: Registered protocol family 17
    [    2.814608] Key type dns_resolver registered
    [    2.820537] aic3262_codec_probe enter
    [    2.820553] driver_init: Allocated Major Number: 245
    [    2.820553]
    [    2.830775] driver_init: Registered cfw driver
    [    2.835439] aic3262_codec_read enter
    [    2.836164] tlv320aic3262-codec 2-0018: p 1 , r 30 7a 1
    [    2.845028] aic3262_codec_read exit
    [    2.845031] aic3262_codec_write enter
    [    2.848536] tlv320aic3262-codec 2-0018: p 1, w 30 7a 5
    [    2.857377] aic3262_codec_write exit
    [    2.897636] aic3262_codec_read enter
    [    2.901633] tlv320aic3262-codec 2-0018: p 1 , r 30 23 10
    [    2.910564] aic3262_codec_read exit
    [    2.910567] aic3262_codec_write enter
    [    2.914079] tlv320aic3262-codec 2-0018: p 1, w 30 23 30
    [    2.923003] aic3262_codec_write exit
    [    2.923299] aic3262_codec_probe exit
    [    2.927015] aic3262_codec_read enter
    [    2.931323] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    2.940089] aic3262_codec_read exit
    [    2.940115] aic3262_codec_read enter
    [    2.944027] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    2.952790] aic3262_codec_read exit
    [    2.952797] aic3262_codec_read enter
    [    2.956701] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    2.965463] aic3262_codec_read exit
    [    2.965468] aic3262_codec_read enter
    [    2.969374] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    2.978133] aic3262_codec_read exit
    [    2.978148] aic3262_codec_read enter
    [    2.982057] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    2.990906] aic3262_codec_read exit
    [    2.990919] aic3262_codec_read enter
    [    2.994828] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.003678] aic3262_codec_read exit
    [    3.003683] aic3262_codec_read enter
    [    3.007589] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.016435] aic3262_codec_read exit
    [    3.016440] aic3262_codec_read enter
    [    3.020344] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.029191] aic3262_codec_read exit
    [    3.029205] aic3262_codec_read enter
    [    3.033106] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.041947] aic3262_codec_read exit
    [    3.041959] aic3262_codec_read enter
    [    3.045870] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.054717] aic3262_codec_read exit
    [    3.054723] aic3262_codec_read enter
    [    3.058629] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.067476] aic3262_codec_read exit
    [    3.067480] aic3262_codec_read enter
    [    3.071382] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.080229] aic3262_codec_read exit
    [    3.080285] aic3262_codec_read enter
    [    3.084485] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.093337] aic3262_codec_read exit
    [    3.093351] aic3262_codec_read enter
    [    3.097253] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.106102] aic3262_codec_read exit
    [    3.106116] aic3262_codec_read enter
    [    3.110030] tlv320aic3262-codec 2-0018: p 1 , r 30 1c 7f
    [    3.118964] aic3262_codec_read exit
    [    3.118973] aic3262_codec_read enter
    [    3.122879] tlv320aic3262-codec 2-0018: p 1 , r 30 1d 7f
    [    3.131811] aic3262_codec_read exit
    [    3.131818] aic3262_codec_read enter
    [    3.135724] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.144573] aic3262_codec_read exit
    [    3.144580] aic3262_codec_read enter
    [    3.148487] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.157333] aic3262_codec_read exit
    [    3.157347] aic3262_codec_read enter
    [    3.161248] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.170087] aic3262_codec_read exit
    [    3.170117] aic3262_codec_read enter
    [    3.174028] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.182874] aic3262_codec_read exit
    [    3.182887] aic3262_codec_read enter
    [    3.186794] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.195640] aic3262_codec_read exit
    [    3.195647] aic3262_codec_read enter
    [    3.199553] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.208398] aic3262_codec_read exit
    [    3.208404] aic3262_codec_read enter
    [    3.212307] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.221156] aic3262_codec_read exit
    [    3.221169] aic3262_codec_read enter
    [    3.225070] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.233910] aic3262_codec_read exit
    [    3.233918] aic3262_codec_read enter
    [    3.237824] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.246672] aic3262_codec_read exit
    [    3.246684] aic3262_codec_read enter
    [    3.250593] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.259441] aic3262_codec_read exit
    [    3.259453] aic3262_codec_read enter
    [    3.263359] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.272206] aic3262_codec_read exit
    [    3.272225] aic3262_codec_read enter
    [    3.276133] tlv320aic3262-codec 2-0018: p 1 , r 30 24 7f
    [    3.285066] aic3262_codec_read exit
    [    3.285077] aic3262_codec_read enter
    [    3.288978] tlv320aic3262-codec 2-0018: p 1 , r 30 26 7f
    [    3.297906] aic3262_codec_read exit
    [    3.297918] aic3262_codec_read enter
    [    3.301826] tlv320aic3262-codec 2-0018: p 1 , r 30 27 7f
    [    3.310758] aic3262_codec_read exit
    [    3.310769] aic3262_codec_read enter
    [    3.314677] tlv320aic3262-codec 2-0018: p 1 , r 30 25 7f
    [    3.323612] aic3262_codec_read exit
    [    3.323631] aic3262_codec_read enter
    [    3.327537] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.336384] aic3262_codec_read exit
    [    3.336394] aic3262_codec_read enter
    [    3.340299] tlv320aic3262-codec 2-0018: p 1 , r 30 2e 7f
    [    3.349235] aic3262_codec_read exit
    [    3.349241] aic3262_codec_read enter
    [    3.353139] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.361980] aic3262_codec_read exit
    [    3.361991] aic3262_codec_read enter
    [    3.365897] tlv320aic3262-codec 2-0018: p 1 , r 30 2f 7f
    [    3.374831] aic3262_codec_read exit
    [    3.374841] aic3262_codec_read enter
    [    3.378747] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.387592] aic3262_codec_read exit
    [    3.387637] aic3262_codec_read enter
    [    3.391838] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.400689] aic3262_codec_read exit
    [    3.400697] aic3262_codec_read enter
    [    3.404602] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.413449] aic3262_codec_read exit
    [    3.413457] aic3262_codec_read enter
    [    3.417363] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.426211] aic3262_codec_read exit
    [    3.426218] aic3262_codec_read enter
    [    3.430124] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.438962] aic3262_codec_read exit
    [    3.438969] aic3262_codec_read enter
    [    3.442875] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.451723] aic3262_codec_read exit
    [    3.451730] aic3262_codec_read enter
    [    3.455636] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.464483] aic3262_codec_read exit
    [    3.464490] aic3262_codec_read enter
    [    3.468394] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.477239] aic3262_codec_read exit
    [    3.477244] aic3262_codec_read enter
    [    3.481142] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.489982] aic3262_codec_read exit
    [    3.489990] aic3262_codec_read enter
    [    3.493898] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.502748] aic3262_codec_read exit
    [    3.502754] aic3262_codec_read enter
    [    3.506659] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.515505] aic3262_codec_read exit
    [    3.515512] aic3262_codec_read enter
    [    3.519417] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.528262] aic3262_codec_read exit
    [    3.528270] aic3262_codec_read enter
    [    3.532173] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.541017] aic3262_codec_read exit
    [    3.541025] aic3262_codec_read enter
    [    3.544922] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.553761] aic3262_codec_read exit
    [    3.553766] aic3262_codec_read enter
    [    3.557671] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.566517] aic3262_codec_read exit
    [    3.566525] aic3262_codec_read enter
    [    3.570431] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.579278] aic3262_codec_read exit
    [    3.579285] aic3262_codec_read enter
    [    3.583189] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.592036] aic3262_codec_read exit
    [    3.592044] aic3262_codec_read enter
    [    3.595948] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.604798] aic3262_codec_read exit
    [    3.604805] aic3262_codec_read enter
    [    3.608709] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.617561] aic3262_codec_read exit
    [    3.617588] aic3262_codec_read enter
    [    3.621503] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.630352] aic3262_codec_read exit
    [    3.630358] aic3262_codec_read enter
    [    3.634246] random: fast init done
    [    3.641270] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.646524] aic3262_codec_read exit
    [    3.646530] aic3262_codec_read enter
    [    3.650437] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.659287] aic3262_codec_read exit
    [    3.659299] aic3262_codec_read enter
    [    3.663202] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.672051] aic3262_codec_read exit
    [    3.672060] aic3262_codec_read enter
    [    3.675964] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.684810] aic3262_codec_read exit
    [    3.684817] aic3262_codec_read enter
    [    3.688721] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.697571] aic3262_codec_read exit
    [    3.697576] aic3262_codec_read enter
    [    3.701479] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.710327] aic3262_codec_read exit
    [    3.710336] aic3262_codec_read enter
    [    3.714242] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.723087] aic3262_codec_read exit
    [    3.723092] aic3262_codec_read enter
    [    3.726996] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.735841] aic3262_codec_read exit
    [    3.735847] aic3262_codec_read enter
    [    3.739752] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.748599] aic3262_codec_read exit
    [    3.748607] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Le
    ft DAC
    [    3.762499] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Left DAC
    [    3.772272] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Left DAC
    [    3.782046] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Ri
    ght DAC
    [    3.792516] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Right DAC
    [    3.802378] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Right DAC
    [    3.812240] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Le
    ft DAC
    [    3.822622] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Left DAC
    [    3.832396] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Left DAC
    [    3.842170] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Ri
    ght DAC
    [    3.852639] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Right DAC
    [    3.862499] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Right DAC
    [    3.872361] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Le
    ft DAC
    [    3.882742] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Left DAC
    [    3.892515] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Left DAC
    [    3.902289] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Ri
    ght DAC
    [    3.912759] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Right DAC
    [    3.922620] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Right DAC
    [    3.932490] aic3262_codec_read enter
    [    3.933180] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    3.942024] aic3262_codec_read exit
    [    3.942036] aic3262_codec_read enter
    [    3.945944] tlv320aic3262-codec 2-0018: p 1 , r 30 12 3f
    [    3.954880] aic3262_codec_read exit
    [    3.954897] aic3262_codec_read enter
    [    3.958804] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    3.967652] aic3262_codec_read exit
    [    3.967663] aic3262_codec_read enter
    [    3.971570] tlv320aic3262-codec 2-0018: p 1 , r 30 13 3f
    [    3.980505] aic3262_codec_read exit
    [    3.980521] aic3262_codec_read enter
    [    3.984719] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    3.993482] aic3262_codec_read exit
    [    3.993489] aic3262_codec_read enter
    [    3.997393] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.006161] aic3262_codec_read exit
    [    4.006180] aic3262_codec_read enter
    [    4.010406] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.019273] aic3262_codec_read exit
    [    4.019284] aic3262_codec_read enter
    [    4.023193] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.032044] aic3262_codec_read exit
    [    4.032050] aic3262_codec_read enter
    [    4.035955] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.044800] aic3262_codec_read exit
    [    4.044806] aic3262_codec_read enter
    [    4.048712] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.057558] aic3262_codec_read exit
    [    4.057564] aic3262_codec_read enter
    [    4.061469] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.070315] aic3262_codec_read exit
    [    4.070322] aic3262_codec_read enter
    [    4.074226] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.083075] aic3262_codec_read exit
    [    4.083081] aic3262_codec_read enter
    [    4.086984] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.095829] aic3262_codec_read exit
    [    4.095836] aic3262_codec_read enter
    [    4.099741] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.108587] aic3262_codec_read exit
    [    4.108602] aic3262_codec_read enter
    [    4.112510] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.121356] aic3262_codec_read exit
    [    4.121367] aic3262_codec_read enter
    [    4.125270] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.134117] aic3262_codec_read exit
    [    4.134132] aic3262_codec_read enter
    [    4.138043] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.146894] aic3262_codec_read exit
    [    4.146913] aic3262_codec_read enter
    [    4.150823] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.159672] aic3262_codec_read exit
    [    4.159678] aic3262_codec_read enter
    [    4.163583] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.172431] aic3262_codec_read exit
    [    4.172438] aic3262_codec_read enter
    [    4.176344] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    4.185191] aic3262_codec_read exit
    [    4.185208] aic3262_codec_read enter
    [    4.189109] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.197954] aic3262_codec_read exit
    [    4.197967] aic3262_codec_read enter
    [    4.201875] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.210723] aic3262_codec_read exit
    [    4.210736] aic3262_codec_read enter
    [    4.214643] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.223493] aic3262_codec_read exit
    [    4.223499] aic3262_codec_read enter
    [    4.227406] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    4.236255] aic3262_codec_read exit
    [    4.236264] aic3262_codec_read enter
    [    4.240171] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.249018] aic3262_codec_read exit
    [    4.249024] aic3262_codec_read enter
    [    4.252923] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.261761] aic3262_codec_read exit
    [    4.261785] aic3262_codec_read enter
    [    4.265984] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.274832] aic3262_codec_read exit
    [    4.274846] aic3262_codec_read enter
    [    4.278754] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.287603] aic3262_codec_read exit
    [    4.287614] aic3262_codec_read enter
    [    4.291521] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.300367] aic3262_codec_read exit
    [    4.300381] aic3262_codec_read enter
    [    4.304288] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.313136] aic3262_codec_read exit
    [    4.313164] aic3262_codec_read enter
    [    4.317359] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.326120] aic3262_codec_read exit
    [    4.326130] aic3262_codec_read enter
    [    4.330038] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.338800] aic3262_codec_read exit
    [    4.338805] aic3262_codec_read enter
    [    4.342708] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.351467] aic3262_codec_read exit
    [    4.351473] aic3262_codec_read enter
    [    4.355379] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.364138] aic3262_codec_read exit
    [    4.364150] aic3262_codec_read enter
    [    4.368058] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.376905] aic3262_codec_read exit
    [    4.376924] aic3262_codec_read enter
    [    4.380828] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.389677] aic3262_codec_read exit
    [    4.389683] aic3262_codec_read enter
    [    4.393590] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.402433] aic3262_codec_read exit
    [    4.402439] aic3262_codec_read enter
    [    4.406343] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.415186] aic3262_codec_read exit
    [    4.415197] aic3262_codec_read enter
    [    4.419103] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.427950] aic3262_codec_read exit
    [    4.427961] aic3262_codec_read enter
    [    4.431864] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.440712] aic3262_codec_read exit
    [    4.440721] aic3262_codec_read enter
    [    4.444627] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.453471] aic3262_codec_read exit
    [    4.453477] aic3262_codec_read enter
    [    4.457383] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.466228] aic3262_codec_read exit
    [    4.466234] aic3262_codec_read enter
    [    4.470140] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.478986] aic3262_codec_read exit
    [    4.478998] aic3262_codec_read enter
    [    4.482906] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.491752] aic3262_codec_read exit
    [    4.491771] aic3262_codec_read enter
    [    4.495679] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.504438] aic3262_codec_read exit
    [    4.504445] aic3262_codec_read enter
    [    4.508350] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.517111] aic3262_codec_read exit
    [    4.517118] aic3262_codec_read enter
    [    4.521015] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.529766] aic3262_codec_read exit
    [    4.529772] aic3262_codec_read enter
    [    4.533677] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.542437] aic3262_codec_read exit
    [    4.542449] aic3262_codec_read enter
    [    4.546354] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.555201] aic3262_codec_read exit
    [    4.555206] aic3262_codec_read enter
    [    4.559111] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.567956] aic3262_codec_read exit
    [    4.567962] aic3262_codec_read enter
    [    4.571866] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.580713] aic3262_codec_read exit
    [    4.580717] aic3262_codec_read enter
    [    4.584626] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.593472] aic3262_codec_read exit
    [    4.593482] aic3262_codec_read enter
    [    4.597389] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.606235] aic3262_codec_read exit
    [    4.606242] aic3262_codec_read enter
    [    4.610145] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.618990] aic3262_codec_read exit
    [    4.618995] aic3262_codec_read enter
    [    4.622900] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.631745] aic3262_codec_read exit
    [    4.631751] aic3262_codec_read enter
    [    4.635653] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.644504] aic3262_codec_read exit
    [    4.644524] asoc-simple-card sound0: soc_probe_component: snd_soc_dapm_add_routes failed: -22
    [    4.656596] aic3262_codec_remove enter
    [    4.656602] aic3262_set_bias_level enter
    [    4.660377] tlv320aic3262-codec 2-0018: set_bias_off
    [    4.669304] aic3262_set_bias_level exit
    [    4.669314] Unable to handle kernel NULL pointer dereference at virtual address 00000000000000a0
    [    4.681990] Oops [#1]
    [    4.684277] Modules linked in:
    [    4.687350] CPU: 0 PID: 25 Comm: kworker/0:1 Not tainted 5.10.41-nb2+ #1198
    [    4.694343] Workqueue: events deferred_probe_work_func
    [    4.699501] epc: ffffffe000218d44 ra : ffffffe0006611e2 sp : ffffffe0029af9e0
    [    4.706652]  gp : ffffffe0024bea28 tp : ffffffe0029a0840 t0 : ffffffe00241c240
    [    4.713898]  t1 : ffffffe0029af9a8 t2 : 00000000000016ad s0 : ffffffe0029afa10
    [    4.721145]  s1 : ffffffe0079eb218 a0 : 0000000000000000 a1 : ffffffe0024812f0
    [    4.728390]  a2 : 0000000000000003 a3 : ffffffe002481310 a4 : 4ade848d5451af00
    [    4.735636]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 4ade848d5451af00
    [    4.742881]  s2 : 0000000000000000 s3 : ffffffe0076da718 s4 : ffffffe0024bf0a8
    [    4.750127]  s5 : ffffffe007a72018 s6 : ffffffe0079eb2d0 s7 : 0000000000000001
    [    4.757373]  s8 : 0000000000000000 s9 : ffffffe0024a3dd0 s10: ffffffffffffffff
    [    4.764620]  s11: ffffffe007a72018 t3 : 4ade848d5451af00 t4 : ffffffe002200328
    [    4.771866]  t5 : ffffffe00240f5d8 t6 : ffffffe0029af748
    [    4.777194] status: 0000000200000120 badaddr: 00000000000000a0 cause: 000000000000000d
    [    4.785150] ---[ end trace 365f4b14e5fd5ae1 ]---
    [   62.656883] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 54s!
    [   62.664852] Showing busy workqueues and worker pools:
    [   62.669919] workqueue events: flags=0x0
    [   62.673769]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256 refcnt=4
    [   62.680579]     in-flight: 25:deferred_probe_work_func BAR(1)
    [   62.686353]     pending: stop_one_cpu_nowait_workfn
    [   62.691256] workqueue events_power_efficient: flags=0x80
    [   62.696581]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256 refcnt=3
    [   62.703390]     pending: neigh_periodic_work, neigh_periodic_work
    [   62.709507] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=54s workers=3 idle: 31 3
    [   93.440880] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 85s!
    [   93.448836] Showing busy workqueues and worker pools:
    [   93.453902] workqueue events: flags=0x0
    [   93.457750]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256 refcnt=4
    [   93.464560]     in-flight: 25:deferred_probe_work_func BAR(1)
    [   93.470330]     pending: stop_one_cpu_nowait_workfn
    [   93.475227] workqueue events_power_efficient: flags=0x80
    [   93.480553]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256 refcnt=3
    [   93.487361]     pending: neigh_periodic_work, neigh_periodic_work
    [   93.493477] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=85s workers=3 idle: 31 3
    如果您需要更多信息,请告诉我
    该错误似乎与DSP固件有关。
    请启用FW downloooding,并提供固件下载的完整登录信息。
    Starting kernel ...
    [    0.000000] Linux version 5.10.41-nb2+ (pragneshp@osubuntu003) (riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.24.0) 8.3.0, GNU ld (crosstool-NG 1.22
    [    0.000000] Memory: 1486304K/1832960K available (4508K kernel code, 4305K rwdata, 4096K rodata, 176K init, 290K bss, 346656K reserved, 0K cma-reser)
    [    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns
    [    0.000008] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
    [    0.001156] Console: colour dummy device 80x25
    [    0.001774] printk: console [tty1] enabled
    [    0.001873] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000)
    [    0.001929] pid_max: default: 32768 minimum: 301
    [    0.002333] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.002540] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.006422] EFI services will not be available.
    [    0.007445] devtmpfs: initialized
    [    0.024870] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.024961] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
    [    0.025208] pinctrl core: initialized pinctrl subsystem
    [    0.026298] NET: Registered protocol family 16
    [    0.055934] fbcon: Taking over console
    [    0.056559] SCSI subsystem initialized
    [    0.056759] pps_core: LinuxPPS API ver. 1 registered
    [    0.056804] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.056904] PTP clock support registered
    [    0.057250] Advanced Linux Sound Architecture Driver Initialized.
    [    0.058987] clocksource: Switched to clocksource riscv_clocksource
    [    0.076100] NET: Registered protocol family 2
    [    0.077565] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.079829] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.080028] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.080744] TCP bind hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.081462] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.082289] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.082541] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.083210] NET: Registered protocol family 1
    [    2.786205] workingset: timestamp_bits=62 max_order=19 bucket_order=0
    [    2.798468] ntfs: driver 2.1.32 [Flags: R/W].
    [    2.799494] Key type asymmetric registered
    [    2.799554] Asymmetric key parser 'x509' registered
    [    2.799687] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    2.799741] io scheduler mq-deadline registered
    [    2.799773] io scheduler kyber registered
    [    2.806505] dw_axi_dmac_platform 261000000.dma-controller: DesignWare AXI DMA Controller, 6 channels
    [    2.807907] dw_axi_dmac_platform 261004000.dma-controller: DesignWare AXI DMA Controller, 8 channels
    [    2.808470] L2CACHE: No. of Banks in the cache: 4
    [    2.808521] L2CACHE: No. of ways per bank: 16
    [    2.808537] L2CACHE: Sets per bank: 256
    [    2.808551] L2CACHE: Bytes per cache block: 64
    [    2.808565] L2CACHE: Index of the largest way enabled: 2
    [    2.846551] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
    [    2.848923] printk: console [ttyS0] disabled
    [    2.849044] 4f0009000.serial: ttyS0 at MMIO 0x4f0009000 (irq = 15, base_baud = 1625000) is a 16550A
    [    3.404400] printk: console [ttyS0] enabled
    [    3.410920] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* No display-controller for display-subsystem.
    [    3.421936] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* nb2_drm_platform_of_probe failed
    [    3.447838] loop: module loaded
    [    3.483582] SCSI Media Changer driver v0.25
    [    3.488355] i2c /dev entries driver
    [    3.495438] tlv320aic3262-codec 2-0018: aic3xxx_device_init beginning
    [    3.512711] tlv320aic3262-codec 2-0018: Device is not a TLV320AIC3262
    [    3.519202] tlv320aic3262-codec 2-0018: aic3xxx_i2c_probe:98: Failed to init device: -22
    [    3.529762] NET: Registered protocol family 10
    [    3.535658] Segment Routing with IPv6
    [    3.540213] NET: Registered protocol family 17
    [    3.544809] Key type dns_resolver registered
    [    3.551513] aic3262_codec_probe enter
    [    3.551538] driver_init: Allocated Major Number: 245
    [    3.551538]
    [    3.561778] driver_init: Registered cfw driver
    [    3.566531] aic3262_codec_read enter
    [    3.567287] tlv320aic3262-codec 2-0018: p 1 , r 30 7a 1
    [    3.576158] aic3262_codec_read exit
    [    3.576161] aic3262_codec_write enter
    [    3.579680] tlv320aic3262-codec 2-0018: p 1, w 30 7a 5
    [    3.588522] aic3262_codec_write exit
    [    3.628791] aic3262_codec_read enter
    [    3.632800] tlv320aic3262-codec 2-0018: p 1 , r 30 23 10
    [    3.641745] aic3262_codec_read exit
    [    3.641748] aic3262_codec_write enter
    [    3.645263] tlv320aic3262-codec 2-0018: p 1, w 30 23 30
    [    3.654204] aic3262_codec_write exit
    [    3.654515] aic3262_codec_probe exit
    [    3.658283] aic3262_codec_read enter
    [    3.662183] tlv320aic3262-codec 2-0018: Firmware binary load
    [    3.671533] Entering crc 7489
    [    3.671845] CRC pass
    [    3.674830] Loaded firmware inside unpickle
    [    3.681264] Unable to handle kernel paging request at virtual address ffffffe049b02a31
    [    3.689226] Oops [#1]
    [    3.691513] Modules linked in:
    [    3.694592] CPU: 0 PID: 3 Comm: kworker/0:0 Not tainted 5.10.41-nb2+ #1201
    [    3.701514] Workqueue: events request_firmware_work_func
    [    3.706846] epc: ffffffe00066165a ra : ffffffe00066161e sp : ffffffe0028abd60
    [    3.713997]  gp : ffffffe0024bea28 tp : ffffffe002891080 t0 : ffffffe002413ff8
    [    3.721241]  t1 : ffffffe00044419a t2 : 00000000000016ad s0 : ffffffe0028abd90
    [    3.728487]  s1 : ffffffe001ef5800 a0 : 000000000000001f a1 : ffffffe0024812f0
    [    3.735735]  a2 : 0000000000000058 a3 : ffffffe049b029f1 a4 : ffffffe001ef5801
    [    3.742980]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 000000000000002e
    [    3.750227]  s2 : ffffffe007a36ac0 s3 : 0000000000000001 s4 : ffffffffc0a7c5f8
    [    3.757473]  s5 : ffffffe00240efe8 s6 : 0000000000000000 s7 : ffffffe00240f050
    [    3.764718]  s8 : 0000000000000001 s9 : 0000000000000402 s10: ffffffffffffffff
    [    3.771965]  s11: ffffffe002832240 t3 : 5f45b39737ecc300 t4 : ffffffe002200328
    [    3.779210]  t5 : ffffffe00240f5d8 t6 : ffffffe0028abac8
    [    3.784536] status: 0000000200000120 badaddr: ffffffe049b02a31 cause: 000000000000000d
    [    3.792496] ---[ end trace f98a1bb8d5b283b0 ]---
    [    3.797651] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.802852] aic3262_codec_read exit
    [    3.802919] aic3262_codec_read enter
    [    3.806861] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.815632] aic3262_codec_read exit
    [    3.815640] aic3262_codec_read enter
    [    3.819556] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.828319] aic3262_codec_read exit
    [    3.828328] aic3262_codec_read enter
    [    3.832244] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.841001] aic3262_codec_read exit
    [    3.841024] aic3262_codec_read enter
    [    3.844942] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.853798] aic3262_codec_read exit
    [    3.853819] aic3262_codec_read enter
    [    3.857734] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.866588] aic3262_codec_read exit
    [    3.866598] aic3262_codec_read enter
    [    3.870508] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.879358] aic3262_codec_read exit
    [    3.879367] aic3262_codec_read enter
    [    3.883266] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.892108] aic3262_codec_read exit
    [    3.892129] aic3262_codec_read enter
    [    3.896041] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.904896] aic3262_codec_read exit
    [    3.904917] aic3262_codec_read enter
    [    3.908835] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.917692] aic3262_codec_read exit
    [    3.917701] aic3262_codec_read enter
    [    3.921615] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.930469] aic3262_codec_read exit
    [    3.930478] aic3262_codec_read enter
    [    3.934392] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.943243] aic3262_codec_read exit
    [    3.943311] aic3262_codec_read enter
    [    3.947526] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.956389] aic3262_codec_read exit
    [    3.956405] aic3262_codec_read enter
    [    3.960319] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.969169] aic3262_codec_read exit
    [    3.969190] aic3262_codec_read enter
    [    3.973109] tlv320aic3262-codec 2-0018: p 1 , r 30 1c 7f
    [    3.982051] aic3262_codec_read exit
    [    3.982061] aic3262_codec_read enter
    [    3.985966] tlv320aic3262-codec 2-0018: p 1 , r 30 1d 7f
    [    3.994907] aic3262_codec_read exit
    [    3.994917] aic3262_codec_read enter
    [    3.998831] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    4.007692] aic3262_codec_read exit
    [    4.007699] aic3262_codec_read enter
    [    4.011616] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    4.020468] aic3262_codec_read exit
    [    4.020486] aic3262_codec_read enter
    [    4.024400] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    4.033260] aic3262_codec_read exit
    [    4.033307] aic3262_codec_read enter
    [    4.037226] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    4.046079] aic3262_codec_read exit
    [    4.046097] aic3262_codec_read enter
    [    4.050015] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    4.058868] aic3262_codec_read exit
    [    4.058878] aic3262_codec_read enter
    [    4.062792] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    4.071643] aic3262_codec_read exit
    [    4.071650] aic3262_codec_read enter
    [    4.075562] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    4.084415] aic3262_codec_read exit
    [    4.084434] aic3262_codec_read enter
    [    4.088346] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    4.097205] aic3262_codec_read exit
    [    4.097213] aic3262_codec_read enter
    [    4.101129] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    4.109988] aic3262_codec_read exit
    [    4.110002] aic3262_codec_read enter
    [    4.113918] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    4.122773] aic3262_codec_read exit
    [    4.122791] aic3262_codec_read enter
    [    4.126706] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    4.135560] aic3262_codec_read exit
    [    4.135587] aic3262_codec_read enter
    [    4.139505] tlv320aic3262-codec 2-0018: p 1 , r 30 24 7f
    [    4.148445] aic3262_codec_read exit
    [    4.148461] aic3262_codec_read enter
    [    4.152378] tlv320aic3262-codec 2-0018: p 1 , r 30 26 7f
    [    4.161323] aic3262_codec_read exit
    [    4.161336] aic3262_codec_read enter
    [    4.165263] tlv320aic3262-codec 2-0018: p 1 , r 30 27 7f
    [    4.174214] aic3262_codec_read exit
    [    4.174233] aic3262_codec_read enter
    [    4.178148] tlv320aic3262-codec 2-0018: p 1 , r 30 25 7f
    [    4.187087] aic3262_codec_read exit
    [    4.187115] aic3262_codec_read enter
    [    4.191021] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    4.199868] aic3262_codec_read exit
    [    4.199884] aic3262_codec_read enter
    [    4.203803] tlv320aic3262-codec 2-0018: p 1 , r 30 2e 7f
    [    4.212743] aic3262_codec_read exit
    [    4.212753] aic3262_codec_read enter
    [    4.216666] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    4.225521] aic3262_codec_read exit
    [    4.225537] aic3262_codec_read enter
    [    4.229453] tlv320aic3262-codec 2-0018: p 1 , r 30 2f 7f
    [    4.238393] aic3262_codec_read exit
    [    4.238409] aic3262_codec_read enter
    [    4.242327] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    4.251183] aic3262_codec_read exit
    [    4.251250] aic3262_codec_read enter
    [    4.255461] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    4.264319] aic3262_codec_read exit
    [    4.264329] aic3262_codec_read enter
    [    4.268241] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    4.277091] aic3262_codec_read exit
    [    4.277102] aic3262_codec_read enter
    [    4.281013] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    4.289865] aic3262_codec_read exit
    [    4.289875] aic3262_codec_read enter
    [    4.293786] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    4.302639] aic3262_codec_read exit
    [    4.302648] aic3262_codec_read enter
    [    4.306560] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    4.315415] aic3262_codec_read exit
    [    4.315424] aic3262_codec_read enter
    [    4.319325] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    4.328169] aic3262_codec_read exit
    [    4.328177] aic3262_codec_read enter
    [    4.332091] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    4.340943] aic3262_codec_read exit
    [    4.340951] aic3262_codec_read enter
    [    4.344864] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    4.353716] aic3262_codec_read exit
    [    4.353725] aic3262_codec_read enter
    [    4.357637] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    4.366487] aic3262_codec_read exit
    [    4.366498] aic3262_codec_read enter
    [    4.370409] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    4.379261] aic3262_codec_read exit
    [    4.379270] aic3262_codec_read enter
    [    4.383175] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    4.392016] aic3262_codec_read exit
    [    4.392025] aic3262_codec_read enter
    [    4.395940] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    4.404790] aic3262_codec_read exit
    [    4.404801] aic3262_codec_read enter
    [    4.408713] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    4.417564] aic3262_codec_read exit
    [    4.417571] aic3262_codec_read enter
    [    4.421484] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    4.430336] aic3262_codec_read exit
    [    4.430345] aic3262_codec_read enter
    [    4.434255] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    4.443109] aic3262_codec_read exit
    [    4.443120] aic3262_codec_read enter
    [    4.447025] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    4.455869] aic3262_codec_read exit
    [    4.455878] aic3262_codec_read enter
    [    4.459786] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    4.468641] aic3262_codec_read exit
    [    4.468651] aic3262_codec_read enter
    [    4.472565] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    4.481415] aic3262_codec_read exit
    [    4.481454] aic3262_codec_read enter
    [    4.485373] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.494224] aic3262_codec_read exit
    [    4.494231] aic3262_codec_read enter
    [    4.498137] random: fast init done
    [    4.505161] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.510416] aic3262_codec_read exit
    [    4.510424] aic3262_codec_read enter
    [    4.514339] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.523187] aic3262_codec_read exit
    [    4.523201] aic3262_codec_read enter
    [    4.527107] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.535956] aic3262_codec_read exit
    [    4.535968] aic3262_codec_read enter
    [    4.539886] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.548738] aic3262_codec_read exit
    [    4.548746] aic3262_codec_read enter
    [    4.552655] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.561507] aic3262_codec_read exit
    [    4.561514] aic3262_codec_read enter
    [    4.565425] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.574273] aic3262_codec_read exit
    [    4.574285] aic3262_codec_read enter
    [    4.578198] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.587050] aic3262_codec_read exit
    [    4.587057] aic3262_codec_read enter
    [    4.590959] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.599808] aic3262_codec_read exit
    [    4.599814] aic3262_codec_read enter
    [    4.603722] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    4.612572] aic3262_codec_read exit
    [    4.612582] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Left DAC
    [    4.626476] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Left DAC
    [    4.636253] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Left DAC
    [    4.646031] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Right DAC
    [    4.656502] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Right DAC
    [    4.666365] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Right DAC
    [    4.676237] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Left DAC
    [    4.686628] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Left DAC
    [    4.696404] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Left DAC
    [    4.706183] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Right DAC
    [    4.716654] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Right DAC
    [    4.726517] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Right DAC
    [    4.736382] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Left DAC
    [    4.746768] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Left DAC
    [    4.756544] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Left DAC
    [    4.766324] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Right DAC
    [    4.776795] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Right DAC
    [    4.786657] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Right DAC
    [    4.796533] aic3262_codec_read enter
    [    4.797238] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    4.806095] aic3262_codec_read exit
    [    4.806111] aic3262_codec_read enter
    [    4.810028] tlv320aic3262-codec 2-0018: p 1 , r 30 12 3f
    [    4.818968] aic3262_codec_read exit
    [    4.818991] aic3262_codec_read enter
    [    4.822896] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    4.831748] aic3262_codec_read exit
    [    4.831762] aic3262_codec_read enter
    [    4.835678] tlv320aic3262-codec 2-0018: p 1 , r 30 13 3f
    [    4.844617] aic3262_codec_read exit
    [    4.844638] aic3262_codec_read enter
    [    4.848846] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.857613] aic3262_codec_read exit
    [    4.857624] aic3262_codec_read enter
    [    4.861536] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.870299] aic3262_codec_read exit
    [    4.870325] aic3262_codec_read enter
    [    4.874536] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.883392] aic3262_codec_read exit
    [    4.883401] aic3262_codec_read enter
    [    4.887309] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.896154] aic3262_codec_read exit
    [    4.896164] aic3262_codec_read enter
    [    4.900081] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.908929] aic3262_codec_read exit
    [    4.908940] aic3262_codec_read enter
    [    4.912852] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.921701] aic3262_codec_read exit
    [    4.921709] aic3262_codec_read enter
    [    4.925618] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.934473] aic3262_codec_read exit
    [    4.934483] aic3262_codec_read enter
    [    4.938396] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.947246] aic3262_codec_read exit
    [    4.947253] aic3262_codec_read enter
    [    4.951154] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.959998] aic3262_codec_read exit
    [    4.960007] aic3262_codec_read enter
    [    4.963916] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.972768] aic3262_codec_read exit
    [    4.972786] aic3262_codec_read enter
    [    4.976698] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.985550] aic3262_codec_read exit
    [    4.985565] aic3262_codec_read enter
    [    4.989478] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.998329] aic3262_codec_read exit
    [    4.998347] aic3262_codec_read enter
    [    5.002265] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    5.011122] aic3262_codec_read exit
    [    5.011148] aic3262_codec_read enter
    [    5.015055] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    5.023901] aic3262_codec_read exit
    [    5.023910] aic3262_codec_read enter
    [    5.027825] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    5.036677] aic3262_codec_read exit
    [    5.036688] aic3262_codec_read enter
    [    5.040601] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    5.049449] aic3262_codec_read exit
    [    5.049466] aic3262_codec_read enter
    [    5.053382] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    5.062233] aic3262_codec_read exit
    很抱歉,请考虑此引导日志,在以前的引导日志中,由于移除子卡,AIC3262编解码器无法在I2C上检测到
       Using Device Tree in place at 000000080f000000, end 000000080f0102e5
    Starting kernel ...
    1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #1201 Fri Apr 22 12:20:56 IST 2022
    526361616960 ns
    [    0.000007] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
    [    0.000741] Console: colour dummy device 80x25
    [    0.001356] printk: console [tty1] enabled
    [    0.001431] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=40
    00)
    [    0.001478] pid_max: default: 32768 minimum: 301
    [    0.001755] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.001897] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.004575] EFI services will not be available.
    [    0.005288] devtmpfs: initialized
    [    0.018108] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.018182] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
    [    0.018353] pinctrl core: initialized pinctrl subsystem
    [    0.019101] NET: Registered protocol family 16
    [    0.041168] fbcon: Taking over console
    [    0.041617] SCSI subsystem initialized
    [    0.041765] pps_core: LinuxPPS API ver. 1 registered
    [    0.041798] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.041877] PTP clock support registered
    [    0.042126] Advanced Linux Sound Architecture Driver Initialized.
    [    0.043292] clocksource: Switched to clocksource riscv_clocksource
    [    0.055183] NET: Registered protocol family 2
    [    0.056227] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.057972] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.058111] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.058621] TCP bind hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.059132] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.059751] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.059930] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.060334] NET: Registered protocol family 1
    [    2.040150] workingset: timestamp_bits=62 max_order=19 bucket_order=0
    [    2.049005] ntfs: driver 2.1.32 [Flags: R/W].
    [    2.049701] Key type asymmetric registered
    [    2.049744] Asymmetric key parser 'x509' registered
    [    2.049838] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    2.049886] io scheduler mq-deadline registered
    [    2.049916] io scheduler kyber registered
    [    2.054681] dw_axi_dmac_platform 261000000.dma-controller: DesignWare AXI DMA Controller, 6 channels
    [    2.055678] dw_axi_dmac_platform 261004000.dma-controller: DesignWare AXI DMA Controller, 8 channels
    [    2.056079] L2CACHE: No. of Banks in the cache: 4
    [    2.056116] L2CACHE: No. of ways per bank: 16
    [    2.056131] L2CACHE: Sets per bank: 256
    [    2.056145] L2CACHE: Bytes per cache block: 64
    [    2.056160] L2CACHE: Index of the largest way enabled: 2
    [    2.085717] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
    [    2.087453] printk: console [ttyS0] disabled
    [    2.087545] 4f0009000.serial: ttyS0 at MMIO 0x4f0009000 (irq = 15, base_baud = 1625000) is a 16550A
    [    2.643236] printk: console [ttyS0] enabled
    [    2.649326] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* No display-controller for displa
    y-subsystem.
    [    2.660312] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* nb2_drm_platform_of_probe failed
    [    2.681440] loop: module loaded
    [    2.707471] SCSI Media Changer driver v0.25
    [    2.712104] i2c /dev entries driver
    [    2.718152] tlv320aic3262-codec 2-0018: aic3xxx_device_init beginning
    [    2.735392] tlv320aic3262-codec 2-0018: TLV320AIC3262 revision G
    [    2.741597] tlv320aic3262-codec 2-0018: aic3xxx_device_init added mfd devices
    [    2.750597] NET: Registered protocol family 10
    [    2.756072] Segment Routing with IPv6
    [    2.760390] NET: Registered protocol family 17
    [    2.764944] Key type dns_resolver registered
    [    2.770905] aic3262_codec_probe enter
    [    2.770922] driver_init: Allocated Major Number: 245
    [    2.770922]
    [    2.781157] driver_init: Registered cfw driver
    [    2.785828] aic3262_codec_read enter
    [    2.786558] tlv320aic3262-codec 2-0018: p 1 , r 30 7a 1
    [    2.795432] aic3262_codec_read exit
    [    2.795436] aic3262_codec_write enter
    [    2.798949] tlv320aic3262-codec 2-0018: p 1, w 30 7a 5
    [    2.807806] aic3262_codec_write exit
    [    2.848085] aic3262_codec_read enter
    [    2.852122] tlv320aic3262-codec 2-0018: p 1 , r 30 23 10
    [    2.861077] aic3262_codec_read exit
    [    2.861080] aic3262_codec_write enter
    [    2.864601] tlv320aic3262-codec 2-0018: p 1, w 30 23 30
    [    2.873539] aic3262_codec_write exit
    [    2.873859] aic3262_codec_probe exit
    [    2.877598] aic3262_codec_read enter
    [    2.881441] tlv320aic3262-codec 2-0018: Firmware binary load
    [    2.890776] Entering crc 7489
    [    2.891077] CRC pass
    [    2.894078] Loaded firmware inside unpickle
    [    2.900507] Unable to handle kernel paging request at virtual address ffffffe049b02a31
    [    2.908472] Oops [#1]
    [    2.910762] Modules linked in:
    [    2.913840] CPU: 0 PID: 3 Comm: kworker/0:0 Not tainted 5.10.41-nb2+ #1201
    [    2.920755] Workqueue: events request_firmware_work_func
    [    2.926090] epc: ffffffe00066165a ra : ffffffe00066161e sp : ffffffe0028abd60
    [    2.933245]  gp : ffffffe0024bea28 tp : ffffffe002891080 t0 : ffffffe002413ff8
    [    2.940495]  t1 : ffffffe00044419a t2 : 00000000000016ad s0 : ffffffe0028abd90
    [    2.947749]  s1 : ffffffe001ef5800 a0 : 000000000000001f a1 : ffffffe0024812f0
    [    2.954998]  a2 : 0000000000000058 a3 : ffffffe049b029f1 a4 : ffffffe001ef5801
    [    2.962246]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 000000000000002e
    [    2.969499]  s2 : ffffffe007a37ac0 s3 : 0000000000000001 s4 : ffffffffc0a7c5f8
    [    2.976747]  s5 : ffffffe00240efe8 s6 : 0000000000000000 s7 : ffffffe00240f050
    [    2.983997]  s8 : 0000000000000001 s9 : 0000000000000402 s10: ffffffffffffffff
    [    2.991249]  s11: ffffffe002832240 t3 : d38f5c81fcb20300 t4 : ffffffe002200328
    [    2.998499]  t5 : ffffffe00240f5d8 t6 : ffffffe0028abac8
    [    3.003832] status: 0000000200000120 badaddr: ffffffe049b02a31 cause: 000000000000000d
    [    3.011819] ---[ end trace 888f4d19a48e1957 ]---
    [    3.016979] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.022175] aic3262_codec_read exit
    [    3.022232] aic3262_codec_read enter
    [    3.026168] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.034949] aic3262_codec_read exit
    [    3.034959] aic3262_codec_read enter
    [    3.038880] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.047655] aic3262_codec_read exit
    [    3.047664] aic3262_codec_read enter
    [    3.051579] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.060346] aic3262_codec_read exit
    [    3.060380] aic3262_codec_read enter
    [    3.064311] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.073177] aic3262_codec_read exit
    [    3.073199] aic3262_codec_read enter
    [    3.077128] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.085990] aic3262_codec_read exit
    [    3.085999] aic3262_codec_read enter
    [    3.089919] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.098782] aic3262_codec_read exit
    [    3.098794] aic3262_codec_read enter
    [    3.102712] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.111584] aic3262_codec_read exit
    [    3.111615] aic3262_codec_read enter
    [    3.115533] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.124391] aic3262_codec_read exit
    [    3.124419] aic3262_codec_read enter
    [    3.128354] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.137220] aic3262_codec_read exit
    [    3.137229] aic3262_codec_read enter
    [    3.141150] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.150014] aic3262_codec_read exit
    [    3.150023] aic3262_codec_read enter
    [    3.153951] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.162815] aic3262_codec_read exit
    [    3.162895] aic3262_codec_read enter
    [    3.167118] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.175982] aic3262_codec_read exit
    [    3.176000] aic3262_codec_read enter
    [    3.179926] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.188787] aic3262_codec_read exit
    [    3.188810] aic3262_codec_read enter
    [    3.192734] tlv320aic3262-codec 2-0018: p 1 , r 30 1c 7f
    [    3.201685] aic3262_codec_read exit
    [    3.201698] aic3262_codec_read enter
    [    3.205618] tlv320aic3262-codec 2-0018: p 1 , r 30 1d 7f
    [    3.214569] aic3262_codec_read exit
    [    3.214580] aic3262_codec_read enter
    [    3.218502] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.227360] aic3262_codec_read exit
    [    3.227372] aic3262_codec_read enter
    [    3.231285] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.240149] aic3262_codec_read exit
    [    3.240175] aic3262_codec_read enter
    [    3.244097] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.252959] aic3262_codec_read exit
    [    3.253006] aic3262_codec_read enter
    [    3.256938] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.265806] aic3262_codec_read exit
    [    3.265830] aic3262_codec_read enter
    [    3.269752] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.278616] aic3262_codec_read exit
    [    3.278629] aic3262_codec_read enter
    [    3.282555] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.291421] aic3262_codec_read exit
    [    3.291430] aic3262_codec_read enter
    [    3.295343] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.304202] aic3262_codec_read exit
    [    3.304230] aic3262_codec_read enter
    [    3.308153] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.317017] aic3262_codec_read exit
    [    3.317029] aic3262_codec_read enter
    [    3.320958] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.329819] aic3262_codec_read exit
    [    3.329844] aic3262_codec_read enter
    [    3.333770] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.342636] aic3262_codec_read exit
    [    3.342658] aic3262_codec_read enter
    [    3.346580] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.355443] aic3262_codec_read exit
    [    3.355476] aic3262_codec_read enter
    [    3.359395] tlv320aic3262-codec 2-0018: p 1 , r 30 24 7f
    [    3.368335] aic3262_codec_read exit
    [    3.368359] aic3262_codec_read enter
    [    3.372288] tlv320aic3262-codec 2-0018: p 1 , r 30 26 7f
    [    3.381241] aic3262_codec_read exit
    [    3.381262] aic3262_codec_read enter
    [    3.385188] tlv320aic3262-codec 2-0018: p 1 , r 30 27 7f
    [    3.394136] aic3262_codec_read exit
    [    3.394157] aic3262_codec_read enter
    [    3.398083] tlv320aic3262-codec 2-0018: p 1 , r 30 25 7f
    [    3.407033] aic3262_codec_read exit
    [    3.407064] aic3262_codec_read enter
    [    3.410986] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.419850] aic3262_codec_read exit
    [    3.419869] aic3262_codec_read enter
    [    3.423801] tlv320aic3262-codec 2-0018: p 1 , r 30 2e 7f
    [    3.432748] aic3262_codec_read exit
    [    3.432761] aic3262_codec_read enter
    [    3.436688] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.445552] aic3262_codec_read exit
    [    3.445575] aic3262_codec_read enter
    [    3.449496] tlv320aic3262-codec 2-0018: p 1 , r 30 2f 7f
    [    3.458443] aic3262_codec_read exit
    [    3.458463] aic3262_codec_read enter
    [    3.462391] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.471253] aic3262_codec_read exit
    [    3.471321] aic3262_codec_read enter
    [    3.475552] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.484407] aic3262_codec_read exit
    [    3.484417] aic3262_codec_read enter
    [    3.488342] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.497204] aic3262_codec_read exit
    [    3.497219] aic3262_codec_read enter
    [    3.501143] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.510006] aic3262_codec_read exit
    [    3.510021] aic3262_codec_read enter
    [    3.513941] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.522807] aic3262_codec_read exit
    [    3.522822] aic3262_codec_read enter
    [    3.526749] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.535609] aic3262_codec_read exit
    [    3.535624] aic3262_codec_read enter
    [    3.539540] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.548397] aic3262_codec_read exit
    [    3.548409] aic3262_codec_read enter
    [    3.552330] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.561187] aic3262_codec_read exit
    [    3.561197] aic3262_codec_read enter
    [    3.565123] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.573981] aic3262_codec_read exit
    [    3.573997] aic3262_codec_read enter
    [    3.577922] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.586786] aic3262_codec_read exit
    [    3.586799] aic3262_codec_read enter
    [    3.590725] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.599588] aic3262_codec_read exit
    [    3.599601] aic3262_codec_read enter
    [    3.603516] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.612374] aic3262_codec_read exit
    [    3.612389] aic3262_codec_read enter
    [    3.616304] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.625180] aic3262_codec_read exit
    [    3.625194] aic3262_codec_read enter
    [    3.629123] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.637986] aic3262_codec_read exit
    [    3.637999] aic3262_codec_read enter
    [    3.641924] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.650787] aic3262_codec_read exit
    [    3.650804] aic3262_codec_read enter
    [    3.654726] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.663583] aic3262_codec_read exit
    [    3.663597] aic3262_codec_read enter
    [    3.667510] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.676365] aic3262_codec_read exit
    [    3.676381] aic3262_codec_read enter
    [    3.680306] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.689172] aic3262_codec_read exit
    [    3.689185] aic3262_codec_read enter
    [    3.693108] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.701971] aic3262_codec_read exit
    [    3.702015] aic3262_codec_read enter
    [    3.705944] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.714810] aic3262_codec_read exit
    [    3.714821] aic3262_codec_read enter
    [    3.718731] random: fast init done
    [    3.725770] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.731034] aic3262_codec_read exit
    [    3.731043] aic3262_codec_read enter
    [    3.734965] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.743826] aic3262_codec_read exit
    [    3.743851] aic3262_codec_read enter
    [    3.747774] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.756636] aic3262_codec_read exit
    [    3.756654] aic3262_codec_read enter
    [    3.760576] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.769440] aic3262_codec_read exit
    [    3.769452] aic3262_codec_read enter
    [    3.773376] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.782236] aic3262_codec_read exit
    [    3.782246] aic3262_codec_read enter
    [    3.786170] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.795035] aic3262_codec_read exit
    [    3.795054] aic3262_codec_read enter
    [    3.798975] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.807835] aic3262_codec_read exit
    [    3.807846] aic3262_codec_read enter
    [    3.811774] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.820631] aic3262_codec_read exit
    [    3.820642] aic3262_codec_read enter
    [    3.824563] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.833428] aic3262_codec_read exit
    [    3.833445] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Le
    ft DAC
    [    3.847350] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Left DAC
    [    3.857141] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Left DAC
    [    3.866931] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> Ri
    ght DAC
    [    3.877421] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Right DAC
    [    3.887292] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Right DAC
    [    3.897177] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Le
    ft DAC
    [    3.907573] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Left DAC
    [    3.917364] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Left DAC
    [    3.927151] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> Ri
    ght DAC
    [    3.937640] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Right DAC
    [    3.947513] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Right DAC
    [    3.957396] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Le
    ft DAC
    [    3.967790] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Left DAC
    [    3.977584] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Left DAC
    [    3.987371] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> Ri
    ght DAC
    [    3.997860] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Right DAC
    [    4.007746] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Right DAC
    [    4.017659] aic3262_codec_read enter
    [    4.018386] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    4.027255] aic3262_codec_read exit
    [    4.027279] aic3262_codec_read enter
    [    4.031211] tlv320aic3262-codec 2-0018: p 1 , r 30 12 3f
    [    4.040165] aic3262_codec_read exit
    [    4.040193] aic3262_codec_read enter
    [    4.044116] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    4.052978] aic3262_codec_read exit
    [    4.053000] aic3262_codec_read enter
    [    4.056929] tlv320aic3262-codec 2-0018: p 1 , r 30 13 3f
    [    4.065876] aic3262_codec_read exit
    [    4.065906] aic3262_codec_read enter
    [    4.070127] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.078912] aic3262_codec_read exit
    [    4.078925] aic3262_codec_read enter
    [    4.082851] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.091626] aic3262_codec_read exit
    [    4.091657] aic3262_codec_read enter
    [    4.095868] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.104733] aic3262_codec_read exit
    [    4.104746] aic3262_codec_read enter
    [    4.108665] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.117530] aic3262_codec_read exit
    [    4.117539] aic3262_codec_read enter
    [    4.121467] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.130326] aic3262_codec_read exit
    [    4.130337] aic3262_codec_read enter
    [    4.134268] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.143135] aic3262_codec_read exit
    [    4.143146] aic3262_codec_read enter
    [    4.147065] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.155928] aic3262_codec_read exit
    [    4.155939] aic3262_codec_read enter
    [    4.159868] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.168731] aic3262_codec_read exit
    [    4.168742] aic3262_codec_read enter
    [    4.172667] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.181529] aic3262_codec_read exit
    [    4.181541] aic3262_codec_read enter
    [    4.185467] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.194329] aic3262_codec_read exit
    [    4.194353] aic3262_codec_read enter
    [    4.198278] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.207142] aic3262_codec_read exit
    [    4.207157] aic3262_codec_read enter
    [    4.211077] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.219942] aic3262_codec_read exit
    [    4.219967] aic3262_codec_read enter
    [    4.223898] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.232757] aic3262_codec_read exit
    [    4.232782] aic3262_codec_read enter
    [    4.236712] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.245576] aic3262_codec_read exit
    [    4.245588] aic3262_codec_read enter
    [    4.249514] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.258378] aic3262_codec_read exit
    [    4.258390] aic3262_codec_read enter
    [    4.262316] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    4.271179] aic3262_codec_read exit
    [    4.271211] aic3262_codec_read enter
    [    4.275135] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.284003] aic3262_codec_read exit
    [    4.284023] aic3262_codec_read enter
    [    4.287955] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.296816] aic3262_codec_read exit
    [    4.296838] aic3262_codec_read enter
    [    4.300765] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.309627] aic3262_codec_read exit
    [    4.309639] aic3262_codec_read enter
    [    4.313562] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    4.322428] aic3262_codec_read exit
    [    4.322447] aic3262_codec_read enter
    [    4.326377] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.335239] aic3262_codec_read exit
    [    4.335250] aic3262_codec_read enter
    [    4.339175] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.348042] aic3262_codec_read exit
    [    4.348082] aic3262_codec_read enter
    [    4.352301] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.361163] aic3262_codec_read exit
    [    4.361190] aic3262_codec_read enter
    [    4.365118] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.373982] aic3262_codec_read exit
    [    4.374005] aic3262_codec_read enter
    [    4.377933] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.386798] aic3262_codec_read exit
    [    4.386821] aic3262_codec_read enter
    [    4.390747] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.399609] aic3262_codec_read exit
    [    4.399649] aic3262_codec_read enter
    [    4.403866] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.412645] aic3262_codec_read exit
    [    4.412660] aic3262_codec_read enter
    [    4.416578] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.425359] aic3262_codec_read exit
    [    4.425368] aic3262_codec_read enter
    [    4.429295] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.438066] aic3262_codec_read exit
    [    4.438077] aic3262_codec_read enter
    [    4.442001] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.450780] aic3262_codec_read exit
    [    4.450804] aic3262_codec_read enter
    [    4.454725] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.463584] aic3262_codec_read exit
    [    4.463616] aic3262_codec_read enter
    [    4.467534] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.476388] aic3262_codec_read exit
    [    4.476400] aic3262_codec_read enter
    [    4.480326] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.489189] aic3262_codec_read exit
    [    4.489200] aic3262_codec_read enter
    [    4.493126] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.501990] aic3262_codec_read exit
    [    4.502014] aic3262_codec_read enter
    [    4.505938] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.514803] aic3262_codec_read exit
    [    4.514822] aic3262_codec_read enter
    [    4.518744] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.527608] aic3262_codec_read exit
    [    4.527624] aic3262_codec_read enter
    [    4.531542] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.540396] aic3262_codec_read exit
    [    4.540408] aic3262_codec_read enter
    [    4.544336] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.553189] aic3262_codec_read exit
    [    4.553199] aic3262_codec_read enter
    [    4.557120] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.565980] aic3262_codec_read exit
    [    4.566005] aic3262_codec_read enter
    [    4.569934] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.578794] aic3262_codec_read exit
    [    4.578826] aic3262_codec_read enter
    [    4.582752] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.591529] aic3262_codec_read exit
    [    4.591541] aic3262_codec_read enter
    [    4.595458] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.604223] aic3262_codec_read exit
    [    4.604233] aic3262_codec_read enter
    [    4.608157] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.616935] aic3262_codec_read exit
    [    4.616946] aic3262_codec_read enter
    [    4.620863] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.629638] aic3262_codec_read exit
    [    4.629662] aic3262_codec_read enter
    [    4.633594] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.642452] aic3262_codec_read exit
    [    4.642462] aic3262_codec_read enter
    [    4.646397] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.655267] aic3262_codec_read exit
    [    4.655276] aic3262_codec_read enter
    [    4.659196] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.668058] aic3262_codec_read exit
    [    4.668067] aic3262_codec_read enter
    [    4.671986] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.680852] aic3262_codec_read exit
    [    4.680878] aic3262_codec_read enter
    [    4.684803] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.693673] aic3262_codec_read exit
    [    4.693684] aic3262_codec_read enter
    [    4.697612] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.706471] aic3262_codec_read exit
    [    4.706481] aic3262_codec_read enter
    [    4.710402] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.719268] aic3262_codec_read exit
    [    4.719278] aic3262_codec_read enter
    [    4.723197] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.732060] aic3262_codec_read exit
    [    4.732098] asoc-simple-card sound0: soc_probe_component: snd_soc_dapm_add_routes failed: -22
    [    4.744183] aic3262_codec_remove enter
    [    4.744189] aic3262_set_bias_level enter
    [    4.747975] tlv320aic3262-codec 2-0018: set_bias_off
    [    4.756919] aic3262_set_bias_level exit
    [    4.756929] Unable to handle kernel NULL pointer dereference at virtual address 00000000000000a0
    [    4.769619] Oops [#2]
    [    4.771908] Modules linked in:
    [    4.774987] CPU: 0 PID: 25 Comm: kworker/0:1 Tainted: G      D           5.10.41-nb2+ #1201
    [    4.783384] Workqueue: events deferred_probe_work_func
    [    4.788544] epc: ffffffe000218d44 ra : ffffffe00066130e sp : ffffffe0029af9e0
    [    4.795700]  gp : ffffffe0024bea28 tp : ffffffe0029a0840 t0 : ffffffe00241c9d0
    [    4.802950]  t1 : ffffffe0029af9a8 t2 : 0000000000000001 s0 : ffffffe0029afa10
    [    4.810199]  s1 : ffffffe0079eb218 a0 : 0000000000000000 a1 : ffffffe0024812f0
    [    4.817450]  a2 : 0000000000000003 a3 : ffffffe002481310 a4 : d38f5c81fcb20300
    [    4.824700]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : d38f5c81fcb20300
    [    4.831949]  s2 : 0000000000000000 s3 : ffffffe0076da718 s4 : ffffffe0024bf0a8
    [    4.839201]  s5 : ffffffe007a72018 s6 : ffffffe0079eb2d0 s7 : 0000000000000001
    [    4.846451]  s8 : 0000000000000000 s9 : ffffffe0024a3dd0 s10: ffffffffffffffff
    [    4.853702]  s11: ffffffe007a72018 t3 : d38f5c81fcb20300 t4 : ffffffe002200328
    [    4.860952]  t5 : ffffffe00023886a t6 : ffffffe0029af748
    [    4.866281] status: 0000000200000120 badaddr: 00000000000000a0 cause: 000000000000000d
    [    4.874266] ---[ end trace 888f4d19a48e1958 ]---
    让我先与固件团队联系
    是否有任何更新?
    您是否会如此友好并共享bin文件?
    再细一点,您会帮我检查它导致崩溃的代码行吗? 谢谢。
    在中,
     666 static inline void *aic3xxx_cfw_ndx2ptr(void *p, u8 *base)
     667 {
     668         printk("base = %p, p = %p, base = %x, p = %x\n", base, p, base, p);
     669         printk("p = %x\n", (int)p);
     670
     671         return &base[(int)p];
     672 }
     763 static struct cfw_project *aic3xxx_cfw_unpickle(void *p, int n)
     764 {
     765         struct cfw_project *pjt = p;
     766         int i, j;
     767
     768         if (pjt->magic != CFW_FW_MAGIC || pjt->size != n ||
     769             pjt->if_id != CFW_FW_IF_ID || !crc_chk(p, n)) {
     770                 error("Version mismatch: unable to load firmware\n");
     771                 return NULL;
     772         }
     773         DBG("Loaded firmware inside unpickle\n");
     774
     775         pjt->desc = aic3xxx_cfw_desc(pjt->desc, p);
     776         pjt->transition = aic3xxx_cfw_ndx2ptr(pjt->transition, p);
     777         for (i = 0; i < CFW_TRN_N; i++) {
     778                 if (!pjt->transition[i])
     779                         continue;
     780                 printk("i = %x\n", i);
     781                 pjt->transition[i] = aic3xxx_cfw_ndx2ptr(pjt->transition[i], p);
     782                 pjt->transition[i]->desc = aic3xxx_cfw_desc(
     783                                                 pjt->transition[i]->desc, p);
     784                 pjt->transition[i]->block = aic3xxx_cfw_ndx2ptr(
     785                                                 pjt->transition[i]->block, p);
     786         }
     787         pjt->pll = aic3xxx_cfw_ndx2ptr(pjt->pll, p);
     788         ......
     789         ......
     790    }
    第782行出现问题。
    日志,
    [ CFW] driver_init:已注册2.71.6827万 驱动程序
    [ 2.72.2202万 ] tlv320aic3262-codec 2-0018:P 1,r 30 7a 1.
    [ 2.72.7479万 ] tlv320aic3262-codec 2-0018:P 1,w 30 7a 5.
    [ 2.77.3295万 ] tlv320aic3262-codec 2-0018:P 1,r 30 23 10.
    [ 2.77.8638万 ] tlv320aic3262-codec 2-0018:P 1,w 30 23 30
    [ 2.78.4182万 ] aic3262_codec_probe exit
    [ 2.78.4481万 ] tlv320aic3262-codec 2-0018:固件二进制加载
    [ 2.79.3806万 ]输入CRC 7489
    [ CRC] 2.79.4106万 通过
    [ 2.79.7104万 ]已在UnPickle内加载固件
    [ 2.80.3508万 ] base =(_____ptrval___),p =(_____ptrval___),base = 1ef5800,p =0
    [ 2.81.0935万 ] p = 0
    [ 2.81.2881万 ] base =(_____ptrval___),p =(_____ptrval___),base = 1ef5800,p =1
    [ 2.82.0307万 ] p = 1
    [ 2.82.2248万 ] i = 0
    [ 2.82.4196万 ] base =(_____ptrval___),p =(_____ptrval___),base = 1ef5800,p = 47c0d1f1
    [ 2.83.223万 ] p = 47c0d1F1
    [ 2.83.4786万 ]无法在虚拟地址ffffffffffe049b02a31处处理内核分页请求
    [ 2.84.2739万 ]糟糕[#1]
    [ 2.84.5025万 ]链接模块:
    [ PID] 2.84.81万 :0 PID: 3 Comm:kworker/0:0 Not W污染5.10 的PID.41-NB2+#1204
    [ 2.85.5011万 ]工作队列:events request_firmware_work_func
    [ EPC] 2.86.0342万 :ffffffffffe0.6616万f0 ra:ffffffe0.6616万e4 sp:ffffffffe0028abd30
    [ 2.86.7492万 gp] gp:ffffffffe0024bea28 tp:ffffffffe0.0289108亿 t0:ffffffe0.2413万f48
    [ 2.87.4738万 ] t1:ffffffffffe4.4419万a t2:00000000000016ad s0:ffffffffe0028abd90
    [ 2.88.1985万 A1] s1:ffffffffffe001ef5800 a0:ffffffffe049b029F1 A1:ffffffe2.4812万f0
    [ 2.88.923万 A2] a2:0万00000003 a30.0003万 a3:ffffffe0.0248131亿 a4:a9aba59a0ac0.15万
    [ 2.89.6476万 A5] a5:ffffffffffe001ef5801 a6:c0万ffefff a7:0万0000001b</s>0.0001万
    [ 2.90.3722万 ] s2:ffffffffe007a38ac0 s3:0万00000000 s40万 s4:00000000000000000000
    [ 2.91.0967万 ] s5:ffffffffe049b029f1 s6:0万0000000b s70万 s7:ffffffffe001fe558.
    [ 2.91.8214万 ] s8:00000000000000000001 s9:0万00000402 s100.0402万 s10:ffffffffffffffffffffffffffffffffffffffffffff
    [ 2.92.5459万 T4] s11:ffffffffffffe0.0283224亿 t3:0万0000000f t40万 t4:ffffffe0.02200328亿
    [ 2.93.2705万 ] T5:ffffffffffe0.024万f5d8 t6:ffffffe0028aba78
    [ 2.93.8031万 ]状态:0.0002万00000120 badaddr0.012万 badaddr:ffffffffffe049b02a31原因:0万0000000d</s>0万
    [ 2.94.5986万 ]--[结束跟踪229e30b7d6f28c01]---
    还可以共享bin文件,谢谢。我将创建一个类似的环境来模拟您的案例。
    e2e.ti.com/.../tlv320aic3262_5F00_fw_5F00_v1.txt
    我已将 tlv320aic3262_fw_v1.bin作为 tlv320aic3262_fw_v1.txt上传,因为无法在此处上传bin文件。
    只需将文件扩展名更改为bin,然后使用它。
    感谢您的bin文件。 我从日志中找到问题
    在我的模拟 平台中,日志如下所示
    输入CRC 10.9295万
    CRC PASS (CRC通过)
    已在不选取的文件中加载固件
    根据驱动程序代码,"输入CRC-"后面的数字是固件文件大小。 因此,请检查您平台中的固件大小为何为7489字节。
    我制作了自己的CFD文件"firmware/built/aic3262/asi1/tlv320aic3262_asi1_slaver.cf"</s>3262
    不使用DSP路由,请在下面进行检查
    <cfw_spec>
        <name>Firmware</name>
        <device>aic3262</device>
        <pll name="asi1_pll8" seq="asi1_pll_8kHz_slave.cfg" />
        <pfw name="PRB" >
            <desc>PRB</desc>
            <prb a="1" d="1"/>
        </pfw>
        <mode name="asi1_8khz_PRB">
            <pfw>PRB</pfw>
            <pll>asi1_pll8</pll>
        </mode>
    </cfw_spec>
    用于生成固件二进制文件的命令
    ./utils/mkcfw firmware/built/aic3262/asi1/tlv320aic3262_asi1_slaver.cfd tlv320aic3262_fw_v1.bin3262 tlv320aic3262_fw_v1.bin</s>3262
    然后
    pragneshp:mkcfw_r6.10fix6_130516$ ls -al tlv320aic3262_fw_v1.bin
    -rw-r--r-- 1 pragneshp engr 7489 Apr 29 09:07 tlv320aic3262_fw_v1.bin
    如果我将使用TI提供的现有CFD文件作为示例
    ./utils/mkcfw firmware/built/aic3262/tlv320aic3262_FW_v1.cfd tlv320aic3262_fw_v1.bin3262 tlv320aic3262_fw_v1.bin</s>3262
    然后
    -rw-r--r-- 1 pragneshp engr 109295 Apr 29 09:09 tlv320aic3262_fw_v1.bin
    我认为固件二进制文件中没有任何问题,如果您需要我提供更多信息,请告诉我
    您能否与我共享您创建的bin文件?
    e2e.ti.com/.../5811.tlv320aic3262_5F00_fw_5F00_v1.txt</s>3262
    用于生成bin文件的工具的"告诉我"版本。
    pragneshp:mkcfw_r6.10fix6_130516$ ./utils/mkcfw -V
    mkcfw 6.10fix6 (if_id:0x3FA6D547) Built May 16 2013 14:38:59
    此链接 mkcfw i ave用于下载mkcfw固件
    请与我共享XML文件以创建bin文件
    firmware/built/aic3262/asi1/tlv320aic3262_asi1_slaver.cfd</s>3262
    <cfw_spec>
        <pfw name="PRB" >
            <desc>PRB</desc>
            <prb a="1" d="1"/>
        </pfw>
            <pfw>PRB</pfw>
        </mode>
    </cfw_spec>
    firmware/builD/aic3262/asi1/asi1_pll_8kHz_slave.cfg
    e2e.ti.com/.../asi1_5F00_pll_5F00_8kHz_5F00_slave.cfg
    命令
    请在函数 aic3xxx_CFW_unpickle中的"DBG"("在unpickle\n");"之后添加一个日志,以十六进制格式打印pjt->dfamily和pjt->device。
    并与我共享日志。 谢谢。
    pjt->dfamily =4,pjt->device =2
    Starting kernel ...
    [    0.000000] Linux version 5.10.41-nb2+ (pragneshp@osubuntu003) (riscv64-unknown-linux-gnu-gcc (crosstool-NG2
    [    0.000000] OF: fdt: Ignoring memory range 0x800600000 - 0x800800000
    [    0.000000] efi: UEFI not found.
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000800800000-0x00000008705fffff]
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000800800000-0x00000008475fcfff]
    [    0.000000]   node   0: [mem 0x00000008475fd000-0x00000008494fffff]
    [    0.000000]   node   0: [mem 0x0000000849500000-0x00000008495fffff]
    [    0.000000]   node   0: [mem 0x0000000849600000-0x00000008585fffff]
    [    0.000000]   node   0: [mem 0x0000000858600000-0x00000008705fffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000800800000-0x00000008705fffff]
    [    0.000000] SBI specification v0.2 detected
    [    0.000000] SBI implementation ID=0x1 Version=0x9
    [    0.000000] SBI v0.2 TIME extension detected
    [    0.000000] SBI v0.2 IPI extension detected
    [    0.000000] SBI v0.2 RFENCE extension detected
    [    0.000000] software IO TLB: mapped [mem 0x0000002800800000-0x0000002804800000] (64MB)
    [    0.000000] CPU with hartid=1 is not available
    [    0.000000] CPU with hartid=2 is not available
    [    0.000000] CPU with hartid=3 is not available
    [    0.000000] riscv: ISA extensions acdfim
    [    0.000000] riscv: ELF capabilities acdfim
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 451975
    [    0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 root=/dev/ram0 rw rdinit=/sbin/init
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Sorting __ex_table...
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1486304K/1832960K available (4508K kernel code, 4305K rwdata, 4096K rodata, 176K init, )
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] riscv-intc: 64 local interrupts mapped
    [    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@1/interrupt-controller
    [    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@2/interrupt-controller
    [    0.000000] riscv-intc: unable to find hart id for /cpus/cpu@3/interrupt-controller
    [    0.000000] plic: interrupt-controller@c000000: mapped 137 interrupts with 1 handlers for 2 contexts.
    [    0.000000] random: get_random_bytes called from start_kernel+0x31a/0x49e with crng_init=0
    [    0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
    [    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: s
    [    0.000724] Console: colour dummy device 80x25
    [    0.001299] printk: console [tty1] enabled
    [    0.001371] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4)
    [    0.001416] pid_max: default: 32768 minimum: 301
    [    0.001688] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.001826] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.004427] EFI services will not be available.
    [    0.005113] devtmpfs: initialized
    [    0.016585] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.016654] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
    [    0.016820] pinctrl core: initialized pinctrl subsystem
    [    0.017545] NET: Registered protocol family 16
    [    0.038595] fbcon: Taking over console
    [    0.039032] SCSI subsystem initialized
    [    0.039172] pps_core: LinuxPPS API ver. 1 registered
    [    0.039205] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.039281] PTP clock support registered
    [    0.039515] Advanced Linux Sound Architecture Driver Initialized.
    [    0.040662] clocksource: Switched to clocksource riscv_clocksource
    [    0.052127] NET: Registered protocol family 2
    [    0.053141] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.054877] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.055012] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.055511] TCP bind hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.056011] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.056562] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.056787] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.057178] NET: Registered protocol family 1
    [    1.982333] workingset: timestamp_bits=62 max_order=19 bucket_order=0
    [    1.989957] ntfs: driver 2.1.32 [Flags: R/W].
    [    1.990589] Key type asymmetric registered
    [    1.990632] Asymmetric key parser 'x509' registered
    [    1.990722] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    1.990765] io scheduler mq-deadline registered
    [    1.990791] io scheduler kyber registered
    [    1.995334] dw_axi_dmac_platform 261000000.dma-controller: DesignWare AXI DMA Controller, 6 channels
    [    1.996195] dw_axi_dmac_platform 261004000.dma-controller: DesignWare AXI DMA Controller, 8 channels
    [    1.996584] L2CACHE: No. of Banks in the cache: 4
    [    1.996620] L2CACHE: No. of ways per bank: 16
    [    1.996635] L2CACHE: Sets per bank: 256
    [    1.996686] L2CACHE: Bytes per cache block: 64
    [    1.996704] L2CACHE: Index of the largest way enabled: 2
    [    2.025315] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
    [    2.026984] printk: console [ttyS0] disabled
    [    2.027072] 4f0009000.serial: ttyS0 at MMIO 0x4f0009000 (irq = 15, base_baud = 1625000) is a 16550A
    [    2.582211] printk: console [ttyS0] enabled
    [    2.588178] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* No display-controller for displ.
    [    2.599156] nb2-drm display-subsystem: [drm:nb2_drm_platform_probe] *ERROR* nb2_drm_platform_of_probe failed
    [    2.619869] loop: module loaded
    [    2.645197] SCSI Media Changer driver v0.25
    [    2.649828] i2c /dev entries driver
    [    2.655809] tlv320aic3262-codec 2-0018: aic3xxx_device_init beginning
    [    2.673036] tlv320aic3262-codec 2-0018: TLV320AIC3262 revision G
    [    2.679208] tlv320aic3262-codec 2-0018: aic3xxx_device_init added mfd devices
    [    2.688146] NET: Registered protocol family 10
    [    2.693578] Segment Routing with IPv6
    [    2.697876] NET: Registered protocol family 17
    [    2.702427] Key type dns_resolver registered
    [    2.708356] aic3262_codec_probe enter
    [    2.708372] driver_init: Allocated Major Number: 245
    [    2.708372]
    [    2.718597] driver_init: Registered cfw driver
    [    2.723974] tlv320aic3262-codec 2-0018: p 1 , r 30 7a 1
    [    2.729249] tlv320aic3262-codec 2-0018: p 1, w 30 7a 5
    [    2.775062] tlv320aic3262-codec 2-0018: p 1 , r 30 23 10
    [    2.780404] tlv320aic3262-codec 2-0018: p 1, w 30 23 30
    [    2.785951] aic3262_codec_probe exit
    [    2.786256] tlv320aic3262-codec 2-0018: Firmware binary load
    [    2.795581] Entering crc 7489
    [    2.795883] CRC pass
    [    2.798879] Loaded firmware inside unpickle
    [    2.805288] pjt->dfamily = 4, pjt->device = 2
    [    2.809669] base = (____ptrval____), p = (____ptrval____), base = 1ef5800, p = 0
    [    2.817096] p = 0
    [    2.819036] base = (____ptrval____), p = (____ptrval____), base = 1ef5800, p = 1
    [    2.826462] p = 1
    [    2.828402] i = 0
    [    2.830351] base = (____ptrval____), p = (____ptrval____), base = 1ef5800, p = 47c0d1f1
    [    2.838386] p = 47c0d1f1
    [    2.840949] Unable to handle kernel paging request at virtual address ffffffe049b02a31
    [    2.848903] Oops [#1]
    [    2.851189] Modules linked in:
    [    2.854264] CPU: 0 PID: 3 Comm: kworker/0:0 Not tainted 5.10.41-nb2+ #1242
    [    2.861174] Workqueue: events request_firmware_work_func
    [    2.866504] epc: ffffffe0006616de ra : ffffffe0006616d2 sp : ffffffe0028abd30
    [    2.873654]  gp : ffffffe0024bea28 tp : ffffffe002891080 t0 : ffffffe002413fa0
    [    2.880900]  t1 : ffffffe00044419a t2 : 00000000000016ad s0 : ffffffe0028abd90
    [    2.888145]  s1 : ffffffe001ef5800 a0 : ffffffe049b029f1 a1 : ffffffe0024812f0
    [    2.895391]  a2 : 0000000000000003 a3 : ffffffe002481310 a4 : eb58ea18fe63df00
    [    2.902637]  a5 : ffffffe001ef5801 a6 : c0000000ffffefff a7 : 000000000000001b
    [    2.909883]  s2 : ffffffe007a37ac0 s3 : 0000000000000000 s4 : 0000000000000000
    [    2.917130]  s5 : ffffffe049b029f1 s6 : 000000000000000b s7 : ffffffe001fea580
    [    2.924375]  s8 : 0000000000000001 s9 : 0000000000000402 s10: ffffffffffffffff
    [    2.931621]  s11: ffffffe002832240 t3 : 000000000000000f t4 : ffffffe002200328
    [    2.938866]  t5 : ffffffe00240f5d8 t6 : ffffffe0028aba78
    [    2.944191] status: 0000000200000120 badaddr: ffffffe049b02a31 cause: 000000000000000d
    [    2.952147] ---[ end trace e7dbbe1da01ab477 ]---
    [    2.957261] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    2.962887] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    2.968457] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    2.974021] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    2.979599] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    2.985259] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    2.990910] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    2.996558] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.002217] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.007875] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.013523] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.019171] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.025167] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.030826] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.036483] tlv320aic3262-codec 2-0018: p 1 , r 30 1c 7f
    [    3.042220] tlv320aic3262-codec 2-0018: p 1 , r 30 1d 7f
    [    3.047957] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.053607] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.059263] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.064939] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.070598] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.076250] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.081899] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.087554] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.093206] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.098863] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.104517] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.110182] tlv320aic3262-codec 2-0018: p 1 , r 30 24 7f
    [    3.115925] tlv320aic3262-codec 2-0018: p 1 , r 30 26 7f
    [    3.121667] tlv320aic3262-codec 2-0018: p 1 , r 30 27 7f
    [    3.127411] tlv320aic3262-codec 2-0018: p 1 , r 30 25 7f
    [    3.133161] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.138825] tlv320aic3262-codec 2-0018: p 1 , r 30 2e 7f
    [    3.144570] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.150229] tlv320aic3262-codec 2-0018: p 1 , r 30 2f 7f
    [    3.155969] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.161954] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.167606] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.173257] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.178907] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.184558] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.190208] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.195859] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.201506] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.207155] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.212805] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.218453] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.224103] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.229752] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.235403] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.241055] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.246706] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.252356] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.258004] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.263674] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.269307] random: fast init done
    [    3.272746] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.278392] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.284046] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.289697] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.295347] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.300994] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.306645] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.312292] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.317937] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.323195] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> LC
    [    3.333582] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Left DAC
    [    3.343358] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Left DAC
    [    3.353134] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [NULL] -> RC
    [    3.363604] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --> Right DAC
    [    3.373464] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -> Right DAC
    [    3.383327] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> LC
    [    3.393709] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Left DAC
    [    3.403483] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Left DAC
    [    3.413258] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [NULL] -> RC
    [    3.423725] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --> Right DAC
    [    3.433586] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -> Right DAC
    [    3.443448] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> LC
    [    3.453829] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Left DAC
    [    3.463603] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Left DAC
    [    3.473378] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [NULL] -> RC
    [    3.483847] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --> Right DAC
    [    3.493709] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -> Right DAC
    [    3.504265] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    3.509922] tlv320aic3262-codec 2-0018: p 1 , r 30 12 3f
    [    3.515670] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    3.521325] tlv320aic3262-codec 2-0018: p 1 , r 30 13 3f
    [    3.527358] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    3.532924] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    3.538790] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    3.544441] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    3.550087] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    3.555736] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    3.561385] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    3.567034] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    3.572686] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    3.578335] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    3.583989] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    3.589639] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    3.595293] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    3.600957] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    3.606606] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    3.612255] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    3.617910] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    3.623566] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    3.629222] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    3.634874] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    3.640527] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    3.646175] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    3.652141] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    3.657805] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    3.663463] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    3.669121] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    3.675085] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    3.680653] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    3.686217] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    3.691777] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    3.697343] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    3.703008] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    3.708659] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    3.714308] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    3.719962] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    3.725616] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    3.731267] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    3.736916] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    3.742565] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    3.748218] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    3.753881] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    3.759447] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    3.765010] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    3.770570] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    3.776135] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    3.781785] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    3.787431] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    3.793079] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    3.798731] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    3.804381] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    3.810029] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    3.815677] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    3.820947] asoc-simple-card sound0: soc_probe_component: snd_soc_dapm_add_routes failed: -22
    [    3.829507] aic3262_codec_remove enter
    [    3.829512] aic3262_set_bias_level enter
    [    3.833285] tlv320aic3262-codec 2-0018: set_bias_off
    [    3.842212] aic3262_set_bias_level exit
    [    3.842221] Unable to handle kernel NULL pointer dereference at virtual address 00000000000000a0
    [    3.854892] Oops [#2]
    [    3.857179] Modules linked in:
    [    3.860254] CPU: 0 PID: 25 Comm: kworker/0:1 Tainted: G      D           5.10.41-nb2+ #1242
    [    3.868644] Workqueue: events deferred_probe_work_func
    [    3.873801] epc: ffffffe000218d44 ra : ffffffe0006612bc sp : ffffffe0029af9e0
    [    3.880951]  gp : ffffffe0024bea28 tp : ffffffe0029a0840 t0 : ffffffe002417750
    [    3.888197]  t1 : ffffffe0029af9a8 t2 : 0000000000000001 s0 : ffffffe0029afa10
    [    3.895443]  s1 : ffffffe0079eb218 a0 : 0000000000000000 a1 : ffffffe0024812f0
    [    3.902689]  a2 : 0000000000000003 a3 : ffffffe002481310 a4 : eb58ea18fe63df00
    [    3.909935]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : eb58ea18fe63df00
    [    3.917182]  s2 : 0000000000000000 s3 : ffffffe0076da718 s4 : ffffffe0024bf0a8
    [    3.924427]  s5 : ffffffe007a72018 s6 : ffffffe0079eb2d0 s7 : 0000000000000001
    [    3.931673]  s8 : 0000000000000000 s9 : ffffffe0024a3dd0 s10: ffffffffffffffff
    [    3.938918]  s11: ffffffe007a72018 t3 : eb58ea18fe63df00 t4 : ffffffe002200328
    [    3.946163]  t5 : ffffffe00023886a t6 : ffffffe0029af748
    [    3.951488] status: 0000000200000120 badaddr: 00000000000000a0 cause: 000000000000000d
    [    3.959441] ---[ end trace e7dbbe1da01ab478 ]---
    [   62.528659] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 58s!
    [   62.536629] Showing busy workqueues and worker pools:
    [   62.541698] workqueue events: flags=0x0
    [   62.545547]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [   62.552359]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [   62.560759]     pending: stop_one_cpu_nowait_workfn
    [   62.565661] workqueue events_power_efficient: flags=0x80
    [   62.570987]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256 refcnt=3
    [   62.577796]     pending: neigh_periodic_work, neigh_periodic_work
    [   62.583923] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=58s workers=3 idle: 31
    [   93.312656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 89s!
    [   93.320610] Showing busy workqueues and worker pools:
    [   93.325676] workqueue events: flags=0x0
    [   93.329526]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [   93.336334]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [   93.344725]     pending: stop_one_cpu_nowait_workfn
    [   93.349623] workqueue events_power_efficient: flags=0x80
    [   93.354948]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256 refcnt=3
    [   93.361755]     pending: neigh_periodic_work, neigh_periodic_work
    [   93.367873] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=89s workers=3 idle: 31
    [  123.872656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 119s!
    [  123.880699] Showing busy workqueues and worker pools:
    [  123.885765] workqueue events: flags=0x0
    [  123.889613]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  123.896422]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  123.904811]     pending: stop_one_cpu_nowait_workfn
    [  123.909709] workqueue events_power_efficient: flags=0x80
    [  123.915035]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  123.921844]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  123.929366] workqueue ipv6_addrconf: flags=0x40008
    [  123.934171]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  123.940806]     pending: addrconf_verify_work
    [  123.945191] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=119s workers=3 idle: 31
    [  154.816656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 150s!
    [  154.824699] Showing busy workqueues and worker pools:
    [  154.829765] workqueue events: flags=0x0
    [  154.833615]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  154.840424]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  154.848812]     pending: stop_one_cpu_nowait_workfn
    [  154.853708] workqueue events_power_efficient: flags=0x80
    [  154.859034]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  154.865843]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  154.873361] workqueue ipv6_addrconf: flags=0x40008
    [  154.878166]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  154.884801]     pending: addrconf_verify_work
    [  154.889182] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=150s workers=3 idle: 31
    [  185.632654] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 181s!
    [  185.640697] Showing busy workqueues and worker pools:
    [  185.645764] workqueue events: flags=0x0
    [  185.649613]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  185.656422]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  185.664811]     pending: stop_one_cpu_nowait_workfn
    [  185.669707] workqueue events_power_efficient: flags=0x80
    [  185.675033]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  185.681840]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  185.689359] workqueue ipv6_addrconf: flags=0x40008
    [  185.694164]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  185.700799]     pending: addrconf_verify_work
    [  185.705179] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=181s workers=3 idle: 31
    [  216.448656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 212s!
    [  216.456698] Showing busy workqueues and worker pools:
    [  216.461766] workqueue events: flags=0x0
    [  216.465616]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  216.472424]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  216.480812]     pending: stop_one_cpu_nowait_workfn
    [  216.485709] workqueue events_power_efficient: flags=0x80
    [  216.491034]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  216.497843]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  216.505359] workqueue ipv6_addrconf: flags=0x40008
    [  216.510164]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  216.516798]     pending: addrconf_verify_work
    [  216.521175] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=212s workers=3 idle: 31
    [  246.752656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 242s!
    [  246.760699] Showing busy workqueues and worker pools:
    [  246.765766] workqueue events: flags=0x0
    [  246.769616]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  246.776424]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  246.784813]     pending: stop_one_cpu_nowait_workfn
    [  246.789709] workqueue events_power_efficient: flags=0x80
    [  246.795035]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  246.801844]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  246.809361] workqueue ipv6_addrconf: flags=0x40008
    [  246.814167]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  246.820801]     pending: addrconf_verify_work
    [  246.825180] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=242s workers=3 idle: 31
    [  277.568657] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 273s!
    [  277.576699] Showing busy workqueues and worker pools:
    [  277.581765] workqueue events: flags=0x0
    [  277.585616]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  277.592424]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  277.600812]     pending: stop_one_cpu_nowait_workfn
    [  277.605708] workqueue events_power_efficient: flags=0x80
    [  277.611033]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  277.617841]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  277.625359] workqueue ipv6_addrconf: flags=0x40008
    [  277.630164]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  277.636800]     pending: addrconf_verify_work
    [  277.641179] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=273s workers=3 idle: 31
    [  308.384655] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 304s!
    [  308.392696] Showing busy workqueues and worker pools:
    [  308.397762] workqueue events: flags=0x0
    [  308.401612]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  308.408420]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  308.416808]     pending: stop_one_cpu_nowait_workfn
    [  308.421705] workqueue events_power_efficient: flags=0x80
    [  308.427031]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  308.433839]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  308.441357] workqueue ipv6_addrconf: flags=0x40008
    [  308.446163]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  308.452797]     pending: addrconf_verify_work
    [  308.457176] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=304s workers=3 idle: 31
    [  339.200656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 335s!
    [  339.208697] Showing busy workqueues and worker pools:
    [  339.213764] workqueue events: flags=0x0
    [  339.217614]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  339.224422]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  339.232808]     pending: stop_one_cpu_nowait_workfn
    [  339.237707] workqueue events_power_efficient: flags=0x80
    [  339.243031]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  339.249840]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  339.257357] workqueue ipv6_addrconf: flags=0x40008
    [  339.262163]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  339.268797]     pending: addrconf_verify_work
    [  339.273174] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=335s workers=3 idle: 31
    [  370.016655] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 366s!
    [  370.024696] Showing busy workqueues and worker pools:
    [  370.029762] workqueue events: flags=0x0
    [  370.033610]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  370.040419]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  370.048806]     pending: stop_one_cpu_nowait_workfn
    [  370.053703] workqueue events_power_efficient: flags=0x80
    [  370.059028]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  370.065836]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  370.073354] workqueue ipv6_addrconf: flags=0x40008
    [  370.078160]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  370.084794]     pending: addrconf_verify_work
    [  370.089172] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=366s workers=3 idle: 31
    [  400.832655] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 396s!
    [  400.840698] Showing busy workqueues and worker pools:
    [  400.845764] workqueue events: flags=0x0
    [  400.849614]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  400.856422]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  400.864810]     pending: stop_one_cpu_nowait_workfn
    [  400.869706] workqueue events_power_efficient: flags=0x80
    [  400.875032]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  400.881839]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  400.889358] workqueue ipv6_addrconf: flags=0x40008
    [  400.894163]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  400.900798]     pending: addrconf_verify_work
    [  400.905178] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=396s workers=3 idle: 31
    [  431.136656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 427s!
    [  431.144698] Showing busy workqueues and worker pools:
    [  431.149765] workqueue events: flags=0x0
    [  431.153614]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  431.160423]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  431.168810]     pending: stop_one_cpu_nowait_workfn
    [  431.173706] workqueue events_power_efficient: flags=0x80
    [  431.179033]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  431.185841]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  431.193358] workqueue ipv6_addrconf: flags=0x40008
    [  431.198163]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  431.204798]     pending: addrconf_verify_work
    [  431.209176] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=427s workers=3 idle: 31
    [  461.952656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 457s!
    [  461.960697] Showing busy workqueues and worker pools:
    [  461.965765] workqueue events: flags=0x0
    [  461.969615]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  461.976423]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  461.984811]     pending: stop_one_cpu_nowait_workfn
    [  461.989707] workqueue events_power_efficient: flags=0x80
    [  461.995033]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  462.001842]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  462.009360] workqueue ipv6_addrconf: flags=0x40008
    [  462.014164]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  462.020800]     pending: addrconf_verify_work
    [  462.025179] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=457s workers=3 idle: 31
    [  492.768656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 488s!
    [  492.776698] Showing busy workqueues and worker pools:
    [  492.781764] workqueue events: flags=0x0
    [  492.785613]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  492.792421]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  492.800811]     pending: stop_one_cpu_nowait_workfn
    [  492.805709] workqueue events_power_efficient: flags=0x80
    [  492.811035]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  492.817845]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  492.825363] workqueue ipv6_addrconf: flags=0x40008
    [  492.830168]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  492.836802]     pending: addrconf_verify_work
    [  492.841182] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=488s workers=3 idle: 31
    [  523.584656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 519s!
    [  523.592699] Showing busy workqueues and worker pools:
    [  523.597765] workqueue events: flags=0x0
    [  523.601616]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  523.608425]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  523.616813]     pending: stop_one_cpu_nowait_workfn
    [  523.621709] workqueue events_power_efficient: flags=0x80
    [  523.627034]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  523.633844]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  523.641361] workqueue ipv6_addrconf: flags=0x40008
    [  523.646165]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  523.652801]     pending: addrconf_verify_work
    [  523.657179] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=519s workers=3 idle: 31
    [  554.400656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 550s!
    [  554.408699] Showing busy workqueues and worker pools:
    [  554.413764] workqueue events: flags=0x0
    [  554.417614]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  554.424423]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  554.432810]     pending: stop_one_cpu_nowait_workfn
    [  554.437707] workqueue events_power_efficient: flags=0x80
    [  554.443033]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  554.449842]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  554.457360] workqueue ipv6_addrconf: flags=0x40008
    [  554.462165]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  554.468799]     pending: addrconf_verify_work
    [  554.473177] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=550s workers=3 idle: 31
    [  584.704655] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 580s!
    [  584.712698] Showing busy workqueues and worker pools:
    [  584.717765] workqueue events: flags=0x0
    [  584.721614]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  584.728422]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  584.736811]     pending: stop_one_cpu_nowait_workfn
    [  584.741708] workqueue events_power_efficient: flags=0x80
    [  584.747033]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  584.753842]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  584.761360] workqueue ipv6_addrconf: flags=0x40008
    [  584.766165]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  584.772799]     pending: addrconf_verify_work
    [  584.777179] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=580s workers=3 idle: 31
    [  615.520656] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 611s!
    [  615.528698] Showing busy workqueues and worker pools:
    [  615.533764] workqueue events: flags=0x0
    [  615.537613]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  615.544422]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  615.552810]     pending: stop_one_cpu_nowait_workfn
    [  615.557706] workqueue events_power_efficient: flags=0x80
    [  615.563032]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  615.569840]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  615.577356] workqueue ipv6_addrconf: flags=0x40008
    [  615.582161]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  615.588794]     pending: addrconf_verify_work
    [  615.593173] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=611s workers=3 idle: 31
    [  646.336655] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 642s!
    [  646.344697] Showing busy workqueues and worker pools:
    [  646.349763] workqueue events: flags=0x0
    [  646.353611]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  646.360420]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  646.368808]     pending: stop_one_cpu_nowait_workfn
    [  646.373705] workqueue events_power_efficient: flags=0x80
    [  646.379031]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  646.385840]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  646.393357] workqueue ipv6_addrconf: flags=0x40008
    [  646.398163]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  646.404796]     pending: addrconf_verify_work
    [  646.409174] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=642s workers=3 idle: 31
    [  677.152655] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 673s!
    [  677.160696] Showing busy workqueues and worker pools:
    [  677.165763] workqueue events: flags=0x0
    [  677.169612]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=5
    [  677.176420]     in-flight: 25:deferred_probe_work_func BAR(1), 3:request_firmware_work_func
    [  677.184808]     pending: stop_one_cpu_nowait_workfn
    [  677.189705] workqueue events_power_efficient: flags=0x80
    [  677.195030]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=3/256 refcnt=4
    [  677.201838]     pending: neigh_periodic_work, neigh_periodic_work, check_lifetime
    [  677.209356] workqueue ipv6_addrconf: flags=0x40008
    [  677.214163]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 refcnt=2
    [  677.220797]     pending: addrconf_verify_work
    [  677.225175] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=673s workers=3 idle: 31
    Starting kernel ...
    [    0.000007] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
    [    2.708372]
    [    2.817096] p = 0
    [    2.826462] p = 1
    [    2.828402] i = 0
    在我的纯解析代码中,日志如下所示。
    dfamily = 2,device = 13
    很可能是gcc版本冲突。
    请修改如下
    在“struct CFW_project”中。
    -enum CFW_dfamily dfamily;/**<设备系列*/
    -enum CFW_device device;/**<设备标识符*/
    + unsigned char dfamily;/**<设备系列*/
    + unsigned char device;/**<设备标识符*/
    附件是在VC++上运行的纯解析代码
    e2e.ti.com/.../tlv320aic3262_5F00_fw.7z
    我已经做了以下更改
    diff --git a/sound/soc/codecs/aic326x/aic3xxx/aic3xxx_cfw.h b/sound/soc/codecs/aic326x/aic3xxx/aic3xxx_cfw.h
    index 2012d51..395459e 100644
    --- a/sound/soc/codecs/aic326x/aic3xxx/aic3xxx_cfw.h
    +++ b/sound/soc/codecs/aic326x/aic3xxx/aic3xxx_cfw.h
    @@ -503,8 +503,8 @@ struct cfw_project {
            u32 tstamp;             /**< Time stamp of firmware build (epoch seconds)*/
            char name[CFW_MAX_ID];  /**< Project name*/
            char *desc;             /**< User string*/
    -       enum cfw_dfamily dfamily;       /**< Device family*/
    -       enum cfw_device device; /**< Device identifier*/
    +       unsigned char dfamily;  /**< Device family*/
    +       unsigned char device;   /**< Device identifier*/
            u32 flags;              /**< CFW flags*/
            struct cfw_transition **transition;     /**< Transition sequences*/
    仍然收到相同的错误
    [    3.269442] aic3262_codec_probe enter
    [    3.269455] driver_init: Allocated Major Number: 244
    [    3.269455]
    [    3.279640] driver_init: Registered cfw driver
    [    3.284139] mmc1: SDHCI controller on 301005000.sdio0 [301005000.sdio0] using PIO
    [    3.291775] mmc0: SDHCI controller on 301007000.emmc [301007000.emmc] using PIO
    [    3.300394] tlv320aic3262-codec 2-0018: p 1 , r 30 7a 1
    [    3.305660] tlv320aic3262-codec 2-0018: p 1, w 30 7a 5
    [    3.351454] tlv320aic3262-codec 2-0018: p 1 , r 30 23 10
    [    3.356792] tlv320aic3262-codec 2-0018: p 1, w 30 23 30
    [    3.362328] aic3262_codec_probe exit
    [    3.362623] tlv320aic3262-codec 2-0018: Firmware binary load
    [    3.371914] Entering crc 7489
    [    3.372226] CRC pass
    [    3.375218] Loaded firmware inside unpickle
    [    3.381623] pjt->dfamily = 4, pjt->device = 2
    [    3.385993] base = (____ptrval____), p = (____ptrval____), base = 18f5dc0, p = 0
    [    3.393417] p = 0
    [    3.395357] base = (____ptrval____), p = (____ptrval____), base = 18f5dc0, p = 1
    [    3.402781] p = 1
    [    3.404728] i = 0
    [    3.406669] base = (____ptrval____), p = (____ptrval____), base = 18f5dc0, p = 47c0d1f1
    [    3.414701] p = 47c0d1f1
    [    3.417263] Unable to handle kernel paging request at virtual address ffffffe049502ff1
    [    3.425213] Oops [#1]
    [    3.427499] Modules linked in:
    [    3.430575] CPU: 0 PID: 40 Comm: kworker/0:3 Not tainted 5.10.41-nb2+ #1247
    [    3.437566] Workqueue: events request_firmware_work_func
    [    3.442894] epc: ffffffe00069e574 ra : ffffffe00069e568 sp : ffffffe0064f3d30
    [    3.450045]  gp : ffffffe001ec2a98 tp : ffffffe0064e8000 t0 : ffffffe001e14730
    [    3.457291]  t1 : ffffffe000444728 t2 : 0000000000001ab7 s0 : ffffffe0064f3d90
    [    3.464538]  s1 : ffffffe0018f5dc0 a0 : ffffffe049502fb1 a1 : ffffffe001e812f0
    [    3.471783]  a2 : 0000000000000003 a3 : ffffffe001e81310 a4 : 631167bc1c1afc00
    [    3.479030]  a5 : ffffffe0018f5dc1 a6 : c0000000ffffefff a7 : 000000000000001b
    [    3.486277]  s2 : ffffffe00649f2c0 s3 : 0000000000000000 s4 : 0000000000000000
    [    3.493524]  s5 : ffffffe049502fb1 s6 : 000000000000000b s7 : ffffffe001a01400
    [    3.500770]  s8 : 0000000000000001 s9 : 0000000000000402 s10: ffffffffffffffff
    [    3.508016]  s11: ffffffe0064a00c0 t3 : 000000000000000f t4 : ffffffe001c00328
    [    3.515263]  t5 : ffffffe001e0f5d8 t6 : ffffffe0064f3a78
    [    3.520589] status: 0000000200000120 badaddr: ffffffe049502ff1 cause: 000000000000000d
    [    3.528540] ---[ end trace 872bea7659cd9aec ]---
    [    3.533632] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.539200] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.544758] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.550315] tlv320aic3262-codec 2-0018: p 4 , r 30 b 0
    [    3.555878] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.561523] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.567167] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.572811] tlv320aic3262-codec 2-0018: p 4 , r 30 1b 0
    [    3.578455] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.584099] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.589738] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.595380] tlv320aic3262-codec 2-0018: p 4 , r 30 2b 0
    [    3.601358] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.606999] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.612643] tlv320aic3262-codec 2-0018: p 1 , r 30 1c 7f
    [    3.618371] tlv320aic3262-codec 2-0018: p 1 , r 30 1d 7f
    [    3.624097] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.629736] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.635382] tlv320aic3262-codec 2-0018: p 1 , r 30 1b 0
    [    3.641030] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.646673] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.652314] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.657958] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.663606] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.669253] tlv320aic3262-codec 2-0018: p 1 , r 30 16 0
    [    3.674902] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.680541] tlv320aic3262-codec 2-0018: p 1 , r 30 17 0
    [    3.686223] tlv320aic3262-codec 2-0018: p 1 , r 30 24 7f
    [    3.691959] tlv320aic3262-codec 2-0018: p 1 , r 30 26 7f
    [    3.697697] tlv320aic3262-codec 2-0018: p 1 , r 30 27 7f
    [    3.703090] mmc0: new MMC card at address 0001
    [    3.707811] tlv320aic3262-codec 2-0018: p 1 , r 30 25 7f
    [    3.714564] mmcblk0: mmc0:0001 DA6032 29.1 GiB
    [    3.720482] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.725931] mmcblk0boot0: mmc0:0001 DA6032 partition 1 4.00 MiB
    [    3.733164] tlv320aic3262-codec 2-0018: p 1 , r 30 2e 7f
    [    3.738706] mmcblk0boot1: mmc0:0001 DA6032 partition 2 4.00 MiB
    [    3.744768] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.750158] mmcblk0rpmb: mmc0:0001 DA6032 partition 3 4.00 MiB, chardev (245:0)
    [    3.757538] mmc1: new SDHC card at address aaaa
    [    3.762413] tlv320aic3262-codec 2-0018: p 1 , r 30 2f 7f
    [    3.769145] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
    [    3.773668] tlv320aic3262-codec 2-0018: p 1 , r 30 2d 0
    [    3.779660] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.785303] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.790938] random: fast init done
    [    3.794363] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.800002] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.805639] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.811276] tlv320aic3262-codec 2-0018: p 4 , r 30 8 50
    [    3.816914] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.822550] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.828188] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.833826] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.839464] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.845111] tlv320aic3262-codec 2-0018: p 4 , r 30 18 0
    [    3.850749] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.856387] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.862024] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.867661] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.873299] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.878936] tlv320aic3262-codec 2-0018: p 4 , r 30 28 0
    [    3.884589] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.890226] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.895861] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.901500] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.907140] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.912775] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.918412] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.924048] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.929684] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.935320] tlv320aic3262-codec 2-0018: p 4 , r 30 76 6
    [    3.940571] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [
    NULL] -> Left DAC
    [    3.950952] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --
    > Left DAC
    [    3.960724] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -
    > Left DAC
    [    3.970497] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN1 Route -> [
    NULL] -> Right DAC
    [    3.980964] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN1 Route --> NULL --
    > Right DAC
    [    3.990822] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN1 Route -> NULL -
    > Right DAC
    [    4.000683] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [
    NULL] -> Left DAC
    [    4.011066] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --
    > Left DAC
    [    4.020839] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -
    > Left DAC
    [    4.030611] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN2 Route -> [
    NULL] -> Right DAC
    [    4.041078] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN2 Route --> NULL --
    > Right DAC
    [    4.050936] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN2 Route -> NULL -
    > Right DAC
    [    4.060796] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [
    NULL] -> Left DAC
    [    4.071176] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --
    > Left DAC
    [    4.080948] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -
    > Left DAC
    [    4.090721] tlv320aic3262-codec 2-0018: Control not supported for path DAC MiniDSP IN3 Route -> [
    NULL] -> Right DAC
    [    4.101188] tlv320aic3262-codec 2-0018: ASoC: no dapm match for DAC MiniDSP IN3 Route --> NULL --
    > Right DAC
    [    4.111045] tlv320aic3262-codec 2-0018: ASoC: Failed to add route DAC MiniDSP IN3 Route -> NULL -
    > Right DAC
    [    4.121586] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    4.127227] tlv320aic3262-codec 2-0018: p 1 , r 30 12 3f
    [    4.132962] tlv320aic3262-codec 2-0018: p 1 , r 30 11 0
    [    4.138601] tlv320aic3262-codec 2-0018: p 1 , r 30 13 3f
    [    4.144620] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.150170] tlv320aic3262-codec 2-0018: p 0 , r 30 0 0
    [    4.156026] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.161664] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.167309] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.172948] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.178586] tlv320aic3262-codec 2-0018: p 1 , r 30 34 0
    [    4.184221] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.189857] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.195494] tlv320aic3262-codec 2-0018: p 1 , r 30 35 0
    [    4.201133] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.206772] tlv320aic3262-codec 2-0018: p 1 , r 30 36 0
    [    4.212410] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.218050] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.223687] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.229323] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    4.234964] tlv320aic3262-codec 2-0018: p 1 , r 30 37 0
    [    4.240603] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.246244] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.251883] tlv320aic3262-codec 2-0018: p 1 , r 30 38 0
    [    4.257522] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.263159] tlv320aic3262-codec 2-0018: p 1 , r 30 39 0
    [    4.269099] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.274739] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.280382] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.286022] tlv320aic3262-codec 2-0018: p 0 , r 30 51 0
    [    4.291976] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.297527] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.303078] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.308628] tlv320aic3262-codec 2-0018: p 4 , r 30 7 1
    [    4.314180] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.319818] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.325455] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.331092] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.336731] tlv320aic3262-codec 2-0018: p 4 , r 30 17 0
    [    4.342371] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.348009] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.353645] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.359282] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.364919] tlv320aic3262-codec 2-0018: p 4 , r 30 27 0
    [    4.370569] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.376120] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.381669] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.387219] tlv320aic3262-codec 2-0018: p 4 , r 30 f 0
    [    4.392771] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.398410] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.404048] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.409685] tlv320aic3262-codec 2-0018: p 4 , r 30 1f 0
    [    4.415335] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.420973] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.426609] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.432248] tlv320aic3262-codec 2-0018: p 4 , r 30 2f 0
    [    4.437509] asoc-simple-card sound0: soc_probe_component: snd_soc_dapm_add_routes failed: -22
    [    4.446068] aic3262_codec_remove enter
    [    4.446074] aic3262_set_bias_level enter
    [    4.449846] tlv320aic3262-codec 2-0018: set_bias_off
    [    4.458767] aic3262_set_bias_level exit
    [    4.458778] Unable to handle kernel NULL pointer dereference at virtual address 00000000000000a0
    [    4.471445] Oops [#2]
    [    4.473731] Modules linked in:
    [    4.476805] CPU: 0 PID: 25 Comm: kworker/0:1 Tainted: G      D           5.10.41-nb2+ #1247
    [    4.485204] Workqueue: events deferred_probe_work_func
    [    4.490361] epc: ffffffe000218fa2 ra : ffffffe00069e152 sp : ffffffe0021f39e0
    [    4.497511]  gp : ffffffe001ec2a98 tp : ffffffe0021e8840 t0 : ffffffe001e18148
    [    4.504757]  t1 : ffffffe0021f39a8 t2 : 0000000000000008 s0 : ffffffe0021f3a10
    [    4.512003]  s1 : ffffffe00647c818 a0 : 0000000000000000 a1 : ffffffe001e812f0
    [    4.519248]  a2 : 0000000000000003 a3 : ffffffe001e81310 a4 : 631167bc1c1afc00
    [    4.526494]  a5 : 0000000000000000 a6 : c0000000ffffefff a7 : 631167bc1c1afc00
    [    4.533740]  s2 : 0000000000000000 s3 : ffffffe0062cab18 s4 : ffffffe001ec30a8
    [    4.540986]  s5 : ffffffe0064d6018 s6 : ffffffe00647c8d0 s7 : 0000000000000001
    [    4.548233]  s8 : 0000000000000000 s9 : ffffffe001ea74d0 s10: ffffffffffffffff
    [    4.555479]  s11: ffffffe0064d6018 t3 : 631167bc1c1afc00 t4 : ffffffe001c00328
    [    4.562723]  t5 : 0000000000000000 t6 : ffffffe0021f3748
    [    4.568049] status: 0000000200000120 badaddr: 00000000000000a0 cause: 000000000000000d
    [    4.576001] ---[ end trace 872bea7659cd9aed ]---
    [   62.532370] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 58s!
    [   62.540326] Showing busy workqueues and worker pools:
    [   62.545393] workqueue events: flags=0x0
    [   62.549244]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=6/256 refcnt=8
    [   62.556054]     in-flight: 25:deferred_probe_work_func BAR(1) deferred_probe_work_func, 42:req
    您是否在任何硬件上尝试此驱动程序?
    我们现在正处于上升阶段,我们能否尽快解决这一问题
    我使用的是64位SoC,不确定这是否也会造成问题
    感谢您的合作。 如你所知,几年前,此代码在内核4.14 中运行,现在 ,我的城市由于新型冠状病毒肺炎(COVID-19)而被锁定,我 被迫在家工作。 并且无法访问任何硬件来重现您的问题。 我尝试模拟您必须支持的环境。 期待您的好消息。
    您好 ,Pragnesh,
    我认为我找到了根本原因,可以再现。
    在VC++中,我使用Win32模式,无法重现此问题。
    如果我使用x64模式或在Linux中编译代码,我可以重现该问题。
    我认为在Linux中,内存地址默认为64位。 是否确定在系统中使用32位?
    登录x64
    输入CRC 7489
    CRC PASS (CRC通过)
    已在不选取的文件中加载固件
    pjt->desc = 0xd20a3930
    dfamily = 4,device = 2
    标志= 0x0084
    D:\localdata\tlv320aic3262_FW\x64\Debug\regbintool.exe (进程1.2176万)退出,代码为-1073741819。
    登录Linux
    root@Desktop-EP4IUBG:/mnt/d/localdata/tlv320aic3262_FW#./regbin -i 5811.tlv320aic3262_fw_v1.bin</s>3262
    输入CRC 7489
    CRC PASS (CRC通过)
    已在不选取的文件中加载固件
    pjt->desc = 0x6.3508万b3e66b0
    标志= 0x0084
    分割故障
    Traget主板是64位SoC,我无法更改,因为它让我知道任何解决方法
    您好,Pragnesh
    我们可以进行配置呼叫吗? 我的电子邮件地址是 shenghao-ding@ti.com。
    现在我要编写固件解析代码。
    巴西
    丁胜浩
    我向您发送了2022年5月6日(印度时间下午2点)的邀请,如果这个时间不合适,您可以在您合适的时间向我发送邀请
