[参考译文] LMX2571:LMX2571输出38.4MHz CAN 输出锁定
Guru**** 2531270 points
https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/794300/lmx2571-lmx2571-output-38-4mhz-can-out-lock
器件型号:LMX2571
38.4M 芯片的输出无法锁定到40M 或38M 可以锁定,下面是,谢谢。
e2e.ti.com/.../Desktop.zip
