[参考译文] CC2541:无法使用 IAR 和 BLESTACK 来编译 SDK 示例
Guru**** 2930320 points
Other Parts Discussed in Thread: CC2541
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1190869/cc2541-cannot-complie-sdk-examples-with-iar-and-blestack
器件型号:CC2541
我尝试安装并运行一些 CC2541示例、我安装 了嵌入式工作平台10.40和 BLE-CC254x-1.4.1.43908b
但我在我的 win11机器上遇到以下错误。
错误[E46]:在?ALLOC_XSTACK8 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.3\8051\LIB\CLIB\cl-pli-blxd-1e16x01.R51)中引用了未定义的外部“?IE”
ERROR[E46]:中央引用的未定义外部"?B"(C:\Texas Instruments\BLE-CC254x-1.4.1.43908b\projects\ble\GlucoseCollector\CC2541\CC2541EM Master\Obj\centr.R51)
    感谢您的参与。
    CC2541示例未针对您使用的操作系统进行测试。
    另请确保参阅发行说明:
    - All projects have been migrated from IAR Embedded Workbench for 8051 v9.10.3 to v10.30.1. In order to build all projects, be sure to upgrade to IAR v10.30.1. Use of other versions of IAR may result in compatibility issues with this SDK release.
     IAR software can be obtained from:
     www.iar.com/.../
    我希望这将对您有所帮助、致以最诚挚的问候、
