[参考译文] TLV320AIC34EVM-K:具有 IMX8MP SoM 的 TLV320AIC34音频编解码器
Guru**** 2390735 points
Other Parts Discussed in Thread: TLV320AIC34
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/1042165/tlv320aic34evm-k-tlv320aic34-audio-codec-with-imx8mp-som
器件型号:TLV320AIC34EVM-K
主题中讨论的其他器件:TLV320AIC34
我想    通过 I2S 连接将 Variscite DT8M 定制板与 TLV320AIC34评估模块连接起来。
出于未知原因、我无法看到 SAI2_MCLK1正常工作、示波器上的值始终为"0"、因此当我尝试播放音频时、似乎阻止了播放。
硬件配置:
SAI vs Codec
SAI2_TXC <-> BCLK
SAI2_TXFS <-> WCLK
SAI2_MCLK <-> MCLK
SAI2_RXD0 <-> DIN
SAI2_TXD0 <-> DOUT
我的设备树配置:
	reg_audio_1v8: regulator-1p8v {
		compatible = "regulator-fixed";
		regulator-name = "1P8V";
		regulator-min-microvolt = <1800000>;
		regulator-max-microvolt = <1800000>;
		regulator-always-on;
	sound-tlv320aic34 {
	compatible = "simple-audio-card";
		simple-audio-card,name = "HTC2-Sound-Card";
		simple-audio-card,format = "i2s";
		simple-audio-card,bitclock-master = <&dailink0_master>;
		simple-audio-card,frame-master = <&dailink0_master>;
		simple-audio-card,widgets =
			"Microphone", "Microphone Jack",
			"Line", "Line In Jack",
			"Line", "Line Out Jack",
			"Headphone", "Headphone Jack",
			"Speaker", "Speaker External";
		simple-audio-card,routing =
			"MIC3L", "Microphone Jack",
			"MIC3R", "Microphone Jack",
			"Headphone Jack", "HPLOUT",
			"Headphone Jack", "HPROUT";
		simple-audio-card,cpu {
			sound-dai = <&sai2 0>;
		dailink0_master: simple-audio-card,codec {
			sound-dai = <&tlv320aic34>;
&sai2 {
	#sound-dai-cells = <1>;
 	pinctrl-names = "default";
 	pinctrl-0 = <&pinctrl_sai2>;
	clocks = <&audiomix_clk IMX8MP_CLK_AUDIOMIX_SAI2_IPG>, <&clk IMX8MP_CLK_DUMMY>, <&audiomix_clk IMX8MP_CLK_AUDIOMIX_SAI2_MCLK1>, <&clk IMX8MP_CLK_DUMMY>, <&clk IMX8MP_CLK_DUMMY>, <&clk IMX8MP_AUDIO_PLL1_OUT>, <&clk IMX8MP_AUDIO_PLL2_OUT>;
	clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3", "pll1", "pll2";
	assigned-clocks = <&clk IMX8MP_CLK_SAI2>;
	assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL2_OUT>;
	assigned-clock-rates = <12000000>;
	fsl,sai-asynchronous;
	fsl,sai-mclk-direction-output;
 	status = "okay";
pinctrl_sai2: sai2grp {
	fsl,pins = <
		MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_SAI2_TX_SYNC			0xd6
		MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_SAI2_TX_BCLK			0xd6
		MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_SAI2_RX_DATA00			0xd6
		MX8MP_IOMUXC_SAI2_TXD0__AUDIOMIX_SAI2_TX_DATA00			0xd6
		MX8MP_IOMUXC_SAI2_MCLK__AUDIOMIX_SAI2_MCLK			 0xd6
i2cdump:
root@imx8mp-var-dart:~# i2cdump -y -f 2 0x18
No size specified (using byte-data access)
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 00 00 00 10 04 00 00 00 00 00 00 01 00 00 00 80    ...??......?...?
10: 80 ff ff 78 78 78 78 78 78 06 00 fe 00 00 fe 00    ?..xxxxxx?.?..?.
20: 00 00 00 00 00 00 00 00 00 00 00 80 80 00 00 00    ...........??...
30: 00 00 00 04 00 00 00 00 00 00 04 00 00 00 00 00    ...?......?.....
40: 00 04 00 00 00 00 00 00 04 00 00 00 00 00 00 00    .?......?.......
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
60: 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00    ......?.........
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
80: 00 00 00 10 04 00 00 00 00 00 00 01 00 00 00 80    ...??......?...?
90: 80 ff ff 78 78 78 78 78 78 06 00 fe 00 00 fe 00    ?..xxxxxx?.?..?.
a0: 00 00 00 00 00 00 00 00 00 00 00 80 80 00 00 00    ...........??...
b0: 00 00 00 04 00 00 00 00 00 00 04 00 00 00 00 00    ...?......?.....
c0: 00 04 00 00 00 00 00 00 04 00 00 00 00 00 00 00    .?......?.......
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
e0: 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00    ......?.........
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
/sys/clk/kernel/debug/clk_summary:
    audio_pll2_ref_sel                0        0        0    24000000          0     0  50000
       audio_pll2                     0        0        0   361267200          0     0  50000
          audio_pll2_bypass           0        0        0   361267200          0     0  50000
             audio_pll2_out           0        0        0   361267200          0     0  50000
                sai2                  0        0        0    12042240          0     0  50000
                   sai2_mclk1_sel       0        0        0    12042240          0     0  50000
                      sai2_mclk1_clk       0        0        0    12042240          0     0  50000
有什么想法可以帮助您? 我已经尝试了很多东西、但 SAI2_MCLK1仍然没有移动。
    Variscite 开发套件文档链接: www.variscite.com/.../
    在此设置中是否使用 USB-MODEVM、如果要使用外部 MCLK、则需要按如下所示配置 SW2。
    此处是 EVM 用户指南的链接、以了解更多详细信息。
    https://www.ti.com/lit/ug/slau855/slau855.pdf?ts=1633530475737&ref_url=https%253A%252F%252Fwww.ti.com%252Ftool%252FTLV320AIC34EVM-K
    此致。
    您好、普琼、
    感谢您的回答、我已经完成了、但它不起作用。
    我的 BLCK 值始终为"1"、MCLK "0"、WCLK "0"
    当我尝试播放音频时,播放被阻止,没有任何错误日志:
    root@imx8mp-var-dart:~# aplay -D sysdefault:HTC2SoundCard /usr/share/sounds/alsa/Front_Left.wav
    Playing WAVE '/usr/share/sounds/alsa/Front_Left.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
    CLK、ID、频率、从 dmesg 映射;
    root@imx8mp-var-dart:~# dmesg | grep tlv
    [    5.136874] tlv320aic3x-codec 2-0018: CLK_ID : 0, FREQ : 12042240
    [    5.144810] asoc-simple-card sound-tlv320aic34: tlv320aic3x-hifi <-> 30c20000.sai mapping ok
    Mathieu。
    首先、您是否在连接到 USB-MODEVM 之前从源 SAI2中检查了 MCLK 是否正确以及频率是多少?
    您是否遵循编解码器驱动程序中提到的 MCLK 频率?
    如果正确、则在配置了上述 SW2后、您将此 MCLK 连接到 EVM 中的哪个位置?
    时钟上始终显示为"1"或"0"时、表明源本身不存在 MCLK、或者存在一些连接问题。
    如果您如上所述设置 SW2、则应在 J14处连接 MCLK、并且可以在 USB-MODEVM J17接头或 TLV320AIC310xEVM MCLK 引脚上对其进行探测。
    一旦 MCLK 与 TLV320AIC310xEVM 正确匹配、音频部件就应提供 WCLK 和 BCLK、因为我认为您将它们配置为主器件。
    可能会在 MCLK 运行后向我发送 MCLK、WCLK 和 BCLK 的示波器捕获。 大多数时候、这是因为 MCLK 不正确。
    此致。
    您好 Pdjuandi、
    MCLK 由 SoM 提供、正如您所说的、BCLK 和 WCLK 由编解码器提供、因为它被配置为主器件。
    我找到了 MCLK 的解决方案、因此我的频率为12MHz、BCLK 频率为1.5MHz、当我尝试使用以下命令行播放音频时、我的 WCLK 频率为48kHz:
    root@imx8mp-var-dart:~ó n speaker-test -D sysdefault:HTC2SoundCard
    但是我仍然听不到耳机上的声音,并且扬声器测试仍然被阻止:
    扬声器测试1.1.9
    回放设备为 sysdefault:HTC2SoundCard
    流参数为48000Hz、S16_LE、1个通道
    使用16个粉色噪声的八倍
    速率设置为48000Hz (请求的48000Hz)
    缓冲器大小范围为64至16384
    周期大小范围为32至8192
    使用最大缓冲器大小16384
    周期= 4
    设置 PERIOD_SIZE = 4096
    设置 buffer_size = 16384
    0 -左前
    Buck 1.5Mhz:
    WCLK 48kHz:
    MCLK 12MHz:
    Mathieu。
    您好、Mathieu、
    这一点很好、您可以让时钟运行、时钟频率看起来是正确的。
    那么、您要测试哪条路径? 您的输入和输出是什么?
    您可以向我发送您的寄存器设置吗?
    此致。
    您好 Pdjuandi、
    我尝试在连接到 HPCOM 的耳机输出上播放声音:
    Simple mixer control 'PCM',0
      Capabilities: pvolume
      Playback channels: Front Left - Front Right
      Limits: Playback 0 - 127
      Mono:
      Front Left: Playback 127 [100%] [0.00dB]
      Front Right: Playback 127 [100%] [0.00dB]
    Simple mixer control 'Line',0
      Capabilities: pvolume pswitch
      Limits: Playback 0 - 9
      Mono:
      Front Left: Playback 0 [0%] [0.00dB] [off]
      Front Right: Playback 0 [0%] [0.00dB] [off]
    Simple mixer control 'Line DAC',0
      Limits: Playback 0 - 118
      Mono:
      Front Left: Playback 0 [0%] [-99999.99dB]
      Front Right: Playback 0 [0%] [-99999.99dB]
    Simple mixer control 'Line Line2 Bypass',0
      Capabilities: volume
      Capture channels: Front Left - Front Right
      Limits: 0 - 118
      Front Left: 0 [0%] [-99999.99dB]
      Front Right: 0 [0%] [-99999.99dB]
    Simple mixer control 'Line PGA Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Mono',0
      Capabilities: pvolume pvolume-joined pswitch pswitch-joined
      Playback channels: Mono
      Mono: Playback 0 [0%] [0.00dB] [off]
    Simple mixer control 'Mono DAC',0
      Mono:
    Simple mixer control 'Mono Line2 Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Mono Mixer DACL1',0
      Capabilities: pswitch pswitch-joined
      Mono: Playback [off]
    Simple mixer control 'Mono Mixer DACR1',0
    Simple mixer control 'Mono Mixer Line2L Bypass',0
    Simple mixer control 'Mono Mixer Line2R Bypass',0
    Simple mixer control 'Mono Mixer PGAL Bypass',0
    Simple mixer control 'Mono Mixer PGAR Bypass',0
    Simple mixer control 'Mono PGA Bypass',0
      Limits: 0 - 118
    Simple mixer control 'ADC HPF Cut-off',0
      Capabilities: enum
      Items: 'Disabled' '0.0045xFs' '0.0125xFs' '0.025xFs'
      Item0: 'Disabled'
      Item1: 'Disabled'
    Simple mixer control 'AGC',0
      Mono:
      Front Left: Playback [off]
      Front Right: Playback [off]
    Simple mixer control 'De-emphasis',0
      Mono:
    Simple mixer control 'HP',0
      Mono:
    Simple mixer control 'HP DAC',0
      Mono:
    Simple mixer control 'HP Line2 Bypass',0
      Limits: 0 - 118
    Simple mixer control 'HP PGA Bypass',0
      Limits: 0 - 118
    Simple mixer control 'HPCOM',0
      Mono:
      Front Left: Playback 9 [100%] [9.00dB] [on]
      Front Right: Playback 9 [100%] [9.00dB] [on]
    Simple mixer control 'HPCOM DAC',0
      Mono:
      Front Left: Playback 118 [100%] [0.00dB]
      Front Right: Playback 118 [100%] [0.00dB]
    Simple mixer control 'HPCOM Line2 Bypass',0
      Limits: 0 - 118
    Simple mixer control 'HPCOM PGA Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Left AGC Attack time',0
      Capabilities: enum
      Items: '8ms' '11ms' '16ms' '20ms'
      Item0: '8ms'
    Simple mixer control 'Left AGC Decay time',0
      Capabilities: enum
      Items: '100ms' '200ms' '400ms' '500ms'
      Item0: '100ms'
    Simple mixer control 'Left AGC Target level',0
      Capabilities: enum
      Items: '-5.5dB' '-8dB' '-10dB' '-12dB' '-14dB' '-17dB' '-20dB' '-24dB'
      Item0: '-5.5dB'
    Simple mixer control 'Left DAC Mux',0
      Capabilities: enum
      Items: 'DAC_L1' 'DAC_L3' 'DAC_L2'
      Item0: 'DAC_L1'
    Simple mixer control 'Left HP Mixer DACL1',0
    Simple mixer control 'Left HP Mixer DACR1',0
      Mono: Playback 118 [100%] [0.00dB] [off]
    Simple mixer control 'Left HP Mixer Line2L Bypass',0
    Simple mixer control 'Left HP Mixer Line2R Bypass',0
      Capabilities: volume volume-joined pswitch pswitch-joined
      Capture channels: Mono
      Limits: 0 - 118
      Mono: 118 [100%] [0.00dB] Playback [off]
    Simple mixer control 'Left HP Mixer PGAL Bypass',0
    Simple mixer control 'Left HP Mixer PGAR Bypass',0
      Limits: 0 - 118
      Mono: 118 [100%] [0.00dB] Playback [on]
    Simple mixer control 'Left HPCOM Mixer DACL1',0
      Mono: Playback [on]
    Simple mixer control 'Left HPCOM Mixer DACR1',0
      Mono: Playback 118 [100%] [0.00dB] [on]
    Simple mixer control 'Left HPCOM Mixer Line2L Bypass',0
      Mono: Playback [on]
    Simple mixer control 'Left HPCOM Mixer Line2R Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Left HPCOM Mixer PGAL Bypass',0
    Simple mixer control 'Left HPCOM Mixer PGAR Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Left HPCOM Mux',0
      Capabilities: enum
      Items: 'differential of HPLOUT' 'constant VCM' 'single-ended'
      Item0: 'differential of HPLOUT'
    Simple mixer control 'Left Line Mixer DACL1',0
    Simple mixer control 'Left Line Mixer DACR1',0
    Simple mixer control 'Left Line Mixer Line2L Bypass',0
    Simple mixer control 'Left Line Mixer Line2R Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Left Line Mixer PGAL Bypass',0
    Simple mixer control 'Left Line Mixer PGAR Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Left Line1L Mux',0
      Capabilities: enum
      Items: 'single-ended' 'differential'
      Item0: 'single-ended'
    Simple mixer control 'Left Line1R Mux',0
      Capabilities: enum
    Simple mixer control 'Left Line2L Mux',0
      Capabilities: enum
    Simple mixer control 'Left PGA Mixer Line1L',0
    Simple mixer control 'Left PGA Mixer Line1R',0
    Simple mixer control 'Left PGA Mixer Line2L',0
    Simple mixer control 'Left PGA Mixer Mic3L',0
    Simple mixer control 'Left PGA Mixer Mic3R',0
    Simple mixer control 'Output Driver Power-On time',0
      Capabilities: enum
      Items: '0us' '10us' '100us' '1ms' '10ms' '50ms' '100ms' '200ms' '400ms' '800ms' '2s' '4s'
      Item0: '0us'
    Simple mixer control 'Output Driver Ramp-up step',0
      Capabilities: enum
      Items: '0ms' '1ms' '2ms' '4ms'
      Item0: '0ms'
    Simple mixer control 'PGA',0
      Capabilities: cvolume cswitch
      Limits: Capture 0 - 119
      Front Left: Capture 32 [27%] [16.00dB] [on]
      Front Right: Capture 32 [27%] [16.00dB] [on]
    Simple mixer control 'Right AGC Attack time',0
      Capabilities: enum
      Item0: '8ms'
    Simple mixer control 'Right AGC Decay time',0
      Capabilities: enum
      Item0: '100ms'
    Simple mixer control 'Right AGC Target level',0
      Capabilities: enum
      Item0: '-5.5dB'
    Simple mixer control 'Right DAC Mux',0
      Capabilities: enum
      Items: 'DAC_R1' 'DAC_R3' 'DAC_R2'
      Item0: 'DAC_R1'
    Simple mixer control 'Right HP Mixer DACL1',0
    Simple mixer control 'Right HP Mixer DACR1',0
    Simple mixer control 'Right HP Mixer Line2L Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Right HP Mixer Line2R Bypass',0
    Simple mixer control 'Right HP Mixer PGAL Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Right HP Mixer PGAR Bypass',0
    Simple mixer control 'Right HPCOM Mixer DACL1',0
    Simple mixer control 'Right HPCOM Mixer DACR1',0
    Simple mixer control 'Right HPCOM Mixer Line2L Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Right HPCOM Mixer Line2R Bypass',0
    Simple mixer control 'Right HPCOM Mixer PGAL Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Right HPCOM Mixer PGAR Bypass',0
    Simple mixer control 'Right HPCOM Mux',0
      Capabilities: enum
      Items: 'differential of HPROUT' 'constant VCM' 'single-ended' 'differential of HPLCOM' 'external feedback'
      Item0: 'differential of HPROUT'
    Simple mixer control 'Right Line Mixer DACL1',0
    Simple mixer control 'Right Line Mixer DACR1',0
    Simple mixer control 'Right Line Mixer Line2L Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Right Line Mixer Line2R Bypass',0
    Simple mixer control 'Right Line Mixer PGAL Bypass',0
      Limits: 0 - 118
    Simple mixer control 'Right Line Mixer PGAR Bypass',0
    Simple mixer control 'Right Line1L Mux',0
      Capabilities: enum
    Simple mixer control 'Right Line1R Mux',0
      Capabilities: enum
    Simple mixer control 'Right Line2R Mux',0
      Capabilities: enum
    Simple mixer control 'Right PGA Mixer Line1L',0
    Simple mixer control 'Right PGA Mixer Line1R',0
    Simple mixer control 'Right PGA Mixer Line2R',0
    Simple mixer control 'Right PGA Mixer Mic3L',0
    Simple mixer control 'Right PGA Mixer Mic3R',0
    00: 00 00 00 10 20 19 80 0a 00 00 00 01 00 00 00 80    ...? ???...?...?
    80: 00 00 00 10 20 19 80 0a 00 00 00 01 00 00 00 80    ...? ???...?...?
    我不明白为什么即使未正确配置音频路由、播放或扬声器测试也会被阻止
    root@imx8mp-var-dart:~# aplay -l
    null
    丢弃所有样本(回放)或生成零样本(捕获)
    脉冲
    PulseAudio Sound 服务器
    sysdefault:card=HTC2SoundCard
    HTC2-Sound 卡、
    默认音频设备
    好的、看看上面的寄存器转储、没有启用任何音频路径。
    下面是将数字音频发送到 HPL 和 HPR 输出的详细信息和需要设置的内容:
    此致。
    未指定大小(使用字节数据访问)
    0 1 2 3 4 5 6 7 8 9 A b c d e f 0123456789abcdef
    00:00 00 00 10 20 19 80 0A 00 00 01 00 00 80 ...? ????????
    10:80 ff 78 78 78 78 78 78 78 78 06 00 fe 00 fe 00 ?.xxxxxx?..
    20:00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 ???...
    30:00 00 00 04 00 00 00 00 00 00 00 00 04 00 00 00 00 00 ...? ?。
    40:00 04 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00。。。。 ?。
    50:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    60:00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 ?..........
    70:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    80:00 00 10 20 19 80 0A 00 00 01 00 00 80 ...? ????????
    90:80 ff 78 78 78 78 78 78 78 06 00 fe 00 fe 00 ?.xxxxxx?..
    A0:00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 ???...
    B0:00 00 04 00 00 00 00 00 00 00 00 04 00 00 00 00 00 ...? ?。
    C0:00 04 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00。。。。 ?。
    D0:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    E0:00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 ?..........
    F0:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    请参阅以上我的反馈。 您的设置未启用音频路径。
    您好 Pdjuandi、
    我尝试手动更改音频设置、当我打开 alsamixer 时、它们会保持不变、但当我尝试使用 aplay 或 speaker-test 时、所有内容都会被修改、看起来像我之前的 i2cdump。
    我尝试了不同的命令,并显示此错误信息:
    root@imx8mp-var-dart:~ó n speaker-test -D sysdefault:HTC2SoundCard -c 2 -t 3
    扬声器测试1.1.9
    流参数为48000Hz、S16_LE、2个通道
    WAV 文件
    缓冲器大小范围为64至16384
    周期大小范围为32至8192
    使用最大缓冲器大小16384
    周期= 4
    0 -左前
    写入错误:-5、输入/输出错误
    xrun_recovery 失败:-5、输入/输出错误
    传输失败:输入/输出错误
    您好、Mathieu、
    我不知道为什么播放或扬声器测试会更改编解码器的设置。
    它们似乎没有在两者之间设置正确的输入/输出。
    此致。
    Peter
    您好 Pdjuandi、
    这是我播放音频时的 DIN CLK, 我没有输入:
    您好、Mathieu、
    我认为该 DIN 是数据输入、而不是时钟。
    尽管如此、问题仍然在于在编解码器上获得正确的配置。 为什么更改了设置?
    此致。
    Peter
    您好 Pdjuandi、
    是的、抱歉、数据不是 CLK、 所有其他信号、BCLK、MCLK 和 WCLK 都是相同的、但 DIN 看起来是这样的。
    Mathieu。
    您好 Pdjuandi、
    感谢所有这些信息,我找到了解决方案,以下是我的设置,供那些想知道的人使用:
    sound-tlv320aic34{
    兼容="简单音频卡";
    simple-audio-card、name ="HTC2-Sound-Card";
    simple-audio-card、format ="I2S";
    simple-audio-card、bitclock-master =<&dailink_master>;
    simple-audio-card、frame-master =<&dailink_master>;
    simple-audio-card、MCLK-FS =<256>;
    simple-audio-card、小工具=
    "麦克风"、"麦克风插孔"、
    "线路"、"插孔中的线路"、
    "线路"、"线路输出插孔"、
    "耳机"、"耳机插孔"、
    "扬声器"、"外部扬声器";
    简单音频卡,路由=
    "耳机插孔"、"HPLOUT"、
    "耳机插孔"、"HPROUT";
    dailink_master:simple-audio-card、CPU{
    Sound-Dai =<&SAI2>;
    简单音频卡、编解码器{
    sound-dai =<&tlv320aic34>;
    时钟=<audioix_clk IMX8MP_CLK_AUDIOMIX_SAI2_MCLK1>;
    SAI2{
    #sound-di-cells =<0>;
    pinctrl-names ="default";
    pinctrl-0 =<&pinctrl_SAI2>;
    分配的时钟=<&clk IMX8MP_CLK_SAI2>;
    分配的时钟父级=<&clk IMX8MP_AUDIO_PLL1_OUT>;
    分配的时钟速率=<12288000>;
    时钟=<audioix_clk IMX8MP_CLK_AUDIOMIX_SAI2_IPG>、<&clk IMX8MP_CLK_dumme>、
    <audioix_clk IMX8MP_CLK_AUDIOMIX_SAI2_MCLK1>、<&clk IMX8MP_CLK_dumme>、
    <&clk IMX8MP_CLK_dumme>、<&clk IMX8MP_AUDIO_PLL1_OUT>、
    时钟名称="bus"、"mclk0"、"mclk1"、"mclk2"、"mclk3"、 "pll8k"、"pll11k";
    FSL、SAI 同步 Rx;
    状态="正常";
    i2c3{(&I)
    tlv320aic34:tlv320aic34@18{
    兼容="ti、tlv320aic3x";
    pinctrl-0 =<&pinctrl_tlv320>;
    reg =<0x18>;
    RESET-GPIO =<&GPIO1 6 GPIO_ACTIVE_LOW>;
    IOVdd-supply =<Registered音频>;/* 3V3 */
    DVDD 电源=<Registered_AUDIO_1v8>;// 1V8 *
    AVDD-SUPPLY =<Registered音频>;/* 3V3 */
    DRVDD-SUPPLY =<Registered音频>;/* 3V3 */
    pinctrl_SAI2:sai2grp{
    FSL、引脚=<
    MX8MP_IOMUXC_SAI2_RXD0_AUDIOMIX_SAI2_RX_DATA00 0xd6
    MX8MP_IOMUXC_SAI2_RXFS_AUDIOMIX_SAI2_RX_SYNC 0xd6
    MX8MP_IOMUXC_SAI2_TXC_AUDIOMIX_SAI2_TX_BCLK 0xd6
    MX8MP_IOMUXC_SAI2_TXD0_AUDIOMIX_SAI2_TX_DATA00 0xd6
    pinctrl_tlv320:tlv320grp{
    FSL、引脚=<
    MX8MP_IOMUXC_GPIO1_IO06_GPIO1_IO06 0x16
    amixer 设置
    简单混频器控制'PCM'、0
    功能:pvolume
    播放频道:左前-右前
    限制:回放0 - 127
    单声道:
    左前:回放100 [79%][-13.50dB]
    右前:回放100 [79%][-13.50dB]
    简单混频器控制'Line'、0
    功能:pvolume psswitch
    播放频道:左前-右前
    限制:回放0 - 9
    单声道:
    左前:回放0 [0%][0.00dB][关闭]
    右前:回放0 [0%][0.00dB][关闭]
    简单混频器控制'Line DAC'、0
    功能:pvolume
    播放频道:左前-右前
    限制:回放0 - 118
    单声道:
    左前:回放0 [0%][-99999.99dB]
    右前:回放0 [0%][-99999.99dB]
    简单混频器控制'Line Line2 Bypwe'、0
    功能:卷
    播放频道:左前-右前
    捕获信道:左前-右前
    限值:0 - 118
    左前:0 [0%][-99999.99dB]
    右前:0 [0%][-99999.99dB]
    简单混频器控制"线路 PGA 旁路"、0
    功能:卷
    播放频道:左前-右前
    捕获信道:左前-右前
    限值:0 - 118
    简单混频器控制"MANO"、0
    功能:pvolume pvolume-joined pswitch pswitch-joined
    回放频道:单声道
    限制:回放0 - 9
    单声道:回放0 [0%][0.00dB][关闭]
    简单混频器控制"ono DAC"、0
    功能:pvolume
    播放频道:左前-右前
    限制:回放0 - 118
    单声道:
    简单混频器控制'ono Line2 Bypo'、0
    功能:卷
    播放频道:左前-右前
    捕获信道:左前-右前
    限值:0 - 118
    简单混频器控制'Mono Mixer DACL1'、0
    功能:pswitch psswitch 已连接
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Mono Mixer DACR1'、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Mono Mixer Line2L Bypo'、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Mono Mixer Line2R Bypo'、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Mono Mixer PGAL Bypo'、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"混频器 PGAR 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'ono PGA Bypo'、0
    功能:卷
    播放频道:左前-右前
    捕获信道:左前-右前
    限值:0 - 118
    简单混频器控制"ADC HPF 切断"、0
    功能:枚举
    项目:"已禁用""0.0045xFs""0.0125xFs""0.025xFs"
    项目0:“已禁用”
    项目1:"已禁用"
    简单混频器控制'AGC'、0
    功能:psswitch
    播放频道:左前-右前
    单声道:
    左前:回放[关闭]
    右前:回放[关闭]
    简单混频器控制"强调"、0
    功能:psswitch
    播放频道:左前-右前
    单声道:
    左前:回放[关闭]
    右前:回放[关闭]
    简单混频器控制'hp'、0
    功能:pvolume psswitch
    播放频道:左前-右前
    限制:回放0 - 9
    单声道:
    左前:回放4 [44%][4.00dB][开]
    右前:回放4 [44%][4.00dB][开]
    简单混频器控制'HP DAC'、0
    功能:pvolume
    播放频道:左前-右前
    限制:回放0 - 118
    单声道:
    左前:回放76 [64%][-21.00dB]
    右前:回放76 [64%][-21.00dB]
    简单混频器控制'HP Line2 Bypwe'、0
    功能:卷
    播放频道:左前-右前
    捕获信道:左前-右前
    限值:0 - 118
    简单混频器控制"HP PGA 旁路"、0
    功能:卷
    播放频道:左前-右前
    捕获信道:左前-右前
    限值:0 - 118
    简单混频器控制'HPCOM'、0
    功能:pvolume psswitch
    播放频道:左前-右前
    限制:回放0 - 9
    单声道:
    简单混频器控制'HPCOM DAC'、0
    功能:pvolume
    播放频道:左前-右前
    限制:回放0 - 118
    单声道:
    简单混频器控制'HPCOM Line2 Bypasse'、0
    功能:卷
    播放频道:左前-右前
    捕获信道:左前-右前
    限值:0 - 118
    简单混频器控制'HPCOM PGA 旁路'、0
    功能:卷
    播放频道:左前-右前
    捕获信道:左前-右前
    限值:0 - 118
    简单混频器控制"左 AGC 攻击时间"、0
    功能:枚举
    项目:'8ms''11ms''16ms''20ms'
    项目0:'8ms'
    简单混频器控制"左 AGC 衰减时间"、0
    功能:枚举
    项目:'100ms''200ms''400ms''500ms'
    项目0:'100ms'
    简单混频器控制"Left AGC Target Level"、0
    功能:枚举
    项目:'-5.5dB''-8dB''-10dB''-12dB''-14dB''-17dB''-20dB''-24dB'
    项目0:'-5.5dB'
    简单混频器控制"左侧 DAC 多路复用器"、0
    功能:枚举
    项目:'DIC_L1''DIC_L3''DIC_L2'
    项目0:'dc_L1'
    简单混频器控制"左侧 HP 混频器 DACL1"、0
    回放频道:单声道
    单声道:回放[ON]
    简单混频器控制"左侧 HP 混频器 DACR1"、0
    回放频道:单声道
    限制:回放0 - 118
    单声道:回放118 [100%][0.00dB][关闭]
    简单混频器控制"左侧 HP 混频器 Line2L 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左侧 HP 混频器 Line2R 旁路"、0
    功能:卷卷连接 pswitch pswitch-joined
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    单声道:118 [100%][0.00dB]播放[关闭]
    简单混频器控制"左 HP 混频器 PGAL 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左 HP 混频器 PGAR 旁路"、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制'Left HPCOM Mixer DACL1'0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Left HPCOM Mixer DACR1'0
    回放频道:单声道
    限制:回放0 - 118
    简单混频器控制'Left HPCom Mixer Line2L Bypwe'、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Left HPCOM Mixer Line2R Bypass、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制'Left HPCOM Mixer PGAL Bypass’、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Left HPCOM Mixer PGAR Bypass、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制'Left HPCOM Mux'、0
    功能:枚举
    项目:" HPLOUT 的输出"恒定 VCM"单端"
    ITem0:' HPLOUT 的电势'
    简单混频器控制"左线混频器 DACL1"0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左线混频器 DACR1"、0
    回放频道:单声道
    限制:回放0 - 118
    简单混频器控制"左线混频器线路2L 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左线混频器线路2R 旁路"、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制"左线混频器 PGAL 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左线混频器 PGAR 旁路"、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制'Left Line1L Mux'、0
    功能:枚举
    项目:"单端""监听"
    ITem0:"单端"
    简单混频器控制'Left Line1R Mux'、0
    功能:枚举
    项目:"单端""监听"
    ITem0:"单端"
    简单混频器控制'Left Line2L Mux'、0
    功能:枚举
    项目:"单端""监听"
    ITem0:"单端"
    简单混频器控制"左 PGA 混频器线路1L"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左 PGA 混频器线路1R"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左 PGA 混频器线路2L"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左 PGA 混频器 Mic3L"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"左 PGA 混频器 Mic3R"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"输出驱动器加电时间"、0
    功能:枚举
    项目:'0us''10us''100us''1ms''10ms''50ms''100ms''200ms''400ms''800ms''2s''4s'
    项目0:'0us'
    简单混频器控制"输出驱动器斜升步进"、0
    功能:枚举
    项目:"0ms""1ms""2ms""4ms"
    项目0:'0ms'
    简单混频器控制'PGA'、0
    功能:cvolume cswitch
    捕获信道:左前-右前
    限制:捕获0 - 119
    左前:采集32 [27%][16.00dB][开]
    右前:采集32 [27%][16.00dB][开]
    简单混频器控制"右 AGC 攻击时间"、0
    功能:枚举
    项目0:'8ms'
    简单混频器控制"右 AGC 衰减时间"、0
    功能:枚举
    项目0:'100ms'
    简单混频器控制"右 AGC 目标电平"、0
    功能:枚举
    项目0:'-5.5dB'
    简单混频器控制"右侧 DAC 多路复用器"、0
    功能:枚举
    项目:'DIC_R1''DIC_R3''DIC_R2'
    项目0:'dc_R1'
    简单混频器控制"右侧 HP 混频器 DACL1"、0
    回放频道:单声道
    限制:回放0 - 118
    简单混频器控制"右侧 HP 混频器 DACR1"、0
    回放频道:单声道
    单声道:回放[ON]
    简单混频器控制"右侧 HP 混频器 Line2L 旁路"、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制"右侧 HP 混频器 Line2R 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"右侧 HP 混频器 PGAL 旁路"、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制"右侧 HP 混频器 PGAR 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Right HPCOM Mixer DACL1'0
    回放频道:单声道
    限制:回放0 - 118
    简单混频器控制'Right HPCOM Mixer DACR1'0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Right HPCom Mixer Line2L Bypwe'、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制'Right HPCom Mixer Line2R Bypass’、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Right HPCOM Mixer PGAL Bypass’、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制'Right HPCOM Mixer PGAR Bypass、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Right HPCOM Mux'、0
    功能:枚举
    项目:'HPROUT'的监听'Constant VCM'的'单端'的监听'HPLCOM'的监听'external feedback'
    ITem0:' HPLCOM 的输出'
    简单混频器控制"右侧线路混频器 DACL1"、0
    回放频道:单声道
    限制:回放0 - 118
    简单混频器控制"右侧线路混频器 DACR1"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"右侧线路混频器线路2L 旁路"、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制"右侧线路混频器线路2R 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"右侧线路混频器 PGAL 旁路"、0
    回放频道:单声道
    捕捉通道:单声道
    限值:0 - 118
    简单混频器控制"右侧线路混频器 PGAR 旁路"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制'Right Line1L Mux'、0
    功能:枚举
    项目:"单端""监听"
    ITem0:"单端"
    简单混频器控制'Right Line1R Mux'、0
    功能:枚举
    项目:"单端""监听"
    ITem0:"单端"
    简单混频器控制'Right Line2R Mux'、0
    功能:枚举
    项目:"单端""监听"
    ITem0:"单端"
    简单混频器控制"右侧 PGA 混频器线路1L"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"右侧 PGA 混频器线路1R"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"右侧 PGA 混频器线路2R"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"右 PGA 混频器 Mic3L"、0
    回放频道:单声道
    单声道:回放[关闭]
    简单混频器控制"右 PGA 混频器 Mic3R"、0
    回放频道:单声道
    单声道:回放[关闭]
    您好、Mathieu、
    很高兴您解决了这个问题、那么您需要在覆盖 编解码器设置的 aplay 中进行哪些更改?
    Peter
    您好 Pdjuandi、
    编解码器必须是从器件而不是主器件,NXP 支持将我指向此配置:
    https://wiki.phytec.com/display/public/MD/L-1008e.A2+phyCORE-i.MX+8M+Plus+Alpha+Kit+Quickstart+Guide
    https://git.phytec.de/linux-imx/tree/arch/arm64/boot/dts/freescale/imx8mp-phyboard-pollux-peb-av-010。
    我把他们的设置和我的设置混合在一起、因为它工作得非常好。
    谢谢您 Mathieu。
