[参考译文] CC2640R2F:如何将传感器控制器 ADC_LEVEL_TRIGGER 示例与 simple_peripheral 合并? (分步指南)
Guru**** 2858700 points
Other Parts Discussed in Thread: CC2640R2F
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1133663/cc2640r2f-how-to-merge-a-sensor-controller-adc_level_trigger-example-with-simple_peripheral-step-by-step-guide
器件型号:CC2640R2F
    您好、Sai、
    请问您是否已尝试使用所需的传感器控制器示例遵循链接线程中提供的指导?
    您能否指定您要阻止的步骤? 确保包括问题说明、如果相关、请提供有关错误的详细信息。
    最后但同样重要的是、请确保指定您正在使用的 SDK 版本和使用的堆栈(BLEStack 或 BLE5STACK)。
    感谢您的回复。
    SDK 版本:5.30.00.03
    ble5stack
    是的、我使用传感器控制器示例尝试了链接线程中提供的指导、并成功获得闪烁 LED 示例的输出。 我需要定期读取 ADC。
    因此、我为 https://dev.ti.com/tirex/explore/node?node=ADLsixZlQbUmRcaDRv27gQ__krol.2c__LATEST 中给出的 ADC 级触发器示例生成了 SC 代码
    我创建了新的服务和字符来读取16位 ADC 值。
    SC 集成到 CCS 代码中,成功构建并上载,没有错误。 阈值的 LED 操作正常、但无法读取正确的 ADC 值。
    我附加了 simpleperipheral.c 的以下代码
     @file  simple_peripheral.c
     @brief This file contains the Simple Peripheral sample application for use
            with the CC2650 Bluetooth Low Energy Protocol Stack.
     Group: WCS, BTS
     Target Device: cc2640r2
     Copyright (c) 2013-2021, Texas Instruments Incorporated
     All rights reserved.
     Redistribution and use in source and binary forms, with or without
     modification, are permitted provided that the following conditions
     are met:
     *  Redistributions of source code must retain the above copyright
        notice, this list of conditions and the following disclaimer.
     *  Redistributions in binary form must reproduce the above copyright
        notice, this list of conditions and the following disclaimer in the
        documentation and/or other materials provided with the distribution.
     *  Neither the name of Texas Instruments Incorporated nor the names of
        its contributors may be used to endorse or promote products derived
        from this software without specific prior written permission.
     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     * INCLUDES
    #include "scif.h"
    #include "myData.h"
    #include "myData1.h"
    #include <string.h>
    #include <ti/sysbios/knl/Task.h>
    #include <ti/sysbios/knl/Clock.h>
    #include <ti/sysbios/knl/Event.h>
    #include <ti/sysbios/knl/Queue.h>
    #include <ti/display/Display.h>
    #if !(defined __TI_COMPILER_VERSION__)
    #include <intrinsics.h>
    #endif
    #include <ti/drivers/utils/List.h>
    #include <icall.h>
    #include "util.h"
    #include <bcomdef.h>
    /* This Header file contains all BLE API and icall structure definition */
    #include <icall_ble_api.h>
    #include <devinfoservice.h>
    #include <simple_gatt_profile.h>
    #ifdef USE_RCOSC
    #include <rcosc_calibration.h>
    #endif //USE_RCOSC
    #include <board.h>
    #include <board_key.h>
    #include <menu/two_btn_menu.h>
    #include "simple_peripheral_menu.h"
    #include "simple_peripheral.h"
    #ifdef PTM_MODE
    #include "npi_task.h"              // To allow RX event registration
    #include "npi_ble.h"               // To enable transmission of messages to UART
    #include "icall_hci_tl.h"          // To allow ICall HCI Transport Layer
    #endif // PTM_MODE
     * MACROS
     * CONSTANTS
    // Address mode of the local device
    // Note: When using the DEFAULT_ADDRESS_MODE as ADDRMODE_RANDOM or
    // ADDRMODE_RP_WITH_RANDOM_ID, GAP_DeviceInit() should be called with
    // it's last parameter set to a static random address
    //extern uint32_t myData;
     //extern uint32_t myData1;
    uint16_t myData;
    uint16_t myData1;
    #define BV(x)    (1 << (x))
    #define DEFAULT_ADDRESS_MODE                  ADDRMODE_PUBLIC
    // General discoverable mode: advertise indefinitely
    #define DEFAULT_DISCOVERABLE_MODE             GAP_ADTYPE_FLAGS_GENERAL
    // Minimum connection interval (units of 1.25ms, 80=100ms) for parameter update request
    #define DEFAULT_DESIRED_MIN_CONN_INTERVAL     80
    // Maximum connection interval (units of 1.25ms, 104=130ms) for  parameter update request
    #define DEFAULT_DESIRED_MAX_CONN_INTERVAL     104
    // Slave latency to use for parameter update request
    #define DEFAULT_DESIRED_SLAVE_LATENCY         0
    // Supervision timeout value (units of 10ms, 300=3s) for parameter update request
    #define DEFAULT_DESIRED_CONN_TIMEOUT          300
    // Pass parameter updates to the app for it to decide.
    #define DEFAULT_PARAM_UPDATE_REQ_DECISION     GAP_UPDATE_REQ_PASS_TO_APP
    // How often to perform periodic event (in ms)
    #define SP_PERIODIC_EVT_PERIOD               5000
    // How often to read current current RPA (in ms)
    #define SP_READ_RPA_EVT_PERIOD               3000
    // Delay (in ms) after connection establishment before sending a parameter update requst
    #define SP_SEND_PARAM_UPDATE_DELAY           6000
    // Task configuration
    #define SP_TASK_PRIORITY                     1
    #ifndef SP_TASK_STACK_SIZE
    #define SP_TASK_STACK_SIZE                   644
    #endif
    // Application events
    #define SP_STATE_CHANGE_EVT                  0
    #define SP_CHAR_CHANGE_EVT                   1
    #define SP_KEY_CHANGE_EVT                    2
    #define SP_ADV_EVT                           3
    #define SP_PAIR_STATE_EVT                    4
    #define SP_PASSCODE_EVT                      5
    #define SP_PERIODIC_EVT                      6
    #define SP_READ_RPA_EVT                      7
    #define SP_SEND_PARAM_UPDATE_EVT             8
    #define SP_CONN_EVT                          9
    #define APP_MSG_SC_TASK_ALERT                0x0099
    // Internal Events for RTOS application
    #define SP_ICALL_EVT                         ICALL_MSG_EVENT_ID // Event_Id_31
    #define SP_QUEUE_EVT                         UTIL_QUEUE_EVENT_ID // Event_Id_30
    // Bitwise OR of all RTOS events to pend on
    #define SP_ALL_EVENTS                        (SP_ICALL_EVT             | \
                                                  SP_QUEUE_EVT)
    // Size of string-converted device address ("0xXXXXXXXXXXXX")
    #define SP_ADDR_STR_SIZE     15
    // Row numbers for two-button menu
    #define SP_ROW_SEPARATOR_1   (TBM_ROW_APP + 0)
    #define SP_ROW_STATUS_1      (TBM_ROW_APP + 1)
    #define SP_ROW_STATUS_2      (TBM_ROW_APP + 2)
    #define SP_ROW_CONNECTION    (TBM_ROW_APP + 3)
    #define SP_ROW_ADVSTATE      (TBM_ROW_APP + 4)
    #define SP_ROW_RSSI          (TBM_ROW_APP + 5)
    #define SP_ROW_IDA           (TBM_ROW_APP + 6)
    #define SP_ROW_RPA           (TBM_ROW_APP + 7)
    #define SP_ROW_DEBUG         (TBM_ROW_APP + 8)
    // For storing the active connections
    #define SP_RSSI_TRACK_CHNLS        1            // Max possible channels can be GAP_BONDINGS_MAX
    #define SP_MAX_RSSI_STORE_DEPTH    5
    #define SP_INVALID_HANDLE          0xFFFF
    #define RSSI_2M_THRSHLD           -30
    #define RSSI_1M_THRSHLD           -40
    #define RSSI_S2_THRSHLD           -50
    #define RSSI_S8_THRSHLD           -60
    #define SP_PHY_NONE                LL_PHY_NONE  // No PHY set
    #define AUTO_PHY_UPDATE            0xFF
    // Spin if the expression is not true
    #define SIMPLEPERIPHERAL_ASSERT(expr) if (!(expr)) simple_peripheral_spin();
     * TYPEDEFS
    // App event passed from stack modules. This type is defined by the application
    // since it can queue events to itself however it wants.
    /*typedef struct
         APP_MSG_SC_CTRL_READY ;
         APP_MSG_SC_TASK_ALERT;
    } app_msg_types_t;*/
    typedef struct
      uint8_t event;                // event type
      void    *pData;               // pointer to message
    } spEvt_t;
    // Container to store passcode data when passing from gapbondmgr callback
    // to app event. See the pfnPairStateCB_t documentation from the gapbondmgr.h
    // header file for more information on each parameter.
    typedef struct
      uint8_t state;
      uint16_t connHandle;
      uint8_t status;
    } spPairStateData_t;
    // to app event. See the pfnPasscodeCB_t documentation from the gapbondmgr.h
    typedef struct
      uint8_t deviceAddr[B_ADDR_LEN];
      uint8_t uiInputs;
      uint8_t uiOutputs;
      uint32_t numComparison;
    } spPasscodeData_t;
    // Container to store advertising event data when passing from advertising
    // callback to app event. See the respective event in GapAdvScan_Event_IDs
    // in gap_advertiser.h for the type that pBuf should be cast to.
    typedef struct
      uint32_t event;
      void *pBuf;
    } spGapAdvEventData_t;
    // Container to store information from clock expiration using a flexible array
    // since data is not always needed
    typedef struct
      uint8_t event;                //
      uint8_t data[];
    } spClockEventData_t;
    // List element for parameter update and PHY command status lists
    typedef struct
      List_Elem elem;
    } spConnHandleEntry_t;
    // Connected device information
    typedef struct
      uint16_t         	    connHandle;                        // Connection Handle
      spClockEventData_t*   pParamUpdateEventData;
      Clock_Struct*    	    pUpdateClock;                      // pointer to clock struct
      int8_t           	    rssiArr[SP_MAX_RSSI_STORE_DEPTH];
      uint8_t          	    rssiCntr;
      int8_t           	    rssiAvg;
      bool             	    phyCngRq;                          // Set to true if PHY change request is in progress
      uint8_t          	    currPhy;
      uint8_t          	    rqPhy;
      uint8_t          	    phyRqFailCnt;                      // PHY change request count
      bool             	    isAutoPHYEnable;                   // Flag to indicate auto phy change
    } spConnRec_t;
     * GLOBAL VARIABLES
    // Display Interface
    Display_Handle dispHandle = NULL;
    Task_Struct spTask;
    #if defined __TI_COMPILER_VERSION__
    #pragma DATA_ALIGN(spTaskStack, 8)
    #else
    #pragma data_alignment=8
    #endif
    uint8_t spTaskStack[SP_TASK_STACK_SIZE];
     * LOCAL VARIABLES
    // Entity ID globally used to check for source and/or destination of messages
    static ICall_EntityID selfEntity;
    // Event globally used to post local events and pend on system and
    // local events.
    static ICall_SyncHandle syncEvent;
    // Queue object used for app messages
    static Queue_Struct appMsgQueue;
    static Queue_Handle appMsgQueueHandle;
    // Clock instance for internal periodic events. Only one is needed since
    // GattServApp will handle notifying all connected GATT clients
    static Clock_Struct clkPeriodic;
    // Clock instance for RPA read events.
    static Clock_Struct clkRpaRead;
    // Memory to pass periodic event ID to clock handler
    spClockEventData_t argPeriodic =
    { .event = SP_PERIODIC_EVT };
    // Memory to pass RPA read event ID to clock handler
    spClockEventData_t argRpaRead =
    { .event = SP_READ_RPA_EVT };
    // Per-handle connection info
    static spConnRec_t connList[MAX_NUM_BLE_CONNS];
    // Current connection handle as chosen by menu
    static uint16_t menuConnHandle = CONNHANDLE_INVALID;
    // List to store connection handles for set phy command status's
    static List_List setPhyCommStatList;
    // List to store connection handles for queued param updates
    static List_List paramUpdateList;
    // GAP GATT Attributes
    static uint8_t attDeviceName[GAP_DEVICE_NAME_LEN] = "Simple Peripheral";
    // Advertisement data
    static uint8_t advertData[] =
      0x02,   // length of this data
      GAP_ADTYPE_FLAGS,
      DEFAULT_DISCOVERABLE_MODE | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED,
      // service UUID, to notify central devices what services are included
      // in this peripheral
      0x03,   // length of this data
      GAP_ADTYPE_16BIT_MORE,      // some of the UUID's, but not all
      LO_UINT16(SIMPLEPROFILE_SERV_UUID),
      HI_UINT16(SIMPLEPROFILE_SERV_UUID)
    // Scan Response Data
    static uint8_t scanRspData[] =
      // complete name
      17,   // length of this data
      GAP_ADTYPE_LOCAL_NAME_COMPLETE,
      'S',
      'i',
      'm',
      'p',
      'l',
      'e',
      'P',
      'e',
      'r',
      'i',
      'p',
      'h',
      'e',
      'r',
      'a',
      'l',
      // connection interval range
      5,   // length of this data
      GAP_ADTYPE_SLAVE_CONN_INTERVAL_RANGE,
      LO_UINT16(DEFAULT_DESIRED_MIN_CONN_INTERVAL),   // 100ms
      HI_UINT16(DEFAULT_DESIRED_MIN_CONN_INTERVAL),
      LO_UINT16(DEFAULT_DESIRED_MAX_CONN_INTERVAL),   // 1s
      HI_UINT16(DEFAULT_DESIRED_MAX_CONN_INTERVAL),
      // Tx power level
      GAP_ADTYPE_POWER_LEVEL,
      0       // 0dBm
    // Advertising handles
    static uint8 advHandleLegacy;
    static uint8 advHandleLongRange;
    // Address mode
    static GAP_Addr_Modes_t addrMode = DEFAULT_ADDRESS_MODE;
    #if defined(BLE_V42_FEATURES) && (BLE_V42_FEATURES & PRIVACY_1_2_CFG)
    // Current Random Private Address
    static uint8 rpa[B_ADDR_LEN] = {0};
    #endif // PRIVACY_1_2_CFG
     * LOCAL FUNCTIONS
    static void scCtrlReadyCallback(void);
    static void scTaskAlertCallback(void);
    static void processTaskAlert(void);
    static void SimplePeripheral_init( void );
    static void SimplePeripheral_taskFxn(UArg a0, UArg a1);
    static uint8_t SimplePeripheral_processStackMsg(ICall_Hdr *pMsg);
    static uint8_t SimplePeripheral_processGATTMsg(gattMsgEvent_t *pMsg);
    static void SimplePeripheral_processGapMessage(gapEventHdr_t *pMsg);
    static void SimplePeripheral_advCallback(uint32_t event, void *pBuf, uintptr_t arg);
    static void SimplePeripheral_processAdvEvent(spGapAdvEventData_t *pEventData);
    static void SimplePeripheral_processAppMsg(spEvt_t *pMsg);
    static void SimplePeripheral_processCharValueChangeEvt(uint8_t paramId);
    static void SimplePeripheral_performPeriodicTask(void);
    static void SimplePeripheral_updateRPA(void);
    static void SimplePeripheral_clockHandler(UArg arg);
    #if defined(GAP_BOND_MGR)
    static void SimplePeripheral_passcodeCb(uint8_t *pDeviceAddr, uint16_t connHandle,
                                            uint8_t uiInputs, uint8_t uiOutputs,
                                            uint32_t numComparison);
    static void SimplePeripheral_pairStateCb(uint16_t connHandle, uint8_t state,
                                             uint8_t status);
    #endif
    static void SimplePeripheral_processPairState(spPairStateData_t *pPairState);
    static void SimplePeripheral_processPasscode(spPasscodeData_t *pPasscodeData);
    static void SimplePeripheral_charValueChangeCB(uint8_t paramId);
    static status_t SimplePeripheral_enqueueMsg(uint8_t event, void *pData);
    static void SimplePeripheral_keyChangeHandler(uint8 keys);
    static void SimplePeripheral_handleKeys(uint8_t keys);
    static void SimplePeripheral_processCmdCompleteEvt(hciEvt_CmdComplete_t *pMsg);
    static void SimplePeripheral_initPHYRSSIArray(void);
    static void SimplePeripheral_updatePHYStat(uint16_t eventCode, uint8_t *pMsg);
    static uint8_t SimplePeripheral_addConn(uint16_t connHandle);
    static uint8_t SimplePeripheral_getConnIndex(uint16_t connHandle);
    static uint8_t SimplePeripheral_removeConn(uint16_t connHandle);
    static void SimplePeripheral_processParamUpdate(uint16_t connHandle);
    static status_t SimplePeripheral_startAutoPhyChange(uint16_t connHandle);
    static status_t SimplePeripheral_stopAutoPhyChange(uint16_t connHandle);
    static status_t SimplePeripheral_setPhy(uint16_t connHandle, uint8_t allPhys,
                                            uint8_t txPhy, uint8_t rxPhy,
                                            uint16_t phyOpts);
    static uint8_t SimplePeripheral_clearConnListEntry(uint16_t connHandle);
    static void SimplePeripheral_menuSwitchCb(tbmMenuObj_t* pMenuObjCurr,
                                              tbmMenuObj_t* pMenuObjNext);
    static void SimplePeripheral_connEvtCB(Gap_ConnEventRpt_t *pReport);
    static void SimplePeripheral_processConnEvt(Gap_ConnEventRpt_t *pReport);
    #ifdef PTM_MODE
    void simple_peripheral_handleNPIRxInterceptEvent(uint8_t *pMsg);      // Declaration
    static void simple_peripheral_sendToNPI(uint8_t *buf, uint16_t len);  // Declaration
    #endif // PTM_MODE
     * EXTERN FUNCTIONS
    extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
     * PROFILE CALLBACKS
    // GAP Bond Manager Callbacks
    static gapBondCBs_t SimplePeripheral_BondMgrCBs =
      SimplePeripheral_passcodeCb,       // Passcode callback
      SimplePeripheral_pairStateCb       // Pairing/Bonding state Callback
    #endif
    // Simple GATT Profile Callbacks
    static simpleProfileCBs_t SimplePeripheral_simpleProfileCBs =
      SimplePeripheral_charValueChangeCB // Simple GATT Characteristic value change callback
     * PUBLIC FUNCTIONS
     * @fn      simple_peripheral_spin
     * @brief   Spin forever
     * @param   none
    void scCtrlReadyCallback(void) {
        // Notify application `Control READY` is active
       //   user_enqueueRawAppMsg(APP_MSG_SC_CTRL_READY, NULL);
    } // scCtrlReadyCallback
    void scTaskAlertCallback(void) {
       //SimplePeripheral_enqueueMsg(SBP_SC_ALERT, NULL, NULL); DELETE ONE NULL
         SimplePeripheral_enqueueMsg(APP_MSG_SC_TASK_ALERT, NULL);
    } // scTaskAlertCallback
        // Clear the ALERT interrupt source
        scifClearAlertIntSource();
        // Do SC Task processing here
        // Get 'state.high', and set highStr to appropriate string
       // uint8_t charValue1= scifTaskData.adcLevelTrigger.output;
       uint16_t myData  =scifTaskData.adcLevelTrigger.output.adcValue;
         // uint8_t high = scifTaskData.adcLevelTrigger.state.high;
        //  char *highStr = (high != 0) ? "HIGH" : "LOW";
          // Set the highStr to the String characteristic in Data Service
          //DataService_SetParameter(DS_STRING_ID, strlen(highStr), highStr);
         // SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR1,sizeof(uint8_t),
                //                        &charValue1);
          MyData_SetParameter(MYDATA_DATA_ID, MYDATA_DATA_LEN,&myData);
          Display_printf(dispHandle, 6, 0, "ADC value1: %d\n",myData);
        //  MyData1_SetParameter(MYDATA1_DATA1_ID, MYDATA1_DATA1_LEN,&myData1);
       //   Display_printf(dispHandle, 6, 0, "ADC value2: %d\n",myData1);
          // Set/clear red LED.
       //   PIN_setOutputValue(ledPinHandle, Board_GPIO_RLED, high);
        // Acknowledge the ALERT event
        scifAckAlertEvents();
    } // processTaskAlert
    static void simple_peripheral_spin(void)
      volatile uint8_t x = 0;
      while(1)
        x++;
    #ifdef PTM_MODE
    * @fn      simple_peripheral_handleNPIRxInterceptEvent
    * @brief   Intercept an NPI RX serial message and queue for this application.
    * @param   pMsg - a NPIMSG_msg_t containing the intercepted message.
    * @return  none.
     // Send Command via HCI TL
     HCI_TL_SendToStack(((NPIMSG_msg_t *)pMsg)->pBuf);
     // The data is stored as a message, free this first.
     ICall_freeMsg(((NPIMSG_msg_t *)pMsg)->pBuf);
     // Free container.
     ICall_free(pMsg);
    * @fn      simple_peripheral_sendToNPI
    * @brief   Create an NPI packet and send to NPI to transmit.
    * @param   buf - pointer HCI event or data.
    * @param   len - length of buf in bytes.
    * @return  none
     npiPkt_t *pNpiPkt = (npiPkt_t *)ICall_allocMsg(sizeof(npiPkt_t) + len);
     if (pNpiPkt)
       pNpiPkt->hdr.event = buf[0]; //Has the event status code in first byte of payload
       pNpiPkt->hdr.status = 0xFF;
       pNpiPkt->pktLen = len;
       pNpiPkt->pData  = (uint8 *)(pNpiPkt + 1);
       memcpy(pNpiPkt->pData, buf, len);
       // Send to NPI
       // Note: there is no need to free this packet.  NPI will do that itself.
       NPITask_sendToHost((uint8_t *)pNpiPkt);
    #endif // PTM_MODE
     * @fn      SimplePeripheral_createTask
     * @brief   Task creation function for the Simple Peripheral.
    void SimplePeripheral_createTask(void)
      Task_Params taskParams;
      // Configure task
      Task_Params_init(&taskParams);
      taskParams.stack = spTaskStack;
      taskParams.stackSize = SP_TASK_STACK_SIZE;
      taskParams.priority = SP_TASK_PRIORITY;
      Task_construct(&spTask, SimplePeripheral_taskFxn, &taskParams, NULL);
     * @fn      SimplePeripheral_init
     * @brief   Called during initialization and contains application
     *          specific initialization (ie. hardware initialization/setup,
     *          table initialization, power up notification, etc), and
     *          profile initialization/setup.
    static void SimplePeripheral_init(void)
      // N0 STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
      // Register the current thread as an ICall dispatcher application
      // so that the application can send and receive messages.
      ICall_registerApp(&selfEntity, &syncEvent);
    #ifdef USE_RCOSC
      RCOSC_enableCalibration();
    #endif // USE_RCOSC
      // Create an RTOS queue for message from profile to be sent to app.
      appMsgQueueHandle = Util_constructQueue(&appMsgQueue);
      // Create one-shot clock for internal periodic events.
      Util_constructClock(&clkPeriodic, SimplePeripheral_clockHandler,
                          SP_PERIODIC_EVT_PERIOD, 0, false, (UArg)&argPeriodic);
      // Set the Device Name characteristic in the GAP GATT Service
      // For more information, see the section in the User's Guide:
      // software-dl.ti.com/.../
      GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
      // Configure GAP
        uint16_t paramUpdateDecision = DEFAULT_PARAM_UPDATE_REQ_DECISION;
        // Pass all parameter update requests to the app for it to decide
        GAP_SetParamValue(GAP_PARAM_LINK_UPDATE_DECISION, paramUpdateDecision);
      // Setup the GAP Bond Manager. For more information see the GAP Bond Manager
      // section in the User's Guide:
        // Don't send a pairing request after connecting; the peer device must
        // initiate pairing
        uint8_t pairMode = GAPBOND_PAIRING_MODE_WAIT_FOR_REQ;
        // Use authenticated pairing: require passcode.
        uint8_t mitm = TRUE;
        // This device only has display capabilities. Therefore, it will display the
        // passcode during pairing. However, since the default passcode is being
        // used, there is no need to display anything.
        uint8_t ioCap = GAPBOND_IO_CAP_DISPLAY_ONLY;
        // Request bonding (storing long-term keys for re-encryption upon subsequent
        // connections without repairing)
        uint8_t bonding = TRUE;
        GAPBondMgr_SetParameter(GAPBOND_PAIRING_MODE, sizeof(uint8_t), &pairMode);
        GAPBondMgr_SetParameter(GAPBOND_MITM_PROTECTION, sizeof(uint8_t), &mitm);
        GAPBondMgr_SetParameter(GAPBOND_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
        GAPBondMgr_SetParameter(GAPBOND_BONDING_ENABLED, sizeof(uint8_t), &bonding);
    #endif
      // Initialize GATT attributes
      GGS_AddService(GATT_ALL_SERVICES);           // GAP GATT Service
      GATTServApp_AddService(GATT_ALL_SERVICES);   // GATT Service
      DevInfo_AddService();                        // Device Information Service
      SimpleProfile_AddService(GATT_ALL_SERVICES); // Simple GATT Profile
      MyData_AddService( selfEntity );
        MyData1_AddService( selfEntity );
      // Setup the SimpleProfile Characteristic Values
      // For more information, see the GATT and GATTServApp sections in the User's Guide:
        uint8_t charValue1 = 0;
        uint8_t charValue2 = 2;
        uint8_t charValue3 = 3;
        uint8_t charValue4 = 4;
        uint8_t charValue5[SIMPLEPROFILE_CHAR5_LEN] = { 1, 2, 3, 4, 5 };
        SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR1,sizeof(uint8_t) ,
                                   &charValue1);
        SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR2, sizeof(uint8_t),
                                   &charValue2);
        SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR3, sizeof(uint8_t),
                                   &charValue3);
        SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR4, sizeof(uint8_t),
                                   &charValue4);
        SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR5, SIMPLEPROFILE_CHAR5_LEN,
                                   charValue5);
        /* Add your new characteristic to the service. These names may vary */
             uint8_t myData_data_initVal[MYDATA_DATA_LEN] = {0};
             MyData_SetParameter(MYDATA_DATA_ID, MYDATA_DATA_LEN, myData_data_initVal);
             uint8_t myData1_data1_initVal[MYDATA1_DATA1_LEN] = {0};
             MyData1_SetParameter(MYDATA1_DATA1_ID, MYDATA1_DATA1_LEN, myData1_data1_initVal);
      // Register callback with SimpleGATTprofile
      SimpleProfile_RegisterAppCBs(&SimplePeripheral_simpleProfileCBs);
      // Start Bond Manager and register callback
      VOID GAPBondMgr_Register(&SimplePeripheral_BondMgrCBs);
    #endif
      // Register with GAP for HCI/Host messages. This is needed to receive HCI
      // events. For more information, see the HCI section in the User's Guide:
      GAP_RegisterForMsgs(selfEntity);
      // Register for GATT local events and ATT Responses pending for transmission
      GATT_RegisterForMsgs(selfEntity);
      // Set default values for Data Length Extension
      // Extended Data Length Feature is already enabled by default
        // Set initial values to maximum, RX is set to max. by default(251 octets, 2120us)
        // Some brand smartphone is essentially needing 251/2120, so we set them here.
        #define APP_SUGGESTED_PDU_SIZE 251 //default is 27 octets(TX)
        #define APP_SUGGESTED_TX_TIME 2120 //default is 328us(TX)
        // This API is documented in hci.h
        // See the LE Data Length Extension section in the BLE5-Stack User's Guide for information on using this command:
        HCI_LE_WriteSuggestedDefaultDataLenCmd(APP_SUGGESTED_PDU_SIZE, APP_SUGGESTED_TX_TIME);
      // Initialize GATT Client
      GATT_InitClient();
      // Init key debouncer
      Board_initKeys(SimplePeripheral_keyChangeHandler);
      // Initialize Connection List
      SimplePeripheral_clearConnListEntry(CONNHANDLE_ALL);
      //Initialize GAP layer for Peripheral role and register to receive GAP events
      GAP_DeviceInit(GAP_PROFILE_PERIPHERAL, selfEntity, addrMode, NULL);
      // Initialize array to store connection handle and RSSI values
      SimplePeripheral_initPHYRSSIArray();
      // The type of display is configured based on the BOARD_DISPLAY_USE...
      // preprocessor definitions
      dispHandle = Display_open(Display_Type_ANY, NULL);
      // Initialize Two-Button Menu module
      TBM_SET_TITLE(&spMenuMain, "Simple Peripheral");
      tbm_setItemStatus(&spMenuMain, TBM_ITEM_NONE, TBM_ITEM_ALL);
      tbm_initTwoBtnMenu(dispHandle, &spMenuMain, 2, SimplePeripheral_menuSwitchCb);
      Display_printf(dispHandle, SP_ROW_SEPARATOR_1, 0, "====================");
     * @fn      SimplePeripheral_taskFxn
     * @brief   Application task entry point for the Simple Peripheral.
     * @param   a0, a1 - not used.
      // Initialize application
      SimplePeripheral_init();
      // Initialize the Sensor Controller
      scifOsalInit();
      scifOsalRegisterCtrlReadyCallback(scCtrlReadyCallback);
      scifOsalRegisterTaskAlertCallback(scTaskAlertCallback);
      scifInit(&scifDriverSetup);
      // Set the Sensor Controller task tick interval to 1 second
      uint32_t rtc_Hz = 1;  // 1Hz RTC
      scifStartRtcTicksNow(0x00010000 / rtc_Hz);
      // Configure Sensor Controller tasks
      scifTaskData.adcLevelTrigger.cfg.threshold = 600;
      // Start Sensor Controller task
      scifStartTasksNbl(BV(SCIF_ADC_LEVEL_TRIGGER_TASK_ID));
      // Application main loop
      for (;;)
        uint32_t events;
        // Waits for an event to be posted associated with the calling thread.
        // Note that an event associated with a thread is posted when a
        // message is queued to the message receive queue of the thread
        events = Event_pend(syncEvent, Event_Id_NONE, SP_ALL_EVENTS,
                            ICALL_TIMEOUT_FOREVER);
        if (events)
          ICall_EntityID dest;
          ICall_ServiceEnum src;
          ICall_HciExtEvt *pMsg = NULL;
          // Fetch any available messages that might have been sent from the stack
          if (ICall_fetchServiceMsg(&src, &dest,
                                    (void **)&pMsg) == ICALL_ERRNO_SUCCESS)
            uint8 safeToDealloc = TRUE;
            if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
              ICall_Stack_Event *pEvt = (ICall_Stack_Event *)pMsg;
              // Check for BLE stack events first
              if (pEvt->signature != 0xffff)
                // Process inter-task message
                safeToDealloc = SimplePeripheral_processStackMsg((ICall_Hdr *)pMsg);
            if (pMsg && safeToDealloc)
              ICall_freeMsg(pMsg);
          // If RTOS queue is not empty, process app message.
          if (events & SP_QUEUE_EVT)
            while (!Queue_empty(appMsgQueueHandle))
              spEvt_t *pMsg = (spEvt_t *)Util_dequeueMsg(appMsgQueueHandle);
              if (pMsg)
                // Process message.
                SimplePeripheral_processAppMsg(pMsg);
                // Free the space from the message.
                ICall_free(pMsg);
     * @fn      SimplePeripheral_processStackMsg
     * @brief   Process an incoming stack message.
     * @param   pMsg - message to process
     * @return  TRUE if safe to deallocate incoming message, FALSE otherwise.
      // Always dealloc pMsg unless set otherwise
      uint8_t safeToDealloc = TRUE;
      switch (pMsg->event)
        case GAP_MSG_EVENT:
          SimplePeripheral_processGapMessage((gapEventHdr_t*) pMsg);
          break;
        case GATT_MSG_EVENT:
          // Process GATT message
          safeToDealloc = SimplePeripheral_processGATTMsg((gattMsgEvent_t *)pMsg);
          break;
        case HCI_GAP_EVENT_EVENT:
          // Process HCI message
          switch(pMsg->status)
            case HCI_COMMAND_COMPLETE_EVENT_CODE:
            // Process HCI Command Complete Events here
              SimplePeripheral_processCmdCompleteEvt((hciEvt_CmdComplete_t *) pMsg);
              break;
            case HCI_BLE_HARDWARE_ERROR_EVENT_CODE:
              AssertHandler(HAL_ASSERT_CAUSE_HARDWARE_ERROR,0);
              break;
            // HCI Commands Events
            case HCI_COMMAND_STATUS_EVENT_CODE:
              hciEvt_CommandStatus_t *pMyMsg = (hciEvt_CommandStatus_t *)pMsg;
              switch ( pMyMsg->cmdOpcode )
                case HCI_LE_SET_PHY:
                  if (pMyMsg->cmdStatus == HCI_ERROR_CODE_UNSUPPORTED_REMOTE_FEATURE)
                    Display_printf(dispHandle, SP_ROW_STATUS_1, 0,
                            "PHY Change failure, peer does not support this");
                  else
                                   "PHY Update Status Event: 0x%x",
                                   pMyMsg->cmdStatus);
                  SimplePeripheral_updatePHYStat(HCI_LE_SET_PHY, (uint8_t *)pMsg);
                  break;
                default:
                  break;
              break;
            // LE Events
            case HCI_LE_EVENT_CODE:
              hciEvt_BLEPhyUpdateComplete_t *pPUC =
                (hciEvt_BLEPhyUpdateComplete_t*) pMsg;
              // A Phy Update Has Completed or Failed
              if (pPUC->BLEEventCode == HCI_BLE_PHY_UPDATE_COMPLETE_EVENT)
                if (pPUC->status != SUCCESS)
                                 "PHY Change failure");
                else
                  // Only symmetrical PHY is supported.
                  // rxPhy should be equal to txPhy.
                  Display_printf(dispHandle, SP_ROW_STATUS_2, 0,
                                 "PHY Updated to %s",
                                 (pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_1M) ? "1M" :
                                 (pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_2M) ? "2M" :
                                 (pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_CODED) ? "CODED" : "Unexpected PHY Value");
                SimplePeripheral_updatePHYStat(HCI_BLE_PHY_UPDATE_COMPLETE_EVENT, (uint8_t *)pMsg);
              break;
            default:
              break;
          break;
        default:
          // do nothing
          break;
    #ifdef PTM_MODE
      // Check for NPI Messages
      hciPacket_t *pBuf = (hciPacket_t *)pMsg;
      // Serialized HCI Event
      if (pBuf->hdr.event == HCI_CTRL_TO_HOST_EVENT)
        uint16_t len = 0;
        // Determine the packet length
        switch(pBuf->pData[0])
          case HCI_EVENT_PACKET:
            len = HCI_EVENT_MIN_LENGTH + pBuf->pData[2];
            break;
          case HCI_ACL_DATA_PACKET:
            len = HCI_DATA_MIN_LENGTH + BUILD_UINT16(pBuf->pData[3], pBuf->pData[4]);
            break;
          default:
            break;
        // Send to Remote Host.
        simple_peripheral_sendToNPI(pBuf->pData, len);
        // Free buffers if needed.
        switch (pBuf->pData[0])
          case HCI_SCO_DATA_PACKET:
            BM_free(pBuf->pData);
          default:
            break;
    #endif // PTM_MODE
      return (safeToDealloc);
     * @fn      SimplePeripheral_processGATTMsg
     * @brief   Process GATT messages and events.
      if (pMsg->method == ATT_FLOW_CTRL_VIOLATED_EVENT)
        // ATT request-response or indication-confirmation flow control is
        // violated. All subsequent ATT requests or indications will be dropped.
        // The app is informed in case it wants to drop the connection.
        // Display the opcode of the message that caused the violation.
        Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "FC Violated: %d", pMsg->msg.flowCtrlEvt.opcode);
      else if (pMsg->method == ATT_MTU_UPDATED_EVENT)
        // MTU size updated
        Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "MTU Size: %d", pMsg->msg.mtuEvt.MTU);
      // Free message payload. Needed only for ATT Protocol messages
      GATT_bm_free(&pMsg->msg, pMsg->method);
      // It's safe to free the incoming message
      return (TRUE);
     * @fn      SimplePeripheral_processAppMsg
     * @brief   Process an incoming callback from a profile.
     * @return  None.
      bool dealloc = TRUE;
        case SP_CHAR_CHANGE_EVT:
          SimplePeripheral_processCharValueChangeEvt(*(uint8_t*)(pMsg->pData));
          break;
        case SP_KEY_CHANGE_EVT:
          SimplePeripheral_handleKeys(*(uint8_t*)(pMsg->pData));
          break;
        case SP_ADV_EVT:
          SimplePeripheral_processAdvEvent((spGapAdvEventData_t*)(pMsg->pData));
          break;
        case SP_PAIR_STATE_EVT:
          SimplePeripheral_processPairState((spPairStateData_t*)(pMsg->pData));
          break;
        case SP_PASSCODE_EVT:
          SimplePeripheral_processPasscode((spPasscodeData_t*)(pMsg->pData));
          break;
        case SP_PERIODIC_EVT:
          SimplePeripheral_performPeriodicTask();
          break;
        case SP_READ_RPA_EVT:
          SimplePeripheral_updateRPA();
          break;
        case SP_SEND_PARAM_UPDATE_EVT:
          // Extract connection handle from data
          uint16_t connHandle = *(uint16_t *)(((spClockEventData_t *)pMsg->pData)->data);
          SimplePeripheral_processParamUpdate(connHandle);
          // This data is not dynamically allocated
          dealloc = FALSE;
          break;
        case SP_CONN_EVT:
          SimplePeripheral_processConnEvt((Gap_ConnEventRpt_t *)(pMsg->pData));
          break;
        case APP_MSG_SC_TASK_ALERT:
          processTaskAlert();
          break;
        default:
          // Do nothing.
          break;
      // Free message data if it exists and we are to dealloc
      if ((dealloc == TRUE) && (pMsg->pData != NULL))
        ICall_free(pMsg->pData);
     * @fn      SimplePeripheral_processGapMessage
     * @brief   Process an incoming GAP event.
      switch(pMsg->opcode)
        case GAP_DEVICE_INIT_DONE_EVENT:
          bStatus_t status = FAILURE;
          gapDeviceInitDoneEvent_t *pPkt = (gapDeviceInitDoneEvent_t *)pMsg;
          if(pPkt->hdr.status == SUCCESS)
            // Store the system ID
            uint8_t systemId[DEVINFO_SYSTEM_ID_LEN];
            // use 6 bytes of device address for 8 bytes of system ID value
            systemId[0] = pPkt->devAddr[0];
            systemId[1] = pPkt->devAddr[1];
            systemId[2] = pPkt->devAddr[2];
            // set middle bytes to zero
            systemId[4] = 0x00;
            systemId[3] = 0x00;
            // shift three bytes up
            systemId[7] = pPkt->devAddr[5];
            systemId[6] = pPkt->devAddr[4];
            systemId[5] = pPkt->devAddr[3];
            // Set Device Info Service Parameter
            DevInfo_SetParameter(DEVINFO_SYSTEM_ID, DEVINFO_SYSTEM_ID_LEN, systemId);
            Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Initialized");
            // Setup and start Advertising
            // For more information, see the GAP section in the User's Guide:
            // Temporary memory for advertising parameters for set #1. These will be copied
            // by the GapAdv module
            GapAdv_params_t advParamLegacy = GAPADV_PARAMS_LEGACY_SCANN_CONN;
            // Create Advertisement set #1 and assign handle
            status = GapAdv_create(&SimplePeripheral_advCallback, &advParamLegacy,
                                   &advHandleLegacy);
            SIMPLEPERIPHERAL_ASSERT(status == SUCCESS);
            // Load advertising data for set #1 that is statically allocated by the app
            status = GapAdv_loadByHandle(advHandleLegacy, GAP_ADV_DATA_TYPE_ADV,
                                         sizeof(advertData), advertData);
            // Load scan response data for set #1 that is statically allocated by the app
            status = GapAdv_loadByHandle(advHandleLegacy, GAP_ADV_DATA_TYPE_SCAN_RSP,
                                         sizeof(scanRspData), scanRspData);
            // Set event mask for set #1
            status = GapAdv_setEventMask(advHandleLegacy,
                                         GAP_ADV_EVT_MASK_START_AFTER_ENABLE |
                                         GAP_ADV_EVT_MASK_END_AFTER_DISABLE |
                                         GAP_ADV_EVT_MASK_SET_TERMINATED);
            // Enable legacy advertising for set #1
            status = GapAdv_enable(advHandleLegacy, GAP_ADV_ENABLE_OPTIONS_USE_MAX , 0);
            // Use long range params to create long range set #2
            GapAdv_params_t advParamLongRange = GAPADV_PARAMS_AE_LONG_RANGE_CONN;
            // Create Advertisement set #2 and assign handle
            status = GapAdv_create(&SimplePeripheral_advCallback, &advParamLongRange,
                                   &advHandleLongRange);
            // Load advertising data for set #2 that is statically allocated by the app
            status = GapAdv_loadByHandle(advHandleLongRange, GAP_ADV_DATA_TYPE_ADV,
            // Set event mask for set #2
            status = GapAdv_setEventMask(advHandleLongRange,
            // Enable long range advertising for set #2
            status = GapAdv_enable(advHandleLongRange, GAP_ADV_ENABLE_OPTIONS_USE_MAX , 0);
    #ifdef PTM_MODE
             // Enable "Enable PTM Mode" option
             tbm_setItemStatus(&spMenuMain, SP_ITEM_PTM_ENBL, SP_ITEM_NONE);
    #endif
            // Display device address
            Display_printf(dispHandle, SP_ROW_IDA, 0, "%s Addr: %s",
                           (addrMode <= ADDRMODE_RANDOM) ? "Dev" : "ID",
                           Util_convertBdAddr2Str(pPkt->devAddr));
            if (addrMode > ADDRMODE_RANDOM)
              // Create one-shot clock for RPA check event.
              Util_constructClock(&clkRpaRead, SimplePeripheral_clockHandler,
                                  SP_READ_RPA_EVT_PERIOD, 0, true,
                                  (UArg) &argRpaRead);
          break;
        case GAP_LINK_ESTABLISHED_EVENT:
          gapEstLinkReqEvent_t *pPkt = (gapEstLinkReqEvent_t *)pMsg;
          // Display the amount of current connections
          uint8_t numActive = linkDB_NumActive();
          Display_printf(dispHandle, SP_ROW_STATUS_2, 0, "Num Conns: %d",
                         (uint16_t)numActive);
          if (pPkt->hdr.status == SUCCESS)
            // Add connection to list and start RSSI
            SimplePeripheral_addConn(pPkt->connectionHandle);
            // Display the address of this connection
            Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Connected to %s",
            // Enable connection selection option
            tbm_setItemStatus(&spMenuMain, SP_ITEM_SELECT_CONN, TBM_ITEM_NONE);
            // Start Periodic Clock.
            Util_startClock(&clkPeriodic);
          if (numActive < MAX_NUM_BLE_CONNS)
            // Start advertising since there is room for more connections
          else
            // Stop advertising since there is no room for more connections
            GapAdv_disable(advHandleLongRange);
            GapAdv_disable(advHandleLegacy);
          break;
        case GAP_LINK_TERMINATED_EVENT:
          gapTerminateLinkEvent_t *pPkt = (gapTerminateLinkEvent_t *)pMsg;
          Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Device Disconnected!");
          // Remove the connection from the list and disable RSSI if needed
          SimplePeripheral_removeConn(pPkt->connectionHandle);
          // If no active connections
          if (numActive == 0)
            // Stop periodic clock
            Util_stopClock(&clkPeriodic);
            // Disable Connection Selection option
            tbm_setItemStatus(&spMenuMain, TBM_ITEM_NONE, SP_ITEM_SELECT_CONN);
          // Clear remaining lines
          Display_clearLine(dispHandle, SP_ROW_CONNECTION);
          break;
        case GAP_UPDATE_LINK_PARAM_REQ_EVENT:
          gapUpdateLinkParamReqReply_t rsp;
          gapUpdateLinkParamReqEvent_t *pReq = (gapUpdateLinkParamReqEvent_t *)pMsg;
          rsp.connectionHandle = pReq->req.connectionHandle;
          // Only accept connection intervals with slave latency of 0
          // This is just an example of how the application can send a response
          if(pReq->req.connLatency == 0)
            rsp.intervalMin = pReq->req.intervalMin;
            rsp.intervalMax = pReq->req.intervalMax;
            rsp.connLatency = pReq->req.connLatency;
            rsp.connTimeout = pReq->req.connTimeout;
            rsp.accepted = TRUE;
          else
            rsp.accepted = FALSE;
          // Send Reply
          VOID GAP_UpdateLinkParamReqReply(&rsp);
          break;
        case GAP_LINK_PARAM_UPDATE_EVENT:
          gapLinkUpdateEvent_t *pPkt = (gapLinkUpdateEvent_t *)pMsg;
          // Get the address from the connection handle
          linkDBInfo_t linkInfo;
          linkDB_GetInfo(pPkt->connectionHandle, &linkInfo);
          if(pPkt->status == SUCCESS)
            // Display the address of the connection update
            Display_printf(dispHandle, SP_ROW_STATUS_2, 0, "Link Param Updated: %s",
                           Util_convertBdAddr2Str(linkInfo.addr));
          else
            // Display the address of the connection update failure
                           "Link Param Update Failed 0x%x: %s", pPkt->opcode,
          // Check if there are any queued parameter updates
          spConnHandleEntry_t *connHandleEntry = (spConnHandleEntry_t *)List_get(&paramUpdateList);
          if (connHandleEntry != NULL)
            // Attempt to send queued update now
            SimplePeripheral_processParamUpdate(connHandleEntry->connHandle);
            // Free list element
            ICall_free(connHandleEntry);
          break;
        default:
          Display_clearLines(dispHandle, SP_ROW_STATUS_1, SP_ROW_STATUS_2);
          break;
     * @fn      SimplePeripheral_charValueChangeCB
     * @brief   Callback from Simple Profile indicating a characteristic
     *          value change.
     * @param   paramId - parameter Id of the value that was changed.
     * @return  None.
      uint8_t *pValue = ICall_malloc(sizeof(uint8_t));
      if (pValue)
        *pValue = paramId;
        if (SimplePeripheral_enqueueMsg(SP_CHAR_CHANGE_EVT, pValue) != SUCCESS)
          ICall_free(pValue);
     * @fn      SimplePeripheral_processCharValueChangeEvt
     * @brief   Process a pending Simple Profile characteristic value change
     *          event.
     * @param   paramID - parameter ID of the value that was changed.
      uint8_t newValue;
      switch(paramId)
        case SIMPLEPROFILE_CHAR1:
          SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR1, &newValue);
          Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Char 1: %d", (uint16_t)newValue);
          break;
        case SIMPLEPROFILE_CHAR3:
          SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR3, &newValue);
          Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Char 3: %d", (uint16_t)newValue);
          break;
        default:
          // should not reach here!
          break;
     * @fn      SimplePeripheral_performPeriodicTask
     * @brief   Perform a periodic application task. This function gets called
     *          every five seconds (SP_PERIODIC_EVT_PERIOD). In this example,
     *          the value of the third characteristic in the SimpleGATTProfile
     *          service is retrieved from the profile, and then copied into the
     *          value of the the fourth characteristic.
     * @param   None.
     * @return  None.
      uint8_t valueToCopy;
      // Call to retrieve the value of the third characteristic in the profile
      if (SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR3, &valueToCopy) == SUCCESS)
        // Call to set that value of the fourth characteristic in the profile.
        // Note that if notifications of the fourth characteristic have been
        // enabled by a GATT client device, then a notification will be sent
        // every time this function is called.
                                   &valueToCopy);
     * @fn      SimplePeripheral_updateRPA
     * @brief   Read the current RPA from the stack and update display
     *          if the RPA has changed.
     * @param   None.
     * @return  None.
      uint8_t* pRpaNew;
      // Read the current RPA.
      pRpaNew = GAP_GetDevAddress(FALSE);
      if (memcmp(pRpaNew, rpa, B_ADDR_LEN))
        // If the RPA has changed, update the display
        Display_printf(dispHandle, SP_ROW_RPA, 0, "RP Addr: %s",
                       Util_convertBdAddr2Str(pRpaNew));
        memcpy(rpa, pRpaNew, B_ADDR_LEN);
     * @fn      SimplePeripheral_clockHandler
     * @brief   Handler function for clock timeouts.
     * @param   arg - event type
     * @return  None.
      spClockEventData_t *pData = (spClockEventData_t *)arg;
     if (pData->event == SP_PERIODIC_EVT)
       // Start the next period
       // Post event to wake up the application
       SimplePeripheral_enqueueMsg(SP_PERIODIC_EVT, NULL);
     else if (pData->event == SP_READ_RPA_EVT)
       Util_startClock(&clkRpaRead);
       // Post event to read the current RPA
       SimplePeripheral_enqueueMsg(SP_READ_RPA_EVT, NULL);
     else if (pData->event == SP_SEND_PARAM_UPDATE_EVT)
        // Send message to app
        SimplePeripheral_enqueueMsg(SP_SEND_PARAM_UPDATE_EVT, pData);
     * @fn      SimplePeripheral_keyChangeHandler
     * @brief   Key event handler function
     * @param   keys - bitmap of pressed keys
     * @return  none
    static void SimplePeripheral_keyChangeHandler(uint8_t keys)
      if (pValue)
        *pValue = keys;
        if(SimplePeripheral_enqueueMsg(SP_KEY_CHANGE_EVT, pValue) != SUCCESS)
          ICall_free(pValue);
     * @fn      SimplePeripheral_handleKeys
     * @brief   Handles all key events for this device.
     * @param   keys - bit field for key events. Valid entries:
     *                 KEY_LEFT
     *                 KEY_RIGHT
      if (keys & KEY_LEFT)
        // Check if the key is still pressed. Workaround for possible bouncing.
        if (PIN_getInputValue(Board_PIN_BUTTON0) == 0)
          tbm_buttonLeft();
      else if (keys & KEY_RIGHT)
        if (PIN_getInputValue(Board_PIN_BUTTON1) == 0)
          tbm_buttonRight();
     * @fn      SimplePeripheral_doSetConnPhy
     * @brief   Set PHY preference.
     * @param   index - 0: 1M PHY
     *                  1: 2M PHY
     *                  2: 1M + 2M PHY
     *                  3: CODED PHY (Long range)
     *                  4: 1M + 2M + CODED PHY
     * @return  always true
    bool SimplePeripheral_doSetConnPhy(uint8 index)
      bool status = TRUE;
      static uint8_t phy[] = {
        HCI_PHY_1_MBPS, HCI_PHY_2_MBPS, HCI_PHY_1_MBPS | HCI_PHY_2_MBPS,
        HCI_PHY_CODED, HCI_PHY_1_MBPS | HCI_PHY_2_MBPS | HCI_PHY_CODED,
        AUTO_PHY_UPDATE
      uint8_t connIndex = SimplePeripheral_getConnIndex(menuConnHandle);
      if (connIndex >= MAX_NUM_BLE_CONNS)
        Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Connection handle is not in the connList !!!");
        return FALSE;
      // Set Phy Preference on the current connection. Apply the same value
      // for RX and TX.
      // If auto PHY update is not selected and if auto PHY update is enabled, then
      // stop auto PHY update
      // Note PHYs are already enabled by default in build_config.opt in stack project.
      if(phy[index] != AUTO_PHY_UPDATE)
        // Cancel RSSI reading  and auto phy changing
        SimplePeripheral_stopAutoPhyChange(connList[connIndex].connHandle);
        SimplePeripheral_setPhy(menuConnHandle, 0, phy[index], phy[index], 0);
        Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "PHY preference: %s",
                       TBM_GET_ACTION_DESC(&spMenuConnPhy, index));
      else
        // Start RSSI read for auto PHY update (if it is disabled)
        SimplePeripheral_startAutoPhyChange(menuConnHandle);
      return status;
     * @fn      SimplePeripheral_advCallback
     * @brief   GapAdv module callback
      spGapAdvEventData_t *pData = ICall_malloc(sizeof(spGapAdvEventData_t));
      if (pData)
        pData->event = event;
        pData->pBuf = pBuf;
        if(SimplePeripheral_enqueueMsg(SP_ADV_EVT, pData) != SUCCESS)
          ICall_free(pData);
     * @fn      SimplePeripheral_processAdvEvent
     * @brief   Process advertising event in app context
     * @param   pEventData
      switch (pEventData->event)
        case GAP_EVT_ADV_START_AFTER_ENABLE:
          Display_printf(dispHandle, SP_ROW_ADVSTATE, 0, "Adv Set %d Enabled",
                         *(uint8_t *)(pEventData->pBuf));
          break;
        case GAP_EVT_ADV_END_AFTER_DISABLE:
          Display_printf(dispHandle, SP_ROW_ADVSTATE, 0, "Adv Set %d Disabled",
          break;
        case GAP_EVT_ADV_START:
          break;
        case GAP_EVT_ADV_END:
          break;
        case GAP_EVT_ADV_SET_TERMINATED:
    #ifndef Display_DISABLE_ALL
          GapAdv_setTerm_t *advSetTerm = (GapAdv_setTerm_t *)(pEventData->pBuf);
    #endif
          Display_printf(dispHandle, SP_ROW_ADVSTATE, 0, "Adv Set %d disabled after conn %d",
                         advSetTerm->handle, advSetTerm->connHandle );
        break;
        case GAP_EVT_SCAN_REQ_RECEIVED:
          break;
        case GAP_EVT_INSUFFICIENT_MEMORY:
          break;
        default:
          break;
      // All events have associated memory to free except the insufficient memory
      // event
      if (pEventData->event != GAP_EVT_INSUFFICIENT_MEMORY)
        ICall_free(pEventData->pBuf);
     * @fn      SimplePeripheral_pairStateCb
     * @brief   Pairing state callback.
     * @return  none
                                             uint8_t status)
      spPairStateData_t *pData = ICall_malloc(sizeof(spPairStateData_t));
      // Allocate space for the event data.
      if (pData)
        pData->state = state;
        pData->connHandle = connHandle;
        pData->status = status;
        // Queue the event.
        if(SimplePeripheral_enqueueMsg(SP_PAIR_STATE_EVT, pData) != SUCCESS)
          ICall_free(pData);
     * @fn      SimplePeripheral_passcodeCb
     * @brief   Passcode callback.
     * @return  none
                                            uint8_t uiInputs,
                                            uint8_t uiOutputs,
      spPasscodeData_t *pData = ICall_malloc(sizeof(spPasscodeData_t));
      // Allocate space for the passcode event.
      if (pData )
        memcpy(pData->deviceAddr, pDeviceAddr, B_ADDR_LEN);
        pData->uiInputs = uiInputs;
        pData->uiOutputs = uiOutputs;
        pData->numComparison = numComparison;
        // Enqueue the event.
        if(SimplePeripheral_enqueueMsg(SP_PASSCODE_EVT, pData) != SUCCESS)
          ICall_free(pData);
    #endif
     * @fn      SimplePeripheral_processPairState
     * @brief   Process the new paring state.
     * @return  none
    static void SimplePeripheral_processPairState(spPairStateData_t *pPairData)
      uint8_t state = pPairData->state;
      uint8_t status = pPairData->status;
      switch (state)
        case GAPBOND_PAIRING_STATE_STARTED:
          Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Pairing started");
          break;
        case GAPBOND_PAIRING_STATE_COMPLETE:
          if (status == SUCCESS)
            Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Pairing success");
          else
            Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Pairing fail: %d", status);
          break;
        case GAPBOND_PAIRING_STATE_ENCRYPTED:
            Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Encryption success");
          else
            Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Encryption failed: %d", status);
          break;
        case GAPBOND_PAIRING_STATE_BOND_SAVED:
            Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Bond save success");
          else
            Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Bond save failed: %d", status);
          break;
        default:
          break;
     * @fn      SimplePeripheral_processPasscode
     * @brief   Process the Passcode request.
     * @return  none
      // Display passcode to user
      if (pPasscodeData->uiOutputs != 0)
        Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Passcode: %d",
                       B_APP_DEFAULT_PASSCODE);
      // Send passcode response
      GAPBondMgr_PasscodeRsp(pPasscodeData->connHandle , SUCCESS,
    #endif
     * @fn      SimplePeripheral_connEvtCB
     * @brief   Connection event callback.
     * @param pReport pointer to connection event report
      // Enqueue the event for processing in the app context.
      if(SimplePeripheral_enqueueMsg(SP_CONN_EVT, pReport) != SUCCESS)
        ICall_free(pReport);
     * @fn      SimplePeripheral_processConnEvt
     * @brief   Process connection event.
      // Get index from handle
      uint8_t connIndex = SimplePeripheral_getConnIndex(pReport->handle);
        return;
      // If auto phy change is enabled
      if (connList[connIndex].isAutoPHYEnable == TRUE)
        // Read the RSSI
        HCI_ReadRssiCmd(pReport->handle);
     * @fn      SimplePeripheral_enqueueMsg
     * @brief   Creates a message and puts the message in RTOS queue.
     * @param   event - message event.
     * @param   state - message state.
      uint8_t success;
      spEvt_t *pMsg = ICall_malloc(sizeof(spEvt_t));
      // Create dynamic pointer to message.
      if(pMsg)
        pMsg->event = event;
        pMsg->pData = pData;
        // Enqueue the message.
        success = Util_enqueueMsg(appMsgQueueHandle, syncEvent, (uint8_t *)pMsg);
        return (success) ? SUCCESS : FAILURE;
      return(bleMemAllocError);
     * @fn      SimplePeripheral_doSelectConn
     * @brief   Select a connection to communicate with
     * @param   index - item index from the menu
    bool SimplePeripheral_doSelectConn(uint8_t index)
      menuConnHandle = connList[index].connHandle;
      // Set the menu title and go to this connection's context
      TBM_SET_TITLE(&spMenuPerConn, TBM_GET_ACTION_DESC(&spMenuSelectConn, index));
      // Clear non-connection-related message
      tbm_goTo(&spMenuPerConn);
      return (true);
     * @fn      SimplePeripheral_addConn
     * @brief   Add a device to the connected device list
     * @return  index of the connected device list entry where the new connection
     *          info is put in.
     *          if there is no room, MAX_NUM_BLE_CONNS will be returned.
      uint8_t i;
      uint8_t status = bleNoResources;
      // Try to find an available entry
      for (i = 0; i < MAX_NUM_BLE_CONNS; i++)
        if (connList[i].connHandle == CONNHANDLE_INVALID)
          // Found available entry to put a new connection info in
          connList[i].connHandle = connHandle;
          // Allocate data to send through clock handler
          connList[i].pParamUpdateEventData = ICall_malloc(sizeof(spClockEventData_t) +
                                                           sizeof (uint16_t));
          if(connList[i].pParamUpdateEventData)
            connList[i].pParamUpdateEventData->event = SP_SEND_PARAM_UPDATE_EVT;
            *((uint16_t *)connList[i].pParamUpdateEventData->data) = connHandle;
            // Create a clock object and start
            connList[i].pUpdateClock
              = (Clock_Struct*) ICall_malloc(sizeof(Clock_Struct));
            if (connList[i].pUpdateClock)
              Util_constructClock(connList[i].pUpdateClock,
                                  SP_SEND_PARAM_UPDATE_DELAY, 0, true,
                                  (UArg) (connList[i].pParamUpdateEventData));
            else
                ICall_free(connList[i].pParamUpdateEventData);
          else
            status = bleMemAllocError;
          // Set default PHY to 1M
          connList[i].currPhy = HCI_PHY_1_MBPS;
          break;
      return status;
     * @fn      SimplePeripheral_getConnIndex
     * @brief   Find index in the connected device list by connHandle
     * @return  the index of the entry that has the given connection handle.
     *          if there is no match, MAX_NUM_BLE_CONNS will be returned.
      uint8_t i;
        if (connList[i].connHandle == connHandle)
          return i;
      return(MAX_NUM_BLE_CONNS);
     * @return  SUCCESS if connHandle found valid index or bleInvalidRange
     *          if index wasn't found. CONNHANDLE_ALL will always succeed.
      uint8_t i;
      // Set to invalid connection index initially
      uint8_t connIndex = MAX_NUM_BLE_CONNS;
      if(connHandle != CONNHANDLE_ALL)
        // Get connection index from handle
        connIndex = SimplePeripheral_getConnIndex(connHandle);
        if(connIndex >= MAX_NUM_BLE_CONNS)
    	  return(bleInvalidRange);
      // Clear specific handle or all handles
      for(i = 0; i < MAX_NUM_BLE_CONNS; i++)
        if((connIndex == i) || (connHandle == CONNHANDLE_ALL))
          connList[i].connHandle = CONNHANDLE_INVALID;
          connList[i].currPhy = 0;
          connList[i].phyCngRq = 0;
          connList[i].phyRqFailCnt = 0;
          connList[i].rqPhy = 0;
          memset(connList[i].rssiArr, 0, SP_MAX_RSSI_STORE_DEPTH);
          connList[i].rssiAvg = 0;
          connList[i].rssiCntr = 0;
          connList[i].isAutoPHYEnable = FALSE;
      return(SUCCESS);
     * @fn      SimplePeripheral_clearPendingParamUpdate
     * @brief   clean pending param update request in the paramUpdateList list
     * @param   connHandle - connection handle to clean
     * @return  none
    void SimplePeripheral_clearPendingParamUpdate(uint16_t connHandle)
      List_Elem *curr;
      for (curr = List_head(&paramUpdateList); curr != NULL; curr = List_next(curr))
        if (((spConnHandleEntry_t *)curr)->connHandle == connHandle)
          List_remove(&paramUpdateList, curr);
     * @fn      SimplePeripheral_removeConn
     * @brief   Remove a device from the connected device list
     *          info is removed from.
     *          if connHandle is not found, MAX_NUM_BLE_CONNS will be returned.
      uint8_t connIndex = SimplePeripheral_getConnIndex(connHandle);
      if(connIndex != MAX_NUM_BLE_CONNS)
        Clock_Struct* pUpdateClock = connList[connIndex].pUpdateClock;
        if (pUpdateClock != NULL)
          // Stop and destruct the RTOS clock if it's still alive
          if (Util_isActive(pUpdateClock))
            Util_stopClock(pUpdateClock);
          // Destruct the clock object
          Clock_destruct(pUpdateClock);
          // Free clock struct
          ICall_free(pUpdateClock);
          // Free ParamUpdateEventData
          ICall_free(connList[connIndex].pParamUpdateEventData);
        // Clear pending update requests from paramUpdateList
        SimplePeripheral_clearPendingParamUpdate(connHandle);
        // Stop Auto PHY Change
        SimplePeripheral_stopAutoPhyChange(connHandle);
        // Clear Connection List Entry
        SimplePeripheral_clearConnListEntry(connHandle);
      return connIndex;
     * @fn      SimplePeripheral_processParamUpdate
     * @brief   Process a parameters update request
     * @return  None
      gapUpdateLinkParamReq_t req;
      uint8_t connIndex;
      req.connectionHandle = connHandle;
      req.connLatency = DEFAULT_DESIRED_SLAVE_LATENCY;
      req.connTimeout = DEFAULT_DESIRED_CONN_TIMEOUT;
      req.intervalMin = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
      req.intervalMax = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
        return;
      // Deconstruct the clock object
      Clock_destruct(connList[connIndex].pUpdateClock);
      // Free clock struct, only in case it is not NULL
      if (connList[connIndex].pUpdateClock != NULL)
        ICall_free(connList[connIndex].pUpdateClock);
        connList[connIndex].pUpdateClock = NULL;
      // Free ParamUpdateEventData, only in case it is not NULL
      if (connList[connIndex].pParamUpdateEventData != NULL)
      // Send parameter update
      bStatus_t status = GAP_UpdateLinkParamReq(&req);
      // If there is an ongoing update, queue this for when the udpate completes
      if (status == bleAlreadyInRequestedMode)
        spConnHandleEntry_t *connHandleEntry = ICall_malloc(sizeof(spConnHandleEntry_t));
        if (connHandleEntry)
          connHandleEntry->connHandle = connHandle;
          List_put(&paramUpdateList, (List_Elem *)connHandleEntry);
     * @fn      SimpleCentral_processCmdCompleteEvt
     * @brief   Process an incoming OSAL HCI Command Complete Event.
     * @return  none
      uint8_t status = pMsg->pReturnParam[0];
      //Find which command this command complete is for
      switch (pMsg->cmdOpcode)
        case HCI_READ_RSSI:
          int8 rssi = (int8)pMsg->pReturnParam[3];
          // Display RSSI value, if RSSI is higher than threshold, change to faster PHY
            uint16_t handle = BUILD_UINT16(pMsg->pReturnParam[1], pMsg->pReturnParam[2]);
            uint8_t index = SimplePeripheral_getConnIndex(handle);
            SIMPLEPERIPHERAL_ASSERT(index < MAX_NUM_BLE_CONNS);
            if (rssi != LL_RSSI_NOT_AVAILABLE)
              connList[index].rssiArr[connList[index].rssiCntr++] = rssi;
              connList[index].rssiCntr %= SP_MAX_RSSI_STORE_DEPTH;
              int16_t sum_rssi = 0;
              for(uint8_t cnt=0; cnt<SP_MAX_RSSI_STORE_DEPTH; cnt++)
                sum_rssi += connList[index].rssiArr[cnt];
              connList[index].rssiAvg = (uint32_t)(sum_rssi/SP_MAX_RSSI_STORE_DEPTH);
              uint8_t phyRq = SP_PHY_NONE;
              uint8_t phyRqS = SP_PHY_NONE;
              uint8_t phyOpt = LL_PHY_OPT_NONE;
              if(connList[index].phyCngRq == FALSE)
                if((connList[index].rssiAvg >= RSSI_2M_THRSHLD) &&
                (connList[index].currPhy != HCI_PHY_2_MBPS) &&
                     (connList[index].currPhy != SP_PHY_NONE))
                  // try to go to higher data rate
                  phyRqS = phyRq = HCI_PHY_2_MBPS;
                else if((connList[index].rssiAvg < RSSI_2M_THRSHLD) &&
                        (connList[index].rssiAvg >= RSSI_1M_THRSHLD) &&
                        (connList[index].currPhy != HCI_PHY_1_MBPS) &&
                  // try to go to legacy regular data rate
                  phyRqS = phyRq = HCI_PHY_1_MBPS;
                else if((connList[index].rssiAvg >= RSSI_S2_THRSHLD) &&
                        (connList[index].rssiAvg < RSSI_1M_THRSHLD) &&
                  // try to go to lower data rate S=2(500kb/s)
                  phyRqS = HCI_PHY_CODED;
                  phyOpt = LL_PHY_OPT_S2;
                  phyRq = BLE5_CODED_S2_PHY;
                else if(connList[index].rssiAvg < RSSI_S2_THRSHLD )
                  // try to go to lowest data rate S=8(125kb/s)
                  phyOpt = LL_PHY_OPT_S8;
                  phyRq = BLE5_CODED_S8_PHY;
                if((phyRq != SP_PHY_NONE) &&
                   // First check if the request for this phy change is already not honored then don't request for change
                   (((connList[index].rqPhy == phyRq) &&
                     (connList[index].phyRqFailCnt < 2)) ||
                     (connList[index].rqPhy != phyRq)))
                  //Initiate PHY change based on RSSI
                  SimplePeripheral_setPhy(connList[index].connHandle, 0,
                                          phyRqS, phyRqS, phyOpt);
                  connList[index].phyCngRq = TRUE;
                  // If it a request for different phy than failed request, reset the count
                  if(connList[index].rqPhy != phyRq)
                    // then reset the request phy counter and requested phy
                    connList[index].phyRqFailCnt = 0;
                  if(phyOpt == LL_PHY_OPT_NONE)
                    connList[index].rqPhy = phyRq;
                  else if(phyOpt == LL_PHY_OPT_S2)
                    connList[index].rqPhy = BLE5_CODED_S2_PHY;
                  else
                    connList[index].rqPhy = BLE5_CODED_S8_PHY;
                } // end of if ((phyRq != SP_PHY_NONE) && ...
              } // end of if (connList[index].phyCngRq == FALSE)
            } // end of if (rssi != LL_RSSI_NOT_AVAILABLE)
            Display_printf(dispHandle, SP_ROW_RSSI, 0,
                           "RSSI:%d dBm, AVG RSSI:%d dBm",
                           (uint32_t)(rssi),
                           connList[index].rssiAvg);
    	  } // end of if (status == SUCCESS)
          break;
        case HCI_LE_READ_PHY:
            Display_printf(dispHandle, SP_ROW_RSSI + 2, 0, "RXPh: %d, TXPh: %d",
                           pMsg->pReturnParam[3], pMsg->pReturnParam[4]);
          break;
        default:
          break;
      } // end of switch (pMsg->cmdOpcode)
    * @fn      SimplePeripheral_initPHYRSSIArray
    * @brief   Initializes the array of structure/s to store data related
    *          RSSI based auto PHy change
    * @param   connHandle - the connection handle
    * @param   addr - pointer to device address
    * @return  index of connection handle
      //Initialize array to store connection handle and RSSI values
      memset(connList, 0, sizeof(connList));
      for (uint8_t index = 0; index < MAX_NUM_BLE_CONNS; index++)
        connList[index].connHandle = SP_INVALID_HANDLE;
     * @fn      SimplePeripheral_startAutoPhyChange
     * @brief   Start periodic RSSI reads on a link.
     * @param   connHandle - connection handle of link
     * @param   devAddr - device address
     * @return  SUCCESS: Terminate started
     *          bleIncorrectMode: No link
     *          bleNoResources: No resources
      status_t status = FAILURE;
      SIMPLEPERIPHERAL_ASSERT(connIndex < MAX_NUM_BLE_CONNS);
      // Start Connection Event notice for RSSI calculation
      status = Gap_RegisterConnEventCb(SimplePeripheral_connEvtCB, GAP_CB_REGISTER, connHandle);
      // Flag in connection info if successful
        connList[connIndex].isAutoPHYEnable = TRUE;
      return status;
     * @fn      SimplePeripheral_stopAutoPhyChange
     * @brief   Cancel periodic RSSI reads on a link.
     * @return  SUCCESS: Operation successful
      // Stop connection event notice
      Gap_RegisterConnEventCb(NULL, GAP_CB_UNREGISTER, connHandle);
      // Also update the phychange request status for active RSSI tracking connection
      connList[connIndex].phyCngRq = FALSE;
      connList[connIndex].isAutoPHYEnable = FALSE;
      return SUCCESS;
     * @fn      SimplePeripheral_setPhy
     * @brief   Call the HCI set phy API and and add the handle to a
     *          list to match it to an incoming command status event
                                            uint16_t phyOpts)
      // Allocate list entry to store handle for command status
        // Add entry to the phy command status list
        List_put(&setPhyCommStatList, (List_Elem *)connHandleEntry);
        // Send PHY Update
        HCI_LE_SetPhyCmd(connHandle, allPhys, txPhy, rxPhy, phyOpts);
      return SUCCESS;
    * @fn      SimplePeripheral_updatePHYStat
    * @brief   Update the auto phy update state machine
    * @return  None
      uint8_t connIndex;
      switch (eventCode)
          // Get connection handle from list
                               (spConnHandleEntry_t *)List_get(&setPhyCommStatList);
            // Get index from connection handle
            connIndex = SimplePeripheral_getConnIndex(connHandleEntry->connHandle);
            // Is this connection still valid?
            if (connIndex < MAX_NUM_BLE_CONNS)
                // Update the phychange request status for active RSSI tracking connection
                connList[connIndex].phyRqFailCnt++;
          break;
        // LE Event - a Phy update has completed or failed
        case HCI_BLE_PHY_UPDATE_COMPLETE_EVENT:
          if(pPUC)
            connIndex = SimplePeripheral_getConnIndex(pPUC->connHandle);
              if (pPUC->status == SUCCESS)
                connList[connIndex].currPhy = pPUC->rxPhy;
              if(pPUC->rxPhy != connList[connIndex].rqPhy)
              else
                // Reset the request phy counter and requested phy
                connList[connIndex].phyRqFailCnt = 0;
                connList[connIndex].rqPhy = 0;
          break;
        default:
          break;
      } // end of switch (eventCode)
     * @fn      SimplePeripheral_menuSwitchCb
     * @brief   Detect menu context switching
     * @param   pMenuObjCurr - the current menu object
     * @param   pMenuObjNext - the menu object the context is about to switch to
     * @return  none
      uint8_t NUMB_ACTIVE_CONNS = linkDB_NumActive();
      // interested in only the events of
      // entering scMenuConnect, spMenuSelectConn, and scMenuMain for now
      if (pMenuObjNext == &spMenuSelectConn)
        static uint8_t* pAddrs;
        uint8_t* pAddrTemp;
        if (pAddrs != NULL)
          ICall_free(pAddrs);
        // Allocate buffer to display addresses
        pAddrs = ICall_malloc(NUMB_ACTIVE_CONNS * SP_ADDR_STR_SIZE);
        if (pAddrs == NULL)
          TBM_SET_NUM_ITEM(&spMenuSelectConn, 0);
        else
          uint8_t i;
          TBM_SET_NUM_ITEM(&spMenuSelectConn, MAX_NUM_BLE_CONNS);
          pAddrTemp = pAddrs;
          // Add active connection info to the menu object
            if (connList[i].connHandle != CONNHANDLE_INVALID)
              linkDB_GetInfo(connList[i].connHandle, &linkInfo);
              // This connection is active. Set the corresponding menu item with
              // the address of this connection and enable the item.
              memcpy(pAddrTemp, Util_convertBdAddr2Str(linkInfo.addr),
                     SP_ADDR_STR_SIZE);
              TBM_SET_ACTION_DESC(&spMenuSelectConn, i, pAddrTemp);
              tbm_setItemStatus(&spMenuSelectConn, (1 << i), SP_ITEM_NONE);
              pAddrTemp += SP_ADDR_STR_SIZE;
            else
              // This connection is not active. Disable the corresponding menu item.
              tbm_setItemStatus(&spMenuSelectConn, SP_ITEM_NONE, (1 << i));
      else if (pMenuObjNext == &spMenuMain)
        // Now we are not in a specific connection's context
        // Clear connection-related message
    #ifdef PTM_MODE
    * @fn      SimplePeripheral_doEnablePTMMode
    * @brief   Stop advertising, configure & start PTM mode
    bool SimplePeripheral_doEnablePTMMode(uint8_t index)
      // Clear Display
      Display_clearLines(dispHandle, 0, 15);
      // Indicate in screen that PTM Mode is initializing
      Display_printf(dispHandle, 1, 0, "PTM Mode initializing!\n\n\rPlease note UART feed will now stop...");
      // Before starting the NPI task close Display driver to make sure there is no shared resource used by both
      Display_close(dispHandle);
      // Start NPI task
      NPITask_createTask(ICALL_SERVICE_CLASS_BLE);
      // Disable Advertising and destroy sets
      GapAdv_destroy(advHandleLegacy,GAP_ADV_FREE_OPTION_ALL_DATA);
      GapAdv_destroy(advHandleLongRange,GAP_ADV_FREE_OPTION_ALL_DATA);
      // Intercept NPI RX events.
      NPITask_registerIncomingRXEventAppCB(simple_peripheral_handleNPIRxInterceptEvent, INTERCEPT);
      // Register for Command Status information
      HCI_TL_Init(NULL, (HCI_TL_CommandStatusCB_t) simple_peripheral_sendToNPI, NULL, selfEntity);
      // Register for Events
      HCI_TL_getCmdResponderID(ICall_getLocalMsgEntityId(ICALL_SERVICE_CLASS_BLE_MSG, selfEntity));
      // Inform Stack to Initialize PTM
      HCI_EXT_EnablePTMCmd();
      // Open back the display to avoid crashes to future calls to Display_printf (even though they won't go through until reboot)
      return TRUE;
    #endif
    您好、Sai、
    感谢您提供的详细信息。 您看起来是在正确的方向上。
    当您说"我无法读取正确的 ADC 值"时、这是否意味着该值卡在0 (或任何其他值)、或者该值不准确?  如果在 processTaskAlert()函数中停止执行,是否在 MyData 中有预期值?
    如果前面的内容 没有帮助、我建议您首先将传感器控制器代码与不太复杂的项目(例如空项目)集成、这样您就可以验证 ADC 读取工作是否符合预期。
    请参阅下面的博文。 博客中使用的 SDK 很旧、因此需要进行调整。
    https://markelthinkslearnscreates.wordpress.com/2022/08/23/sensor-controller/
    -kel
    谢谢、我尝试了空项目...我能够读取预期值... 但无法在 BLE 项目中读取。
    感谢您分享@Markel。 我跟在你的教学中。 我成功构建并运行了代码。 但我无法在 ble app 中读取 ADC 值、它显示为零。
    以下是我的代码:
     Group: WCS, BTS
     are met:
     * INCLUDES
    #include <string.h>
    #endif
    #include <icall.h>
    #include "util.h"
    #include "myData.h"
    #ifdef USE_RCOSC
    #endif //USE_RCOSC
    #include <board.h>
    #include <scif.h>
    #ifdef PTM_MODE
    #endif // PTM_MODE
     * MACROS
     * CONSTANTS
    extern uint16_t myData;
    extern uint16_t myData1;
    #endif
    #define SP_SCTASK_EVT                        Event_Id_04
                                                  SP_QUEUE_EVT             | \
                                                  SP_SCTASK_EVT)
     * TYPEDEFS
    typedef struct
    } spEvt_t;
    typedef struct
      uint8_t state;
      uint8_t status;
    typedef struct
      uint8_t uiInputs;
      uint8_t uiOutputs;
    } spPasscodeData_t;
    typedef struct
      uint32_t event;
      void *pBuf;
    typedef struct
      uint8_t event;                //
      uint8_t data[];
    typedef struct
      List_Elem elem;
    typedef struct
      uint8_t          	    rssiCntr;
      int8_t           	    rssiAvg;
      uint8_t          	    currPhy;
      uint8_t          	    rqPhy;
    } spConnRec_t;
     * GLOBAL VARIABLES
    Task_Struct spTask;
    #else
    #endif
     * LOCAL VARIABLES
    // local events.
    static uint16_t adcData = 0; // added
      GAP_ADTYPE_FLAGS,
      // complete name
      'S',
      'i',
      'm',
      'p',
      'l',
      'e',
      'P',
      'e',
      'r',
      'i',
      'p',
      'h',
      'e',
      'r',
      'a',
      'l',
      // Tx power level
      0       // 0dBm
    // Address mode
     * LOCAL FUNCTIONS
                                             uint8_t status);
    #endif
                                            uint16_t phyOpts);
    #ifdef PTM_MODE
    #endif // PTM_MODE
     * EXTERN FUNCTIONS
     * PROFILE CALLBACKS
    #endif
     * PUBLIC FUNCTIONS
     * @fn      SensorController_readyCallback
     * @brief
    void SensorController_readyCallback(void){
     * @fn      SensorController_taskalertCallback
     * @brief
    void SensorController_taskalertCallback(void){
        uint32_t bvAlertEvents = 0;
    bvAlertEvents = scifGetAlertEvents();
     if(bvAlertEvents & BV(SCIF_ADC_LEVEL_TRIGGER_TASK_ID))
       // ... Access Sensor Controller task data structures here ...
    //          adcData = scifTaskData.adcLevelTrigger.output;
        adcData = scifTaskData.adcLevelTrigger.output.adcValue;
        Event_post(syncEvent,SP_SCTASK_EVT);
     * @fn      SensorController_adcSample
     * @brief
    static void SensorController_adcSample(void){
        while (scifWaitOnNbl(0) != SCIF_SUCCESS);
        scifResetTaskStructs(BV(SCIF_ADC_LEVEL_TRIGGER_TASK_ID),BV(SCIF_STRUCT_OUTPUT));
        scifExecuteTasksOnceNbl(BV(SCIF_ADC_LEVEL_TRIGGER_TASK_ID));
     * @fn      SensorController_init
    static void SensorController_init(void){
        // Initialize the SCIF operating system abstraction layer
        scifOsalInit();
        scifOsalRegisterCtrlReadyCallback(SensorController_readyCallback);
        scifOsalRegisterTaskAlertCallback(SensorController_taskalertCallback);
        // Initialize the SCIF driver
        // Enable RTC ticks, with N Hz tick interval
        scifStartRtcTicksNow(0x00010000 / 1);
     * @param   none
      while(1)
        x++;
    #ifdef PTM_MODE
    * @return  none.
     // Free container.
     ICall_free(pMsg);
    * @return  none
     if (pNpiPkt)
       // Send to NPI
    #endif // PTM_MODE
      // Configure task
    #ifdef USE_RCOSC
    #endif // USE_RCOSC
      // Configure GAP
        // initiate pairing
      SensorController_init();
    #endif
        uint8_t charValue1 = 1;
        SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR1, sizeof(uint8_t),
                                   &charValue1);
                                   &charValue2);
                                   &charValue3);
                                   &charValue4);
                                   charValue5);
    #endif
      GATT_InitClient();
      for (;;)
        uint32_t events;
        if (events)
              if (pMsg)
                // Process message.
                ICall_free(pMsg);
        case GAP_MSG_EVENT:
          break;
          break;
              break;
              break;
                  else
                                   pMyMsg->cmdStatus);
                  break;
                default:
                  break;
              break;
            // LE Events
                else
              break;
            default:
              break;
          break;
        default:
          // do nothing
          break;
    #ifdef PTM_MODE
        uint16_t len = 0;
            break;
            break;
          default:
            break;
          default:
            break;
    #endif // PTM_MODE
        // MTU size updated
      return (TRUE);
     * @return  None.
          break;
          break;
        case SP_ADV_EVT:
          break;
          break;
          break;
          break;
        case SP_SCTASK_EVT:
                              MYDATA_DATA_LEN,
                              &adcData);
          break;
          break;
          dealloc = FALSE;
          break;
        case SP_CONN_EVT:
          break;
        default:
          // Do nothing.
          break;
            systemId[4] = 0x00;
            systemId[3] = 0x00;
                                   &advHandleLegacy);
    #ifdef PTM_MODE
    #endif
          break;
          else
          break;
          if (numActive == 0)
          break;
          else
          // Send Reply
          break;
          else
          break;
        default:
          break;
     *          value change.
     * @return  None.
      if (pValue)
        *pValue = paramId;
          ICall_free(pValue);
     *          event.
      uint8_t newValue;
      switch(paramId)
          break;
          break;
        default:
          break;
     * @param   None.
     * @return  None.
        SensorController_adcSample();
     /* uint8_t valueToCopy;
                                   &valueToCopy);
     * @param   None.
     * @return  None.
      uint8_t* pRpaNew;
     * @return  None.
     * @return  none
      if (pValue)
        *pValue = keys;
          ICall_free(pValue);
     *                 KEY_LEFT
     *                 KEY_RIGHT
          tbm_buttonLeft();
          tbm_buttonRight();
     *                  1: 2M PHY
     *                  2: 1M + 2M PHY
      bool status = TRUE;
        AUTO_PHY_UPDATE
        return FALSE;
      // for RX and TX.
      else
      return status;
      if (pData)
        pData->pBuf = pBuf;
          ICall_free(pData);
     * @param   pEventData
          break;
          break;
          break;
          break;
    #endif
        break;
          break;
          break;
        default:
          break;
      // event
     * @return  none
                                             uint8_t status)
      if (pData)
        // Queue the event.
          ICall_free(pData);
     * @return  none
                                            uint8_t uiInputs,
                                            uint8_t uiOutputs,
      if (pData )
          ICall_free(pData);
    #endif
     * @return  none
      switch (state)
          break;
          else
          break;
          else
          break;
          else
          break;
        default:
          break;
     * @return  none
    #endif
        return;
        // Read the RSSI
      uint8_t success;
      if(pMsg)
      return (true);
     *          info is put in.
      uint8_t i;
                                                           sizeof (uint16_t));
            else
          else
          break;
      return status;
      uint8_t i;
          return i;
      uint8_t i;
      return(SUCCESS);
     * @return  none
      List_Elem *curr;
      return connIndex;
     * @return  None
      uint8_t connIndex;
        return;
     * @return  none
        case HCI_READ_RSSI:
                  else
                           (uint32_t)(rssi),
          break;
          break;
        default:
          break;
      return status;
      return SUCCESS;
                                            uint16_t phyOpts)
        // Send PHY Update
      return SUCCESS;
    * @return  None
      uint8_t connIndex;
      switch (eventCode)
          break;
          if(pPUC)
              else
          break;
        default:
          break;
     * @return  none
        uint8_t* pAddrTemp;
        if (pAddrs != NULL)
          ICall_free(pAddrs);
        if (pAddrs == NULL)
        else
          uint8_t i;
          pAddrTemp = pAddrs;
                     SP_ADDR_STR_SIZE);
            else
    #ifdef PTM_MODE
      // Clear Display
      // Start NPI task
      return TRUE;
    #endif
    您好、Sai、
    您似乎已将传感器控制器项目正确集成到 CCS 项目中。 下面是一些问题。 您能否将非 BLE5简单外设示例程序作为基础进行尝试。 也不建议使用使用 CC2640R2F 的 BLE5堆栈。
    1. 您是否使用传感器控制器项目和任务测试读取了模拟传感器?
    2. 您正在使用什么模拟输入?
    3. 您是否在传感器控制器项目任务中选择了基于 RTC 的执行调度?
    博客文章中的程序是 simple_poter。 安装 SDKv3.30、并将应用程序和堆栈项目导入 CCSv9.20、同时使用复制到工作区选项。 它可以正常工作、我只是对它进行了测试。 简单电位器不使用基于 RTC 的执行调度。 它使用应用周期计时器通过传感器控制器读取电位计。
    另一件事是、许多 TI BLE 项目或产品开发使用简单外设并进行修改。 我要做的是在将简单外设示例导入到 CCS 工程之前、将其正确重命名为简单电位器。 然后、我准备低功耗示例程序。 这似乎需要大量工作、但这是必要的。 我已经为此发布了一篇博文。
    https://markelthinkslearnscreates.wordpress.com/2022/08/21/creating-your-first-custom-bluetooth-application/
    -kel
    1. 您是否使用传感器控制器项目和任务测试读取了模拟传感器? 是的。
    2. 您正在使用什么模拟输入? 来自函数发生器的模拟信号。
    3. 您是否在传感器控制器项目任务中选择了基于 RTC 的执行调度? 是的。 我正在使用模拟电平触发示例传感器控制器程序。 SDK 版本:5.30.00.03,CCS v11.I 调用此函数                                                    “MyData_SetParameter (MyData_data_ID、MyData_data_LEN 和 adcData)”;//在  SensorController_taskalertCallback 函数中添加了“。现在,我能够通过 ble 读取预期值。 在这里调用该函数的方法是否正确?我认为我需要更新 char 值,所以我在这里调用了。
       * @brief
          adcData = 0;
          MyData_SetParameter(MYDATA_DATA_ID, MYDATA_DATA_LEN,&adcData); //ADDED
    使用传感器控制器集成有什么优点? 禁用 ADC 后、它是否会进入待机模式?
    您好、Sai、
    我再次查看了您的原始代码。 您所做的错误是处理 Event_post (syncEvent、SP_SCTASK_EVT);。 发布事件时,应 在 SimplePeripheral_taskFxn()中处理该事件,如下所示。
      for (;;)
        uint32_t events;
        if (events)
              if (pMsg)
                // Process message.
                ICall_free(pMsg);
    	  if (events & SP_SCTASK_EVT)
    [引用 userid="505260" URL"~/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1133663/cc2640r2f-how-to-merge-a-sensor-controller-adc_level_trigger-example-with-simple_peripheral-step-by-step-guide/4213952 #4213952]使用传感器控制器集成有什么优点? 禁用 ADC 后、它是否会进入待机模式?[/quot]
    传感器控制器可以与主应用并行运行。 使用传感器控制器非常有利、尤其是当您对模拟传感器进行多次采样并在将数据发送到主应用之前对其进行处理时。
    当没有事件时、主应用程序将进入待机模式。 一个事件示例是蓝牙广播、应用事件。
    -kel
    我在 SimplePeripheral_taskFxn ()中添加了"MyData_SetParameter (MyData_data_ID、MyData_data_LEN、&adcData);//added "、但我无法在 BLE 应用中读取数据、只有零才会出现、这是因为我们将 char 值初始化为零。它不会更新。
    adcData 需要是最上层的、并且对所有 c 函数都可见。
    静态 uint16_t adcData = 0;//已添加
    SimplePeripheral_taskFxn()中的代码需要与此类似
    IF (事件和 SP_SCTASK_EVT)
    MyData_SetParameter (MyData_data_ID、MyData_data_LEN、&adcData);//添加
    您可以在 MyData_SetParameter 和 watch 变量 adcData 中添加断点。
    -kel
    是的、我将 adcData 初始化为全局变量。
    我发现我们需要插入此代码,
    "IF (事件和 SP_SCTASK_EVT)
    在该 IF 条件之后
    "IF (事件和 SP_queue_EVT)
    您似乎错过了"IF (EVENT & SP_SCTASK_EVT)"之前的一个"}"
    非常感谢 Markel 的帮助。
    现在我能够读取 BLE 数据。
      for (;;)
        uint32_t events;
        if (events)
              if (pMsg)
                // Process message.
                ICall_free(pMsg);
    我想降低 cc2640r2的功耗、因此我计划使用传感器控制器收集 ADC 数据20分钟、并在20分钟后通过 BLE 发送数据。我尝试了、但我正面临 issues..ca、您将指导我如何正确执行此操作。
    您好、Sai、
    我建议您创建有关此新问题的新帖子。
    -kel
    好的、谢谢
