[参考译文] CCS:编译错误
Guru**** 2540720 points
Other Parts Discussed in Thread: CC2650STK, HDC1000, OPT3001
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/580202/ccs-compilation-error
主题中讨论的其他部件:CC2650STK
工具/软件:Code Composer Studio
生成项目时出现以下错误
****为项目sensortag_cc2650stk_app构建配置FlashROM****
/opt/ti/ccsv6/utils/bin/gmake -k -j 1 all -o
构建文件:/opt/ti/ble SDK_2_02_01_18/examples/cc2650stk/sensortag/CCS/config/app_ble.cfg
正在调用: XDCtools
/opt/ti/xdctools_3_32_00_06_core/xs"--xdcpath="/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/packages;/opt/ti/cctos_cctos_cc13xx_cc13xx_opts_base_20.r_ccts_cctos_20.x_ccts_cctos_3/r_ccts_ccts_base_20.x_ccts_ccts_ccts_ccts_ccts_base_3k_base_base_k/r_ccts_ccts_ccts_ccts_base_k/r_ccts_base_k/r_20.x_ccts_ccts_ccts_ccts_ccts_cck_20.x_base_k/r_ccts_cck/r_ccts_ccts_base_k_20.x_ccts_base_k_20.x_k/r_base_3_cck_base_k_ccts_ccts_ccts_c_ ti.platforms.simplelink:CC2650F128 15.12 15.12 include_path=\"/opt/ti/ble sdk_2_01/src/profiles/cc26xx\"--include_path=\"/opt/ti/ble sdk_2_02_18/src/profiles/roles/cc26xx\"--include_path=\"opt/ti_sdk_2_p_2/bmp_18/src/mgr_h/cr_18\"src/hp_02_cc26xx\"--include_sk_hp_/src/hp_/src/02_/srk_/srk_/srk_hp_18\"-/hp_/srk_/srk_/src/02/ define=HEAPMGR_size=0 --define=ICALL_MAX_NUM_ENTIES=11 --define=ICALL_MAX_NUM_THATS=8 --define=POWER_Saving --define=use_ICALL --define=use_ICALL--define=XDC_runtime _断 言_disable_all --diag_screb_scrag_super_func=50k_screble_scrble_scrag_scrble_sup_sup_scrag-------25/scrag_scrag_scrble_scrble_scrk_scrble_scrble_scrble_scrk_scrble=50k_scrag_scrag_supu_scr
完成构建:/opt/ti/ble SDK_2_02_01_18/examples/cc2650stk/sensortag/CCS/config/app_ble.cfg
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --pre-diag_warrag_confl=-scree_screble/sechtag_express/scre_scree_scree_screble="-express/scree_scrag_express/scree_s="-scree_scrag/scree_samples="-scr_express/scr_express/scr_express/scr_express/scr_express="-express/
>>编译失败
application/subdir_rules.mk:7:目标'Application/sensortag.obj'的配方失败
"/opt/ti/ble SDK _2_02_01_18/src="/examples/sensortag/cc26xx/app/sensortag.c",第60行:致命错误#1965:无法打开源文件"iCall.h"
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag.obj]错误1
"/opt/ti/ble SDK _2_02_01_18/src/components/osal/src/inc/osal.h",第65行:致命错误#1965:无法打开源文件"OSAL_Memory.h"
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_bar.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_bar.obj]错误1.
在"/opt/ti/ble_sdk_2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_batt.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_BATT.OBJ]错误1
"/opt/ti/ble_sdk_2_02_01_18/src="/examples/sensortag/cc26xx/app/sensortag_b蜂 鸣器.c",第60行:致命错误#1965:无法打开源文件"driverLib/timer.h"
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_buzer.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_buzer.pob]错误1
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_hum.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_hum.obj]错误1
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_io.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_io.obj]错误1
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_keys.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_keys.obj]错误1.
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_mov.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_mov.obj]错误1.
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_opt.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_opt.obj]错误1.
"/opt/ti/ble SDK _2_02_01_18/src="/examples/sensortag/cc26xx/app/sensortag_register.c"第55行:致命错误#1965:无法打开源文件"Board.h"
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_register.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_register.obj]错误1.
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_tmp.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Application/sensortag_tmp.obj]错误1
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_bar.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_sections=on --abi=eabi --preti_scre_screble_screb=/scre_scree_screble/crap_scree_scree_screble="-scrag/scree_scree_screble="-sc/scr_scr_scree_screble="-scrapp_tag/sc/scr_suppress/scr_express_express_express/"-express_express_express_express_ex
>>编译失败
application/subdir_rules.mk:14:目标'Application/sensortag_bar.obj'的配方失败
构建文件:/opt/ti/ble_sdk_2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_batt.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --pre_scre_scap_confrag_scree_screb=-scree_scrag/cret_scree_scrk/cret_scree_scree_scree_screb="-/cret/cret_scrk="-scrk/cret_scree_scrk/cret_scrb_scrk="-p_scrk/d_scrb_scrb_scrbp_express="-/
>>编译失败
application/subdir_rules.mk:21:目标'Application/sensortag_batt.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_buzer.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言_disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_asse=48 --gen_func_sencc子节=on --abi=eabi --preti_preti_scre_scp和crap_screble/crap/crap_scre_scree_sc/crap/cruel="-scrag_se_se_samples/sechtag_sc/cruel="-scre_scr_scr_scrk/cret_scree_scree_scrapp_express/cruel="-express/cru_express_scr
>>编译失败
application/subdir_rules.mk:28:目标'Application/sensortag_p蜂 鸣器.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_conn_ctrl.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --pre_confrag_scree_scree_scap_confrag=/contrl_express/cr_express_express_express_examples="-/tr_scp /cr_scr_express_express_express_scp -/cr_scp -/cr_scp
完成构建:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_conn_ctrl.c.
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_factoryreset.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_sections=on --abi=eabi --preview_screp_express_express_express_express_express_express_express/express_express_express_express_express/express_express_express_example_ref="-express_express_express_express_express_express_express_express_express_express_express_express_express_express_express_express_express_express_express_express
完成构建:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_factoryreset.c.
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_hum.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --pre-diag_warrag_express_express=-express_express_express_express_express_express_scap_orum/cru_express_express_scap_express/cru_scp /crum/cru_example_scree_s="-/cru_express_express_express/cran_sc/cru_sc/-/cran_scr_express_express_express_ex
>>编译失败
application/subdir_rules.mk:49:目标'Application/sensortag_hum.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_io.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --preti_scre_screble_sc/compensor="-scp_express_express_express_express_express_express/ip_express_express_express_express_express/express/ip_express_express_express_express_express/ip_express="-express_express_express_express_express_express_express_express_express_express_express/a"
>>编译失败
application/subdir_rules.mk:56:目标'Application/sensortag_io.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_keys.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --preti_with cdi_screble_confrag=-scre_express/cron_scree_keys -cru_scrag_scree_scree_scree_screble="-scrk/cru_scree_scrk/cru_scrag_express/cru_scree_s="-scrag_express/cru_express_scrag_express/-/-/cru_scr
>>编译失败
application/subdir_rules.mk:63:目标'Application/sensortag_keys.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_mov.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_sections=on --abi=eabi --pre_scre_model_scre_express/model="-scp_express_express_express_scp /cr_express/cr_express/cru_scree_scp /cr_or="-scp
>>编译失败
application/subdir_rules.mk:70:目标'Application/sensortag_mov.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_oad.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --preti_with cd_scap_suppress_screap_or=-scree_screap/scree_screap/crap_or="-scree_screap/scree_screap/scree="-scr_or="-scree_scr_press/scree_scr_or="-scr_press_express_express_express_express_express/a"
完成构建:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_oad.c
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_opt.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --preti_conf_scree_screble=/scree_express/express_express_express_express_express_express_express_express="-scp /scp /express_express_express_express_express_examples/sec_express="-/"
>>编译失败
application/subdir_rules.mk:84:目标'Application/sensortag_opt.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_register.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --preti_scree_screap_confrag=-scrag_scree_screble/secomp_scrag_express="-express/cret_scrag_express_scree_scrag_express="-scr_express/scrag_express/cret_express="-scr_express_express_express/"
>>编译失败
application/subdir_rules.mk:91:目标'Application/sensortag_register.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_tmp.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用所有--display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --preti_ag_warning=225 --crag_suppress_scree_scp文件-cr_scrag_scp =-scrag_sens_scr_scp -express_scr_scp -express_scr_scr_scp -scr_scrk_scp -express_express_express_express_express/scp -express_examples/seck_express_express_express_express/
>>编译失败
application/subdir_rules.mk:98:目标'Application/sensortag_tmp.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/common/cc26xx/util.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --pre-diag_warrag_confl=2c/common_scd_confrender="-/cru_up_/subrk_/subrk="-/cruble="-/cru_/sub_/subrk="-20.d/a"-cru_scd_suppress="-/cru/-/cru_-/cru_-/-/cru_-/-/cr_
完成构建:/opt/ti/ble SDK _2_02_01_18/src/common/cc26xx/util.c.
构建文件:/opt/ti/ble SDK _2_02_01_18/src/common/cc26xx/ecc/ECCROMCC26XX.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg dip_diag=48 --gen_func_Subsection=on --abi=eabi --prep_ecc/ecc_compilenc/cruc_cruc_26xx/cruel_cruc/cruc_cruc/cru_screndor="-cru_sc/cru/cru/cru/cru_sc/cru/cru/cru_sc/cru_sc/cru/cru/cru/cru/cru/cru/cru/cru_ssd="-c_di="-c_di_di="-
完成构建:/opt/ti/ble SDK _2_02_01_18/src/common/cc26xx/ecc/ECCROMCC26XX.c
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/I2c.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_wrap=off --diag_diag=off --pkg_diag=48 --gen_func_Subs=on --abi=eabi --pre-pred_compos_ccti_g2c_scr_scr_scr.xx/creti2c/creti2_scr_scr_scr.xx/creti2_scr_d_scr.creti2_scr.cru_scr.cru_scr.xx/cru_scr./-d_scr.cru_-/cru2_d_scr.xx/cru2_scr.cru2_scr./-/
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/I2c.c.
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/i2c/I2CCC26XX.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_wrap=off --diag_diag=off --pkg_diag=48 --gen_func_Subs=on --abi=eabi --pre-prede_c_diag_compos_c_目录d2c/ipc_c_编译器-c2crk_c_目录-c_
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/i2c/I2CCC26XX.c.
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages /ti/drivers/pinCC26XX.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_wrap=off --pag_diag_compiler=48 --gen_func_Subs=on --abi=eabi --pretos_products_diag_compos_pin_crets=20/creti_creti_cretixx/cret_creti_creti_di_creti_cret_cret_creti="-20/creti_cretixx/creti_di_di_cret_cret_cret_creti_creti="-20/cret_creti_creti="-20/cret_creti="-20/cret_cret_creti="-20/creti="-20/cret_
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/pinCC26XX.c.
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages /ti/drivers/RF/RFCC26XX_singlemode.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_wrap=off --diag_wrap=off --packag_diag_diag=48 --gen_func_Subsections=on --abi=eabi --pre-pre-pred_r_cr_cr_cr_scrf_scrf_creti_scrf_creti_creti=220/creti_scrf_scrf_scrf_creti_scrf_creti="20/creti="20/creti="-20/crk/crk_crk_crk/crk_crk_scrf_scrf_scrf_scrf_scrf_scrf_scrf_scrf_scrf_creti_cr
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/RF/RFCC26XX_singlemode.c.
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/spi.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_wrap=off --diag_diag=off --p_diag_suppress=48 --gen_func_Subsection=on --abi=eabi --pre-pred_sci_products/spi_scr_scr_creti_creti_20/creti="20/creti="20/cru_20/cru_20/cru_20/cru_20/cru_-20/crtos_-20/crtos_scr.xx_scr.xx_scr.xx_scr.xx_scr_di_scr_di="-cr_scr_scr_di_scr_di_scr_scr_di="-cr_
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/spi.c.
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/SPI/SPICC26XXDMA.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_wrap=off --spiag_wrap=off --p_diag_diag=48 --gen_func_Subsection=on --abi=eabi --pre-pred_scdim_scr_scr_scr_scr_scd=2/creti_scr_scr.creti_scr_scr.creti_scr.xx/cdr_scr_scr.cr_scr.xx/cdr_scr_scr_scr_scr.cr_scr.xx/cdr.cr_scr.cr_scr.cr/cr_scr.cr/cr_scr.xx/crk="-cr_scr_scr_scr_
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/SPI/SPICC26XXDMA.c.
构建文件:/opt/ti/ble SDK _2_02_01_18/src/components/hal/src/target/_common/TRNGCC26XX.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --preti_gu_conf_reble/trp_trp_trp_trp=-re/trp_trp_trp_tr/trp_trp_reble="-/trp_trp_trp_/srble/trp_trp_tr02/
已完成构建:/opt/ti/ble SDK _2_02_01_18/src/components/hal/src/target/_common/TRNGCC26XX.c
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/DMACC26XX.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_wrap=off --dag_diag=off --dma_diag=48 --gen_func_Subsection=on --abi=eabi --pre-predag_scdma_compos_scd/文件-dma_scdma_scdimpress_scr.cret_scr.cr_scr.xx/creti_scr_scr_scr.xx/creti="-dma_scrk_scr_scr.xx_scrk/dma_scr_scr_scr_scr.xx/creti="-dma_scrk/dma_scr_scr_scr.xx_scr_scr_scr.xx/cret_
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/drivers/DMACC26XX.c.
构建文件:/opt/ti/ble SDK _2_02_01_18/src/components/iCall/src/iCall.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_suppress=48 --gen_func_Subsection=on --abiabi--preti_conf_confirt_ref="/ip_confrble="-ref="-ref="-c_c_ref="-c="-ref="-c_ref="-c="-c"-cref="-cref="-c_suppress_c"-cref="-cref="-c"-cref="-cref="-cref="-cref="-c"-cref="-cref="-c
>>编译失败
iCall/subdir_rules.mk:7:目标'iCall/iCall.obj'的配方失败
"/opt/ti/ble SDK _2_02_01_18/src="/components/iCall/src/iCall_platform.h",第51行:致命错误#1965:无法打开源文件"iCall.h"
在"/opt/ti/ble SDK _2_02_01_18/src/components/iCall/src/iCall.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[iCall/iCall.obj]错误1
在"/opt/ti/ble SDK _2_02_01_18/src/components/iCall/src/iCall_cc260.c"的编译中检测到1个灾难性错误
编译已终止。
gmake:***[iCall/iCall_cc260.obj]错误1
构建文件:/opt/ti/ble SDK _2_02_01_18/src/components/iCall/src/iCall_cc260.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg dag_diag=48 --gen_func_Subsection=on --abi=eabi --pre_conf_cref_cref="-ce_cref="-cref="-ce_cref="-cref="-ce_cref="-cref="-cref="-c="-cref="-cref="-cref="-cref="-c="-cref="-cref="-cref="-cref="-cref="-cref="-cref="-cref="-cref="-cref="-cref="-c
>>编译失败
iCall/subdir_rules.mk:14:目标'iCall/iCall_cc260.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/iCall/app/ble用户_config.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --pre-diag_warrag_confl=-scd_confl_confl_confl_confl=-/ip_confrble_en_confrble/-/ip_confrble_en_en_en_user_config-/ip_confrble="-/confrble_user_config_user_config_./--/ip_user_config_user_config_.-/d/
>>编译失败
ICallBLE/subdir_rules.mk:7:目标'ICallBLE/BLE_USER_CONFIG.OBJ'的配方失败
"/opt/ti/ble SDK _2_02_01_18/src="/app/ble用户_config.c",第54行:致命错误#1965:无法打开源文件"ti/drivers/RF/RF.h"
在"/opt/ti/ble SDK _2_02_01_18/src/iCall/app/ble用户配置.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[ICallBLE/BLE_USER_CONFIG.OBJ]错误1
在"/opt/ti/ble SDK _2_02_01_18/src/iCall/app/iCall_API.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[ICallBLE/iCall_API.obj]错误1
"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/extflash/ExtFlash.c",第44行:致命错误#1965:无法打开源文件"Board.h"
在"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/extflash/ExtFlash.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Middleware/extflash/ExtFlash.obj]错误1.
构建文件:/opt/ti/ble SDK _2_02_01_18/src/iCall/app/iCall_API.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_Subsection=on --abi=eabi --prep_scp_confl_ip=/ip_confrendence_ip-ip_ip/iprobe_ip_iprob_-ip_./iproc_ip_iprob_./ip_-ip_ip_./ip_-ip_enip_./ip_ip_/iprob_-/ip_/ip_-/ip_-/ip_suppress_-/ip_-/ip_/ip_
>>编译失败
ICallBLE/subdir_rules.mk:14:目标'ICallBLE/iCall_API.obj'的配方失败
"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/sensor/SensorBmp280.c",第44行:致命错误#1965:无法打开源文件"Board.h"
在"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/sensorBmp280.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[中间件/传感器/SensorBmp280.obj]错误1.
"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/传感器/SensorHdc1000.c",第44行:致命错误#1965:无法打开源文件"Board.h"
在"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/sensorHdc1000.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[中间件/传感器/传感器Hdc1000.obj]错误1.
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/extflash/ExtFlash.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=off --diag_wrap=off --dag_diag_suppress=48 --gen_func_sections=on --abi=eabi --prep_coblig_extr_extr_extrap_extr_extrap_extran_extruelf_extruer_extruer_extrap=-20/x_extranx_extranx_extruelf_extrlextrlip=20
>>编译失败
中间件/extflash/subdir_rules.mk:7:目标'Middleware/extflash/ExtFlash.obj'的配方失败
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensor/SensorBmp280.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=off --diag_wrap=off --pkg dlag_suppress=48 --gen_func_Subsection=on --abi=eabi --pre-pre-diag_warr_warrects_crn=220/cctos_scr2xx
>>编译失败
中间件/传感器/subdir_rules.mk:7:目标'Middleware/sensor/SensorBmp280.obj'的配方失败
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensor/SensorHdc1000.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=off --diag_wrap=off --pkg ddiag_suppress=48 --gen_func_Subsection=on --abi=eabi --pre-pre-predag_ccti_scrects_c_cscrful件-g_scrk_c_
>>编译失败
中间件/传感器/subdir_rules.mk:14:目标'Middleware/sensors/SensorHdc1000.obj'的配方失败
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensorI2c.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=off --diag_wrap=off --packag_diag_suppress=48 --gen_func_sections=on --abi=eabi --prep_mw_c_带有sect_c_cscr_cscr_creflewer_c_
>>编译失败
中间件/传感器/subdir_rules.mk:21:目标'Middleware/sensor/SensorI2C.obj'的配方失败
"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/sensor/SensorI2C.c",第51行:致命错误#1965:无法打开源文件"Board.h"
在"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensorI2C.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Middleware/sensor/SensorI2C.obj]错误1.
"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensors/SensorMp9250/c",第44行:致命错误#1965:无法打开源代码文件"Board.h"
在"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/MW/sensorMp9250.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Middleware/sensor/SensorMp9250/obj]错误1.
"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/传感器/SensorOpt3001.c",第44行:致命错误#1965:无法打开源文件"Board.h"
在"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensorOpt3001.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[中间件/传感器/传感器Opt3001.obj]错误1.
"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/sensor/SensorTmp007.c",第45行:致命错误#1965:无法打开源文件"Board.h"
在"/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/sensorTmp007.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Middleware/sensors/SensorTmp007.obj]错误1.
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensor/SensorMp925.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=225 --diag_wrap=off --packag_diag_suppress=48 --gen_func_Subsection=on --abi=eabi --pre-prep_mw_c_cscrects_p_creflects_c_
>>编译失败
中间件/传感器/subdir_rules.mk:28:目标'Middleware/sensors/SensorMpubx.obj'的配方失败
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/传感器/SensorOpt3001.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=off --diag_wrap=off --packag_diag_suppress=48 --gen_func_Subsections=on --abi=eabi --pre-pre-predag_scrects_c_3xx/screct_3xx_scr_scrfulf_3xx/pref="press_scr_3xx_scrbulful件-scr_3xx_3xx_scrontr_scr_scr_scr_3xx/cretr_scr_3xx/crontrf_scr_scr_3xx/cruelfulfulf_3xx/cruelf_3xx/scrontr_scr_scr_scr
>>编译失败
中间件/传感器/subdir_rules.mk:35:目标'Middleware/sensors/SensorOpt3001.obj'的配方失败
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensor/SensorTmp007.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=off --diag_wrap=off --dag_diag_suppress=48 --gen_func_Subsection=on --abi=eabi --pre-pre-predag_c_ c_ c_ c_ c_包装-c_
>>编译失败
中间件/传感器/subdir_rules.mk:42:目标'Middleware/sensors/SensorTmp007.obj'的配方失败
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensorUtil.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=Use_ICALL --define=XDC_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=off --diag_wrap=off --packag_diag_suppress=48 --gen_func_sections=on --abi=eabi --prep_mw_scrects_p_screct_screct_c_
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensorUtil.c.
构建文件:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mw/sensortag/SensorTagTest.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --display_error=225 --diag_warning=off --diag_wrap=off --packag_diag_suppress=48 --gen_func_sencc_子节=on --abi=eabi --pre-predag_scag_products_cscrag_scrag_scrag_scr_scrag_scr_pref="20/cretrx_scrk/crtog_scrk="-k/crtos_scrk_scrx_scrk_scrk/cretr.x_scrk_scrk_scrx_scrk/cretr.x_scrx_scr.x_scr_scr.x_scr_scr_scrk/cretr.x
在"/opt/ti/ble_sdk_2_02_01_18/src/profiles/sensor _profile/cc26xx/barometerservice.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/barometerservice.obj]错误1.
完成的建筑:/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages/ti/mW/sensortag/SensorTagTest.c.
构建文件:/opt/ti/ble_sdk_2_02_01_18/src/profiles/sensor _profile/cc26xx/barometerservice.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg dip_diag=48 --gen_func_Subsections=on --abi=eabi --preti_confrenc_prox_profilel=-p_supervisor/cran_20文件-cr_suppress/p_20
>>编译失败
profiles/subdir_rules.mk:7:目标'profiles/barometerservice.obj'的配方失败
在编译"/opt/ti/ble_sdk_2_02_01_18/src/profiles/batt/cc26xx/battservice.c"时检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/battservice.obj]错误1
构建文件:/opt/ti/ble_sdk_2_02_01_18/src/profiles/batt/cc26xx/Battservice.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --pre-diag_warrag_prox_profilel=-p_p_-crabb_-cret_-/crave_d/crub_-crub_-/crub_-crub_-/crub_-/d="cret_scp_-/d="crub_scp_scd="---/d_suppress--/d_scp_scp_d/p_p_
>>编译失败
profiles/subdir_rules.mk:14:目标'profiles/battservice.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/ccservice.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_sections=on --abi=eabi --pre-diag_warrag_profilel=-sc_profilel/cr_-crucp_suppress_--cr_-d/cscd_profilel="-cr_----cr_scd/cscd_suppress/d_profilel="---crk_sc/d/d_suppress----crk_scp_scp_scrble="--------
"/opt/ti/ble SDK _2_02_01_18/src/components/osal/src/inc/osal.h",第65行:致命错误#1965:无法打开源文件"OSAL_Memory.h"
在汇编"/opt/ti/ble_sdk_2_02_01_18/src/profiles/dev_info/cc26xx/devinfoservice.c"时检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/devinfoservice.obj]错误1
在"/opt/ti/ble_sdk_2_02_01_18/src/host/gat_uuuid.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/g尾_uuid.obj]错误1
编译"/opt/ti/ble SDK _2_02_01_18/src/host/gattservapp_util.c"时检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/gattservapp_util.obj]错误1.
完成构建:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/ccservice.c.
构建文件:/opt/ti/ble_sdk_2_02_01_18/src/profiles/dev_info/cc26xx/devinfoservice.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --preti_confrect_supervice_profilel=-形式/cr_device_suppress/confrendors/ip_suppress_profilel="-形式-cr_suppress_suppress_suppress_suppress/fice_suppress--/f_suppress/fice_suppress---/fice_suppress-/--/fice_profilel="-/d/
>>编译失败
profiles/subdir_rules.mk:28:目标'profiles/devinfoservice.obj'的配方失败
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/humidityservice.c"编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/humidityservice.obj]错误1.
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/ioservice.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/ioservice.obj]错误1
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/irtempservice.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/irtempservice.obj]错误1
构建文件:/opt/ti/ble_sdk_2_02_01_18/src="/host/GATT_uuid.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg dip_diag=48 --gen_func_Subsections=on --abi=eabi --pre_with_proc/uu_profilel_-形式-proc_proc_confrender="-形式/u_d/sgble="-形式-proc_proc_p_p_p_ass_pref="-形式-prokc/en/sgble="-形式-prok_./sgble="-p_p_p_p_pref="p_pref="p_
>>编译失败
profiles/subdir_rules.mk:35:目标'profiles/GATT_uuuid.obj'的配方失败
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/movementservice.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/movementservice.obj]错误1
在编译"/opt/ti/ble SDK _2_02_01_18/src/profiles/oad/cc26xx/oad.c"时检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/oad.obj]错误1
构建文件:/opt/ti/ble SDK _2_02_01_18/src/host/gattservapp_util.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --preserv_with cmd_proc_profilel=-util_up_util/proc_up_profilel_-形式-proc_up_up_up_host_up_util="p_up_util="-gp_up_util="-"-形式 的proc_proc_proc_up_util_profile.p_up_up_up_util="-"-形式-形式 的文件-形式-proc_proc_
>>编译失败
profiles/subdir_rules.mk:42:目标'profiles/gattservapp_util.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/humidityservice.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言_disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_Subsections=on --abi=eabi --prep_confrence_profilel/profilel="-cryp_ace_suppress_acity-p_acity-p_acity_suppress/service_profilel="-p_p_acity-p_d/p_d/p_suppress/d="-d/
>>编译失败
profiles/subdir_rules.mk:49:目标'profiles/humidityservice.obj'的配方失败
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/opticservice.c"编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/opticservice.obj]错误1
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/ioservice.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_Subsections=on --abi=eabi --preti_ervise_per_conflos/profilel="-cr_suppress/crue_suppress/cru_-/crue_suppress_diag_diag_-/cruisor_-/cruel="-/crue_d/cruisor_-/crue_d="-x_supp_suppress/d/"
>>编译失败
profiles/subdir_rules.mk:56:目标'profiles/ioservice.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/irtempservice.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用所有--display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --pre-diag_warrag_prox=225 --proc_proc_profilel/profilel="-crp_-cr_suppress/cr_-cru_-cru_.xx/cru_sc/cru_-/cru_-d="-/cru_scd="p_suppress/d="-d/
>>编译失败
profiles/subdir_rules.mk:63:目标'profiles/irtempservice.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/movementservice.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_sections=on --abi=eabi --pre_model_proc/model_profilel="-sc/model_profilel="-cr_model/model_model="-cr_model="-scd/seck_model="-scd/seck_profilel="-p_model="-">
>>编译失败
profiles/subdir_rules.mk:70:目标'profiles/movementservice.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/oad/cc26xx/oad.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_asse=48 --gen_func_sections=on --abi=eabi --pre-pre_proc/config_profile -crue_scd_suppress_-/cru_--crue_scd="-/cru_scd="------/cru_scd/cru_scd="---------/cru_oblip_scd="-----------/cru_scd/cru_ob
>>编译失败
profiles/subdir_rules.mk:77:目标'profiles/oad.obj'的配方失败
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/roles/cc26xx/peripheral.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/peripheral.obj]错误1
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/oad/cc26xx/oad_target_external_flash.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言_disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_Subsections=on --abi=eabi --pre_scp文件-cr_suppress_external_profile -cru_scd_confr_-cru_scd=-cru_obl_scd_obl_scd_conf./-cru_obl_sc_--/crue_ass_obl_scd_---cru_ob_obl_scd_---/cru_ob_---/cru_scd_obl_obl_
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/registerservice.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/registerservice.obj]错误1.
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/keys/cc26xx/simplekeys.c"编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/simplekeys.obj]错误1.
在"/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/st_util.c"编译中检测到1个灾难性错误。
编译已终止。
gmake:***[profiles/st_util.obj]错误1
完成构建:/opt/ti/ble SDK _2_02_01_18/src/profiles/oad/cc26xx/oad_target_external_flash.c.
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/opticservice.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsections=on --abi=eabi --pre-diag_warrag_profilel=/profilel_suppress/profilel="-_suppress/service_profilel="-p_-cret_suppress_--/p_-/p_-crtic="-cr_-/d/p_suppress/d/d/d/
>>编译失败
profiles/subdir_rules.mk:91:目标'profiles/opticservice.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/roles/cc26xx/peripheral_c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_Subsections=on --abi =eabi --pre-pre_prox_prox_profilel=-形式/cru_-cru_suppress/cruel_-/cruel_-d="-/cretimperipheral -/cru_suppress_-/-/cruel="-/-/d="-/cru_-/d/d/d="-/cru_scp_suppress_------
>>编译失败
profiles/subdir_rules.mk:98:目标'profiles/peripher.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/registerservice.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言_disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg dip_diag=48 --gen_func_sections=on --abi=eabi --pre-pre_reguls_filel_-cruel_scd/seck_profilel_-cret_suppress/-cran?-cran_-d/crucrendor_sc/crucr_-d="-d/scd/scr_profilel="--/crk_suppress-d/cr_--/cran_-d/d/d/d/scp_profilel="
>>编译失败
profiles/subdir_rules.mk:105:目标'profiles/registerservice.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/keys/cc26xx/simplekeys.c.
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言_disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_compiler=48 --gen_func_Subsections=on --abi=eabi --pre-diag_warrag_warning=225 -proc_keys.com/filel/crus_-cru_cruel_suppress-cru_-cru_-cru_-cru_-d_-cruel_-d/sm/d="cruel_suppress/d="-d="-d/
>>编译失败
profiles/subdir_rules.mk:112:目标'profiles/simplekeys.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/profiles/sensor _profile/cc26xx/st_util.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg dip_diag=48 --gen_func_sections=on --abi=eabi --preti_up_profile -cru_up_profilel_-cru_up/cru_up_-cru_upd/cru_upd="-/cru_scd="-d_suppress_upd/p_profilel="-d="-d/p_upd/p_/suble="-scrble="-">
>>编译失败
profiles/subdir_rules.mk:119:目标'profiles/st_util.obj'的配方失败
构建文件:/opt/ti/ble SDK _2_02_01_18/src/target/board.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用所有--display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_Subsections=on --abi=eabi --pre-pre_port_warrag_off -proc/en_confrbe_up_-p_reble="-scd_up_up_d/p_d="-形式-prok_reble="-p_up_p_p_d/1"-proc/proble="-形式-prok_suppress_d_re_reble="-/1"-prok_re
完成构建:/opt/ti/ble SDK _2_02_01_18/src/target/board.c.
构建文件:/opt/ti/ble SDK _2_02_01_18/examples/cc2650stk/sensortag/IAR/config/ccfg_app_ble
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg dip_diag=48 --gen_func_Subsection=on --abi=eabi --prep_stip_compens_scp_scp_express_express_scp_express_express/cru_scp_express_scp_examples=-up_scp_scp_scp_scp_scp_scp_express/-scp_express_express_express_express_exp -/cru_scp_scp_express_express_exp -p_scp_exp -c_
完成构建:/opt/ti/ble SDK _2_02_01_18/examples/cc2650stk/sensortag/iar/config/ccfg_app_ble
构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/main.c
正在调用:ARM编译器
"/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12-cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_ICALL --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用所有--display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_Subsections=on --abi=eabi --pre-express_report_up_scd=/confrag_examples="-cret_scp_express/cru_express/cru_express-/cru_scp_re_-/cru_examples="-/cru_scp_express/cru_express-/-/cru_scp_express/-/cru_scp_express-/-/-/
>>编译失败
startup/subdir_rules.mk:21:目标'Startup/main.obj'的配方失败
"/opt/ti/ble SDK _2_02_01_18/src="/examples/sensortag/cc26xx/app/sensortag.h",第59行:致命错误#1965:无法打开源文件"iCall.h"
在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/main.c"的编译中检测到1个灾难性错误。
编译已终止。
gmake:***[Startup/main.obj]错误1
gmake:由于错误,目标'all'没有重制。
****构建已完成****
    R K 说:
    "/opt/ti/ble_sdk_2_02_01_18/src="/examples/sensortag/cc26xx/app/sensortag.h"第59行:致命错误#1965:无法打开源文件"iCall.h"
    错误消息表明找不到头文件iCall.h
    但是,该文件位于:
    [报价用户="R K"]--include_path="/opt/ti/ble_sdk_2_02_01_18/src/components/iCall/src/inc"[/报价]
    包含搜索路径编译器选项中的内容。
    我怀疑这是一个区分大小写的问题。 在我安装相同版本的BLE SDK时,文件为"iCall.h"-所有的大写字母都较低。 在Windows中,这不是问题。 但在Linux中,这是一个问题。
    这表明这是SDK中的一个错误。 您是否可以尝试重命名头文件并查看是否可以解决问题?
    KI
    感谢您的回复,更改了icall.h和board.h文件名,之后我的错误有所减少。
    仍然缺少获取头文件(timer.h,...
    文件路径为:
    root@#定位timer.h
    /opt/ti/ble SDK _2_02_01_18/src/components/hal/src/inc/hal_timer.h
    /opt/ti/ble SDK _2_02_01_18/src/components/osal/src/inc/osal_cbtimer.h
    /opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/bios_6_46_01_38/packages/ti/catalog/arm/peripherals/timers/timer.h
    /opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/cc13xxware_2_04_02_1.724万/driverlib/aux_timer.h
    /opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/cc13xxware_2_04_02_1.724万/driverlib/timer.h
    /opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/cc13xxware_2_04_02_1.724万/inc/hw_aux_timer.h
    /opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/cc26xxware_2_24_02_1.7393万/driverlib/aux_timer.h
    /opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/cc26xxware_2_24_02_1.7393万/driverlib/timer.h
    /opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/cc26xxware_2_24_02_1.7393万/inc/hw_aux_timer.h
    ****为项目sensortag_cc2650stk_app构建配置FlashROM ****
    /opt/ti/ccsv6/utils/bin/gmake -k -j 1 all -o
    构建文件:/opt/ti/ble SDK _2_02_01_18/examples/cc2650stk/sensortag/CCS/config/app_ble.cfg
    正在调用: XDCtools
    /opt/ti/xdctools_3_32_00_06_core/xs"--xdcpath="/opt/ti/tirtos_cc13xx_cc26xx_2_20_01_08/packages;/opt/ti/cctos_cctos_cc13xx_cc13xx_opts_base_20.r_ccts_cctos_20.x_ccts_cctos_3/r_ccts_ccts_base_20.x_ccts_ccts_ccts_ccts_ccts_base_3k_base_base_k/r_ccts_ccts_ccts_ccts_base_k/r_ccts_base_k/r_20.x_ccts_ccts_ccts_ccts_ccts_cck_20.x_base_k/r_ccts_cck/r_ccts_ccts_base_k_20.x_ccts_base_k_20.x_k/r_base_3_cck_base_k_ccts_ccts_ccts_c_ ti.platforms.simplelink:CC2650F128 15.12 15.12 include_path=\"/opt/ti/ble sdk_2_01/src/profiles/cc26xx\"--include_path=\"/opt/ti/ble sdk_2_02_18/src/profiles/roles/cc26xx\"--include_path=\"opt/ti_sdk_2_p_2/bmp_18/src/mgr_h/cr_18\"src/hp_02_cc26xx\"--include_sk_hp_/src/hp_/src/02_/srk_/srk_/srk_hp_18\"-/hp_/srk_/srk_/src/02/ define=HEAPMGR_size=0 --define=ICALL_MAX_NUM_ENTIES=11 --define=ICALL_MAX_NUM_THATS=8 --define=POWER_Saving --define=use_ICALL --define=use_ICALL--define=XDC_runtime _断 言_disable_all --diag_screb_scrag_super_func=50k_screble_scrble_scrag_scrble_sup_sup_scrag-------25/scrag_scrag_scrble_scrble_scrk_scrble_scrble_scrble_scrk_scrble=50k_scrag_scrag_supu_scr
    完成构建:/opt/ti/ble SDK _2_02_01_18/examples/cc2650stk/sensortag/CCS/config/app_ble.cfg
    构建文件:/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_buzer.c
    正在调用: ARM 编译器
    "/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12 -cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12  include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言_disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_asse=48 --gen_func_sencc子节=on --abi=eabi --preti_preti_scre_scp和crap_screble/crap/crap_scre_scree_sc/crap/cruel="-scrag_se_se_samples/sechtag_sc/cruel="-scre_scr_scr_scrk/cret_scree_scree_scrapp_express/cruel="-express/cru_express_scr
    编译 失败
    application/subdir_rules.mk:28:目标'Application/sensortag_p蜂 鸣器.obj'的配方失败
    "/opt/ti/ble_sdk_2_02_01_18/src="/examples/sensortag/cc26xx/app/sensortag_b蜂 鸣器.c",第60行:致命错误#1965:无法打开源文件"driverLib/timer.h"
    在"/opt/ti/ble SDK _2_02_01_18/src/examples/sensortag/cc26xx/app/sensortag_buzer.c"的编译中检测到1个灾难性错误。
    编译 已终止。
    gmake: *** [Application/sensortag_buzer.pob] 错误 1
    构建 文件: /opt/ti/ble SDK _2_02_01_18/src/common/cc26xx/util.c
    正在调用: ARM 编译器
    "/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12 -cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12  include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=xdc_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --pre-diag_warrag_confl=2c/common_scd_confrender="-/cru_up_/subrk_/subrk="-/cruble="-/cru_/sub_/subrk="-20.d/a"-cru_scd_suppress="-/cru/-/cru_-/cru_-/-/cru_-/-/cr_
    编译 失败
    application/subdir_rules.mk:105:目标'Application/util.obj'的配方失败
    "/opt/ti/ble SDK _2_02_01_18/src/common/cc26xx/util.c",第62行:致命错误#1965:无法打开源文件"iCall.h"
    编译"/opt/ti/ble SDK _2_02_01_18/src/common/cc26xx/util.c"时检测到1个灾难性错误。
    编译 已终止。
    gmake: *** [Application/util.obj] 错误 1
    正在调用: ARM 编译器
    "/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12 -cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12  include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_suppress=48 --gen_func_Subsection=on --abiabi--preti_conf_confirt_ref="/ip_confrble="-ref="-ref="-c_c_ref="-c="-ref="-c_ref="-c="-c"-cref="-cref="-c_suppress_c"-cref="-cref="-c"-cref="-cref="-cref="-cref="-c"-cref="-cref="-c
    编译 失败
    iCall/subdir_rules.mk:7:   目标 'iCall/iCall.obj'的配方 失败
    "/opt/ti/ble SDK _2_02_01_18/src="/components/iCall/src/iCall.c",第61行:致命错误#1965:无法打开源文件"iCall.h"
    编译 已终止。
    gmake: *** [iCall/iCall.obj] 错误 1
    正在调用: ARM 编译器
    "/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12 -cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12  include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg_diag=48 --gen_func_Subsection=on --abi=eabi --pre-diag_warrag_confl=-scd_confl_confl_confl_confl=-/ip_confrble_en_confrble/-/ip_confrble_en_en_en_user_config-/ip_confrble="-/confrble_user_config_user_config_./--/ip_user_config_user_config_.-/d/
    编译 失败
    编译 已终止。
    gmake: *** [ICallBLE/BLE_USER_CONFIG.OBJ] 错误 1
    构建 文件: /opt/ti/ble SDK _2_02_01_18/src/iCall/app/iCall_API.c
    正在调用: ARM 编译器
    "/opt/ti/ccssv6/tools/compiler/arm_sens_tag/cs/app/./../opt/ti/sk_2_02_01_18/examples/cc2650stk/psm/sensort_sc/app/app/./compiler 15.12 -cc2650k/scrs/scr_ps-scr_ps-scr./scr_ps-scr./scr_ps-scr./seck/scr_ps-scr_ps-scr./sm/scrb_ps-/seck/scrm_/seck/scrm_ps-scr./scrm/scrm/ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps-ps./psk/scr./seck/scr./seck/scr./seck/scr./seck/scr./seck/ps 15.12  include_path="/opt/ti/ble sdk_2_01_18/src/components/hal/src/inc26xx"--include_path="/opt/ti/ble sdk_2_02_18/src/components/hal/src/src="/components/src="/opt_/sk_02_/sk_/intel/02_intel/opt_intel/sk_intel/iments/opt_intel/intel/opt_intel/intel/sk_s/ip_s/ip_intel/opt_s/ip_intel_s/ip_s/ip_sk_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_s/ip_sk_s/ip_/ip_s/ip_s/ip_s/ip_s/ip_sk_sd/sd/sd_/ip_/ip_/ip_/ip_/ip_/ip_/sd/sd_/s_/sd_/s_/sd/s_/sd_/sd_/sd_/sd_/sk_/sk_/ip_/ define=use_icall --define=XDC_runtime断言disable_all --define=xdc_runtime日志禁用_all --display_error_number --diag_warning=225 --diag_wrap=off --pkg diag_diag=48 --gen_func_Subsection=on --abi=eabi --prep_scp_confl_ip=/ip_confrendence_ip-ip_ip/iprobe_ip_iprob_-ip_./iproc_ip_iprob_./ip_-ip_ip_./ip_-ip_enip_./ip_ip_/iprob_-/ip_/ip_-/ip_-/ip_suppress_-/ip_-/ip_/ip_
    编译 失败
    "/opt/ti/ble SDK _2_02_01_18/src="/iCall/app/iCall_api.c",第53行:致命错误#1965:无法打开源文件"iCall.h"
    编译 已终止。
    gmake: *** [ICallBLE/iCall_API.obj] 错误 1
    gmake: 由于      错误,目标'all'没有重制。
    **** 构建 已完成 ****
    有关在Linux上使用BLE SDK的更多建议,我将查看以下指南:
    processors.wiki.ti.com/.../Building_BLE_Projects_on_Linux
    请注意第一段,其中指出Linux上不正式支持此功能,但应该可以使其正常工作。
    如果您仍然有问题,我建议您在BLE论坛上发布。 那里的专家最熟悉SDK,可以帮助您实现最佳发展。
    KI
