[参考译文] PLLATINUMSIM-SW:某些器件的十进制数存在问题
Guru**** 2773145 points
Other Parts Discussed in Thread: LMX2581, LMX2582
https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1367322/pllatinumsim-sw-problem-with-decimal-numbers-for-some-devices
器件型号:PLLATINUMSIM-SW
主题中讨论的其他器件:LMX2582、LMX2581
我在使用 PLLatinum sim 1.6.3.0仿真 LMX2582时遇到问题。
当我为 Fosc 输入十进制数时、我得到一个例外:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: Conversion from string "16.384,6" to type 'Double' is not valid. ---> System.FormatException: Input string was not in a correct format.
   at System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
   at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
   at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
   --- End of inner exception stack trace ---
   at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value)
   at TIPLLatinumSim.GeneralFunctions.Parser_EvaluateBlock(String Rule)
   at TIPLLatinumSim.GeneralFunctions.Parser_EvaluateRule(String Rule)
   at TIPLLatinumSim.TIPLLatinumForm.Parser_ExecuteRule(String Rule)
   at TIPLLatinumSim.TIPLLatinumForm.UpdateLockTimeMetrics(Boolean UpdateSMCLK)
   at TIPLLatinumSim.TIPLLatinumForm.UpdatePerformanceMetrics()
   at TIPLLatinumSim.TIPLLatinumForm.UpdatePLLFrequencies(String ChangeIndicator)
   at TIPLLatinumSim.TIPLLatinumForm.UserEntry_PLLDiagram_LostFocus(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnLostFocus(EventArgs e)
   at System.Windows.Forms.Control.WmKillFocus(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.TextBoxBase.WndProc(Message& m)
   at System.Windows.Forms.TextBox.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4724.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
TIPLLatinumSim
    Assembly Version: 1.6.3.0
    Win32 Version: 1.6.3.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLLatinumSim/TIPLLatinumSim.exe
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    Win32 Version: 4.8.4654.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4718.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Runtime.Remoting
    Win32 Version: 4.8.4690.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Windows.Forms.DataVisualization
    Win32 Version: 4.8.4200.0
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
我已按照 https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1348123/pllatinumsim-sw-pllatinum-sim-software-unhandled-exception 中的建议完成 、但它对该 TI PLL 器件没有帮助。 它在其他 TI PLL 器件上有所帮助。
