Thread 中讨论的其他器件: CC2650、 SYSBIOS
我使用的是 SimpleLink CC2640板。 我已经安装了 ble_cc26xx_setupwin32_2_01_00_44423和 IAR 7.30。 但在编译代码期间、我遇到以下错误:
在本例中、我尝试构建 SimpleBLEPeripheral.c
构建配置:CC2640App - FlashROM
正在更新生成树...
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\configPkg\package.mak
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\board_LCD.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\simpleBLEPeripheral.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\util.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\iCall.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\ICallCC2650.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\bleUserConfig.PBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\ICallBleAPI.PBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\devinfoservice.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\GATT_uuid.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashROM_Obj\gattservapp_util.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\peripheral.PBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\simpleGATTprofile.PBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\Board.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashROM_Obj\ccfg_appBLE.pBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashROM\Obj\main.PBI
C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashRO\Obj\CC2640App.pBD
已 删除17个文件。
正在更新生成树...
执行预编译操作
"C:\ti\xdctools_3_31_01_33_core/xs"-xdcpath="C:\ti_tirtos_simplelink_2_13_00_06\products\BIOS_6_42_00_08\packages " IAR.tools.configuro -c "C:\
程序文件(x86)\IAR Systems\Embedded Workbench 7.0\ARM"--cc "C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.0\ARm\bin\
iccarm.exe"--device "CC2640F128"--compileOptions "-D use_ICALL -D power_saving -D HEAPMGR_size=2672 -D
TI_DRIVERS_SPI_DMA_INCLUDED TI_DRIVERS_LCD_INCLUDED ICALL_MAX_NUM_TES=3 -D ICALL_MAX_NUM_ENTIES=6 -D
xdc_runtime_assert_disable_all -D xdc_runtime_Log_disable_all -D CC26XXWARE -D CC26XX --diag_suppress Pa050 -o C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\FlashROM\Obj\--debug --endian=little --cpu=Cortex-M3
f C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\projects\ble\config\
buildComponents.opt -f C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\configPkg\
compiler.opt.defs -f C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\..\Config\
IAR-Boundary.bdef -e --FPU=None --dlib_config \"C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.0\arm\INC\c\DLib_Config_Normal.h\"-i C:\
TI\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\-I C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../Source/Application -I C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Projects/ble/Include -I C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Projects/ble/ICall/Include -I C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Projects/ble/Profiles/Roles/CC26xx -I C:\ti\
simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Projects/ble/Profiles/Roles -I C:\
TI\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Projects/ble/Profiles/DevInfo -I
CC2640/。/../../../../../../Projects/ble/Profiles/SimpleProfile/CC26xx - I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\
CC26xx\IAR\Application\CC2640/。/../../../../../../Projects/ble/Profiles/SimpleProfile -I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\
SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Projects/ble/common/cc26xx -I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\
BLE\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/applib/heap - I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\
BLE\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/ble/hci - I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\
SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/ble/controller/CC26xx/include -I C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/ble/host -I C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/hal/target/CC2650/rom -I C:\ti\
CC2640/。/../../../../../../Components/hal/target/CC2650TIRTOS - I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\
IAR\Application\CC2640/。/../../../../../../Components/hal/target/_common/cc26xx - I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\
SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/hal/include -I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\
SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/osal/include -I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\
SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/services/sdata -I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\
BLE\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/services/saddr - I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\
项目\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/./../../../../../../Components/icall/include -I C:\ti\simplelink\ble_cc26xx_2_01_00_44423\
项目\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640/。/../../../../../../Components/ble/include - I C:\ti_tirtos_simplelink_2_13_00_06\products\
cc26xxware_2_21_01_15600\-I C:\ti_tirtos_simplelink_2_13_00_06\packages/i C:\ti_tirtos_simplelink_2_13_00_06\packages\ti\boards\SRF06EB\
CC2650EM_7ID\-Ohz"-linkOptions "-o C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\
FlashROM\EXE\SimpleBLEPeripheralAppFlashROM.out --map C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\
IAR\Application\CC2640\FlashRO\List\SimpleBLEPeripheralAppFlashROM.map --config C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\
SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\..\..\..\..\common\cc26xx\IAR\cc26xx_ble_app.ICF --keep __vector_table -f C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\configPkg\linker.cmd -f C:\ti\simplelink\
BLE_cc26xx_2_01_00_44423\projects\ble\SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\..\Config\IAR-Boundary.xcl C:\ti\
tirtos_simplelink_2_13_00_06\products\cc26xxware_2_21_01_15600\driverlib\bin\IAR\driverlib.lib C:\ti_tirtos_simplelink_2_13_00_06\packages/ti\drivers\lib\
drivers_cc26xxware.arm3 --entry __IAR_program_start --vfe"--profile 发行版--projFile "C:\ti\simplelink\ble_cc26xx_2_01_00_44423\projects\ble\
SimpleBLEPeripheral\CC26xx\IAR\Application\CC2640\CC2640App.EWP"
使用 RTSC 配置文件:C:/ti/simplelink/ble_cc26xx_2_01_00_44423/Projects/ble/SimpleBLEPeripheral/CC26xx/IAR/Application/CC2640/..。\Config\
appBLE.cfg...
正在制作 package.mak (由于 package.bld)...
从 package/cfg/appBLE_prm3.cfg 配置 appBLE.xrm3 ...
警告:xdc.cfg.Program:"c:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/hal/Hwi.xs、第181行:xdc.cfg.Program
STACK:对于 IAR 目标、忽略 Program.STACK。 C 和 Hwi 堆栈大小由链接器内 CSTACK 段定义的大小决定
命令文件。
警告:xdc.cfg.incompatible _target_version:当前目标'IAR.target.arm.m3'使用的编译器版本[7.30.4.8167]不兼容
与用于构建以下软件包的目标编译器版本兼容;软件包 IAR.targets.arm.rts [在
C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/iar/targets/arm/rts //]是使用带有编译器的目标'IAR.targets.arm.m3'构建的
版本[7.40.2.18]。
;包 ti.sysbios [在 C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios 中/]是使用目标'IAR.targets.arm.m3'构建的
编译器版本[7.40.2.18]。
;包 ti.sysbios.KNL [在 C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/knl 中/]是使用目标构建的
'IAR.targets.arm.m3'的编译器版本[7.40.2.18]。
;包 ti.sysbios.family.arm.m3 [在 C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/family/arm/m3中]是使用构建的
编译器版本为[7.40.2.18]的目标'IAR.targets.arm.m3'。
;软件包 ti.sysbios.family.arm.cc26xx [在 C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/family/arm/cc26xx 中]为
使用目标'IAR.targets.arm.m3'和编译器版本[7.40.2.18]构建。
;包 ti.sysbios.hal [在 C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/hal 中/]是使用目标构建的
;包 ti.sysbios.堆[in C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/heaps //]是使用目标构建的
;包 ti.sysbios.gates [在 C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/gates 中/]是使用目标构建的
;软件包 ti.sysbios.xdcruntime [在 C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/xdcruntime 中/]是使用构建的
目标'IAR.targets.arm.m3'的编译器版本[7.40.2.18]。
;包 ti.sysbios.utils [在 C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/ti/sysbios/utils 中/]是使用目标构建的
正在生成自定义 ROM 库 makefile ...
正在开始构建库源...
制作 C:/ti/simplelink/ble_cc26xx_2_01_00_44423/Projects/ble/SimpleBLEPeripheral/CC26xx/IAR/Config/src/sysbios/sysbios.arm3 ...
gmake[1]:输入目录`C:/ti/simplelink/ble_cc26xx_2_01_00_44423/Projects/ble/SimpleBLEPeripheral/CC26xx/IAR/Config/src/sysbios
预处理库源文件...
C:/Users/faleas1/AppData/Local/Temp/make1736-5.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-2.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-3.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-4.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-6.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-7.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-8.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-9.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-b.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-a.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-10.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-d.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-c.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-f.sh:1:语法错误:"("意外
C:/Users/faleas1/AppData/Local/Temp/make1736-e.sh:1:语法错误:"("意外
gmake[1]:***[man翻转_BIOS_lib.pp]错误2.
gmaking[1]:***正在等待未完成的作业...
gmaked[1]:***[manifed_ti.sysbios.BIOS_config_lib.pp]错误2.
gmake[1]:***[manifed_ti.sysbios.BIOS_rtsGateProxy_config_lib.ppp]错误2.
gmaked[1]:***[MAN翻转_KNL_Clock_lib.pp]错误2.
gmaked[1]:***[man翻转_KNL_Intrinsics_lib.ppp]错误2.
gmaked[1]:***[MAN翻转_KNL_Event_lib.pp]错误2.
gmaked[1]:***[manifl_ti.sysbios.KNL.Mailbox_config_lib.ppp]错误2.
gmaked[1]:***[MAN翻转_KNL_Queue_lib.pp]错误2.
gmaked[1]:***[man翻转_KNL_Swi_lib.ppp]错误2.
C:/Users/faleas1/AppData/Local/Temp/make1736-1.sh:1:语法错误:"("意外
gmaked[1]:***[manifl_ti.sysbios.KNL.Clock_config_lib.ppp]错误2.
gmaked[1]:***[man翻转_KNL_Swi_andn_lib.ppp]错误2.
gmaked[1]:***[man翻转_KNL_Idle_lib.ppp]错误2.
gmaked[1]:***[man翻转_KNL_Mailbox_lib.ppp]错误2.
gmaked[1]:***[manifl_ti.sysbios.KNL.Queue_config_lib.ppp]错误2.
gmake[1]:***[man翻转_KNL_Semaphore_lib.pp]错误2.
gmake[1]:***[manifl_ti.sysbios.KNL.semaphore_config_lib.ppp]错误2.
gmake[1]:离开目录`C:/ti/simplelink/ble_cc26xx_2_01_00_44423/Projects/ble/SimpleBLEPeripheral/CC26xx/IAR/Config/src/sysbios
gmake:***[C:/ti/simplelink/ble_cc26xx_2_01_00_44423/Projects/ble/SimpleBLEPeripheral/CC26xx/IAR/Config/src/sysbios/sysbios.arm3 ]错误2.
库构建失败。
错误:xdc.cfg.SourceDir:"c:/ti/xdctools_3_31_01_33_core/packages/xdc/cfg/SourceDir.xs,第209行:xdc.cfg.SourceDir:生成的源代码的构建
库失败:退出状态= 2:
JS:"c:/ti/xdctools_3_31_01_33_core/packages/xdc/cfg/Main.xs、第160行:错误:配置失败!
gmake.exe:***[package/cfg/appBLE_prm3.xdl]错误1.
gmake.exe:***删除文件`package/cfg/appBLE_prm3.xdl'
gmake.exe:***[package/cfg/appBLE_prm3.xdl]删除文件`package/cfg/appBLE_prm3.h'
gmake.exe:***[package/cfg/appBLE_prm3.xdl]删除文件`package/cfg/appBLE_prm3.c'
JS:"c:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/iar/tools/configuro/Main.xs、第93行:错误:xdc.tools.configuro:配置
由于早期错误(状态= 2)而失败;已删除'linker.cmd'。
运行"C:\ti\xdctools_3_31_01_33_core/xs"-xdcpath="C:\ti_tirtos_simplelink_2_13_00_06\products\BIOS_6_42_00_08\packages 时出错"
iar.tools.configuro -c "C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.0\ARM"--cc "C:\Program Files (x86)\IAR Systems\Embedded
Workbench 7.0\arm\bin\iccarm.exe"--device "CC2640F128"--compileOptions "-D use_ICALL -D power_saving -D HEAPMGR_size=2672 -D
错误总数:1.
警告总数:0
