[参考译文] CC2564C:TI/PAN1316C 协议栈是否支持 A2DP v1.3 BT 规范要求的低复杂性子频带编解码器?
Guru**** 2803255 points
Other Parts Discussed in Thread: CC2564C
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/828038/cc2564c-does-ti-pan1316c-stack-support-low-complexity-sub-band-codec-as-is-required-by-a2dp-v1-3-bt-specification
器件型号:CC2564C
根据 A2DP v1.3 BT 规范的要求、TI/PAN1316C 栈是否支持低复杂性子频带编解码器?
