[参考译文] TAS2780:我遇到错误、但不知道如何解决
Guru**** 2989100 points
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/1260831/tas2780-i-encountered-an-error-but-do-not-know-how-to-solve-it
器件型号:TAS2780
从错误日志来看、问题似乎是 i2c。但是、i2c 下面的其它外设可以正常通信
    请确保硬件连接正常。 然后使用以下命令:
    i2cdump -y -f 0 0x38
    0 is i2c bus no
    0x38 is 7-bit i2c device address
    One more thing, what the 7-bit i2c address on your device? It seemed 0x70, this address is so strange,
    kindly check the datasheet and hardware engineer.
