[参考译文] LP-CC2652RB:无法构建 SimpleLink 音频插件示例
Guru**** 2555630 points
Other Parts Discussed in Thread: LP-CC2652RB, CC2652RB, SIMPLELINK-CC13X2-26X2-SDK, UNIFLASH, CC3200AUDBOOST, CC2642R, LAUNCHXL-CC26X2R1, CC2652R
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/996008/lp-cc2652rb-cannot-build-simplelink-audio-plugin-examples
器件型号:LP-CC2652RB
主题中讨论的其他器件: CC2652RBCC2650SYSBIOSSIMPLELINK-CC13X2-26X2-SDKUNIFLASHCC2642RLAUNCHXL-CC26X2R1CC2652R
我正在使用在线代码编写工具(CCS 云)
它可以正确检测我的器件  LP-CC2652RB
可以成功导入工程:
SimpleLink CC13x2 26x2 SDK > project_zero_lp_CC2652rb_tirtos_ccs (生成和运行工作)
SimpleLink 音频插件> central_bidirectional 音频_CC2652RB_LAUNCHXL_tirtos_ccs (构建失败)
SimpleLink 音频插件>  peripheral_bidirectal_audio_CC2652RB_LAUNCHXL_tirtos_ccs (构建失败)
出现 API 冲突或其他问题。  构建日志如下所示:
**** Clean-only build of configuration Debug for project central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs ****
/mnt/ccs/ccs/utils/bin/gmake -k clean
cleaning ../src/sysbios ...
rm -rf  "central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs.hex"  "configPkg/linker.cmd" "configPkg/compiler.opt"  "central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs.out"
rm -rf "CC2652RB_LAUNCHXL.obj" "CC2652RB_LAUNCHXL_fxns.obj" "ti_radio_config.obj" "Application/ble_audio.obj" "Application/board_key.obj" "Application/central_bidirectional_audio.obj" "Application/central_bidirectional_audio_menu.obj" "Application/two_btn_menu.obj" "AudioHAL/AudioHAL.obj" "AudioHAL/AudioHALCodec.obj" "AudioHAL/AudioHAL_I2C.obj" "AudioHAL/MCLKCC26XX.obj" "AudioHAL/TLV320AIC3254.obj" "AudioStream/Packetizer.obj" "Drivers/NV/crc.obj" "Drivers/NV/nvocmp.obj" "Profiles/audio_client_disc.obj" "Profiles/audio_profile_dle.obj" "Profiles/devinfoservice.obj" "Profiles/gatt_uuid.obj" "Profiles/gattservapp_util.obj" "Startup/UartLog.obj" "Startup/ble_user_config_stack.obj" "Startup/ccfg_app_ble.obj" "Startup/main.obj" "Startup/osal_icall_ble.obj" "Startup/rom_init.obj" "Util/util_assert.obj" "Util/util_clock.obj" "Util/util_gap.obj" "Util/util_queue.obj" "iCall/icall.obj" "iCall/icall_cc2650.obj" "iCall/icall_user_config.obj" "iCallBLE/ble_user_config.obj" "iCallBLE/icall_api_lite...(line truncated)...
rm -rf "CC2652RB_LAUNCHXL.d" "CC2652RB_LAUNCHXL_fxns.d" "ti_radio_config.d" "Application/ble_audio.d" "Application/board_key.d" "Application/central_bidirectional_audio.d" "Application/central_bidirectional_audio_menu.d" "Application/two_btn_menu.d" "AudioHAL/AudioHAL.d" "AudioHAL/AudioHALCodec.d" "AudioHAL/AudioHAL_I2C.d" "AudioHAL/MCLKCC26XX.d" "AudioHAL/TLV320AIC3254.d" "AudioStream/Packetizer.d" "Drivers/NV/crc.d" "Drivers/NV/nvocmp.d" "Profiles/audio_client_disc.d" "Profiles/audio_profile_dle.d" "Profiles/devinfoservice.d" "Profiles/gatt_uuid.d" "Profiles/gattservapp_util.d" "Startup/UartLog.d" "Startup/ble_user_config_stack.d" "Startup/ccfg_app_ble.d" "Startup/main.d" "Startup/osal_icall_ble.d" "Startup/rom_init.d" "Util/util_assert.d" "Util/util_clock.d" "Util/util_gap.d" "Util/util_queue.d" "iCall/icall.d" "iCall/icall_cc2650.d" "iCall/icall_user_config.d" "iCallBLE/ble_user_config.d" "iCallBLE/icall_api_lite.d" "iCallBLE/icall_hci_tl.d"
rm -rf  "configPkg/"
Finished clean
**** Build Finished ****
**** Build of configuration Debug for project central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs ****
/mnt/ccs/ccs/utils/bin/gmake -k all
Building file: "../central_bidirectional_audio_app.cfg"
Invoking: XDCtools
"/mnt/tirex-content/xdctools_3_60_02_34_core/xs" --xdcpath="/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source;/mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/source;/mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M4F -p ti.platforms.simplelink:CC2642R1F -r release -c "/mnt/ccs/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS" --compileOptions "-mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path=\"/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs\" --include_path=\"/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application\" --include_path=\"/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util\" --include_path=\"/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles\" --include_path=\"/home/guest/ide/default/central_bid...(line truncated)...
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring central_bidirectional_audio_app.xem4f from package/cfg/central_bidirectional_audio_app_pem4f.cfg ...
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making /home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/src/sysbios/sysbios.aem4f ...
clem4f /mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/BIOS.c ...
asmem4f /mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi_asm.sv7M ...
asmem4f /mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi_asm_switch.sv7M ...
asmem4f /mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/IntrinsicsSupport_asm.sv7M ...
asmem4f /mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/TaskSupport_asm.sv7M ...
arem4f BIOS.obj m3_Hwi_asm.obj m3_Hwi_asm_switch.obj m3_IntrinsicsSupport_asm.obj m3_TaskSupport_asm.obj ...
Build of libraries done.
clem4f package/cfg/central_bidirectional_audio_app_pem4f.c ...
Finished building: "../central_bidirectional_audio_app.cfg"
making ../src/sysbios/sysbios.aem4f ...
gmake[1]: Entering directory '/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/src/sysbios'
gmake[1]: Nothing to be done for 'all'.
gmake[1]: Leaving directory '/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/src/sysbios'
Building file: "../CC2652RB_LAUNCHXL.c"
Invoking: Arm Compiler
"/mnt/ccs/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="/mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="/mnt/tirex-content/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="/home/guest/ide/default/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="/home/guest/id...(line truncated)...
>> Compilation failure
subdir_rules.mk:7: recipe for target 'CC2652RB_LAUNCHXL.obj' failed
"../CC2652RB_LAUNCHXL.c", line 720: error #20: identifier "I2CCC26XX_fxnTable" is undefined
"../CC2652RB_LAUNCHXL.c", line 720: error #137: struct "I2C_Config_" has no field "fxnTablePtr"
2 errors detected in the compilation of "../CC2652RB_LAUNCHXL.c".
gmake: *** [CC2652RB_LAUNCHXL.obj] Error 1
Building file: "../CC2652RB_LAUNCHXL_fxns.c"
Finished building: "../CC2652RB_LAUNCHXL_fxns.c"
Building file: "../ti_radio_config.c"
>> Compilation failure
subdir_rules.mk:35: recipe for target 'ti_radio_config.obj' failed
"../ti_radio_config.c", line 83: error #60: function call is not allowed in a constant expression
1 error detected in the compilation of "../ti_radio_config.c".
gmake: *** [ti_radio_config.obj] Error 1
Building file: "../Application/ble_audio.c"
Finished building: "../Application/ble_audio.c"
Building file: "../Application/board_key.c"
Finished building: "../Application/board_key.c"
Building file: "../Application/central_bidirectional_audio.c"
Finished building: "../Application/central_bidirectional_audio.c"
Building file: "../Application/central_bidirectional_audio_menu.c"
Finished building: "../Application/central_bidirectional_audio_menu.c"
Building file: "../Application/two_btn_menu.c"
Finished building: "../Application/two_btn_menu.c"
Building file: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/AudioHAL.c"
Finished building: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/AudioHAL.c"
Building file: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHALCodec.c"
Finished building: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHALCodec.c"
Building file: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHAL_I2C.c"
Finished building: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHAL_I2C.c"
Building file: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/MCLKCC26XX.c"
Finished building: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/MCLKCC26XX.c"
Building file: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/TLV320AIC3254.c"
Finished building: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/TLV320AIC3254.c"
Building file: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/stream/Packetizer.c"
Finished building: "/mnt/tirex-content/simplelink_audio_plugin_3_30_00_06/source/ti/audio/stream/Packetizer.c"
Building file: "../Drivers/NV/crc.c"
Finished building: "../Drivers/NV/crc.c"
Building file: "../Drivers/NV/nvocmp.c"
Finished building: "../Drivers/NV/nvocmp.c"
Building file: "../Profiles/audio_client_disc.c"
Finished building: "../Profiles/audio_client_disc.c"
Building file: "../Profiles/audio_profile_dle.c"
Finished building: "../Profiles/audio_profile_dle.c"
Building file: "../Profiles/devinfoservice.c"
Finished building: "../Profiles/devinfoservice.c"
Building file: "../Profiles/gatt_uuid.c"
Finished building: "../Profiles/gatt_uuid.c"
Building file: "../Profiles/gattservapp_util.c"
Finished building: "../Profiles/gattservapp_util.c"
Building file: "../Startup/UartLog.c"
Finished building: "../Startup/UartLog.c"
Building file: "../Startup/ble_user_config_stack.c"
Finished building: "../Startup/ble_user_config_stack.c"
Building file: "../Startup/ccfg_app_ble.c"
Finished building: "../Startup/ccfg_app_ble.c"
Building file: "../Startup/main.c"
Finished building: "../Startup/main.c"
Building file: "../Startup/osal_icall_ble.c"
>> Compilation failure
Startup/subdir_rules.mk:35: recipe for target 'Startup/osal_icall_ble.obj' failed
"../Startup/osal_icall_ble.c", line 161: error #167: too few arguments in function call
"../Startup/osal_icall_ble.c", line 165: error #167: too few arguments in function call
2 errors detected in the compilation of "../Startup/osal_icall_ble.c".
gmake: *** [Startup/osal_icall_ble.obj] Error 1
Building file: "../Startup/rom_init.c"
Finished building: "../Startup/rom_init.c"
Building file: "../Util/util_assert.c"
Finished building: "../Util/util_assert.c"
Building file: "../Util/util_clock.c"
Finished building: "../Util/util_clock.c"
Building file: "../Util/util_gap.c"
Finished building: "../Util/util_gap.c"
Building file: "../Util/util_queue.c"
Finished building: "../Util/util_queue.c"
Building file: "../iCall/icall.c"
Finished building: "../iCall/icall.c"
Building file: "../iCall/icall_cc2650.c"
Finished building: "../iCall/icall_cc2650.c"
Building file: "../iCall/icall_user_config.c"
Finished building: "../iCall/icall_user_config.c"
Building file: "../iCallBLE/ble_user_config.c"
>> Compilation failure
iCallBLE/subdir_rules.mk:7: recipe for target 'iCallBLE/ble_user_config.obj' failed
"../iCallBLE/ble_user_config.c", line 70: fatal error #1965: cannot open source file "ecc/ECCROMCC26XX.h"
1 catastrophic error detected in the compilation of "../iCallBLE/ble_user_config.c".
Compilation terminated.
gmake: *** [iCallBLE/ble_user_config.obj] Error 1
Building file: "../iCallBLE/icall_api_lite.c"
Finished building: "../iCallBLE/icall_api_lite.c"
Building file: "../iCallBLE/icall_hci_tl.c"
Finished building: "../iCallBLE/icall_hci_tl.c"
gmake: Target 'all' not remade because of errors.
有什么想法吗?
我还尝试过 Windows 上的 CCS 桌面、但也遇到了与此不相关的各种其他问题。  我还无法使 PROJECT_ZERO 在那里工作。
    供参考更新:我让 CCS v10.3在 Windows 上运行(由于某种原因、我以前运行的是 v9.1)。 全新安装。
    现在可以正确编译和运行 project_zero。  音频示例的故障方式类似。
    **** Build of configuration Debug for project peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs ****
    "C:\\ti\\ccs1030\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
    Building file: "../peripheral_bidirectional_audio_app.cfg"
    Invoking: XDCtools
    "C:/ti/ccs1030/xdctools_3_62_00_08_core/xs" --xdcpath="C:/ti/simplelink_audio_plugin_3_30_00_06/source;C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source;C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M4F -p ti.platforms.simplelink:CC2642R1F -r release -c "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS" --compileOptions "-mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path=\"C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs\" --include_path=\"C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application\" --include_path=\"C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util\" --include_path=\"C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles\" --include_path=\"C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream\" --include_path=\"C:/ti/simplelink_audio_plugin_3_30_00_06/source\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs\" --include_path=\"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include\" --define=uartlog_FILE=\"\"\"\" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi  " "../peripheral_bidirectional_audio_app.cfg"
    configuring peripheral_bidirectional_audio_app.xem4f from package/cfg/peripheral_bidirectional_audio_app_pem4f.cfg ...
    making C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/src/sysbios/sysbios.aem4f ...
    clem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/BIOS.c ...
    asmem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi_asm.sv7M ...
    asmem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi_asm_switch.sv7M ...
    asmem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/IntrinsicsSupport_asm.sv7M ...
    asmem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/TaskSupport_asm.sv7M ...
    clem4f package/cfg/peripheral_bidirectional_audio_app_pem4f.c ...
    Finished building: "../peripheral_bidirectional_audio_app.cfg"
            1 file(s) copied.
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ti_radio_config.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ti_radio_config.d_raw" --cmd_file="configPkg/compiler.opt"  "../ti_radio_config.c"
    >> Compilation failure
    subdir_rules.mk:37: recipe for target 'ti_radio_config.obj' failed
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"CC2652RB_LAUNCHXL.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="CC2652RB_LAUNCHXL.d_raw" --cmd_file="configPkg/compiler.opt"  "../CC2652RB_LAUNCHXL.c"
    >> Compilation failure
    subdir_rules.mk:9: recipe for target 'CC2652RB_LAUNCHXL.obj' failed
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"CC2652RB_LAUNCHXL_fxns.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="CC2652RB_LAUNCHXL_fxns.d_raw" --cmd_file="configPkg/compiler.opt"  "../CC2652RB_LAUNCHXL_fxns.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/AudioHAL.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"AudioHAL.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/AudioHAL.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/AudioHAL.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/AudioHAL.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/MCLKCC26XX.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"MCLKCC26XX.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/MCLKCC26XX.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/MCLKCC26XX.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/MCLKCC26XX.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHAL_I2C.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"AudioHAL_I2C.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/AudioHAL_I2C.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHAL_I2C.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHAL_I2C.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"crc.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/NV/crc.d_raw" --obj_directory="Drivers/NV" --cmd_file="configPkg/compiler.opt"  "../Drivers/NV/crc.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/TLV320AIC3254.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"TLV320AIC3254.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/TLV320AIC3254.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/TLV320AIC3254.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/TLV320AIC3254.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/stream/Packetizer.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"Packetizer.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioStream/Packetizer.d_raw" --obj_directory="AudioStream" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/stream/Packetizer.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/stream/Packetizer.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"gatt_uuid.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/gatt_uuid.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/gatt_uuid.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHALCodec.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"AudioHALCodec.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/AudioHALCodec.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHALCodec.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHALCodec.c"
    Building file: "../Application/peripheral_bidirectional_audio.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"peripheral_bidirectional_audio.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/peripheral_bidirectional_audio.d_raw" --obj_directory="Application" --cmd_file="configPkg/compiler.opt"  "../Application/peripheral_bidirectional_audio.c"
    Finished building: "../Application/peripheral_bidirectional_audio.c"
    Invoking: Arm Compiler
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ble_audio.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/ble_audio.d_raw" --obj_directory="Application" --cmd_file="configPkg/compiler.opt"  "../Application/ble_audio.c"
    Finished building: "../Application/ble_audio.c"
    Building file: "../Profiles/audio_profile_dle.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"audio_profile_dle.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/audio_profile_dle.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/audio_profile_dle.c"
    Finished building: "../Profiles/audio_profile_dle.c"
    Building file: "../Profiles/audio_client_disc.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"audio_client_disc.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/audio_client_disc.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/audio_client_disc.c"
    Finished building: "../Profiles/audio_client_disc.c"
    Building file: "../Startup/ccfg_app_ble.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ccfg_app_ble.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/ccfg_app_ble.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/ccfg_app_ble.c"
    Finished building: "../Startup/ccfg_app_ble.c"
    Building file: "../Startup/UartLog.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"UartLog.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/UartLog.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/UartLog.c"
    Finished building: "../Startup/UartLog.c"
    Building file: "../Startup/osal_icall_ble.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"osal_icall_ble.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/osal_icall_ble.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/osal_icall_ble.c"
    >> Compilation failure
    Startup/subdir_rules.mk:37: recipe for target 'Startup/osal_icall_ble.obj' failed
    "../Startup/osal_icall_ble.c", line 161: error #167: too few arguments in function call
    "../Startup/osal_icall_ble.c", line 165: error #167: too few arguments in function call
    2 errors detected in the compilation of "../Startup/osal_icall_ble.c".
    gmake: *** [Startup/osal_icall_ble.obj] Error 1
    Building file: "../Profiles/devinfoservice.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"devinfoservice.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/devinfoservice.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/devinfoservice.c"
    Finished building: "../Profiles/devinfoservice.c"
    Building file: "../Drivers/NV/nvocmp.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"nvocmp.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/NV/nvocmp.d_raw" --obj_directory="Drivers/NV" --cmd_file="configPkg/compiler.opt"  "../Drivers/NV/nvocmp.c"
    Finished building: "../Drivers/NV/nvocmp.c"
    Building file: "../Startup/ble_user_config_stack.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ble_user_config_stack.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/ble_user_config_stack.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/ble_user_config_stack.c"
    Finished building: "../Startup/ble_user_config_stack.c"
    Building file: "../Profiles/gattservapp_util.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"gattservapp_util.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/gattservapp_util.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/gattservapp_util.c"
    Finished building: "../Profiles/gattservapp_util.c"
    Building file: "../Startup/main.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"main.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/main.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/main.c"
    Finished building: "../Startup/main.c"
    Building file: "../Startup/rom_init.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"rom_init.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/rom_init.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/rom_init.c"
    Finished building: "../Startup/rom_init.c"
    Building file: "../iCall/icall_cc2650.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall_cc2650.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCall/icall_cc2650.d_raw" --obj_directory="iCall" --cmd_file="configPkg/compiler.opt"  "../iCall/icall_cc2650.c"
    Finished building: "../iCall/icall_cc2650.c"
    Building file: "../Util/util_assert.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"util_assert.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Util/util_assert.d_raw" --obj_directory="Util" --cmd_file="configPkg/compiler.opt"  "../Util/util_assert.c"
    Finished building: "../Util/util_assert.c"
    Building file: "../iCallBLE/ble_user_config.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ble_user_config.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCallBLE/ble_user_config.d_raw" --obj_directory="iCallBLE" --cmd_file="configPkg/compiler.opt"  "../iCallBLE/ble_user_config.c"
    >> Compilation failure
    iCallBLE/subdir_rules.mk:9: recipe for target 'iCallBLE/ble_user_config.obj' failed
    "../iCallBLE/ble_user_config.c", line 70: fatal error #1965: cannot open source file "ecc/ECCROMCC26XX.h"
    1 catastrophic error detected in the compilation of "../iCallBLE/ble_user_config.c".
    Compilation terminated.
    gmake: *** [iCallBLE/ble_user_config.obj] Error 1
    Building file: "../Util/util_clock.c"
    Invoking: Arm Compiler
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"util_clock.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Util/util_clock.d_raw" --obj_directory="Util" --cmd_file="configPkg/compiler.opt"  "../Util/util_clock.c"
    Finished building: "../Util/util_clock.c"
    Building file: "../Util/util_gap.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"util_gap.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Util/util_gap.d_raw" --obj_directory="Util" --cmd_file="configPkg/compiler.opt"  "../Util/util_gap.c"
    Finished building: "../Util/util_gap.c"
    Building file: "../Util/util_queue.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"util_queue.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Util/util_queue.d_raw" --obj_directory="Util" --cmd_file="configPkg/compiler.opt"  "../Util/util_queue.c"
    Finished building: "../Util/util_queue.c"
    Building file: "../iCall/icall_user_config.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall_user_config.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCall/icall_user_config.d_raw" --obj_directory="iCall" --cmd_file="configPkg/compiler.opt"  "../iCall/icall_user_config.c"
    Finished building: "../iCall/icall_user_config.c"
    Building file: "../iCallBLE/icall_api_lite.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall_api_lite.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCallBLE/icall_api_lite.d_raw" --obj_directory="iCallBLE" --cmd_file="configPkg/compiler.opt"  "../iCallBLE/icall_api_lite.c"
    Finished building: "../iCallBLE/icall_api_lite.c"
    Building file: "../iCall/icall.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCall/icall.d_raw" --obj_directory="iCall" --cmd_file="configPkg/compiler.opt"  "../iCall/icall.c"
    Finished building: "../iCall/icall.c"
    Building file: "../iCallBLE/icall_hci_tl.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/peripheral_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/peripheral_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall_hci_tl.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCallBLE/icall_hci_tl.d_raw" --obj_directory="iCallBLE" --cmd_file="configPkg/compiler.opt"  "../iCallBLE/icall_hci_tl.c"
    Finished building: "../iCallBLE/icall_hci_tl.c"
    gmake: Target 'all' not remade because of errors.
    **** Build Finished ****
    **** Clean-only build of configuration Debug for project central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs ****
    "C:\\ti\\ccs1030\\ccs\\utils\\bin\\gmake" -k -j 8 clean -O
    cleaning ../src/sysbios ...
    DEL /F  "central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs.hex"  "configPkg\linker.cmd" "configPkg\compiler.opt"  "central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs.out"
    DEL /F "CC2652RB_LAUNCHXL.obj" "CC2652RB_LAUNCHXL_fxns.obj" "ti_radio_config.obj" "Application\ble_audio.obj" "Application\board_key.obj" "Application\central_bidirectional_audio.obj" "Application\central_bidirectional_audio_menu.obj" "Application\two_btn_menu.obj" "AudioHAL\AudioHAL.obj" "AudioHAL\AudioHALCodec.obj" "AudioHAL\AudioHAL_I2C.obj" "AudioHAL\MCLKCC26XX.obj" "AudioHAL\TLV320AIC3254.obj" "AudioStream\Packetizer.obj" "Drivers\NV\crc.obj" "Drivers\NV\nvocmp.obj" "Profiles\audio_client_disc.obj" "Profiles\audio_profile_dle.obj" "Profiles\devinfoservice.obj" "Profiles\gatt_uuid.obj" "Profiles\gattservapp_util.obj" "Startup\UartLog.obj" "Startup\ble_user_config_stack.obj" "Startup\ccfg_app_ble.obj" "Startup\main.obj" "Startup\osal_icall_ble.obj" "Startup\rom_init.obj" "Util\util_assert.obj" "Util\util_clock.obj" "Util\util_gap.obj" "Util\util_queue.obj" "iCall\icall.obj" "iCall\icall_cc2650.obj" "iCall\icall_user_config.obj" "iCallBLE\ble_user_config.obj" "iCallBLE\icall_api_lite.obj" "iCallBLE\icall_hci_tl.obj"
    DEL /F "CC2652RB_LAUNCHXL.d" "CC2652RB_LAUNCHXL_fxns.d" "ti_radio_config.d" "Application\ble_audio.d" "Application\board_key.d" "Application\central_bidirectional_audio.d" "Application\central_bidirectional_audio_menu.d" "Application\two_btn_menu.d" "AudioHAL\AudioHAL.d" "AudioHAL\AudioHALCodec.d" "AudioHAL\AudioHAL_I2C.d" "AudioHAL\MCLKCC26XX.d" "AudioHAL\TLV320AIC3254.d" "AudioStream\Packetizer.d" "Drivers\NV\crc.d" "Drivers\NV\nvocmp.d" "Profiles\audio_client_disc.d" "Profiles\audio_profile_dle.d" "Profiles\devinfoservice.d" "Profiles\gatt_uuid.d" "Profiles\gattservapp_util.d" "Startup\UartLog.d" "Startup\ble_user_config_stack.d" "Startup\ccfg_app_ble.d" "Startup\main.d" "Startup\osal_icall_ble.d" "Startup\rom_init.d" "Util\util_assert.d" "Util\util_clock.d" "Util\util_gap.d" "Util\util_queue.d" "iCall\icall.d" "iCall\icall_cc2650.d" "iCall\icall_user_config.d" "iCallBLE\ble_user_config.d" "iCallBLE\icall_api_lite.d" "iCallBLE\icall_hci_tl.d"
    RMDIR /S/Q  "configPkg\"
    Could Not Find C:\Users\tscha\workspace_v10\central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs\Debug\central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs.hex
    Could Not Find C:\Users\tscha\workspace_v10\central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs\Debug\central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs.out
    Finished clean
    **** Build of configuration Debug for project central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs ****
    "C:\\ti\\ccs1030\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
    Building file: "../central_bidirectional_audio_app.cfg"
    Invoking: XDCtools
    "C:/ti/ccs1030/xdctools_3_62_00_08_core/xs" --xdcpath="C:/ti/simplelink_audio_plugin_3_30_00_06/source;C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source;C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M4F -p ti.platforms.simplelink:CC2642R1F -r release -c "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS" --compileOptions "-mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path=\"C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs\" --include_path=\"C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application\" --include_path=\"C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util\" --include_path=\"C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles\" --include_path=\"C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream\" --include_path=\"C:/ti/simplelink_audio_plugin_3_30_00_06/source\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/\" --include_path=\"C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs\" --include_path=\"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include\" --define=uartlog_FILE=\"\"\"\" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi  " "../central_bidirectional_audio_app.cfg"
    making package.mak (because of package.bld) ...
    generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
    configuring central_bidirectional_audio_app.xem4f from package/cfg/central_bidirectional_audio_app_pem4f.cfg ...
    generating custom ti.sysbios library makefile ...
    Starting build of library sources ...
    making C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/src/sysbios/sysbios.aem4f ...
    clem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/BIOS.c ...
    asmem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi_asm.sv7M ...
    asmem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi_asm_switch.sv7M ...
    asmem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/IntrinsicsSupport_asm.sv7M ...
    asmem4f C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/kernel/tirtos/packages/ti/sysbios/family/arm/m3/TaskSupport_asm.sv7M ...
    arem4f BIOS.obj m3_Hwi_asm.obj m3_Hwi_asm_switch.obj m3_IntrinsicsSupport_asm.obj m3_TaskSupport_asm.obj ...
    Build of libraries done.
    clem4f package/cfg/central_bidirectional_audio_app_pem4f.c ...
    Finished building: "../central_bidirectional_audio_app.cfg"
            1 file(s) copied.
    making ../src/sysbios/sysbios.aem4f ...
    gmake[1]: Nothing to be done for 'all'.
    Building file: "../ti_radio_config.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ti_radio_config.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ti_radio_config.d_raw" --cmd_file="configPkg/compiler.opt"  "../ti_radio_config.c"
    >> Compilation failure
    subdir_rules.mk:37: recipe for target 'ti_radio_config.obj' failed
    "../ti_radio_config.c", line 83: error #60: function call is not allowed in a constant expression
    1 error detected in the compilation of "../ti_radio_config.c".
    gmake: *** [ti_radio_config.obj] Error 1
    Building file: "../CC2652RB_LAUNCHXL_fxns.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"CC2652RB_LAUNCHXL_fxns.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="CC2652RB_LAUNCHXL_fxns.d_raw" --cmd_file="configPkg/compiler.opt"  "../CC2652RB_LAUNCHXL_fxns.c"
    Finished building: "../CC2652RB_LAUNCHXL_fxns.c"
    Building file: "../CC2652RB_LAUNCHXL.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"CC2652RB_LAUNCHXL.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="CC2652RB_LAUNCHXL.d_raw" --cmd_file="configPkg/compiler.opt"  "../CC2652RB_LAUNCHXL.c"
    >> Compilation failure
    subdir_rules.mk:9: recipe for target 'CC2652RB_LAUNCHXL.obj' failed
    "../CC2652RB_LAUNCHXL.c", line 720: error #20: identifier "I2CCC26XX_fxnTable" is undefined
    "../CC2652RB_LAUNCHXL.c", line 720: error #137: struct "I2C_Config_" has no field "fxnTablePtr"
    2 errors detected in the compilation of "../CC2652RB_LAUNCHXL.c".
    gmake: *** [CC2652RB_LAUNCHXL.obj] Error 1
    Building file: "../Application/two_btn_menu.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"two_btn_menu.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/two_btn_menu.d_raw" --obj_directory="Application" --cmd_file="configPkg/compiler.opt"  "../Application/two_btn_menu.c"
    Finished building: "../Application/two_btn_menu.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/AudioHAL.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"AudioHAL.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/AudioHAL.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/AudioHAL.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/AudioHAL.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/MCLKCC26XX.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"MCLKCC26XX.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/MCLKCC26XX.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/MCLKCC26XX.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/MCLKCC26XX.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHAL_I2C.c"
    Invoking: Arm Compiler
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"AudioHAL_I2C.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/AudioHAL_I2C.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHAL_I2C.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHAL_I2C.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/TLV320AIC3254.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"TLV320AIC3254.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/TLV320AIC3254.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/TLV320AIC3254.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/TLV320AIC3254.c"
    Building file: "../Drivers/NV/crc.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"crc.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/NV/crc.d_raw" --obj_directory="Drivers/NV" --cmd_file="configPkg/compiler.opt"  "../Drivers/NV/crc.c"
    Finished building: "../Drivers/NV/crc.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/stream/Packetizer.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"Packetizer.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioStream/Packetizer.d_raw" --obj_directory="AudioStream" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/stream/Packetizer.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/stream/Packetizer.c"
    Building file: "../Application/central_bidirectional_audio_menu.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"central_bidirectional_audio_menu.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/central_bidirectional_audio_menu.d_raw" --obj_directory="Application" --cmd_file="configPkg/compiler.opt"  "../Application/central_bidirectional_audio_menu.c"
    Finished building: "../Application/central_bidirectional_audio_menu.c"
    Building file: "../Application/board_key.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"board_key.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/board_key.d_raw" --obj_directory="Application" --cmd_file="configPkg/compiler.opt"  "../Application/board_key.c"
    Finished building: "../Application/board_key.c"
    Building file: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHALCodec.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"AudioHALCodec.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="AudioHAL/AudioHALCodec.d_raw" --obj_directory="AudioHAL" --cmd_file="configPkg/compiler.opt"  "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHALCodec.c"
    Finished building: "C:/ti/simplelink_audio_plugin_3_30_00_06/source/ti/audio/hal/codec/AudioHALCodec.c"
    Building file: "../Application/ble_audio.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ble_audio.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/ble_audio.d_raw" --obj_directory="Application" --cmd_file="configPkg/compiler.opt"  "../Application/ble_audio.c"
    Finished building: "../Application/ble_audio.c"
    Building file: "../Application/central_bidirectional_audio.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"central_bidirectional_audio.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/central_bidirectional_audio.d_raw" --obj_directory="Application" --cmd_file="configPkg/compiler.opt"  "../Application/central_bidirectional_audio.c"
    Finished building: "../Application/central_bidirectional_audio.c"
    Building file: "../Profiles/gatt_uuid.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"gatt_uuid.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/gatt_uuid.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/gatt_uuid.c"
    Finished building: "../Profiles/gatt_uuid.c"
    Building file: "../Profiles/audio_client_disc.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"audio_client_disc.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/audio_client_disc.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/audio_client_disc.c"
    Finished building: "../Profiles/audio_client_disc.c"
    Building file: "../Profiles/audio_profile_dle.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"audio_profile_dle.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/audio_profile_dle.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/audio_profile_dle.c"
    Finished building: "../Profiles/audio_profile_dle.c"
    Building file: "../Startup/ccfg_app_ble.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ccfg_app_ble.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/ccfg_app_ble.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/ccfg_app_ble.c"
    Finished building: "../Startup/ccfg_app_ble.c"
    Building file: "../Startup/UartLog.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"UartLog.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/UartLog.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/UartLog.c"
    Finished building: "../Startup/UartLog.c"
    Building file: "../Startup/osal_icall_ble.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"osal_icall_ble.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/osal_icall_ble.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/osal_icall_ble.c"
    >> Compilation failure
    Startup/subdir_rules.mk:37: recipe for target 'Startup/osal_icall_ble.obj' failed
    "../Startup/osal_icall_ble.c", line 161: error #167: too few arguments in function call
    "../Startup/osal_icall_ble.c", line 165: error #167: too few arguments in function call
    2 errors detected in the compilation of "../Startup/osal_icall_ble.c".
    gmake: *** [Startup/osal_icall_ble.obj] Error 1
    Building file: "../Drivers/NV/nvocmp.c"
    Invoking: Arm Compiler
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"nvocmp.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/NV/nvocmp.d_raw" --obj_directory="Drivers/NV" --cmd_file="configPkg/compiler.opt"  "../Drivers/NV/nvocmp.c"
    Finished building: "../Drivers/NV/nvocmp.c"
    Building file: "../Profiles/devinfoservice.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"devinfoservice.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/devinfoservice.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/devinfoservice.c"
    Finished building: "../Profiles/devinfoservice.c"
    Building file: "../Startup/ble_user_config_stack.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ble_user_config_stack.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/ble_user_config_stack.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/ble_user_config_stack.c"
    Finished building: "../Startup/ble_user_config_stack.c"
    Building file: "../Profiles/gattservapp_util.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"gattservapp_util.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Profiles/gattservapp_util.d_raw" --obj_directory="Profiles" --cmd_file="configPkg/compiler.opt"  "../Profiles/gattservapp_util.c"
    Finished building: "../Profiles/gattservapp_util.c"
    Building file: "../Startup/rom_init.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"rom_init.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/rom_init.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/rom_init.c"
    Finished building: "../Startup/rom_init.c"
    Building file: "../Startup/main.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"main.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/main.d_raw" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt"  "../Startup/main.c"
    Finished building: "../Startup/main.c"
    Building file: "../iCall/icall_cc2650.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall_cc2650.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCall/icall_cc2650.d_raw" --obj_directory="iCall" --cmd_file="configPkg/compiler.opt"  "../iCall/icall_cc2650.c"
    Finished building: "../iCall/icall_cc2650.c"
    Building file: "../Util/util_assert.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"util_assert.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Util/util_assert.d_raw" --obj_directory="Util" --cmd_file="configPkg/compiler.opt"  "../Util/util_assert.c"
    Finished building: "../Util/util_assert.c"
    Building file: "../Util/util_clock.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"util_clock.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Util/util_clock.d_raw" --obj_directory="Util" --cmd_file="configPkg/compiler.opt"  "../Util/util_clock.c"
    Finished building: "../Util/util_clock.c"
    Building file: "../Util/util_queue.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"util_queue.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Util/util_queue.d_raw" --obj_directory="Util" --cmd_file="configPkg/compiler.opt"  "../Util/util_queue.c"
    Finished building: "../Util/util_queue.c"
    Building file: "../iCallBLE/ble_user_config.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"ble_user_config.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCallBLE/ble_user_config.d_raw" --obj_directory="iCallBLE" --cmd_file="configPkg/compiler.opt"  "../iCallBLE/ble_user_config.c"
    >> Compilation failure
    iCallBLE/subdir_rules.mk:9: recipe for target 'iCallBLE/ble_user_config.obj' failed
    "../iCallBLE/ble_user_config.c", line 70: fatal error #1965: cannot open source file "ecc/ECCROMCC26XX.h"
    1 catastrophic error detected in the compilation of "../iCallBLE/ble_user_config.c".
    Compilation terminated.
    gmake: *** [iCallBLE/ble_user_config.obj] Error 1
    Building file: "../Util/util_gap.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"util_gap.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Util/util_gap.d_raw" --obj_directory="Util" --cmd_file="configPkg/compiler.opt"  "../Util/util_gap.c"
    Finished building: "../Util/util_gap.c"
    Building file: "../iCallBLE/icall_api_lite.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall_api_lite.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCallBLE/icall_api_lite.d_raw" --obj_directory="iCallBLE" --cmd_file="configPkg/compiler.opt"  "../iCallBLE/icall_api_lite.c"
    Finished building: "../iCallBLE/icall_api_lite.c"
    Building file: "../iCall/icall_user_config.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall_user_config.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCall/icall_user_config.d_raw" --obj_directory="iCall" --cmd_file="configPkg/compiler.opt"  "../iCall/icall_user_config.c"
    Finished building: "../iCall/icall_user_config.c"
    Building file: "../iCall/icall.c"
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCall/icall.d_raw" --obj_directory="iCall" --cmd_file="configPkg/compiler.opt"  "../iCall/icall.c"
    Finished building: "../iCall/icall.c"
    Building file: "../iCallBLE/icall_hci_tl.c"
    Invoking: Arm Compiler
    "C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Tools/Defines/central_bidirectional_audio_app.opt" --cmd_file="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/build_config.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/config/factory_config.opt"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Application" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Util" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/Profiles" --include_path="C:/Users/tscha/workspace_v10/central_bidirectional_audio_CC2652RB_LAUNCHXL_tirtos_ccs/AudioStream" --include_path="C:/ti/simplelink_audio_plugin_3_30_00_06/source" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/npi/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx/rcosc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/target" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/heapmgr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/dev_info" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/profiles/simple_profile" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/ble5stack/services/src/sdata" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/devices/cc13x2_cc26x2/driverlib/" --include_path="C:/ti/simplelink_cc13x2_26x2_sdk_5_10_00_48/source/ti/posix/ccs" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=uartlog_FILE="\"icall_hci_tl.c\"" --define=DeviceFamily_CC26X2 --define=CC26X2R1_LAUNCHXL --define=CC26X2 --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="iCallBLE/icall_hci_tl.d_raw" --obj_directory="iCallBLE" --cmd_file="configPkg/compiler.opt"  "../iCallBLE/icall_hci_tl.c"
    Finished building: "../iCallBLE/icall_hci_tl.c"
    gmake: Target 'all' not remade because of errors.
    **** Build Finished ****
    当我导入音频项目时、我会收到一条警告、该警告可能很重要、也可能不重要:
    您好、Tom、
    在这两种情况下(本地 CCS 和 CCS 云)、问题都是由使用的 SDK 版本引起的。 SimpleLink 音频插件应与 SIMPLELINK-CC13X2-26X2-SDK 3.30配合使用。
    如果您有更多问题、请告诉我。
    好的、这使事情变得更糟、谢谢。  HA 哈。
    我设法将 SDK 版本恢复到 v3.30、并在 Windows 上的 CCS 10.3中成功编译了音频示例。
    但是、当我运行示例时、我没有任何东西、没有 UART 输出、没有蓝牙 ID 等
    现在... 即使我尝试使用 v5.10 SDK (以前使用过)重新加载 project_zero ... 没有。  无 UART、无 BT。  调试器启动、单步执行等操作正常。  不确定它在哪里死去。
    此时电路板会被砖砌。
    是否有人可以在  LP-CC2652RB 上实际运行这些音频示例并确认它们仍然可以正常工作?
    似乎他们没有、或者我没有使用正确的配置。
    供参考: 他们的新 PROJECT_ZERO 崩溃了。  不确定这是否有用。  我将看到我是否可以弄清楚如何擦除电路板并重新开始。
    我设法使用 Uniflash 和十六进制文件使电路板恢复运行:
    simplelink_cc13x2_26x2_sdk_3_30_00_03\examples\rtos\cc2652rb_LAUNCHXL\ble5stack\hexfiles\project_zero_unsecure_app.hex
    如果我尝试构建并运行音频示例文件、它会再次将其砖墙。
    中央_双向_音频_CC2652RB_LAUNCHXL_tirtos_ccs
    外设_双向_音频_CC2652RB_LAUNCHXL_tirtos_ccs
    对于上述示例、非常有用的是几个十六进制文件、因此我可以确认此示例的操作。  我搜索过、但找不到任何预编译文件。
    您好、Tom、
    您能否确认在 CC2652RB Launchpad 上正确设置 CC3200AUDBOOST 的情况下运行音频示例? 如果不是、这将导致问题。
    由于出口法规、我不允许在公共论坛上共享十六进制文件。
    我安装了电路板、如本示例所示:
    https://dev.ti.com/tirex/explore/node?node=AFqrqQ6ChsQGd9nzgnY9Sg__RW99gST__LATEST
    1.是否有人可以确认此示例目前是否有效?
    2.您能告诉我您正在使用的配置吗?
    Code Composer 版本、 simplelink_cc13x2_26x2_SDK 版本、 peripheral_bidirectal_audio 版本、tirtos 版本?  我可能会丢失任何其他内容。  我认为这是一个基本配置问题。
    代码出现故障、如下所示。  无论是否存在音频板、它都能执行相同的操作。  我运行了 i2secho 程序、该程序看起来工作正常(即它不会崩溃、如下所示)。
    如果您可以将示例十六进制文件发送到我的电子邮件地址、那可以吗?
    您好、Tom、
    首先、我要感谢您的耐心等待、并对给您带来的不便深表歉意。  老实说、BAW 器件上的音频示例没有那么多使用-请注意、您可以评估 CC2642R 上的示例。
    我已经研究过这个问题,我发现了两个需要修改的内容。
    1:CCFG 配置不正确。 应在 ccfg.c 中修改以下代码:
    // Special HF clock source setting
    #ifndef SET_CCFG_MODE_CONF_XOSC_FREQ
    // #define SET_CCFG_MODE_CONF_XOSC_FREQ 0x0 // HF source is 48 MHz TCXO
    #define SET_CCFG_MODE_CONF_XOSC_FREQ 0x1 // HF source is HPOSC (BAW) (only valid for CC2652RB) // ==> Uncomment this line
    //#define SET_CCFG_MODE_CONF_XOSC_FREQ 0x2 // HF source is a 48 MHz xtal  ==> Comment this line
    // #define SET_CCFG_MODE_CONF_XOSC_FREQ 0x3 // HF source is a 24 MHz xtal (not supported)
    #endif
    在 CCS 中、您可能希望使用以下文件覆盖项目中的文件 Startup\ccfg_app_ble.c: /cfs-file/__key/communityserver-discussions-components-files/538/8360.ccfg_5F00_app_5F00_ble.c
    2 -一个预定义符号有一个拼写错误。
    在 CCS 中、右键单击您的项目>属性>构建>预定义符号、删除符号"CC26X2R1_LAUNCHXl"并添加符号"CC2652RB_LAUNCHXl"。
    应针对 central_bidirectional 音频_CC2652RB_LAUNCHXL_tirtos_ccs 和 peripheral_bidirectional 音频_CC2652RB_LAUNCHXL_tirtos_ccs 应用这两个修复。
    感谢您的努力。  这似乎有所帮助。
    SDK 中有很多 ccfg.c。  为清楚说明、我相信您参考的是以下文件:
    这在本地工程的 ccfg_app_ble.c 中引用:
    至于使用8360/ccfg_app_ble.c 文件、您说可以*交替*完成此操作、而不是如上所示编辑文件、建议的更改与其他代码更改无关。
     将 830.ccfg_app_ble.c 文件的内容复制到项目的 ccfg_app_ble.c 文件中、并更改预定义符号后、我现在可以进行 UART 通信!
    外设
    中央(请注意、Tera Term 的 VT100终端模式不适用于中央、我必须使用 Putty)
    对于其他人、当演示说明中提到"左键"和"右键"时、他们谈论的是 LP 板按钮、而不是键盘输入。  您还需要稍微按住这些键、以获得预期的响应。
    问题:
    是否可以在  LAUNCHXL-CC26X2R1中开箱即用?
    2.如果我获得该 Launchpad、那么我应该撤消刚才所做的更改还是恢复到原始 代码?
    LAUNCHXL-CC26X2R1 (CPU = CC2652R)
    LP-CC2652RB (CPU = CC2652RB)
    演示现在主要起作用、central 音频连接到 peripheral_audio。  它随后几乎立即断开连接、但我将对此进行处理、如果问题仍然存在、我将提出一个新问题。
    干得不错! 感谢您分享所有这些详细信息。
    1 -我帮助纠正的问题不会影响 CC2652R -实际上是由于在 CC2652RB 上使用 CC2652R 设置导致的
    正确、使用 LAUNCHXL-CC26X2R1、无需更改代码。 如果您仅修改了文件 Startup\ccfg_app_ble.c 和预定义符号、则不需要恢复-因为这些符号仅影响工程。 我建议恢复所有其他更改。
    最后、断开连接问题是由于环境导致数据包丢失。 在噪声较低的环境中、您可能会避免这种情况。
    开箱即用示例包含一段代码、如果错过了3个以上的数据包、则强制断开连接。 注释掉文件 ble_audio.c 的第436行可以安全地启用此功能
          Log_warning1("Connection Event Error: %s", (uintptr_t)statusStr);
          missedPackets++;
          if(missedPackets == BLEAUDIO_BUF_DEPTH)
            Log_warning0("Missed packets > buffer length, stopping stream and connection");
            /* If we have missed more events that can be accounted for by the
             * amount of buffer space then stop the stream */
            //BleAudio_stopStream(); // ==> Comment out this line
