[参考译文] CC2340R5:在我的构建结束时发送 strage 信息消息
Guru**** 2933120 points
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1505732/cc2340r5-strage-info-message-at-the-end-of-my-build
器件型号:CC2340R5
主题:SysConfig 中讨论的其他器件
在构建过程结束时、我收到以下消息(蓝色)
[203]生成目标:"MyProject.out"
[204]调用:ARM 链接器
[C:xml"/ti/ccs2011/ccs/tools/compiler/ti-cgt-armllvm_4.0.2.LTS/bin/tiarmclang.exe @"C:/ti/simplelink_lowpower_f3_sdk_8_40_02_01/source/ti/ble5stack_flash/config/build_components.opt xml"@"C:xml" "C:/ti/simplelink_lowpower_f3_sdk_8_40_02_01/source/ti/ble5stack_flash/config/factory_config.opt /ti/simplelink_lowpower_f3_sdk_8_40_02_01/source /ti/ccs2011/ccs/tools/compiler/ti-cgt-armllvm_4.0.2.LTS/lib /syscfg/ti_radio_config.o -March=thumbv6m -MCpu=cortex-m0plus -mfloat-abi=soft -mlittle-endian /Dev/ClockProjector/CC2340RX/FW/MyProject/Debug/syscfg /syscfg/ti_ble_config.o /syscfg/ti_devices_config.o /syscfg/ti_drivers_config.o /syscfg/ti_freertos_config.o /syscfg/ti_freertos_portable_config.o /app/Profiles/app_dev_info.o /app/Profiles/app_simple_gatt.o /app/app_broadcaster.o /app/app_central.o /app/app_connection.o /app/app_data.o /app/app_discovery.o /app/app_l2cap_coc.o /app/app_main.o /app/app_menu.o /app/app_observer.o /app/app_pairing.o /app/app_peripheral.o /app/app_snv.o /app/main_thread.o /common/BLEAppUtil/bleapputil_init.o /common/BLEAppUtil/bleapputil_process.o /common/BLEAppUtil/bleapputil_stack_callbacks.o /common/BLEAppUtil/bleapputil_task.o /common/Drivers/NV/crc.o /common/Drivers/NV/nvocmp.o /common/MenuModule/menu_module.o /common/Profiles/simple_gatt/simple_gatt_profile.o /common/Services/dev_info/dev_info_service.o /common/Startup/ble_user_config_stack.o /common/Startup/osal_icall_ble.o /common/Startup/rom_init.o /common/iCall/icall_POSIX.o /common/iCall/icall_cc23x0.o /common/iCall/icall_user_config.o /common/iCallBLE/ble_stack_api.o /common/iCallBLE/ble_user_config.o /common/iCallBLE/icall_api_lite.o
[206]已完成的建筑目标:"我的项目。
[207]C:/ti/simplelink_lowpower_f3_sdk_8_40_02_01/tools/common/crc_tool/crc_tool patch-image --elf MyProject.out -symbol-prefix ti_utils_build_GenMap_sym_crc_CCFG -o MyProject.out
[208]C:/ti/ccs2011/ccs/tools/compiler/ti-cgt-armllvm_4.0.2.LTS/bin/tiarmobjcopy -O ihex MyProject.out MyProject.hex
[209]info:root:迭代符号、查找前缀:TI_UTILS_BUILD_GenMap_SYM_CRC_CCFG
[210]INFO:ROOT:为具有 STEM 的变量对插入 CRC 部分:TI_UTILS_BUILD_GENMAP_SYM_CRC_CCFG_BOOT_CFG =(0x4e020000、0x4e02000b)
[211]INFO:ROOT:根据[0x4e020000、0x4e02000b]范围中的数据更新 CRC32字段@地址0x4e02000c。 值从0x00000000更改为0xffffffff
[212]INFO:ROOT:为具有 STEM 的变量对插入 CRC 部分:TI_UTILS_BUILD_GenMap_SYM_CRC_CCFG =(0x4e020010、0x4e02074b)
[213]INFO:ROOT:根据[0x4e020010、0x4e02074b]范围中的数据更新 CRC32字段@地址0x4e02074c。 值从0x00000000更改为0xb714dfb7
[214]INFO:root:为具有 STEM 的变量对插入 CRC 段:TI_UTILS_BUILD_GENMAP_SYM_CRC_CCFG_USER_RECORD =(0x4e020750、0x4e0207cb)
[215]INFO:ROOT:根据[0x4e020750、0x4e0207cb]范围中的数据更新 CRC32字段@地址0x4e0207cc。 值从0x00000000更改为0x15d70e0c
[216]INFO:root:为具有 STEM 的变量对插入 CRC 段:TI_UTILS_BUILD_GENMAP_SYM_CRC_CCFG_DEBUG =(0x4e0207d0、0x4e0207fb)
[217]INFO:ROOT:根据[0x4e0207d0、0x4e0207fb]范围中的数据更新 CRC32字段@地址0x4e0207fc。 值从0x00000000变为0x627294a2
[218]INFO:root:将经过修补的 ELF 文件写入 MyProject.out
[219]*****构建完成****
我在 Windows 10上使用以下内容:
CCS 版本:20.1.1.8__1.7.1
默认 VS Code API:1.92.2
simplelinkke 低功耗 SDK 8.40.2.01
SysConfig 1.23.1
TIClang v4.0.2LTS
蓝色可能是因为它是一个蓝牙相关的,但我应该小心吗?  我该怎么办呢?
    您好:
    感谢您联系我们! 我们将查看您的问题并尽快回复您。
    Tarek
    您好、
    感谢您联系我们! 末尾的蓝字体是由于这些控制台日志中包含了信息标签。 这是正常现象、因为这是提供给 CRC 脚本输出的标签。 这不是警告、所有低功耗蓝牙工程都应该在成功构建后显示该警告。
    1月
