[参考译文] 是否有通信时钟高于25MHz 的 SPI 电平转换芯片?
Guru**** 2387060 points
https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1246090/is-there-an-spi-level-conversion-chip-with-a-communication-clock-above-25mhz
主题中讨论的其他器件:TXU0104SN74AXC4T774
