[参考译文] TAS2560:TAS2560 Android 驱动程序
Guru**** 2943400 points
Other Parts Discussed in Thread: TAS2560EVM, TAS2560
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/991318/tas2560-tas2560-android-driver
器件型号:TAS2560
你(们)好。
我正在使用连接到定制板的 TAS2560EVM。 电源、IRQ 和 i2c 通信似乎正常。 我正在使用此处提供的驱动程序 :https://git.ti.com/cgit/tas256xsw-android/tas2560-android-driver/ 、但在尝试使用 tinyplay 时出现以下错误:
tinyplay sdcard/Download/piano2.wav -D 5
[   28.109946] tas2560 3-004c: tas2560_startup
[   28.114288] tas2560 3-004c: tas2560_shutdown
[   28.122316] tas2560 3-004c: tas2560_startup
[   28.126660] tas2560 3-004c: tas2560_hw_params
Playing sample: 2 ch, 48000 hz, 16 bit
[   28.133395] tas2560 3-004c: tas2560_prepare
[   28.137744] tas2560 3-004c: SND_SOC_DAPM_POST_PMU
[   28.142899] tas2560 3-004c: tas2560_mute, 0
[   28.147131] tas2560 3-004c: tas2560_enable power up
[   28.152813] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38
[   28.159704] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39
[   28.166439] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x02
[   28.174097] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
[   28.183292] tas2560 3-004c: tas2560_i2c_load_data, mdelay = 2
[   28.190410] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:108, len: 0x04
[   28.199121] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:40, len: 0x04
[   28.207775] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:44, len: 0x04
[   28.216364] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:48, len: 0x04
[   28.225032] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:28, len: 0x04
[   28.233622] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:32, len: 0x04
[   28.242328] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:36, len: 0x04
[   28.251444] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:24, len: 0x04
[   28.260118] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:100, len: 0x04
[   28.269271] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:52, len: 0x04
[   28.277974] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:56, len: 0x04
[   28.288725] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:60, len: 0x04
[   28.297343] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:64, len: 0x04
[   28.305949] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:68, len: 0x04
[   28.313767] tas2560 3-004c: tas2560_enable skip unmute
[   28.319981] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x0b
[   28.327738] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0xff
[   28.335792] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x40
[   28.342988] tas2560 3-004c: tas2560_enable enableIRQ
[   28.348090] tas2560 3-004c: tas2560_enable enableIRQ OK
[   28.368223] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
[   28.376103] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38
[   28.382990] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39
[   28.389214] tas2560 3-004c: IRQ status : 0x0, 0x0
[   28.394640] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
[   28.400902] tas2560 3-004c: PowSts B: 0x0, check again after 10ms
[   28.430356] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
[   28.436568] tas2560 3-004c: irq_work_routine, Critical ERROR B[0]_P[0]_R[42]= 0x0
[   28.444202] tas2560 3-004c: tas2560_LoadConfig power down to load config
[   28.451892] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
[   28.459782] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x00
[   28.468254] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
[   28.495244] tas2560 3-004c: tas2560_i2c_load_data, msleep = 10
[   28.501594] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x01
[   28.535526] tas2560 3-004c: tas2560_i2c_load_data, msleep = 20
[   28.541881] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x01
[   28.550854] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:1, VAL: 0x01
[   28.572214] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:73, VAL: 0x0c
[   28.579941] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:60, VAL: 0x33
[   28.588069] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:80, VAL: 0x21
[   28.595838] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:35, VAL: 0x41
[   28.603809] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:36, VAL: 0x80
[   28.615162] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:15, VAL: 0x01
[   28.623041] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:16, VAL: 0x20
[   28.631037] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:17, VAL: 0x00
[   28.638807] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:18, VAL: 0x00
[   28.646626] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:8, VAL: 0x01
[   28.654340] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:13, VAL: 0x08
[   28.662155] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:14, VAL: 0x10
[   28.669923] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:9, VAL: 0x9b
[   28.677183] tas2560 3-004c: tas2560_set_ASI_fmt, 16385
[   28.683774] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:24, mask: 0x3e, val=0x2
[   28.693054] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x1c, val=0x0
[   28.702351] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:22, VAL: 0x00
[   28.709636] tas2560 3-004c: tas2560_set_bit_rate, 16
[   28.716283] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x3, val=0x0
[   28.724839] tas2560 3-004c: tas2560_LoadConfig power up
[   28.730476] tas2560 3-004c: tas2560_dev_write, ERROR, L=123, E=-6
[   28.736673] tas2560 3-004c: irq_work_routine, start timer
[   33.763707] tas2560 3-004c: tas2560_dev_write, ERROR, L=123, E=-11
[   33.769907] tas2560 3-004c: tas2560_LoadConfig power down to load config
[   33.776940] tas2560 3-004c: tas2560_dev_write, ERROR, L=123, E=-11
[   33.783179] tas2560 3-004c: irq_work_routine, start timer
[   34.582413] tas2560 3-004c: tas2560_mute, 1
[   34.586638] tas2560 3-004c: tas2560_enable power down
[   34.592123] tas2560 3-004c: tas2560_dev_write, ERROR, L=123, E=-11
[   34.598386] tas2560 3-004c: tas2560_shutdown
[   39.787564] tas2560 3-004c: SND_SOC_DAPM_POST_PMD
我尚未使用您的 PPC3工具创建任何音频 cfg、因为该驱动程序似乎未读取任何配置文件。 这是正确的方法吗?
该错误是否与缺少的配置文件有关?
我应该改用此驱动程序吗?: https://git.ti.com/cgit/tas2557sw-android/tas2559-android-driver/
伊冯·涅托
    大家好、Ivonne、
    我们的团队正在研究此主题、并将尽快做出响应。
    Justin Beigel
    您好 Justin、您对此主题是否有任何反馈?
    目前、我们的电路板未将特定复位 GPIO 连接到 TAS2560EVM (直接连接到 POR)、这是否会影响驱动器的功能?
    伊冯·涅托
    大家好、Ivonne、
    我仍在与我们的固件团队合作研究此问题。 我不会期望重置会成为问题、但在我们处理此问题时、我一定会记住这一点。
    Justin Beigel
    在使用 tinyplay 之前、I2S clk 应已就绪。 TAS2560使用外部 DSP 来运行 spk 保护、因此如果没有 ppc3工具、它可以在 ROM 模式或旁路模式下运行。
    RESET 引脚应始终处于未激活模式。 否则、芯片将无法工作。
    您好、shenghao、复位是引脚处于非激活模式。 我还做了一些返工、现在我将 RESET 引脚连接到 GPIO、并由驱动器正确驱动、但仍会发生严重错误。
    感谢您的指示、我确保 I2S 时钟始终处于启用状态、irq_work_routine, Critical ERROR B[0]_P[0]_R[42]= 0x0但日志已更改、我再也看不到:
    现在日志更大(歌曲始终尝试重现)
    我最终得到:
    Error playing sample
    我注意到、虽然我正在播放6秒的音频、但超时时间在12秒后发生。
    此外、我只有1个 tas2560 IC、我正在使用 Android 单声道驱动程序、但当我尝试重现单声道音频时、我会遇到以下错误:
    Sample is 1 channels, device only supports >= 2 channels
    现在、我已经使用48kHz 速率进行了测试、I2S 时钟设置为1536000Hz。
    附加的是新日志
    e2e.ti.com/.../tas2560.log
    伊冯·涅托
    您好、Ivonne、
    我们将查看您的最新更新、并尽快提供进一步的评论、
    -Ivan Salazar
    应用工程师-低功耗音频和传动器
    你(们)好,Ivonne
    尽管存在单声道应用、但请使用立体声音频文件来播放。 在播放期间、请转储寄存器
    命令
    i2cset -y -f 0 4c 0 0
    i2cset -y -f 0 4c 7f 0
    i2cdump -y -f 0 4c
    PS:
    0是 i2c 总线编号
    4c is 7-bit i2c device address
    很抱歉耽误
    这是打印输出:
    :/ # tinyplay sdcard/Download/pcm_stereo_16_bit_44.1kHz.wav -D 5 &
    [1] 4216
    control4:/ # Playing sample: 2 ch, 44100 hz, 16 bit
    i2cset -y -f 3 0x4c 0x0 0x0
    :/ # i2cset -y -f 3 0x4c 0x7f 0x0
    :/ # i2cset -y -f 3 0x4c 0x0 0x0
    :/ # i2cdump -y -f 3 0x4c
    No size specified (using byte-data access)
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
    00: 00 00 01 20 5f 00 00 00 01 83 02 00 00 08 10 01    ..? _...???..???
    10: 20 00 00 0b 02 00 00 00 02 00 00 00 7f 00 00 00     ..??...?...?...
    20: 00 00 00 00 54 00 00 00 91 00 00 32 03 00 00 00    ....T...?..2?...
    30: 00 00 07 44 00 00 32 10 00 00 00 20 33 0a 00 00    ..?D..2?... 3?..
    40: 00 00 00 00 00 00 00 00 05 0c 00 02 13 00 00 00    ........??.??...
    50: 21 00 00 00 8c 03 01 00 03 06 07 81 00 80 00 00    !...???.????.?..
    60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    70: 00 00 00 00 00 00 00 00 00 60 00 00 07 00 02 00    .........`..?.?.
    80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    b0: 00 00 00 00 00 00 00 00 XX XX XX XX XX XX XX XX    ........XXXXXXXX
    c0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
    d0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
    e0: XX XX XX XX XX XX XX XX XX XX XX XX 00 00 00 00    XXXXXXXXXXXX....
    f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    :/ # Error playing sample
    我想知道、我是否可以检查任何寄存器指南?
    Ivonne
    为什么寄存器2为0x01而不是0x00、这意味着芯片处于断电状态。 您确定芯片已通电吗?
    我手动将寄存器设置为0、并尝试播放音频。 日志显示了相同的情况、最后我转储寄存器、它返回到1。
    这是当我尝试使用 tinymix 开机时出现的错误:
    :/ # tinymix -D 5 'TAS2560 PowerCtrl' 1
    [  241.552601] tas2560 3-004c: tas2560_power_ctrl_get = 0x0
    [  241.557963] tas2560 3-004c: tas2560_enable power up
    [  241.563597] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38
    [  241.570429] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39
    [  241.577129] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x02
    [  241.584762] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
    [  241.593914] tas2560 3-004c: tas2560_i2c_load_data, mdelay = 2
    [  241.607254] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:108, len: 0x04
    [  241.615895] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:40, len: 0x04
    [  241.624384] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:44, len: 0x04
    [  241.632928] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:48, len: 0x04
    [  241.641477] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:28, len: 0x04
    [  241.650021] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:32, len: 0x04
    [  241.658570] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:36, len: 0x04
    [  241.667598] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:24, len: 0x04
    [  241.676149] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:100, len: 0x04
    [  241.685264] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:52, len: 0x04
    [  241.693815] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:56, len: 0x04
    [  241.702358] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:60, len: 0x04
    [  241.710909] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:64, len: 0x04
    [  241.719452] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:68, len: 0x04
    [  241.727211] tas2560 3-004c: tas2560_enable unmute
    [  241.732924] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x0b
    [  241.740647] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0xff
    [  241.748366] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x40
    [  241.755516] tas2560 3-004c: tas2560_enable enableIRQ
    [  241.760505] tas2560 3-004c: tas2560_enable enableIRQ OK
    control4:/ # [  241.776257] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
    [  241.784184] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38
    [  241.790979] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39
    [  241.797188] tas2560 3-004c: IRQ status : 0x0, 0x0
    [  241.802513] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
    [  241.808718] tas2560 3-004c: PowSts B: 0x0, check again after 10ms
    [  241.838791] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
    [  241.844985] tas2560 3-004c: irq_work_routine, Critical ERROR B[0]_P[0]_R[42]= 0x0
    [  241.852578] tas2560 3-004c: tas2560_LoadConfig power down to load config
    [  241.859792] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
    [  241.867508] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x00
    [  241.875234] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
    [  241.899716] tas2560 3-004c: tas2560_i2c_load_data, msleep = 10
    [  241.906047] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x01
    [  241.939996] tas2560 3-004c: tas2560_i2c_load_data, msleep = 20
    [  241.946327] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x01
    [  241.981428] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:1, VAL: 0x01
    [  242.000203] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:73, VAL: 0x0c
    [  242.007967] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:60, VAL: 0x33
    [  242.015682] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:80, VAL: 0x21
    [  242.023405] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:35, VAL: 0x41
    [  242.031121] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:36, VAL: 0x80
    [  242.038843] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:15, VAL: 0x01
    [  242.046560] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:16, VAL: 0x20
    [  242.054282] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:17, VAL: 0x00
    [  242.061998] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:18, VAL: 0x00
    [  242.069720] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:8, VAL: 0x01
    [  242.077349] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:13, VAL: 0x08
    [  242.085072] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:14, VAL: 0x10
    [  242.092788] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:9, VAL: 0x9b
    [  242.099939] tas2560 3-004c: tas2560_set_ASI_fmt, 16385
    [  242.106172] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:24, mask: 0x3e, val=0x2
    [  242.115402] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x1c, val=0x0
    [  242.124507] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:22, VAL: 0x00
    [  242.131743] tas2560 3-004c: tas2560_set_bit_rate, 16
    [  242.137799] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x3, val=0x0
    [  242.146338] tas2560 3-004c: tas2560_LoadConfig power up
    [  242.152046] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x02
    [  242.159673] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
    [  242.168824] tas2560 3-004c: tas2560_i2c_load_data, mdelay = 2
    [  242.175873] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:108, len: 0x04
    [  242.184496] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:40, len: 0x04
    [  242.193039] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:44, len: 0x04
    [  242.201574] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:48, len: 0x04
    [  242.210116] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:28, len: 0x04
    [  242.218654] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:32, len: 0x04
    [  242.227195] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:36, len: 0x04
    [  242.236229] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:24, len: 0x04
    [  242.244766] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:100, len: 0x04
    [  242.253880] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:52, len: 0x04
    [  242.262415] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:56, len: 0x04
    [  242.270958] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:60, len: 0x04
    [  242.279494] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:64, len: 0x04
    [  242.288038] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:68, len: 0x04
    [  242.296758] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x0b
    [  242.304480] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0xff
    [  242.312196] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x40
    [  242.319349] tas2560 3-004c: irq_work_routine, start timer
    [  242.332206] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
    [  242.340092] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38
    [  242.346886] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39
    [  242.353082] tas2560 3-004c: IRQ status : 0x0, 0x0
    [  242.358396] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
    [  242.364592] tas2560 3-004c: PowSts B: 0x0, check again after 10ms
    [  242.388603] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
    [  242.394793] tas2560 3-004c: irq_work_routine, Critical ERROR B[0]_P[0]_R[42]= 0x0
    [  242.402354] tas2560 3-004c: tas2560_LoadConfig power down to load config
    [  242.409551] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
    [  242.417272] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x00
    [  242.424988] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
    [  242.451995] tas2560 3-004c: tas2560_i2c_load_data, msleep = 10
    [  242.458324] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x01
    [  242.491976] tas2560 3-004c: tas2560_i2c_load_data, msleep = 20
    [  242.498306] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x01
    [  242.537639] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:1, VAL: 0x01
    [  242.562385] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:73, VAL: 0x0c
    [  242.570110] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:60, VAL: 0x33
    [  242.577833] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:80, VAL: 0x21
    [  242.585549] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:35, VAL: 0x41
    [  242.593271] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:36, VAL: 0x80
    [  242.600987] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:15, VAL: 0x01
    [  242.608709] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:16, VAL: 0x20
    [  242.616425] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:17, VAL: 0x00
    [  242.624146] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:18, VAL: 0x00
    [  242.631870] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:8, VAL: 0x01
    [  242.639499] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:13, VAL: 0x08
    [  242.647220] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:14, VAL: 0x10
    [  242.654936] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:9, VAL: 0x9b
    [  242.662087] tas2560 3-004c: tas2560_set_ASI_fmt, 16385
    [  242.668373] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:24, mask: 0x3e, val=0x2
    [  242.677610] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x1c, val=0x0
    [  242.686722] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:22, VAL: 0x00
    [  242.693957] tas2560 3-004c: tas2560_set_bit_rate, 16
    [  242.700042] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x3, val=0x0
    [  242.708576] tas2560 3-004c: tas2560_LoadConfig power up
    [  242.714356] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x02
    [  242.721985] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
    [  242.731136] tas2560 3-004c: tas2560_i2c_load_data, mdelay = 2
    [  242.738156] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:108, len: 0x04
    [  242.746782] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:40, len: 0x04
    [  242.755318] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:44, len: 0x04
    [  242.763859] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:48, len: 0x04
    [  242.772376] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:28, len: 0x04
    [  242.780912] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:32, len: 0x04
    [  242.789455] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:36, len: 0x04
    [  242.798474] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:24, len: 0x04
    [  242.807017] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:100, len: 0x04
    [  242.816169] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:52, len: 0x04
    [  242.824705] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:56, len: 0x04
    [  242.833247] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:60, len: 0x04
    [  242.841791] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:64, len: 0x04
    [  242.850340] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:68, len: 0x04
    [  242.859068] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x0b
    [  242.866790] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0xff
    [  242.874506] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x40
    [  242.881660] tas2560 3-004c: irq_work_routine, start timer
    [  242.896202] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
    [  242.904089] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38
    [  242.910883] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39
    [  242.917079] tas2560 3-004c: IRQ status : 0x0, 0x0
    [  242.922475] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
    [  242.928666] tas2560 3-004c: PowSts B: 0x0, check again after 10ms
    [  242.958806] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
    [  242.965006] tas2560 3-004c: irq_work_routine, Critical ERROR B[0]_P[0]_R[42]= 0x0
    [  242.972571] tas2560 3-004c: tas2560_LoadConfig power down to load config
    [  242.979773] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
    [  242.987489] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x00
    [  242.995210] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
    [  243.019715] tas2560 3-004c: tas2560_i2c_load_data, msleep = 10
    [  243.026045] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x01
    [  243.059978] tas2560 3-004c: tas2560_i2c_load_data, msleep = 20
    [  243.066308] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x01
    [  243.110770] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:1, VAL: 0x01
    [  243.128204] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:73, VAL: 0x0c
    [  243.136042] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:60, VAL: 0x33
    [  243.143776] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:80, VAL: 0x21
    [  243.151491] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:35, VAL: 0x41
    [  243.159213] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:36, VAL: 0x80
    [  243.166930] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:15, VAL: 0x01
    [  243.174653] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:16, VAL: 0x20
    [  243.182368] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:17, VAL: 0x00
    [  243.190091] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:18, VAL: 0x00
    [  243.197807] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:8, VAL: 0x01
    [  243.205441] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:13, VAL: 0x08
    [  243.213158] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:14, VAL: 0x10
    [  243.220880] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:9, VAL: 0x9b
    [  243.228026] tas2560 3-004c: tas2560_set_ASI_fmt, 16385
    [  243.234324] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:24, mask: 0x3e, val=0x2
    [  243.243549] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x1c, val=0x0
    [  243.252661] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:22, VAL: 0x00
    [  243.259893] tas2560 3-004c: tas2560_set_bit_rate, 16
    [  243.266022] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x3, val=0x0
    [  243.274557] tas2560 3-004c: tas2560_LoadConfig power up
    [  243.280339] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x02
    [  243.287971] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
    [  243.297117] tas2560 3-004c: tas2560_i2c_load_data, mdelay = 2
    [  243.304171] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:108, len: 0x04
    [  243.312794] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:40, len: 0x04
    [  243.321336] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:44, len: 0x04
    [  243.329872] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:48, len: 0x04
    [  243.338414] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:28, len: 0x04
    [  243.346949] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:32, len: 0x04
    [  243.355490] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:50:36, len: 0x04
    [  243.364559] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:24, len: 0x04
    [  243.373097] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:51:100, len: 0x04
    [  243.382208] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:52, len: 0x04
    [  243.390744] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:56, len: 0x04
    [  243.399288] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:60, len: 0x04
    [  243.407870] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:64, len: 0x04
    [  243.416375] tas2560 3-004c: tas2560_dev_bulk_write: BOOK:PAGE:REG 0:52:68, len: 0x04
    [  243.425094] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x0b
    [  243.432815] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0xff
    [  243.440531] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x40
    [  243.447683] tas2560 3-004c: irq_work_routine, start timer
    [  243.464682] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
    [  243.472519] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:38
    [  243.479320] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:39
    [  243.485512] tas2560 3-004c: IRQ status : 0x0, 0x0
    [  243.490891] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
    [  243.497082] tas2560 3-004c: PowSts B: 0x0, check again after 10ms
    [  243.526778] tas2560 3-004c: tas2560_dev_read: BOOK:PAGE:REG 0:0:42
    [  243.532978] tas2560 3-004c: irq_work_routine, Critical ERROR B[0]_P[0]_R[42]= 0x0
    [  243.540539] tas2560 3-004c: tas2560_LoadConfig power down to load config
    [  243.547771] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:37, VAL: 0x00
    [  243.555487] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:33, VAL: 0x00
    [  243.563208] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x41
    [  243.587716] tas2560 3-004c: tas2560_i2c_load_data, msleep = 10
    [  243.594048] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:7, VAL: 0x01
    [  243.627981] tas2560 3-004c: tas2560_i2c_load_data, msleep = 20
    [  243.634311] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x01
    ^C
    130|control4:/ # [  243.670814] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:1, VAL: 0x01
    [  243.688467] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:73, VAL: 0x0c
    [  243.698612] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:60, VAL: 0x33
    [  243.706338] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:80, VAL: 0x21
    [  243.714061] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:35, VAL: 0x41
    [  243.721777] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:36, VAL: 0x80
    [  243.729500] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:15, VAL: 0x01
    [  243.737217] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:16, VAL: 0x20
    [  243.744940] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:17, VAL: 0x00
    [  243.752656] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:18, VAL: 0x00
    [  243.760378] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:8, VAL: 0x01
    [  243.768113] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:13, VAL: 0x08
    [  243.775874] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:14, VAL: 0x10
    [  243.783590] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:9, VAL: 0x9b
    [  243.790741] tas2560 3-004c: tas2560_set_ASI_fmt, 16385
    [  243.796977] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:24, mask: 0x3e, val=0x2
    [  243.806207] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x1c, val=0x0
    [  243.815310] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:22, VAL: 0x00
    [  243.822547] tas2560 3-004c: tas2560_set_bit_rate, 16
    [  243.829024] tas2560 3-004c: tas2560_dev_update_bits: BOOK:PAGE:REG 0:0:20, mask: 0x3, val=0x0
    [  243.837567] tas2560 3-004c: tas2560_LoadConfig power up
    [  243.843368] tas2560 3-004c: tas2560_dev_write: BOOK:PAGE:REG 0:0:2, VAL: 0x02
    我不知道这些寄存器、是否有任何文档可以查看它们?
    伊冯·涅托
    从日志中可以看到所有控制流和寄存器设置都很好。
    从寄存器转储中、为什么 b0p0r7bit[7:6]仍然为0、这意味着芯片断电、
    当日志告诉我它设置为0x40时、请参阅以下引述。
    [引用 userid="482929" URL"~/support/audio/f/audio-forum/991318/tas2560-tas2560-android-driver/3686235 #3686235"][243.440531] tas2560 3-004C:tas2560_dev_write:book:page:REG 0:0:7、VAL:0x40
    b0p0r0X2D 为0、您确定 Vbat 连接正常吗? 请参阅附件。
    你(们)好。
    很抱歉、我的回复很晚、我看到 Vbat 为5V、J2已连接。
    从上一封邮件中:
    [引用 userid="460493" URL"~/support/audio-group/audio/f/audio-forum/991318/tas2560-tas2560-android-driver/3687655 #3687655 "]
    [/报价]
    我意识到任何 i2c 配置都适用、但如果我使用 i2set 手动写入、就会适用。
    我将调试设置寄存器的驱动程序部分、并使用可能发现 的任何结果进行更新。
    伊冯·涅托
    请检查 I2S clk (bck 和 WS clk)在上电期间是否稳定
    你(们)好。
    我仔细检查我的 i2c 通信、一切都好。
    此外、Vbatt 连接到5V、IOVdd (J30)连接到3.3V。
    我尝试使用和不使用升压功能为器件加电、并重新生成不支持电池保护、欠压和 H 类的模式2 96k 但仍然不幸运。
    我将按照建议彻底检查 I2S 信号。
    伊冯·涅托
    您好、Ivonne、
    请告诉我们您对 I2S 的发现、我们将继续研究此主题。
    -Ivan Salazar
    应用工程师-低功耗音频和传动器
    大家好、Ivan、我确实对以稳定的方式启用 I2S 有问题。
    我们目前正在研究这个问题
    您好、Ivonne、
    感谢您提供的详细信息、让我们知道测试是如何进行的。
    -Ivan Salazar
    应用工程师-低功耗音频和传动器
    很抱歉、由于其他一些优先事项、我们的回复延迟了。 我们无法使 i2c 时钟信号正常工作、这可能是由于某些硬件返工。 不过、我们已经讨论过、客户希望继续使用 TI 系列中的另一个 IC。
    感谢你的所有帮助。 我认为您可以将此主题标记为已关闭、因为我们将不再使用此特定 IC。
    大家好、Ivonne、感谢大家注意到、只是出于完整性考虑、他们是否转向模拟输入放大器?
    -Ivan Salazar
    应用工程师-低功耗音频和传动器
    另一个数字输入 D 类放大器
    明白了、感谢您的输入、我现在要关闭此主题。
    -Ivan Salazar
    应用工程师-低功耗音频和传动器
