[参考译文] LMK05318BEVM:不能接受基准、10Hz ->8MHz 时钟生成失败
Guru**** 2509705 points
https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1267489/lmk05318bevm-the-reference-can-not-be-accepted-and-the-10hz---8mhz-clock-generation-failes
器件型号:LMK05318BEVM
主题中讨论的其他器件:LMK05318B
我一直在尝试在 EVB 上生成后续时钟。
设置和悬停
  •  从50ppm SG 到 XO 的输入12.8 MHz
     在50ppm SG 至 PRIREF 范围内、输入为10Hz
     输出8 MHz 与 PRIREF 边沿同步到 OUT7P
     设置如下:XO12.8M_REF10 Hz_OUT7_8M.TCS
结果-保持并且不接受 PRIREF
*我知道需要额外的设置来同步8 MHz 输出到 PRIREF 的边缘,但我会考虑同步当前的频率,并计划在这之后添加额外的设置。
XO12.8M_REF10 Hz_OUT7_8M.tcs
[设置]
ADDRESS= 888
CLOCK= 8
DATA= 4
LE= 2
PART= K52 05318B
IFACE=
地址_I2C=0x65
interface_speed=400
[针脚]
PINNAME00= F 沟道
LOCATION00= 9
PINVALUE00=
PINNAME01=_计数器
LOCATION01= 7
PINVALUE01=
PINNAME02= 52
LOCATION02= 3
PINVALUE02=
PINNAME03= IO0
LOCATION03= 8
PINVALUE03=
PINNAME04= IO1
LOCATION04= 6
PINVALUE04=
PINNAME05= 52 IO2
LOCATION05= 5
PINVALUE05=
PINNAME06=统计0
LOCATION06= 10
PINVALUE06=
PINNAME07=统计1
LOCATION07= 11
PINVALUE07=
[模式]
NAME00= R0
VALUE00= 16
NAME01=
VALUE01= 267
NAME02=
VALUE02= 56
NAME03=
VALUE03= 834
NAME04=
VALUE04= 1038
NAME05=
VALUE05=
NAME06= R.6
VALUE06= 1560
NAME07= R.7
VALUE07= 1934
NAME08= R.8
VALUE08=
NAME09= R.10
VALUE09= 2760
NAME10= R.11
VALUE10= 2816
NAME11= 12
VALUE11= 3099
NAME12= R.13
VALUE12= 3328
NAME13= R.14
VALUE13= 3776
NAME14= R.15
VALUE14= 3840
NAME15= R.16
VALUE15=
NAME16= R.17
VALUE16= 4381
NAME17= R.18
VALUE17= 4863
NAME18= R.19
VALUE18= 4877
NAME19= R.20
VALUE19= 5336
NAME20= R.21
VALUE20= 5377
NAME21= R.22
VALUE21= 5632
NAME22= R.23
VALUE22= 5973
NAME23= R.24
VALUE23= 6229
NAME24= R.25
VALUE24=
NAME25= R.26
VALUE25= 6656
NAME26= R.27
VALUE26= 6912
NAME27= R.28
VALUE27= 7169
NAME28= R.29
VALUE28= 7443
NAME29= R.30
VALUE29= 7744
NAME30= R.32
VALUE30= 8260
NAME31= R.35
VALUE31= 52
NAME32= R.36
VALUE32=高论19
NAME33= R.37
VALUE33= 9472
NAME34= R.38
VALUE34= 9728
NAME35= R.39
VALUE35= 9986
NAME36= R.40
VALUE36= 10255
NAME37= R.41
VALUE37= 10496
NAME38= R.42
VALUE38= 10769
NAME39= R.43
VALUE39= 11202
NAME40= R.44
VALUE40= 52
NAME41= R.45
VALUE41= 52
NAME42= R.46
VALUE42= 52
NAME43= R.47
VALUE43= 12039
NAME44= R.48
VALUE44= 52
NAME45= R.49
VALUE45= 52
NAME46= R.50
VALUE46= 52
NAME47= R.51
VALUE47= 13056
NAME48= R.52
VALUE48= 13312
NAME49= R.53
VALUE49= 13583
NAME50= R.54
VALUE50= 13824
NAME51= R.55
VALUE51= 14080
NAME52= R.56
VALUE52= 14351
NAME53= R.57
VALUE53= 14592
NAME54= R.58
VALUE54= 14863
NAME55= R.59
VALUE55= 15104
NAME56= R.60
VALUE56= 15375
NAME57= R.61
VALUE57= 15616
NAME58= R.62
VALUE58= 15887
NAME59= R.63
VALUE59= 16318
NAME60= R.64
VALUE60= 16384
NAME61= R.65
VALUE61= 16640
NAME62= R.66
VALUE62= 16896
NAME63= R.67
VALUE63= 17397
NAME64= R.68
VALUE64= 17416
NAME65= R.69
VALUE65= 17664
NAME66= R.70
VALUE66= 17920
NAME67= R.71
VALUE67= 18176
NAME68= R.72
VALUE68= 18483
NAME69= R.73
VALUE69= 18688
NAME70= R.74
VALUE70= 18944
NAME71= R.75
VALUE71= 19200
NAME72= R.76
VALUE72= 19456
NAME73= R.77
VALUE73=斯比27
NAME74= R.78
VALUE74= 20.068
NAME75= R.79
VALUE75= 20225
NAME76= R.80
VALUE76= 20480
NAME77= R.81
VALUE77= 20746
NAME78= R.82
VALUE78= 20992
NAME79= R.83
VALUE79= 21255
NAME80= R.84
VALUE80= 52
NAME81= R.85
VALUE81= 21760型
NAME82= R.86
VALUE82= 22016
NAME83= R.87
VALUE83= 22302
NAME84= R.88
VALUE84= 22660
NAME85= R.89
VALUE85= 22912
NAME86= R.90
VALUE86= 23040
NAME87= R.91
VALUE87= 23316
NAME88= R.92
VALUE88= 23552
NAME89= R.93
VALUE89= 23815
NAME90= R.94
VALUE90= 24192
NAME91= R.95
VALUE91= 24320
NAME92= R.96
VALUE92= 24576
NAME93= R.97
VALUE93= 24862
NAME94= R.98
VALUE94= 25220
NAME95= R.99
VALUE95= 25472
NAME96= R.100
VALUE96= 52
NAME97= R101
VALUE97= 25857
NAME98= R.102
VALUE98= 26146
NAME99= R.103
VALUE99= 26383
NAME100= R.104
VALUE100= 26655
NAME101= R.105
VALUE101= 52
NAME102= R.106
VALUE102= 27136
NAME103= R.107
VALUE103= 27492
NAME104= R108
VALUE104= 27648
NAME105= R.109
VALUE105= 28001
NAME106= R.110
VALUE106= 28328
NAME107= R.111
VALUE107= 28416
NAME108= R.112
VALUE108= 28672
NAME109= R.113
VALUE109= 28928
NAME110= R.114
VALUE110= 29184
NAME111= R.115
VALUE111= 29443
NAME112= R.116
VALUE112= 29697
NAME113= R.117
VALUE113= 29952
NAME114= R.118
VALUE114= 30208
NAME115= R.119
VALUE115= 30464
NAME116= R.120
VALUE116= 30720
NAME117= R.121
VALUE117= 30976
NAME118= R.122
VALUE118= 312 32
NAME119= R.123
VALUE119= 52
NAME120= R.124
VALUE120= 31744
NAME121= R.125
VALUE121= 32017
NAME122= R.126
VALUE122= 32377
NAME123= R.127
VALUE123= 32634
NAME124= R.128
VALUE124= 32368
NAME125= R.129
VALUE125= 52
NAME126= R.130
VALUE126= 33280
NAME127= R.131
VALUE127= 33537
NAME128= R.132
VALUE128= 33793
NAME129= R.133
VALUE129= 34167
NAME130= R.134
VALUE130= 34304
NAME131= R.135
VALUE131= 34602
NAME132= R.136
VALUE132= 34816
NAME133= R.137
VALUE133= 35196
NAME134= R.138号
VALUE134= 35384
NAME135= R.139
VALUE135= 35587
NAME136= 140
VALUE136= 35842
NAME137= R.141
VALUE137= 52
NAME138= R.142
VALUE138= 36353
NAME139= R.143
VALUE139= 36609
NAME140= R.144
VALUE140= 36983
NAME141= R.145
VALUE141= 37121
NAME142= R.146
VALUE142= 37513
NAME143= R.147
VALUE143= 37664
NAME144= R.149
VALUE144= 38157
NAME145= R.150
VALUE145= 38400
NAME146= R151
VALUE146= 38657
NAME147= R152
VALUE147= 38925
NAME148= R.153
VALUE148= 39209
NAME149= R.154
VALUE149= 39460
NAME150= R.155
VALUE150= 39730
NAME151= R.156
VALUE151= 39937
NAME152= R.157
VALUE152= 40192
NAME153= R.158
VALUE153= 40448
NAME154= R159
VALUE154= 40704
NAME155= R.160
VALUE155= 41212
NAME156= R.161
VALUE156= 41266
NAME157= R.162
VALUE157= 41472
NAME158= R.164
VALUE158= 41984
NAME159= R.165
VALUE159= 42240
NAME160= R.167
VALUE160= 42753
NAME161= R.178
VALUE161= 45568
NAME162= R.180
VALUE162= 46080
NAME163= R.181
VALUE163= 46336
NAME164= R.182
VALUE164= 46592
NAME165= R.183
VALUE165= 46848
NAME166= R.184
VALUE166= 47104
NAME167=
VALUE167= 47365
NAME168= R.186
VALUE168= 47624
NAME169= R.187
VALUE169= 47872
NAME170= R.188
VALUE170= 48128
NAME171= R.189
VALUE171= 48384
NAME172= R.190
VALUE172= 48684
NAME173= R.191
VALUE173= 48896
NAME174= R.192
VALUE174= 49264
NAME175=
VALUE175= 49432
NAME176= R.194
VALUE176= 49664
NAME177= R.195
VALUE177= 49920
NAME178= R.196
VALUE178= 50176
NAME179= R.197
VALUE179= 50461
NAME180= R.198
VALUE180= 50688
NAME181= R.199
VALUE181= 50944
NAME182= R.200
VALUE182= 5129
NAME183= R.201
VALUE183= 51456
NAME184= R.202
VALUE184= 52
NAME185= R.203
VALUE185= 51968
NAME186= R.204
VALUE186= 52245
NAME187= R.205
VALUE187= 52480
NAME188= R.206
VALUE188= 52736
NAME189= R.207
VALUE189= 52
NAME190= R.208
VALUE190= 53248
NAME191= R.209
VALUE191= 53524
NAME192= R.210
VALUE192= 53760
NAME193= R.211
VALUE193= 52
NAME194= R.212
VALUE194=:54272
NAME195= R.213
VALUE195= 54548
NAME196= R.214
VALUE196= 54784
NAME197= R215
VALUE197= 52
NAME198= R.216
VALUE198= 55311
NAME199= R.217
VALUE199= 55552
NAME200= R.218
VALUE200= 55808
NAME201= R.219
VALUE201= 56089
NAME202= R220
VALUE202= 56430
NAME203= R.221
VALUE203= 56576
NAME204= R.222
VALUE204= 56835
NAME205= R.223
VALUE205= 57101
NAME206= R.224
VALUE206= 5715
NAME207= R.225
VALUE207= 57600
NAME208= R.226
VALUE208= 57856
NAME209= R.227
VALUE209= 58137
NAME210= R.228
VALUE210= 58478
NAME211= R.229
VALUE211= 58 624
NAME212= R.230
VALUE212= 58883
NAME213= R.231
VALUE213= 59149
NAME214= R232
VALUE214= 59463
NAME215= R.233
VALUE215= 59664
NAME216= R.234
VALUE216= 59920
NAME217= R.235
VALUE217= 60160
NAME218= R.236
VALUE218= 60455
NAME219= R.237
VALUE219= 60688
NAME220= R.238
VALUE220= 0928
NAME221= R.239
VALUE221= 52
NAME222= R.240
VALUE222= 4574
NAME223= R.241
VALUE223= 61856
NAME224= R.242
VALUE224= 61952
NAME225= R.243
VALUE225= 62271
NAME226= R.244
VALUE226= 62464
NAME227= R.249
VALUE227= 63777
NAME228= R.250
VALUE228= 64000
NAME229= R251
VALUE229= 64259
NAME230= R.252
VALUE230= 64557
NAME231= R.253
VALUE231= 64768
NAME232= R254
VALUE232= 52
NAME233= R255
VALUE233= 65280
NAME234= R.256
VALUE234= 65536
NAME235= R.257
VALUE235= 65793
NAME236= R.258
VALUE236= 6048
NAME237= R.259
VALUE237= 66304
NAME238= R.260
VALUE238= 66562
NAME239= R.261
VALUE239= 66944
NAME240= R.262
VALUE240= 67072
NAME241= R.263
VALUE241= 67357
NAME242= R.264
VALUE242= 67789
NAME243= R.265
VALUE243= 67941
NAME244= R.266
VALUE244= 68096
NAME245= R.267
VALUE245= 68512
NAME246= R.268
VALUE246= 68612
NAME247= R.269
VALUE247= 68864
NAME248= R.270
VALUE248= 69122
NAME249= R.271
VALUE249= 69415
NAME250= R.272
VALUE250= 69632
NAME251= R.273
VALUE251= 69888
NAME252= R.274
VALUE252= 70144
NAME253= R.275
VALUE253= 70418
NAME254= R.276
VALUE254= 70674
NAME255= R.277
VALUE255= 70930
NAME256= R.278
VALUE256= 4573
NAME257= R.279
VALUE257= 71429
NAME258= R.280
VALUE258= 71685
NAME259= R.281
VALUE259= 71937
NAME260= R.282
VALUE260= 72193
NAME261= R.283
VALUE261= 72449
NAME262= R.284
VALUE262= 72734
NAME263= R.285
VALUE263= 72990
NAME264= R.286
VALUE264= 73216
NAME265= R.287
73 VALUE265= 472
NAME266= R.288
VALUE266= 73728
NAME267= R.289
VALUE267= 73984
NAME268= R.290
VALUE268= 74243
NAME269= R.291
VALUE269= 74725
NAME270= R.292
VALUE270= 74761
NAME271= R.293
VALUE271=版本5月009
NAME272= R.294
VALUE272= 75
NAME273= R295
VALUE273= 75564
NAME274= R.296
VALUE274= 75789
NAME275= R.297
VALUE275= 76045
NAME276= R.298
VALUE276= 76301
NAME277= R.299
VALUE277= 76545
NAME278= R.300
VALUE278= 76800
NAME279= R.301
VALUE279= 77080
NAME280= R.302
VALUE280= 77343
NAME281= R.303
VALUE281= 77569
NAME282= R.304
VALUE282= 77839
NAME283= R.305
VALUE283= 78080
NAME284=
VALUE284= 78448
NAME285= R.307
VALUE285= 78642
NAME286= R.308
VALUE286= 78957
NAME287= R.309
VALUE287= 79149
NAME288= R.310
VALUE288= 79405
NAME289= R.311
VALUE289= 79661
NAME290= R.312
VALUE290= 79917
NAME291= R.313
VALUE291= 80173
NAME292= R.314
VALUE292= 80639
NAME293= R.315
VALUE293= 80895
NAME294= R.316
VALUE294= 52
NAME295= R.317
VALUE295= 81407
NAME296= R.318
VALUE296= 81663
NAME297= R.319
VALUE297= 81667
NAME298= R.320
VALUE298= 81920
NAME299= R.321
VALUE299= 82186
NAME300= R.322
VALUE300= 52
NAME301= R.323
VALUE301= 82688
NAME302= R.324
VALUE302= 52
NAME303= R.325
VALUE303= 83201
NAME304= R.326
VALUE304= 83456
NAME305= R.327
VALUE305= 83870
NAME306= R.328
VALUE306= 84210
NAME307= R.329
VALUE307= 848251
NAME308= R.330
VALUE308= 84480
NAME309= R.331
VALUE309= 84836
NAME310= R.332
VALUE310= 848992
NAME311= R.333
VALUE311= 85248
NAME312= R.334
VALUE312= 52
NAME313= R.335
VALUE313= 52
NAME314= R.336
VALUE314= 86016
NAME315=
VALUE315= 86430
NAME316= R.338
VALUE316= 86770
NAME317= R.339
VALUE317= 86811
NAME318= R340
VALUE318= 52
NAME319= R.341
VALUE319= 87296
NAME320= R.342
VALUE320= 52
NAME321= R.343
VALUE321= 87808
NAME322= R.344
VALUE322=八十八64
NAME323= R.345
VALUE323= 88320
NAME324= R.346
VALUE324= 88578
NAME325= R.347
VALUE325= 88832
NAME326= R.348
VALUE326= 89088
NAME327= R.349
VALUE327= RAND344
NAME328= R.350
VALUE328= RAND600
NAME329= R.351
VALUE329= 89856
NAME330= R.352
VALUE330= 90112
NAME331= R.357
VALUE331= 91432
NAME332= R.367
VALUE332= 93992
NAME333= R.411
VALUE333= 105220
[柔性]
CH0_PREDRIVER = 0
CH1_PREDRIVER = 0
CH2_PREDRIVER = 0
CH3_PREDRIVER = 0
CH4_PREDRIVER = 0
通道5_PREDRIVER = 0
Ch6_PREDRIVER = 0
CH7_PREDRIVER = 0
DPLL_REF_LOOPCTL_CHG_QUANT_INTG=0
DPLL_REF_MASHSEED=0
DPLL_REF_UNLOCKDET_CNTSTRT=0
DPLL_REF_UNLOCKDET_CNTSTRT_MSB_6=0
DPLL_REF_UNLOCKDET_VCO_CNTSTRT=0
DPLL_REF_UNLOCKDET_VCO_CNTSTRT_MSB_22=0
MUTE_DPLL_FRLOCK = 0
OUT0_freq= 156.25 MHz
out1_freq= 156.25 MHz
OUT2_freq= 156.25 MHz
OUT3_freq= 156.25 MHz
OUT4_freq= 156.25 MHz
out5_freq= 156.25 MHz
OUT6_freq= 156.25 MHz
OUT7_freq= 8.0 MHz
PLL1_BAW_CAPDAC=0
PLL1_CP_TRIM=0
PLL1_VCBO_VAR2CON=0
PRIREFBUFGAIN= 0
SECREFBUFGAIN= 0
TARGET_ADDR_GPIO1_SW=0
VCO1_freq=2500
vco2_freq=5904
xo_freq=12.8
bFindAddressBTn=查找 I2C 地址
i2cAddr=0
stdc_freq=10.0Hz
BTN_page0_next=next>
COMBO_REWARD_兼容=0
COMBO_DPLL_MODE=0
MATLAB_RUNTIME_URL=www.mathworks.com/.../matlab-runtime.html
BTN_page1_back=<返回
BTN_page1_next=next>
btn_xo_show_instructions=显示指令
sxo_freq=12800000
S_wizard_xo_message_box=XO 频率设置成功!\n\n 整数边界杂散= 8.8 MHz \n\n\NxO R divider = 1\NxO 倍频器已启用\nPFD 频率= 25.6 MHz
OUT7_freq= 8.0 MHz
PLL1_RDIV_StaticText=PLL2 R 分频器(两级)
bCALC_FREQPLAN=计算频率规划
btn_freq_plan_show_instructions=显示说明
BTN_FREQUENCY_PLAN_AP应用 解决方案=应用所选解决方案
BTN_page2_back=<返回
BTN_page2_next=next>
CB_ALLOW_PLL2_PREScaler_of_2 = 0
cb_manual_override_pll2_rdiv=0
sCH0_1_in_freq=
sCH0_1_MUX=不适用
SCH2_3_in_freq=
SCH2_3_MUX=不适用
sCh4_IN_freq=
sCH4_MUX=不适用
sCH5_in_freq=
sCH5_MUX=不适用
sCH6_in_freq=
sCH6_MUX=不适用
sCH7_in_freq=8000000
sCH7_MUX=APLL2
s_wizard_freqplan_message_box=频率计划已完成!\n\n 选定的频率计划:\nVCO1频率=\nVCO2\nVCO26\nAPLL1频率= 5904.0 MHz:\nAPLL1设置:\nPFD 频率= 25600000Hz\nn 分频器= 97\n 数字分频器= 721554505728\n 数字分频器= 10991N2\nAPPR2\146002\1N2\PFC2N2\N 分频器= 1N2N2\PFC46002\N 分频器= 1N2\1N2N2N2\PFC46002N2\N 分频器= 2500.0 MHz = 1N2\N2N2N2N2N2\PFC460042N2\N 分频器: = 3
TABLE_FREQUENCY_PLAN_PLL1=0
TABLE_FREQUENCY_PLAN_PLL2=0
BTN_page3_back=<返回
BTN_page3_next=next>
BTN_REFCLK_show_instructions=显示指令
CB_ENABLE_PRIREF=1
CB_ENABLE_SECREF=0
COMBO_PRIREF_BUF_TYPE=2
COMBO_SECREF_BUF_TYPE=2
组合型 ref_priority=0
REFCLK_PIN_SELECT=
sPRIREF_freq=10
sSECREF_freq=
S_wizard_REFCLK_message_box=指令:\n\n1. 根据需要启用或禁用 PRIREF 和 SECREF。 如果未使用 DPLL,则禁用两个引用并跳过此页。\n\n2. 键入 PRIREF 和/或 SECREF 的频率、单位为 Hz。 频率格式示例:\n\n1\n25e6\n100e6 / 3\n\n3. 选择接口类型。 根据基准频率自动选择交流或直流缓冲器。 如果基准频率低于5 MHz、则使用直流缓冲器。 否则、请使用交流缓冲器。 要为交流缓冲器选择接口类型、请参阅 XO 向导页面中的"接口类型选择提示"。 同样可以应用于 PRIREF 和 SECREF。\n\n4. 选择输入开关模式。 根据 PRIREF 和 SECREF 使能的状态自动选择输入开关模式。 当启用两个参考时、选择自动非反向。 如果只启用了一个参考、则选择手动保持。 但是、强烈建议阅读此向导页面中的"输入开关模式选择指南"并作出决定。\n\n5. 如果选择了手动回退或手动保持、则在通过寄存器手动选择和通过 REFSEL 引脚手动选择之间进行选择。
BTN_page4_back=<返回
BTN_page4_next=next>
BTN_ref_validation_show_instructions=显示说明
sPRIREF_ACCESSITION_PPM=10
sPRIREF_AVG_COUNT=2
sPRIREF_EARLY_MARGIN=1
sPRIREF_EARLY_calc=不适用
sPRIREF_LAUND=0
sPRIREF_LAST_MARGIN=1
sPRIREF_LATED_calc=不适用
sPRIREF_PH_VALID_calc=2.46us
sPRIREF_PPM_INVALIDE=110
sPRIREF_PPM_TIMER =不适用
sPRIREF_PPM_VALIDE=100
sSECREF_ACCESSITION_PPM=10
sSECREF_AVG_COUNT=2
sSECREF_EARLY_MARGIN=1
sSECREF_EARLY_calc=n/a
sSECREF_LATED=0
sSECREF_LIGHT_MARGIN=1
sSECREF_LIGHT_calc=N/A
sSECREF_PH_VALID_calc=n/a
sSECREF_PPM_INVALIDE=110
sSECREF_PPM_TIMER=N/A
sSECREF_PPM_VALIDE=100
s_wizard_reference_validation_message_box=说明:\n\n 如果禁用 DPLL,则跳过此页面。 所有参考验证方法都是根据参考频率和接口类型自动启用或禁用的。 但是、强烈建议阅读说明并根据应用需求松散或拧紧阈值。\n\n 频率检测和早期/后期窗口检测仅对参考频率>=2kHz 的情况有效。 1pps 相位检测器仅对参考频率< 2kHz 有效。 对于1pps 输入、仅启用1pps 相位检测器并禁用所有其它检测器。\n\n1. 验证计时器。 基准必须在"验证计时器"有效时间段内保持有效、然后才能被视为有效。 建议将验证计时器设置为大于总基准验证测量时间的两倍。 频率检测测量时间显示在向导上。 振幅检测、早期/后期时钟检测以及1pps 相位检测的测量时间约为参考时钟的一个周期。 因此、如果参考频率>= 2kHz、则总测量时间大概等于频率检测测量时间。 如果参考频率< 2kHz、则总测量时间约为参考时钟的1个周期。\n\n2. 振幅检测器。 有两种模式:振幅检测器模式和 CMOS 转换率检测器模式。 在振幅检测器模式下、如果信号摆幅高于所选阈值、则基准被视为有效。 在 CMOS 转换率检测器模式下、检测方法可以是转换率检测或 VIH/VIL 检测。 对于压摆率检测、输入压摆率必须快于0.2 V/ns。 对于 VIH/VIL 检测、输入高电平必须高于1.8V、低电平必须低于0.6V。振幅检测模式不能用于低于5 MHz 的基准频率。 如果基准频率高于5 MHz、则建议对差分输入使用振幅检测模式、对单端输入使用 CMOS 压摆率检测模式。 如果输入摆幅太低(例如、LVDS 电压摆幅为400mV、与振幅检测模式的最小阈值相比、此值处于边缘)、则可以禁用振幅检测器。\n\n3. 频率检测器。 该检测器仅在 PRIREF / SECREF 频率>= 2kHz 时有效。 频率检测需要4个参数:以 ppm 为单位的有效阈值、以 ppm 为单位的无效阈值、以 ppm 为单位的精度和平均计数。 如果 PRIREF / SECREF 和 XO 之间的频率误差在有效阈值内、则认为 PRIREF 或 SECREF 有效。 虽然频率有效、但如果频率误差超过无效阈值、则被视为频率无效。 以 ppm 为单位的精度指示有效和无效阈值的精确度。 换句话说、这是有效和无效阈值计数器的分辨率。 最小平均计数为2。 该值保持为2、除非参考时钟漂移过多且 DPLL 环路带宽过窄。 在这种情况下、将平均计数提高到不超过10。 如前所述、用于频率检测的"0误差"参考为 XO。 当然、实际上、XO 频率不是"0误差"。 因此、有效和无效阈值必须考虑 XO ppm 误差。 最小有效阈值应为最大 XO 频率误差+最大 PRIREF/SECREF 频率误差+以 ppm 为单位的精度。 最小无效阈值应是有效阈值+精确度(以 ppm 为单位)。\n\n4. 早期和后期时钟窗口检测器。 该检测器仅在 PRIREF / SECREF 频率>= 2kHz 时有效。 需要3个参数:早期计数器、延迟计数器和丢失时钟的数量。 在设置早期和晚期计数器后、会相应地计算 T_EARLY 和 T_LATE。 如时序图所示、如果下一个时钟边沿位于理想下一个边沿- T_early 和理想下一个边沿+ T_late、则 PRIREF/SECREF 被视为有效。 将缺少时钟的数量设置为 x 相当于将 x * reference_clock_period 添加到 T_late。 因此、除非需要支持间隙时钟、否则缺失时钟的数量通常设置为0。 早期和后期时钟检测器使用分频的 BAW VCO 频率作为其"0错误"参考。 但是、这是一种非常粗略的检测方法(T_early 和 T_late 计数器的分辨率大约为1.6ns)、因此 BAW VCO 本身的 ppm 误差不是问题。\n\n5。 1pps 相位检测器。 该检测器仅对 PRIREF / SECREF 频率< 2kHz 有效。 T_jitter 根据相位检测器计数器自动计算。 如时序图所示、如果下一个时钟边沿处于理想下一个边沿- T_jitter 和理想下一个边沿+ T_jitter 内、则 PRIREF/SECREF 被视为有效。 请注意、1pps 相位检测器的"0误差"时钟基准是 XO、因此 T_jitter 必须大于:(1)通过一个 PRIREF / SECREF 时钟周期累积的 XO 相位误差的总和(例如、1pps 输入时为1秒)。 这包括由频率误差、累积抖动以及漂移引起的相位误差。 (2) PRIREF/SECREF 的最大周期抖动。 因此、建议为1pps 输入使用低频和高稳定性 XO。 这是因为对于具有相同频率稳定性的 XO、具有较低频率的 XO 在固定时间段内累积的相位误差更小。 建议将12.8 MHz TCXO/OCXO 用于1pps 输入。
DPLL_VCO_freq=2500
brun_script=运行脚本
BTN_DPLL_show_instructions=显示指令
BTN_page5_back=<返回
BTN_page5_next=next>
BTN_RESTORE_DPLL_REG=恢复计算得出的 DPLL 设置
CB_SHOW_DPLL_REGISTERS=0
COMBO_DISABLE_FASTLOC=1
COMBO_SET_max_TDC_freq=0
COMBO_SWITCHING_METHOD=0
sDPLL_LBW=0.01
sDPLL_LBW_ACT=0.0101
sDPLL_PEAK = 0.1
sDPLL_PEAK_ERROR=1
SMAx_TDC_freq=26000000
sPRIREF_freq_display=10.0Hz
sSECREF_freq_display=已禁用
stdc_freq=10.0Hz
s_wizard_DPLL_message_box=DPLL 计算已完成!\n\n TDC 频率= 10\n\n 平移 VCO1频率= 2500000000\n 模拟 VCO1频率= 2500000000\nPLL1频率错误= 0 ppb\n\n 平移 VCO2频率= 590400Fs\n 总 VCO2频率= 5904000000\nPLL1频率锁定时间= 0.00\nDPLL = 0.0f ~ f = 0.0f \n 频率锁定时间锁定 f = 0.0f 时间+ 2 * DPLL 频率锁定测量时间\n\n 总 DPLL 相位锁定时间~= DPLL 快速锁定时间+ 2 * DPLL 相位锁定测量时间
BAW_LOCK_PPM_THRESH=5
BAW_UNLK_PPM_THRESH=10
DPLL_PL_LOCK_calc=371.69ps
DPLL_PL_UNLK_calc=47.58ns
BTN_BAW_LOCK_DETECT_DEFAULT=设置默认值
BTN_dpll2_show_instructions=显示指令
BTN_DPLL_freq_lock_detect_default=设置默认值
BTN_history_recommend=必需的最小值
BTN_page6_BACK=<返回
BTN_page6_next=next>
BTN_PH_THRESHOLD_建议=建议值
sBAW_LOCK_ACCESSITION_PPM=1
sBAW_LOCK_AVG = 2
sBAW_TMEAS_LOCK_calc=19.2000 ms
sDPLL_HISTCNT_calc=26.21k
sDPLL_HISTDLY_calc=4.61ks
sDPLL_LOCK_ACCESSITION_PPM=1
sDPLL_LOCK_AVG = 10
sDPLL_LOCK_PPM=1
sDPLL_PL_MEAS_TIME=99.01s
sDPLL_TMEAS_LOCK_calc=100.0000 ms
sDPLL_UNLK_PPM=10
s_wizard_dpll2_message_box=说明:\n\n 在运行 DPLL 脚本后,所有锁定检测设置均设置为默认值或建议值。 不过,强烈建议您仔细阅读说明并进行调整。\n\n1. BAW 频率锁定检测。 如果启用了 DPLL、则禁用此功能。 仅当 DPLL 被禁用且器件在自由运行模式下工作时、该检测器才有用。 以 ppm 为单位输入锁定阈值、以 ppm 为单位输入解锁阈值、平均计数(最小值= 2)、以 ppm 为单位输入精度。 如果 BAW 和 XO 之间的频率误差处于锁定阈值范围内、则认为 BAW (VCO1)处于锁定阈值内。 BAW 一旦锁定、如果频率误差超过解锁阈值、则被视为已解锁。 以 ppm 为单位的锁定和解锁阈值的步长=精度/平均值。 如果对 BAW 锁定检测没有特定要求、请单击"设置默认值"。\n\n2. DPLL 频率锁定检测。 以 ppm 为单位输入锁定和解锁阈值、平均计数(最小值= 2)并以 ppm 为单位输入精度。 如果 VCO1与基准之间的频率误差在锁定阈值内、则 DPLL 被视为频率锁定。 当 DPLL 处于频率锁定状态时、如果频率误差超过解锁阈值、则被视为频率解锁。 锁定和解锁阈值的步长=精度/平均值。 如果对 DPLL 频率锁定检测没有特定要求、请单击"设置默认值"。\n\n3. DPLL 锁相检测。 设置锁定和解锁阈值计数器。 然后相应地计算秒内的实际锁定和解锁阈值。 如果 TDC 的两个输入(分频基准和分频 VCO1)之间的相位差处于锁定阈值内、则将 DPLL 视为锁相。 当 DPLL 处于锁相状态时、如果相位差超过解锁阈值、则它被视为已解锁相位。 为此、请使用建议值。 不应手动设置锁定和解锁计数器,它们仅用于工程调试目的。\n\n4. 调优字历史记录。 该块设置保持的调优字历史记录。 设置历史记录计数器和延迟计数器。 然后自动计算平均时间和延迟时间。 有关详细信息、请参阅数据表中的"9.3.7.4调整字历史记录"部分。 如果没有关于保留调优词的特定要求、请单击"所需的输入值"。 这可以确保延迟时间超过参考频率验证测量时间的8倍、并且平均值计算时间长于延迟时间。
BTN_page7_BACK=<返回
PLL1_24b_den=0
PLL1_24b_NUM=43008
PLL1_DEN = 1099511627776
PLL1_PFD_freq=25.6
VCO1_freq=2500
xo_freq=12.8
PLL2_DEN_FIXED=16777216
PLL2_PFD_freq=138.8888888889
VCO1_freq=2500
vco2_freq=5904
xo_freq=12.8
OUT7_freq= 8.0 MHz
PLL2PDIV1_freq=1968
PLL2PDIV2_freq=1968
VCO1_freq=2500
vco2_freq=5904
sOUT7_DIV=246
AbsDCO_ppb_error=0.01
DPLL_DCO_FREQ_PPB_ACT=0
DPLL_DCO_STEP_ACT_0
DPLL_REF_NUM_calculed=194031463725
bDPLL_FDECR=减量
bDPLL_FINCR=增量
bResetNumerator0ppb=重新加载原始 DPLL Numerator
CBDCO_MODE=1
sDPLL_DCO_STEP=0.01
bReadStatus=读取状态
bClearAllFlagStickyStatus=清除所有标志
txtNVMSCRC=0x3B
txtNVMCNT=0x01
值 erev=0
valNVM_SPARE_BY1=0
valNVM_SPARE_BY0=0
valNVM_SPARE_BY2=0
valNVM_SPARE_BY3=0
CMbI2C_ADDR=0
btnEE_READSTATUS=读取 EEPROM 状态
btnEE_TICS2SEQ=导出 EEPROM 序列
btnEE_TICS2EPR =导出 EEPROM 映射
btnEE_TICS2DUT=对 EEPROM 进行编程
btnEE_DUT2TICS=读取额外的 EEPROM 字节
cmbSEL_EXTRA_EE_BYTES = 0
txtNVMLCRC=0x00
txtNVMCRCERR=0
txtNVMBUSY=0
VAL_EE_DUMP=
