[参考译文] CCS/CC2650:错误#1.0234万-D:CC2650开发套件的生物样本Eddystone Beacon应用程序仍存在未解析的符号
Guru**** 2589265 points
Other Parts Discussed in Thread: CC2650STK
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/571840/ccs-cc2650-error-10234-d-unresolved-symbols-remain-when-biulding-sample-eddystone-beacon-app-for-cc2650-dev-kit
部件号:CC2650
工具/软件:Code Composer Studio
大家好,我是CCS开发环境的新用户,我正在尝试构建和加载TI simple eddystone演示应用程序,以便可以加载到CC2650STK开发套件中。
我收到如下编译器错误,肯定存在一些文件或文件夹路径问题,但我不知道是什么,因为我可以判断路径是否正常?
请帮助。
Chris
                      未定义的第一个引用
 文件中的符号
 GAGE_EndDiscoverable            ./ICallable/BLLE_DISPATC.OBJ
 GAGE_MakeDiscoverable           ./ICallBLE/BLE_DISPATC.OBJ
 Gap_PeriConnRegister           ./profiles/Gap.obj
 Gap_PeriDevMgrInit             ./profiles/Gap.obj
 GAGE_RemoveAdvToken             ./ICallBLE/BLE_DISPATC.OBJ
 GAGE_SendSlaveSecurityRequest   ./ICallBLE/BLE_DISPATSIT.OBJ
 GAGE_SetAdvToken                ./ICallBLE/BLE_DISPATC.OBJ
 GAGE_UpdateAdvTokens            ./ICallBLE/BLE_DISPATC.OBJ
 GAGE_UpdateAdvertisingData      ./ICallBLE/BLE_DISPATC.OBJ
 LL_EncLtkNegReply              ./Startup/ROM_JT.obj
 LL_EncLtkReply                 ./Startup/ROM_JT.obj
 LL_SetAdvControl               ./Startup/ROM_JT.obj
 LL_SetAdvParam                 ./Startup/ROM_JT.obj
 sm_ResponseInit               ./profiles/gap.obj
 llAdv_TaskConnect              ./Startup/ROM_JT.obj
 llAdv_TaskEnd                  ./Startup/ROM_JT.obj
 llDirAdv_TaskEnd               ./Startup/ROM_JT.obj
 llProcessSlaveControlPacket    ./Startup/ROM_JT.obj
 llProcessSlaveControlProcesses ./Startup/ROM_JT.obj
 llSetupNextSlaveEvent          ./Startup/ROM_JT.obj
 llSetupStartEncReq             ./Startup/ROM_JT.obj
 llSlave_TaskEnd                ./Startup/ROM_JT.obj
错误#1.0234万-D:仍存在未解析的符号
错误#1.001万:链接时出错;未生成“simile_eddystone_cc2650lp_stack.out”
>>编译失败
Makefile:191:目标'simple_eddystone_cc2650lp_stack.out的配方失败
gmake [2]:***[simile_eddyston_cc2650lp_stack.ut]错误1.
gmake [1]:***[main-builD]错误2
Makefile:187:目标'main-builm'的配方失败
Makefile:182:目标'All'的配方失败
gmake:***[All]错误2
说明 资源 路径 位置 类型
gmake [2]:***[simile_eddystone_cc2650lp_stack.ut]错误1 simile_eddystone_cc2650lp_stack   C/C++问题
未解析的符号GAGE_EndDiscoverable,首先引用于./ICallBLE/BLE_DISPATH.OBJ simile_eddystone_cc2650lp_stack   C/C++ problem
未解析的符号GAGE_MakeDiscoverable,首先引用于./ICallBLE/BLE_DISPATC.OBJ simile_eddystone_cc2650lp_stack   C/C++ problem
未解析的符号GAGE_PeriConnRegister,首先在./profiles/gap.obj simile_eddyston_cc2650lp_stack   C/C++ problem中引用
未解析的符号GAGE_PeriDevMgrInit,首先在./profiles/gap.obj simile_eddystone_cc2650lp_stack   C/C++ problem中引用
未解析的符号GAGE_RemoveAdvToken,首先引用于./ICallBLE/BLE_DISPATC.OBJ simile_eddyston_cc2650lp_stack   C/C++ problem
未解析的符号GAGE_SendSlaveSecurityRequest,首先引用于./ICallBLE/ble_dispatch.obj simile_eddystone_cc2650lp_stack   C/C++ problem
未解析的符号GAGE_SetAdvToken,首先引用于./ICallBLE/BLE_DISPATC.OBJ simile_eddystone_cc2650lp_stack   C/C++ problem
未解析的符号GAGE_UpdateAdvertisingData,首先引用于./ICallBLE/BLE_DISPATH.OBJ simile_eddyston_cc2650lp_stack   C/C++问题
未解析的符号GAGE_UpdateAdvTokens,首先引用于./ICallBLE/BLE_DISPATH.OBJ simile_eddyston_cc2650lp_stack   C/C++ problem
未解析的符号LL_EncLtkNegReply,首先在./Startup/ROM_JT.obj simple_eddystone_cc2650lp_stack   C/C++ problem中引用
未解析的符号LL_EncLtkReply,首先在./Startup/ROM_JT.obj simple_eddystone_cc2650lp_stack   C/C++ problem中引用
未解析的符号LL_SetAdvControl,首先引用在./Startup/ROM_JT.obj simile_eddystone_cc2650lp_stack   C/C++ problem中
未解析的符号LL_SetAdvParam,首先在./Startup/ROM_JT.obj simile_eddystone_cc2650lp_stack   C/C++ problem中引用
未解析的符号llAdv_TaskConnect,首先引用于./Startup/ROM_JT.obj simile_eddystone_cc2650lp_stack   C/C++ problem
未解析的符号llAdv_TaskEnd,首先在./Startup/ROM_JT.obj simile_eddyston_cc2650lp_stack   C/C++ problem中引用
未解析的符号llDirAdv_TaskEnd,首先在./Startup/ROM_JT.obj simile_eddyston_cc2650lp_stack   C/C++ problem中引用
未解析的符号llProcessSlaveControlPacket,首先在./Startup/ROM_JT.obj simile_eddystone_cc2650lp_stack   C/C++问题中引用
未解析的符号llProcessSlaveControlProcedures,最初引用于./Startup/ROM_JT.obj simile_eddystone_cc2650lp_stack   C/C++ problem
未解析的符号llSetupNextSlaveEvent,首先在./Startup/ROM_JT.obj simile_eddystone_cc2650lp_stack   C/C++问题中引用
未解析的符号llSetupStartEncReq,首先在./Start/ROM_JT.obj simile_eddyston_cc2650lp_stack   C/C++ problem中引用
未解析的符号llSlave_TaskEnd,首先在./Startup/ROM_JT.obj simile_eddystone_cc2650lp_stack   C/C++ problem中引用
未解析的符号SM_ResponseInit,首先在./profiles/gap.obj simile_eddyston_cc2650lp_stack   C/C++ problem中引用
