[参考译文] CCS:CCS v7升级失败
Guru**** 2587365 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/604332/ccs-ccs-v7-upgrade-fails
工具/软件:Code Composer Studio
日志是正确的,在引用的下载文件夹中没有存储库,但我不知道为什么。
!Session 2017年06月20日 15:59: 40.515 ----------------------------------
Eclipse.buildId=Eclipse.0.I2016.0606万-1100<xmt-block0>1100 4.6
java.version=java.0_112 1.8
java.vendor=Oracle Corporation
引导加载程序常量:OS=Win32,ARCH=x86,WS=Win32,NL=en_US
框架参数:-application org.eclipse.equinox.p2.director -repository文件:/C:/ti/ccsv7/eclipse/downloads/featurerepo,文件:/C:/ti/ccsv7/eclipse/downloads/baserepo/eclipserepo -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group -roaming -uninstalliu org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group
命令行参数:-OS Win32 -ws Win32 -arch x86 -data C:/Users/Bruce/AppData/local/Temp/CS_40.4163万fc-75c1-4103-6154-fef36411fab8/workspace -application4103 -application org.eclipse.equinox.p2.director6154 org.eclipse.equinox.p2.director -installrepository3.6411万 -installrepository file:/C:/ti/ccsv7/eceri/slipe/roam/cru/cru/crusipose/cru/cru/crackiepo:/cru/下载:org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group
!entry org.eclipse.equinox.p2.artifact.repository 41000 2017年06月20日 15:59: 43.161
!message No repository found at file:/C:/ti/ccsv7/eclipse/downloads/featurerepo。
!entry org.eclipse.equinox.p2.artifact.repository 41000 2017年06月20日 15:59: 43.178
!消息未在文件:/C:\ti/ccsv7/eclipse/downloads/baserepo/eclipserepo中找到存储库。
!条目org.eclipse.equinox.p2.metada.repository 41000 2017年06月20日 15:59:43.259
!条目org.eclipse.equinox.p2.metada.repository 41000 2017年06月20日 15:59:43.279
!条目org.eclipse.equinox.p2.core 4 0 2017年06月20日 15:59:43.288
!消息无法加载存储库。
    Bruce,
    您是否正在尝试将7.1 更新到7.2 ,或者这是其它类型的更新?
    此致,
    John
    是的,v 7.1 到v 7.2
    v 7.1 仍然运行正常,如果我要求检查更新,则会得到的回答是软件是最新的。
    我们尚未发布7.2 的更新。 从技术上讲,您可以下载7.2 安装程序并将其指向7.1 ,它将执行更新。 本周更新应该已结束。
    请注意,我们目前遇到许多Web问题,因此下载文件甚至访问TI.com上的网页都是不可靠的。 希望这一问题很快得到解决。
    此致,
    John
