[参考译文] LMX2491:请帮助查看原理图设计、并提供相同的建议? 客户目前无法配置此芯片
Guru**** 2928980 points
https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1172718/lmx2491-pls-help-review-schematic-diagram-designing-and-give-same-suggestion-the-customer-cannot-configure-this-chip-at-this-time
器件型号:LMX2491
e2e.ti.com/.../4118.LMX2491.pdf
    您好、Xiaofu、
    原理图不错、只是无需分流电容器。
