[参考译文] 编译器/CC2640R2F:编译器演示错误
Guru**** 2573695 points
Other Parts Discussed in Thread: CC2640R2F, CC2650, SYSBIOS
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/588148/compiler-cc2640r2f-compiler-demo-errors
器件型号:CC2640R2F
Thread 中讨论的其他器件: CC2650SYSBIOS
工具/软件:TI C/C++编译器
你(们)好
我使用 IAR for ARM V8.10.1编译 simple_peripheral_oad_offchip 工作区。  编译器向我抛出异常、如下所示:
构建配置:cc2640r2lp_app - FlashROM_OAD_Offchip
正在更新生成树...
执行预编译操作
"C:\ti\xdctools_3_50_00_10_core/xs"-xdcpath="C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\cc2640R2_LAUNCHXL_blestack\
simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\kernel\tirtos\packages;C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\source;C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack" IAR.tools.configuro -c "D:\Program Files (x86)\IAR
Systems\Embedded Workbench 8.0\arm"-cc "D:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\bin\iccarm.exe"-device "CC2640R2F"
--compileOptions "dummy.c -D CC2640R2_LAUNCHXL -D CC26XX -D CC26XX_R2 -D device_family=cc26x0r2 -D Display_disable_all -D
xDisplay_disable_all -D feature_OAD -D HAL_image_E -D HEAPMGR_size=0 -D ICALL_Events -D ICALL_JT -D ICALL_Lite -D
iCall_MAX_NUM_ENTRICALL_MAX_NUM_TASKs=3 -D MAX_NUM_BLE_CONns=1 -D POWER_SAVE_D USE_CORE_SDK -D USE_ICALL -D
xdc_runtime_assert_disable_all -D xdc_runtime_Log_disable_all --diag_suppress Pa050 -o C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\FlashROM_OAD_Offchip\Obj --debug --endian=little-CPU=Cortex-M3 -f C:\ti\
simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti.com
blestack/config/build_components。op-f C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL_blestack\simple_peripheral_oad_offchip\
tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/config/factory_config.op-f C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\cc2640r2xL_LAUNCH\blestack\
simple_peripheral_oad_offchip\tirtos\IAR\app\..\stack\build_config.op-f C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL_blestack\
simple_peripheral_oad_offchip\tirtos\IAR\app\..\config\configPkg\compiler.opt.defs -f C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\.\config\IAR_bound.bdef -e --FPU=None --dlib_config \"D:\Program Files (x86)\IAR
Systems\Embedded Workbench 8.0\arm\INC\c\DLib_Config_Normal. h\"-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\
blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/controllers/ccs26xx_R2/inc\-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25
examples\rtos\cC2640R2_LAUNCHXL_blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/inc\-i C:\ti\
blestack/common/cc26xx\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\
APP\...\..\src/app\-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..
..\..\..\..\..\..\..\source\ti\blestack/iCall/inc\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL_blestack\simple_peripheral_oad_offchip\
tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/inc\-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\cc2640R2_LAUNCHXL\blestack
simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/profiles/dev_info\-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/profiles/oad/ccc26xx\-i C:\ti\
blestack/profiles/Roles \-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL_blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\.\
..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/profiles/c26xx\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL_blestack\
simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/profiles/simple_profiles\-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/profiles/simple_profiles/cc26xx\-i C:\ti\
blestack/target\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..
..\..\..\..\..\source\ti\blestack/hal/src/inc\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\
tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/hal/src="target/_common\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640rack\LAUNCHXL_CL\CC2640R2\blestack\ble_C
simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/hal/src/target/_common/cc26xx\-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25
examples\rtos\cC2640R2_LAUNCHXL_blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/hal/src="target/cc2650\rom\-i\-C:\C
blestack/heapmgr\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..
..\..\..\..\..\..\..\..\..\source\ti\blestack/iCall/src/inc\-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL_blestack\
simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/osal/src/inc\-i C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\rtos\examples
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack/services/src/saddr\-i C:\ti\
blestack/services/src/sdata\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\
APP\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\devices\cc26x0r2\-I C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\
simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\source\-Ohz"--linkOptions "-o C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\FlashROM_OAD_Offchip\EXE\simple_peripheral_cc2640r2lp_app.out -config_def
CC2650=2 -config_def RTOS_ROM=1 -config_def app_image_start=0x0000 -map C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\FlashROM_OAD_Offchip\List\simple_peripheral_cc2640r2lp_app.map -config C:\ti\
blestack/common/cc26xx/IAR/cc26xx_app_oad.ICF --keep __vector_table -f C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\cc2640R2_LAUNCHXl\
blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\.\config\configPkg\linker.cmd -f C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\.\config\IAR_boundar.xcl C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\
CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\blestack\rom\ble_rom_releases\cc26xx_R2\Final_Release\
common_R2.symbols C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..
..\..\..\..\..\..\..\..\..\..\..\source\ti\devices\cc26x0r2\driverlib\bin\IAR\driverlib.lib C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL_blestack\
simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\kernel\tirtos\packages/ti\DPL\lib\DPL_cc26x0r2.arm3 C:\ti\simplelink_cc2640r2_sdk_1_30_examples\
rtos\CC2640R2_LAUNCHXL.\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\drivers\lib\drivers_cc26x0r2.arm3 C:\ti\
simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\drivers
rf\lib\rf_singlemode_cc26x0r2.arm3 C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\
tirtos\IAR\app\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\source\ti\display\lib\display.arm3 --entry __IAR_program_start --vfe --text_out location"--profile release --projFile "C:\ti\
simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\CC2640R2_LAUNCHXL\blestack\simple_peripheral_oad_offchip\tirtos\IAR\app\cc2640r2lp_app.ewP"
--cfgArgs NO_ROM=0,OAD_IMG_E=1
使用 RTSC 配置文件:
C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral_oad_offchip/tirtos/iar/app/../config/app_ble.cfg...
从 package/cfg/app_ble_prm3.cfg 配置 app_ble.xrm3 ...
警告:xdc.cfg.Program:"c:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages/ti/sysbios/hal/Hwi.xs、第181行:xdc.cfg.Program stack:对于 IAR 目标、
忽略 program.stack。 C 和 Hwi 堆栈大小由链接器命令文件中 CSTACK 段定义的大小决定。
正在生成自定义 ROM 库 makefile ...
正在开始构建库源...
制造
C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral_oad_offchip/tirtos/iar/config/src/sysbios/rom_sysbio
S.arm3...
gmaked[1]:输入目录
`C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral_oad_offchip/tirtos/iar/config/src/sysbios
正在创建包含 ROM 中未包含的 API 的 SYS/BIOS 库...
C:/Users/BRIANW~1/AppData/local/Temp/make5460-1.sh:第1行:意外令牌附近出现语法错误`('
C:/Users/BRIANW~1/AppData/local/Temp/make5460-1.sh:第1行:`lc_all=C D:/Program Files (x86)/IAR Systems/Embedded Workbench 8.0/ARM/bin/iccram
--aeabi --cpu=Cortex-M3 --diag_suppress=Pa050,Go005 --endian=little -e --thumb --silent --mFC -Ohz -DTI_SYSBIOS_KNL_Task_minimizeLatency__D=false
-dTI_SysBIOS_family_ARM_cc26xx_Boot_driverlibVersion=2 -dit_SysBIOS_KNL_Clock_stopCheckNext_D=true
-dTI_SYSBIOS_family_ARM_m3/Hwi_enableException_D=true -dTI_SYSBIOS_family_ARM_m3/Hwi_disablePriority __D=32U
-dTI_SYSBIOS_family_ARM_m3/Hwi_numSparseInterrupts__D=0U -dlib_config D:/程序文件(x86)/IAR Systems/Embedded Workbench
8.0/arm/inc/c/DLib_Config_Normal.h -o rom_SysBIOS.obj -dTI_SysBIOS_BIOS_swiEnabled__D=true -dTI_SysBIOS_taskEnabled__D=true
-dit_sysbios_bios_clockEnabled__D=true -dit_sysbios_bios_runtimeCreatesEnabled__D=true -dit_sysbios_KNL_Task_moduleStateCheckFlag__D=false
-dTI_SYSBIOS_KNL_Task_objectCheckFlag__D=false -dTI_SYSBIOS_hal_Hwi_disable_all_hooks -dTI_SYSBIOS_KNL_Swi_disable_All_hooks
-DTI_SysBIOS_BIOS_smpEnabled__D=false -DTI_SysBIOS_build_useHwiMacros -DTI_SysBIOS_build_useIndirectReferences=false
-dTI_SysBIOS_KNL_Swi_numPriorities __D=6 -dTI_SysBIOS_KNL_Task_deleteTerminatedTasks__D=false -dTI_SysBIOS_KNL_Task_numPriorities __D=6
-dTI_SysBIOS_KNL_Task_checkStackFlag__D=false -dTI_SysBIOS_KNL_Task_initStackFlag__D=true -dTI_SysBIOS_KNL_Task_disable_all_hooks
-DTI_SysBIOS_KNL_Clock_tick_source=ti_SysBIOS_KNL_Clock_TickSource_timer
-dTI_SYSBIOS_KNL_Clock_tick_mode=ti_SYSBIOS_KNL_Clock_TickMode_dynamic -dit_SYSBIOS_hal_Core_Delegate_detid=ti_SysBIOS_hal_CoreNull_getid_E
-DTI_SysBIOS_hal_Core_Delegate_interruptCore=ti_SysBIOS_hal_CoreNull_interruptCore__E
-DTI_SysBIOS_hal_Core_Delegate_lock=ti_SysBIOS_hal_CoreNull_lock___E -DTI_SysBIOS_hal_Core_Delegate_dunlock=ti_SysBIOS_hal_CoreNull_unlock___E
-dTI_SYSBIOS_hal_Core_numCores__D=1 -dTI_SysBIOS_hal_CoreNull_numCores__D=1 -dTI_SYSBIOS_utils_Load_taskEnabled__D=true
-dit_sysbios_utils_Load_swiEnabled__D=false -dit_sysbios_utils_Load_hwiEnabled__D=false
-dit_sysbios_family_arm_m3/hwi_de调度 SwiSupport_D_=true -dit_SYSBIOS_family_arm_m3/hwi_depatcherTaskSupport_D_true
-dit_sysbios_family_arm_m3/hwi_dispatcherAutoNestingSupport__D=true -dit_SYSBIOS_family_ARM_m3/patcherIrpTrackingSupport_D_true
-dTI_SysBIOS_KNL_Semaphore_supportsEvertion__D=false -dTI_SysBIOS_KNL_Semaphore_supportsPriority__D=false -Dxdc_runtime_asserte_disable_all
-dxdc_runtime_Log_disable_all -DCC2640R2_LAUNCHXL -DCC26XX -DCC26XX_R2 -DDEVICE_family=cc26x0r2 -Display_disable_all
-DxDisplay_disable_all -DFEATURE_OAD -dhal_image_E -DHEAPMGR_size=0 -DICALL_Events -DICALL_JT -DICALL_Lite
-DICALL_MAX_NUM_ENDS=6 -DICALL_MAX_NUM_TES=3 -DMMAX_NUM_BLE_CONns=1 -DPOWER_SAVE_DULE_SDK -Duse_ICALL
-Dxdc_runtime_assert_disable_all -Dxdc_runtime_Log_disable_all -i"C:/ti/xdctools_3_50_00_10_core/packages
-i"C:/ti/xdctools_3_50_00_10_core/packages /"-Dxdc_target_Types__=C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages/iar/targets/arm/std.h
-Dxdc_target_name___=M3 -i"C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages
-i"C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages /"-i"C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/source /"
-i"C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/source/ti/blestack /"-i"C:/ti/xdctools_3_50_00_10_core/packages /"-I"-i"/""/packages//"-make_all_definitions_weak \'
gmake.1]:***[ROM_SysBIOS.obj]错误258
gmaking[1]:***正在等待未完成的作业...
C:/Users/BRIANW~1/AppData/local/Temp/make5460-1.sh:第1行:`LC_ALL=C D:/Program Files (x86)/IAR Systems/Embedded Workbench 8.0/ARM/bin/iasmam
-CPU Cortex-M3 -endian little -S -o ROM_ARM_m3/intrinsicsSupport_ASM_IAR_lib.obj
-ic:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages/ti/sysbios/family/arm/m3 -dTI_sysbios_BIOS_swiEnabled__D=true
-DTI_SysBIOS_BIOS_taskEnabled__D=true -DTI_SysBIOS_BIOS_clockEnabled__D=true -DTI_SysBIOS_BIOS_runtimeCreatesEnabled__D=true
-dTI_SYSBIOS_KNL_Task_moduleStateCheckFlag__D=false -dTI_SYSBIOS_KNL_Task_objectCheckFlag__D=false -dTI_SYSBIOS_hal_Hwi_disable_all_hooks
-dTI_SYSBIOS_KNL_Swi_disable_All_hooks -dTI_SYSBIOS_BIOS_smpEnabled_D_=false -dTI_SysBIOS_build_useHwiMacros
-dTI_SYSBIOS_build_useIndirectReferences=false -dTI_SYSBIOS_KNL_Swi_numPriorities __D=6 -dTI_SYSBIOS_KNL_Task_deletedTasks__D=false
-dTI_SysBIOS_KNL_Task_numPriorities __D=6 -dTI_SysBIOS_KNL_Task_checkStackFlag__D=false -dTI_SysBIOS_KNL_Task_initStackFlag__D=true
-DTI_SysBIOS_KNL_Task_disable_All_hooks -DTI_SysBIOS_KNL_Clock_tick_source=ti_SysBIOS_KNL_Clock_TickSource_timer
-Dxdc_runtime_Log_disable_all -i"C:/ti/xdctools_3_50_00_10_core/packages /"-i"C:/ti/xdctools_3_50_00_10_core/packages
-Dxdc_target_Types__=C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages/iar/targets/arm/std.h -Dxdc_target_name____=M3
-i"C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages /"-i"C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages /"
-i"C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/source /"-i"C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/source/ti/blestack /"
-i"C:/ti/xdctools_3_50_00_10_core/packages /"-i"/"-i"/packages//" rom_arm_m3/intrinsicsSupport_ASM_IAR_lib.asm"
gmaked[1]:***[ROM_ARM_m3/intrinsicsSupport_ASM_IAR_lib.obj]错误258
-CPU Cortex-M3 -endian little -S -o ROM_ARM_m3/Hwi_asm_switch_IAR_lib.obj
-i"C:/ti/xdctools_3_50_00_10_core/packages /"-i"/"-i"/packages//" rom_arm_m3/Hwi_asm_switch_IAR_lib.asm"
gmake.1]:***[ROM_ARM_m3/Hwi_asm_switch_IAR_lib.obj]错误258
--CPU Cortex-M3 --endian little -S -o rom_arm_m3/TaskSupport_asm_IAR_lib.obj
-i"C:/ti/xdctools_3_50_00_10_core/packages /"-i"/"-i"/packages//" rom_arm_m3/TaskSupport_ASM_IAR_lib.asm"
gmake.1]:***[ROM_ARM_m3/TaskSupport_ASM_IAR_lib.obj]错误258
-CPU Cortex-M3 -endian little -S -o ROM_ARM_m3/Hwi_asm_IAR_lib.obj -ic:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages/ti/sysbios/family/arm/m3
-dTI_SYSBIOS_BIOS_swiEnabled__D=true -dTI_SYSBIOS_BIOS_taskEnabled__D=true -dTI_SYSBIOS_BIOS_clockEnabled__D=true
-dTI_SYSBIOS_BIOS_runtimeCreatesEnabled"已启用__D=true -dTI_SYSBIOS_KNL_Task_moduleStateCheckFlag__D=false
-i"C:/ti/xdctools_3_50_00_10_core/packages /"-i"/"-i"/packages//" rom_arm_m3/Hwi_asm_IAR_lib.asm"
gmake.1]:***[ROM_ARM_m3/Hwi_asm_IAR_lib.obj]错误258
gmaked[1]:离开目录
Gmake:***
[C:/ti/simplelink_cc2640r2_sdk_1_30_00_25/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral_oad_offchip/tirtos/iar/config/src/sysbios/rom_sysbio
S.arm3]错误2.
库构建失败。
错误:xdc.cfg.SourceDir:"c:/ti/xdctools_3_50_00_10_core/packages/xdc/cfg/SourceDir.xs,第209行:xdc.cfg.SourceDir:生成的源库构建失败:
退出状态= 2:
JS:"c:/ti/xdctools_3_50_00_10_core/packages/xdc/cfg/Main.xs、第160行:错误:配置失败!
xdctools_3_50_00_10_core\gmake.exe:***[package/cfg/app_ble_prm3.xdl]错误1.
xdctools_3_50_00_10_core\gmake.exe:***删除文件`package/cfg/app_ble_prm3.xdl'
xdctools_3_50_00_10_core\gmake.exe:***[package/cfg/app_ble_prm3.xdl]删除文件`package/cfg/app_ble_prm3.h'
xdctools_3_50_00_10_core\gmake.exe:***[package/cfg/app_ble_prm3.xdl]删除文件`package/cfg/app_ble_prm3.c'
JS:"c:/ti/simplelink_cc2640r2_sdk_1_30_00_25/kernel/tirtos/packages/iar/tools/configuro/Main.xs、第133行:错误:xdc.tools.configuro:配置因而失败
先前的错误(状态= 2);已删除'linker.cmd'。
运行"C:\ti\xdctools_3_50_00_10_core/xs"-xdcpath="C:\ti\simplelink_cc2640r2_sdk_1_30_00_25\examples\rtos\cc2640R2_LAUNCHXL_blestack\时出错
错误总数:1.
警告总数:0
如何解决这个问题。 提前感谢
    您可以尝试使用推荐版本的 IAR 7.80.3吗?
    Fredrik
