[参考译文] 编译器/TMS320F2.8377万S:链接.cmd文件时遇到问题,因此生成错误#1.0026万-D正在发生...不知道发生了什么事情!
Guru**** 2595805 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/622528/compiler-tms320f28377s-having-trouble-with-linking-cmd-file-and-due-to-that-build-error-10026-d-is-occurring-idk-what-s-happening
部件号:TMS320F2.8377万S
主题中讨论的其他部件:C2000WARE
工具/软件:TI C/C++编译器
您好,先生/女士,
首先,感谢这一论坛设施。 我在过去的4个月里一直在使用CCS v 7.1 ,但第二天早上我突然无法在软件中构建程序。
-我尝试更新版本。 (现在是CCS v 7.2)
-已尝试在“项目属性”>>CCS常规>>->链接器命令文件>>“无”中进行设置。  (通过此更改,错误得以减少,但未能消除)
问题就在这里... (我已将下面的错误行标记为红色...这表示故障是由链接过程引起的。
****为项目ePWM_DEADBACDE_cpu01构建配置CPU1_FLASH ****
"C:\\Users\\meghavi\\Desktop\\CCssv7\\utils\\bin\\gmake 7.2 "-k all
'正在构建目标:ePWM_DEADBACDE_cpu01.OUT '
'调用:C2000连接器'
c:/Users/meghavi/Desktop/Ccslts/ccsv7/tools/compiler/ti-CGT-compiler_CCTS.3.lts/bin/cl2000" 7.2 -v28 -ml -mt --cla_support=cc1 --flo_support=fpu32 --tmut_support=tmut_support=tcscvc_mp_supervics/span_megurs=-m/sav_span_span_span_m/subi -g/span_m=-scand/spi 16.9 -gip-g-g/spi -gip-gip-f_m/sub-g-g-g/cr-g-gip-g_m/sub-g/cr-g-g-g-g-g/sp-gip-g-gip-gip-g_lip-g-g-g_m/sub-g-g_updip-g_updip-g_updip-g_up/p-g_-g-g-g-cz/p-c 7.2 16.9 7.2 16.9 7.2 7.2
链接>
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第77行:错误#1.0045万-D:
非法输入字符:"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第77行:错误#1.0026万-D:
需要输出部分,组或联合而不是"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第78行:错误#1.0045万-D:
非法输入字符:"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第78行:错误#1.0026万-D:
需要输出部分,组或联合而不是"#"
需要输出部分,组或联合而不是">="
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第88行:错误#1.0045万-D:
非法输入字符:"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第88行:错误#1.0026万-D:
需要输出部分,组或联合而不是"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第98行:错误#1.0045万-D:
非法输入字符:"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第98行:错误#1.0026万-D:
需要输出部分,组或联合而不是"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第99行:错误#1.0045万-D:
非法输入字符:"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第99行:错误#1.0026万-D:
需要输出部分,组或联合而不是"#"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第91行:警告#1.019万-D:
要重新定义的绝对符号"_RamfuncsLoadStart"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第92行:警告#1.019万-D:
要重新定义的绝对符号"_RamfuncsLoadSize"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第93行:警告#1.019万-D:
要重新定义的绝对符号"_RamfuncsLoadEnd"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第94行:警告#1.019万-D:
要重新定义的绝对符号"_RamfuncsRunStart"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第95行:警告#1.019万-D:
要重新定义的绝对符号"_RamfuncsRunSize"
"C:/Users/meghavi/Desktop/CCSTL 7.2 /C2000Ware_1_00_01_00/device_support/f2837xs/common/Cmd/2837xS_Generic_flash_lnk.cmd",2837,第2837第96行:警告#1.019万-D:
要重新定义的绝对符号"_RamfuncsRunEnd"
错误#1.001万:链接期间遇到错误;"ePWM_DEADBACDE_cpu01.out不是
已构建
>>编译失败
Makefile:153:目标'ePWM_DEADBACDEBAD_cpu01.OUT的配方失败
gmake:***[ePWM_deadband _cpu01.Out ]错误1
gmake:由于错误,目标'all'没有重制。
****构建已完成****
希望尽快得到积极的答复。 我已将.cmd文件附在此处
e2e.ti.com/.../2837xS_5F00_Generic_5F00_FLASH_5F00_lnk.cmd_2800_1_2900_.txte2e.ti.com/.../2837xS_5F00_Generic_5F00_FLASH_5F00_lnk.cmd.txt</s>2800 29002837
    我不确定原因,但您正在使用链接器选项--disable_pp.  删除该选项,它将正常工作。
    谢谢,此致,
    -George
