[参考译文] PCMD3140:CH3和 CH4不起作用
Guru**** 2782625 points
Other Parts Discussed in Thread: PCMD3140
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/1120598/pcmd3140-ch3-and-ch4-does-not-working
器件型号:PCMD3140
我尝试使用4个 PDM 麦克风输入在我们的电路板(IMX8MQ)上设置 PCMD3140。
目前、ASI 输出通道格式为 TDM 模式并设置4通道输入、CH1和 CH2工作正常、但 CH3和 CH4不工作。
我还根据数据表上的示例设置配置、但 CH3和 CH4仍然不起作用。
根据 DEV_STS0寄存器(0x76)、看起来 ch3和 Ch4功率状态不正确。
完整寄存器信息如下所示。
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 00 00 81 00 00 05 00 04 00 00 00 00 01 02 03 00    ..?..?.?....???.
10: 00 00 00 02 48 44 10 10 04 20 02 08 00 00 02 40    ...?HD??? ??..?@
20: 00 00 41 00 00 00 00 00 00 00 00 54 00 00 00 00    ..A........T....
30: 00 00 00 ff 00 00 40 00 40 00 00 00 00 fc ff 80    ...?..@.@....???
40: 00 00 fc ff 80 00 00 00 ff 80 00 00 00 ff 80 00    ..???...??...??.
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
60: 00 00 00 00 00 00 00 00 00 00 00 01 40 7b 00 00    ...........?@{..
70: e7 00 00 f0 f0 e0 c0 e0 00 00 ff 00 ff ac 50 00    ?..?????..?.??P.
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
Jay
