[参考译文] CODECOMPOSER:Theia ->launch.jsonn`t 未按预期工作
Guru**** 2937200 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/1490869/codecomposer-theia---launch-json-doesn-t-work-as-expect
器件型号:CODECOMPOSER
我`m 使用随附的 launch.json:
    "version": "0.2.0",
    "configurations": [
            "name": "CV3-C3T0-TIVA",
            "type": "ccs-debug",
            "request": "launch",
            "projectInfo": {
                "resourceId": "/CV3-C3T0-TIVA"
            "debuggerSettings": {
                "targetConfigs/Tiva TM4C1290NCPDT.ccxml": {
                    "Texas Instruments XDS110 USB Debug Probe/CORTEX_M4_0": {
                        "data": "<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"no\" ?>\n<PropertyValues>\n\n  <property id=\"FlashProgramOption\">\n    <curValue>Use the Erase Options Specified Below</curValue>\n  </property>\n\n  <property id=\"FlashEraseType\">\n    <curValue>By Address Range</curValue>\n  </property>\n\n  <property id=\"FlashEraseStartAddr\">\n    <curValue>0x00004000</curValue>\n  </property>\n\n  <property id=\"FlashEraseEndAddr\">\n    <curValue>0x00100000</curValue>\n  </property>\n\n  <property id=\"FlashBlankCheckSelection\">\n    <curValue>By Address Range</curValue>\n  </property>\n\n  <property id=\"FlashBlankCheckStartAddr\">\n    <curValue>0x00004000</curValue>\n  </property>\n\n  <property id=\"FlashBlankCheckEndAddr\">\n    <curValue>0x00100000</curValue>\n  </property>\n\n  <property id=\"FlashChecksumSelection\">\n    <curValue>By Address Range</curValue>\n  </property>\n\n  <property id=\"FlashChecksumStartAddr\">\n    <curValue>0x00004000</curValue>\n  </property>\n\n  <property id=\"FlashChecksumEndAddr\">\n    <curValue>0x00100000</curValue>\n  </property>\n\n  <property id=\"FlashVerboseMode\">\n    <curValue>1</curValue>\n  </property>\n\n</PropertyValues>\n"
e2e.ti.com/.../.theia.zip
它`m 为不会将闪存从0覆盖到0x4000、因为我在该闪存区域中使用引导加载程序、但它始终擦除整个闪存。 这是n`t CCS 12.8.1的情况。 我`m 当前使用的是 CCS 20.1.0。
这是已知问题吗?
Steffen
