[参考译文] CC2745R10-Q1:LL_PHY_REQ 传输期间可能收到的错误
Guru**** 2930520 points
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1529111/cc2745r10-q1-errors-that-may-be-received-during-ll_phy_req-transmission
器件型号:CC2745R10-Q1
Hello,
After receiving LL_CHANNEL_MAP_IND, I sent LL_PHY_REQ 500ms later, and I encountered the error HCI_ERROR_CODE_DIFFERENT_TRANSACTION_COLLISION as defined in ti\simplelink_lowpower_f3_sdk_8_30_00_11_ea\source\ti\ble5stack_flash\inc\hci.h under HCI_Error_Codes.
If possible, could you please let me know which HCI_Error_Codes may occur during the transmission of LL_PHY_REQ?LL_PHY_REQ
